[U-Boot] U-boot debugging on Canyonlands using BDI3000
Can someone please share BDI3000 configuration file suitable for u-boot debugging on 460EX evaluation board (Canyonlands). I use the following file, which doesn't work
[TARGET] JTAGCLOCK 1 ;use 16 MHz JTAG clock CPUTYPE 440 ;the used target CPU type WAKEUP 500 ;wakeup time after reset BREAKMODE HARD ;SOFT or HARD, HARD uses PPC hardware breakpoint STEPMODE HWBP ;JTAG or HWBP, HWBP uses one or two hardware breakpoints ;MMU XLAT ;MMU support enabled ;PTBASE 0x000000f0 ;pointer to the page table pointers
[HOST] IP 10.0.0.10 PROMPT 460EX>
[REGS] IDCR1 0x010 0x011 ;MCIF0_CFGADDR and MCIF0_CFGDATA IDCR2 0x012 0x013 ;EBC0_CFGADDR and EBC0_CFGDATA IDCR3 0x014 0x015 ;EBM0_CFGADDR and EBM0_CFGDATA IDCR4 0x016 0x017 ;PPM0_CFGADDR and PPM0_CFGDATA IDCR5 0x00C 0x00D ;CPR0_CFGADDR and CPR0_CFGDATA IDCR6 0x00E 0x00F ;SDR0_CFGADDR and SDR0_CFGDATA PMM1 0x40000 ;Peripheral (base addr 4_0000_0000) PMM2 0xC0000 ;PCI (base addr C_0000_0000) FILE $reg460ex.def
I get the following errors:
460EX>reset - TARGET: processing user reset request - TARGET: resetting target passed - TARGET: processing target startup .... - TARGET: core #0 PVR is 0x130218A2 - TARGET: processing target startup passed 460EX>ti Core number : 0 Core state : debug mode Debug entry cause : JTAG stop request Current PC : 0x00040190 Current CR : 0x010ff7f5 Current MSR : 0x00000000 Current LR : 0x395cc044 # Step timeout detected 460EX>ti 0xfffffffc Core number : 0 Core state : debug mode Debug entry cause : JTAG stop request Current PC : 0xfffffffc Current CR : 0x00004009 Current MSR : 0x00000000 Current LR : 0x644e4009 # PPC: JTAG instruction stuff overrun 460EX>bi 0xfffff000 Breakpoint identification is 0 460EX>go # PPC: JTAG instruction stuff overrun
I had a feeling that my Canyonlands is broken, but maybe I'm doing something dumb. BTW, I can program u-boot on NOR using this BDI3000 and different configuration file.
Thanks a lot.
Felix.
Felix Radensky
