[U-Boot] [PATCH 5/7] FAT: get_cluster: Add buffer bouncing
Add a buffer bouncing mechanism to get_cluster. This can be useful for misaligned applicative buffers passed through get_contents. This is required for the following patches in the case of data aligned differently relatively to buffers and clusters.
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com Cc: Wolfgang Denk wd@denx.de --- .../fs/fat/fat.c | 42 ++++++++++++++------ 1 file changed, 30 insertions(+), 12 deletions(-)
diff --git u-boot-66714b1.orig/fs/fat/fat.c u-boot-66714b1/fs/fat/fat.c index 943cdb6..4c80820 100644 --- u-boot-66714b1.orig/fs/fat/fat.c +++ u-boot-66714b1/fs/fat/fat.c @@ -274,7 +274,6 @@ get_cluster (fsdata *mydata, __u32 clustnum, __u8 *buffer, { __u32 idx = 0; __u32 startsect; - __u32 nr_sect; int ret;
if (clustnum > 0) { @@ -286,25 +285,44 @@ get_cluster (fsdata *mydata, __u32 clustnum, __u8 *buffer,
debug("gc - clustnum: %d, startsect: %d\n", clustnum, startsect);
- nr_sect = size / mydata->sect_size; - ret = disk_read(startsect, nr_sect, buffer); - if (ret != nr_sect) { - debug("Error reading data (got %d)\n", ret); - return -1; - } - if (size % mydata->sect_size) { + if ((unsigned long)buffer & (ARCH_DMA_MINALIGN - 1)) { ALLOC_CACHE_ALIGN_BUFFER(__u8, tmpbuf, mydata->sect_size);
+ debug("FAT: Misaligned buffer address (%p)\n", buffer); + + while (size >= mydata->sect_size) { + ret = disk_read(startsect++, 1, tmpbuf); + if (ret != 1) { + debug("Error reading data (got %d)\n", ret); + return -1; + } + + memcpy(buffer, tmpbuf, mydata->sect_size); + buffer += mydata->sect_size; + size -= mydata->sect_size; + } + } else { idx = size / mydata->sect_size; - ret = disk_read(startsect + idx, 1, tmpbuf); + ret = disk_read(startsect, idx, buffer); + if (ret != idx) { + debug("Error reading data (got %d)\n", ret); + return -1; + } + startsect += idx; + idx *= mydata->sect_size; + buffer += idx; + size -= idx; + } + if (size) { + ALLOC_CACHE_ALIGN_BUFFER(__u8, tmpbuf, mydata->sect_size); + + ret = disk_read(startsect, 1, tmpbuf); if (ret != 1) { debug("Error reading data (got %d)\n", ret); return -1; } - buffer += idx * mydata->sect_size;
- memcpy(buffer, tmpbuf, size % mydata->sect_size); - return 0; + memcpy(buffer, tmpbuf, size); }
i'd suggest making this a printf. bounce buffers are not cheap. -mike
OK. I chose debug to do like mmc.c. I'll switch to printf if you prefer. However, debug is better here IMHO to avoid visual pollution on stdout because this bouncing can still occur in normal conditions with perfectly aligned buffers, in the case data is read from an unaligned position relative to the file to an aligned offset relative to the buffer. This can be avoided by improving the file format by aligning its data structures, but one can not always change a file format. debug would allow to detect misaligned buffers or to optimize file formats while not being bothering for the compelled file formats containing misaligned data structures.
Indeed.
Anything else before I post a v2 of the series?
Regards, Benoît
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com Cc: Wolfgang Denk wd@denx.de --- Changes for v2: - Patch renumbering because of the new v2 1/8. - Possible code style changes due to the new v2 1/8. - Use printf instead of debug for the misalignment message.
diff --git u-boot-66714b1.orig/fs/fat/fat.c u-boot-66714b1/fs/fat/fat.c index 5d08948..101eb3a 100644 --- u-boot-66714b1.orig/fs/fat/fat.c +++ u-boot-66714b1/fs/fat/fat.c @@ -273,7 +273,6 @@ get_cluster(fsdata *mydata, __u32 clustnum, __u8 *buffer, unsigned long size) { __u32 idx = 0; __u32 startsect; - __u32 nr_sect; int ret;
if (clustnum > 0) { @@ -285,25 +284,44 @@ get_cluster(fsdata *mydata, __u32 clustnum, __u8 *buffer, unsigned long size)
+ printf("FAT: Misaligned buffer address (%p)\n", buffer); + + while (size >= mydata->sect_size) { + ret = disk_read(startsect++, 1, tmpbuf); + if (ret != 1) { + debug("Error reading data (got %d)\n", ret); + return -1; + } + + memcpy(buffer, tmpbuf, mydata->sect_size); + buffer += mydata->sect_size; + size -= mydata->sect_size; + } + } else { idx = size / mydata->sect_size; - ret = disk_read(startsect + idx, 1, tmpbuf); + ret = disk_read(startsect, idx, buffer); + if (ret != idx) { + debug("Error reading data (got %d)\n", ret); + return -1; + } + startsect += idx; + idx *= mydata->sect_size; + buffer += idx; + size -= idx; + } + if (size) { + ALLOC_CACHE_ALIGN_BUFFER(__u8, tmpbuf, mydata->sect_size); + + ret = disk_read(startsect, 1, tmpbuf); if (ret != 1) { debug("Error reading data (got %d)\n", ret); return -1; } - buffer += idx * mydata->sect_size;
Dear Benoît Thébaudeau,
In message 1423162220.332690.1342790468790.JavaMail.root@advansee.com you wrote:
Add a buffer bouncing mechanism to get_cluster. This can be useful for misaligned applicative buffers passed through get_contents. This is require= d for the following patches in the case of data aligned differently relatively to buffers and clusters.
Signed-off-by: Beno=C3=AEt Th=C3=A9baudeau benoit.thebaudeau@advansee.com Cc: Wolfgang Denk wd@denx.de
Changes for v2:
.../fs/fat/fat.c | 42 ++++++++++++++--=
Applied, thanks.
Benoît Thébaudeau
Mike Frysinger
