[U-Boot] [ARM] start.s for 920t brocken?
14 Dec
2010
14 Dec
'10
8:38 p.m.
Hello,
is it possible that, start.s for arm920t is broken with relocation?
I try make my board run with relocation and start from NOR Flash.
<snip> start_code: /* * set the cpu to SVC32 mode */ mrs r0, cpsr bic r0, r0, #0x1f orr r0, r0, #0xd3 msr cpsr, r0
bl coloured_LED_init bl red_LED_on
#if <snip>
I found out, that the board crashes on calling coloured_LED_init.
So I comment out "bl coloured_LED_init" and "bl red_LED_on" and the board boots. I think this both calls should be removed at this position or moved to a better place. At this early position the C environment and stack are not initialized !?
Can anybody confirm this? Any suggestions or patches?
Thanks
Jens Scharsig
5260
Jens Scharsig
