Hi, Albert,
Sorry, I don't know the reason why I cannot receive your email, and your email-address cannot be seen either.
So text following is copied from mailing list.
Hi Shawn, Le 13/08/2011 17:33, shawn Bai a écrit :
Hello, guys.
I have 2 questions about duart on MPC837xE-rdb board.
why not implement duart driver in interrupt-driven mode, in addition to polling-mode?
from the existing implementation of uboot, I find there is only polling-mode duart driver.
Well, why would interrupts be needed for? Remember that U-Boot is not a multi-tasking OS, but a single-thread bootloader, so we tend to use interrupts only if there is a good case for it as far as bootloading is concerned.
Well, I see. This is the answer I wanna know for a period of time.
Speaking of interrupt-driven mode DUART, it depens on the requirement from upper application.
DUART is used in redundant communication. Each end on DUART has no idea when the data from the other
end will come. and the cpu time cannot be wasted on waiting, even a little. So interrupt-driven mode
DUART is what we want.
- According to requirements from upper application, interrupt-driven mode duart driver is needed to be implemented on our board.
You mean you will run a native application directly from U-Boot? No OS such as Linux for instance?
Actually, not directly based on u-boot, which is referenced often.
But the process is very very similar.
There is a mainloop in uboot code. Accordingly, in our project, after the boot process, the main()
function will also be entered, and cannot return.
There is no any OS, and just a while(1){...} loop in the main() function.
hings are done in the while loop.
But, there is a question on which I have spent a whole Saturday, even so, it has not been worked out yet. DUART's basic paramenters, such as character's length, stop bits' length, odd or even parity, baudrate, are configured normally, and also FIFO mode. DUART is used in interrupt-driven mode, so both external interrupt(EE in MSR), and UART1 interrupt in IPIC module is enabled. And interrupt handler routine has already been connected with DUART hardware interrupt signal. When a block of data is needed to transmit, the address of that block of data will be passed to uart driver as the parameter of uart tx function, like uint32 uart_put_buf(uchar channel, uchar *buf, uint32 len). When run in uart_put_buf function, interrupt THREI(transmitter holding register empty interrupt) is enabled first, then,the first data in that buf is written into uart transmitter holding register, like *((volatile uchar*)IMMRBAR + 0x4500 + 0x00) = *buf;
(oh God. Does your code really have this line as you show it?)
yes,
to reference duart peripheral in mpc837xe-rdb board, structure duart83xx_t defined by uboot is used.
first, define a pointer, duart83xx_t *p_base = NULL;
then make p_base equal to ( (duart83xx_t *)(IMMRBAR + 0x4500 + (channel-1) * (0x1 << 8) ) ), according to the uart channel used now.
after that, statement <p_base->uthr = *buf> will put the first data in buf into thr register.
and the buf and length passed by user is stored in 2 global variables, which are used in DUART ISR. like g_tranbuf = buf + 1; /* 'cause first data in buf is transmitted in the funcion*/ g_tranlength = len - 1; /*the same reason as above*/
in my opinion, the rest of datas is transmitted in interrupt handler routine when THREI interrupt happens.
That is the usual design, yes.
Here the question comes, after the first data in buf is written into uthr register, this character is displayed on the screen actually as we expect, things are going well until now, but there is no THREI interrupt signal which should be triggered by completion of the first data transmission. Because Interrupt handler routine can not be run, the rest of datas in buf cannot be transmitted. After transmission of the first data in buf, there is no vector in IPIC vector register, which indicates the highest priority interrupt pending, and also value of the interupt pending register is 0, which means there is no interrupt pending. What seems strange is the whole way interrupts will pass through is set as needed, EE in MSR, UART1 int in IPIC module, THREI int in DUART moduel, and the first data in buf is written into thr register, which will also bring the presence of THREI interrupt. But, why interrupt handler routine cannot be entered?
Hard to tell. That is your code, not U-Boot's. Plus I don't know your UART -- I am ashamed to tell I only deal(t) with 8250/16550-like UARTs, which emit a THRE every time you can write again to the xmit buffer, and I never saw such a problem as you expose.
yes, it is the code of my own, not uboot.
In mpc837xe manual, it is said that DUART programming is PC16552D compatible.
The machanism you said is the fundation of interrupt-driven transmission.
And I also think so.
To accomplish it, I enabled external interupt(EE, bit16 in MSR), UART1 INT(bit24 in simrh) in IPIC
module, and THRE INT(bit6 in ier) in DUART module.
Interrupt handler routine is already connected with UART1 INT in IPIC, after this, once UART1 interrupt
happens, the handler routine will be called.
Strangely, handler routine is called once or twice, but right after THRE is enabled in uart_put_buf
function. In DUART handler routine, IP(interrupt pending bit in iir, interrupt identification register)
is checked, if it is 1, then no interrupt is pending. handler routine will return.
Even if entered, handler routine will return in this if branch.
Are some main points missed?
I could hardly tell, but what I can tell is that your problem in itself is a reason why using interrupts without a cause should be avoided. I do understand you have it as a requirement, but then it seems you have two conflicting requirements: use interrupts and run directly atop of U-Boot.
Upper level applications have no idea how DUART transmission is implemented. But one thing must be
ensured, which is that do not waste cpu time, and is as real-time as possible.
So interrupt-driven mode is the choice.
Could you give me some guidance? Any suggestion is welcome.
Well, I can only offer generic advice: use a JTAG probe to break when your interrupt handler is entered and see what it does then: does it indeed write a character out? If it does, examine the UART's status bits: does it say it is busy transmitting? Does it say its xmit buffer is free (independently of raising an interrupt). Is the *whole* chain if interrupt handling correctly ackowledged after the interrupt? Etc. But the best advice I can offer is: if you have a requirement of interrupt-driven application behavior, do not run an application right above U-Boot; use a real-time OS of sorts, including Linux ones.
CodeWarrior USB Tap is the JTAG tool used now.
the first data in buf in transmitted in uart_put_buf(), not in handler routine.
And the first data is already seen from PC display.
I thought THRE INT will be triggered, but not.
To recognize the event causing interrupt, IIR(interrupt identification register) should be read when
interrupt-driven mode is used, and bit7 in it should be 0, which indicated there is interrupt pending
in current DUART channel. Buf in fact, it is 1, so there is no further handling to happen.
The transmitter status in LSR(line status register), is 1, which implies there is space for the next
data, but in interrupt-driven mode, we depend on THRE INT in IIR.
OS is out of our consideration now, and it is not determined by myself.
So many thanks for the help.
-Shawn
Thanks a lot.
np
-Shawn
Amicalement,
Albert.
Hi, Albert,
Hello, guys.
- why not implement duart driver in interrupt-driven mode, in addition to polling-mode?
things are done in the while loop.
yes,
after that, statement uthr = *buf> will put the first data in buf into thr register.
Interrupt handler routine is already connected with UART1 INT in IPIC, after this, once UART1 interrupt happens, the handler routine will be called.
function. In DUART handler routine, IP(interrupt pending bit in iir, interrupt identification register) is checked, if it is 1, then no interrupt is pending. handler routine will return.
-Shawn
Thanks a lot.
np
-Shawn
Amicalement,
Albert.
Hello, guys.
Well... If you cannot waste even a little CPU time on waiting for the UART, that pretty much amounts to saying you cannot work from inside a bootloader; you need a real-time OS. That's the reason they exist.
This is *even worse* than using a standalone application, because a) you're heavily modifying U-Boot in a way that it was not designed for, whereas you could do it with a standalone app, which is the documented way of doing that kind of thing in U-Boot.
yes,
to reference duart peripheral in mpc837xe-rdb board, structure duart83xx_t defined by uboot is used. [...]
I did not mean to doubt the *functionality* of the code, but the programming style: it uses direct volatile accesses, which are not welcome in U-Boot where such accesses are provided for with macros; it uses base+offset style whereas U-Boot mandates C structs; and it uses magic constants.
That in itself is in contradiction with using U-Boot. U-Boot has *no* reason to be real-time, and even less to provide real-time support to U-Boot standalone applications.
If it is a question of physical resources, there are real-time OSes out there with limited footprint. If it is a question of price, there are free ones too. But one thing is sure: U-Boot is not what you want if you are required to have real-time -- or you'll have to add the real-time capabilities yourself, but then, you won't be able to ask for help on this list, which is devoted to the U-Boot mainline code.
You're welcome. Sorry not to be able to get any further.
Amicalement,
Sorry -- "b)" was meant to be "use a standalone app", but I somehow half-rewrote my sentence in mid-air.
Amicalement,
Date: Sun, 14 Aug 2011 16:25:35 +0200 From: albert.u.boot@aribaud.net To: programassem@hotmail.com CC: u-boot@lists.denx.de Subject: Re: [U-Boot] Question about interrupt-driven mode duart on MPC837xE-rdb board.(with the subject)
Hello, guys.
Well... If you cannot waste even a little CPU time on waiting for the UART, that pretty much amounts to saying you cannot work from inside a bootloader; you need a real-time OS. That's the reason they exist. From the perspective of our manager, more things to handle, more possible to go wrong,
So, there is NO any OS, even real-time OS.
Actually, not modifying but referencing, we have source code of our own written by ourself.
yes,
yeah, I agress with you. It's just an example to show what we do.
Yes, this is the point. And you are right. For this question, I won't ask for answers or suggestions on the list again. I will try in another way to solve this question. Many thanks, anyway.
Amicalement,
Albert.
Albert ARIBAUD
shawn Bai
