[U-Boot] [PATCH] ARM: dts: uniphier: sync DT with Linux 4.17-rc1
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/dts/uniphier-ld11-global.dts | 109 ++++++++++++++++++++++--- arch/arm/dts/uniphier-ld11-ref.dts | 25 ++++-- arch/arm/dts/uniphier-ld11.dtsi | 127 ++++++++++++++++++++++++++--- arch/arm/dts/uniphier-ld20-global.dts | 111 ++++++++++++++++++++++--- arch/arm/dts/uniphier-ld20-ref.dts | 25 ++++-- arch/arm/dts/uniphier-ld20.dtsi | 138 +++++++++++++++++++++++++++++--- arch/arm/dts/uniphier-ld4-ref.dts | 14 ++-- arch/arm/dts/uniphier-ld4.dtsi | 14 ++-- arch/arm/dts/uniphier-ld6b-ref.dts | 25 ++++-- arch/arm/dts/uniphier-ld6b.dtsi | 14 ++-- arch/arm/dts/uniphier-pinctrl.dtsi | 64 +++++++++++++-- arch/arm/dts/uniphier-pro4-ace.dts | 25 ++++-- arch/arm/dts/uniphier-pro4-ref.dts | 25 ++++-- arch/arm/dts/uniphier-pro4-sanji.dts | 25 ++++-- arch/arm/dts/uniphier-pro4.dtsi | 32 ++++++-- arch/arm/dts/uniphier-pro5.dtsi | 14 ++-- arch/arm/dts/uniphier-pxs2-gentil.dts | 49 ++++++++++-- arch/arm/dts/uniphier-pxs2-vodka.dts | 62 ++++++++++++-- arch/arm/dts/uniphier-pxs2.dtsi | 89 +++++++++++++++++--- arch/arm/dts/uniphier-pxs3-ref.dts | 36 +++++++-- arch/arm/dts/uniphier-pxs3.dtsi | 52 +++++++++--- arch/arm/dts/uniphier-ref-daughter.dtsi | 14 ++-- arch/arm/dts/uniphier-sld8-ref.dts | 14 ++-- arch/arm/dts/uniphier-sld8.dtsi | 14 ++-- arch/arm/dts/uniphier-support-card.dtsi | 14 ++-- 25 files changed, 925 insertions(+), 206 deletions(-)
diff --git a/arch/arm/dts/uniphier-ld11-global.dts b/arch/arm/dts/uniphier-ld11-global.dts index 5ffe7de..11be2aa 100644 --- a/arch/arm/dts/uniphier-ld11-global.dts +++ b/arch/arm/dts/uniphier-ld11-global.dts @@ -1,14 +1,13 @@ -/* - * Device Tree Source for UniPhier LD11 Global Board - * - * Copyright (C) 2016-2017 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com - * Kunihiko Hayashi hayashi.kunihiko@socionext.com - * - * SPDX-License-Identifier: (GPL-2.0+ OR MIT) - */ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +// +// Device Tree Source for UniPhier LD11 Global Board +// +// Copyright (C) 2016-2017 Socionext Inc. +// Author: Masahiro Yamada yamada.masahiro@socionext.com +// Kunihiko Hayashi hayashi.kunihiko@socionext.com
/dts-v1/; +#include <dt-bindings/gpio/uniphier-gpio.h> #include "uniphier-ld11.dtsi"
/ { @@ -37,6 +36,53 @@ device_type = "memory"; reg = <0 0x80000000 0 0x40000000>; }; + + dvdd_reg: reg-fixed { + compatible = "regulator-fixed"; + regulator-name = "DVDD"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + amp_vcc_reg: reg-fixed { + compatible = "regulator-fixed"; + regulator-name = "AMP_VCC"; + regulator-min-microvolt = <24000000>; + regulator-max-microvolt = <24000000>; + }; + + sound { + compatible = "audio-graph-card"; + label = "UniPhier LD11"; + widgets = "Headphone", "Headphone Jack"; + dais = <&i2s_port2 + &i2s_port3 + &i2s_port4 + &spdif_port0 + &comp_spdif_port0>; + }; + + spdif-out { + compatible = "linux,spdif-dit"; + #sound-dai-cells = <0>; + + port@0 { + spdif_tx: endpoint { + remote-endpoint = <&spdif_hiecout1>; + }; + }; + }; + + comp-spdif-out { + compatible = "linux,spdif-dit"; + #sound-dai-cells = <0>; + + port@0 { + comp_spdif_tx: endpoint { + remote-endpoint = <&comp_spdif_hiecout1>; + }; + }; + }; };
&serial0 { @@ -47,9 +93,43 @@ status = "okay"; };
+&i2s_hpcmout1 { + dai-format = "i2s"; + remote-endpoint = <&tas_speaker>; +}; + +&spdif_hiecout1 { + remote-endpoint = <&spdif_tx>; +}; + +&comp_spdif_hiecout1 { + remote-endpoint = <&comp_spdif_tx>; +}; + &i2c0 { status = "okay";
+ tas5707a@1d { + compatible = "ti,tas5711"; + reg = <0x1d>; + reset-gpios = <&gpio UNIPHIER_GPIO_PORT(23, 4) GPIO_ACTIVE_LOW>; + pdn-gpios = <&gpio UNIPHIER_GPIO_PORT(23, 5) GPIO_ACTIVE_LOW>; + #sound-dai-cells = <0>; + AVDD-supply = <&dvdd_reg>; + DVDD-supply = <&dvdd_reg>; + PVDD_A-supply = <&_vcc_reg>; + PVDD_B-supply = <&_vcc_reg>; + PVDD_C-supply = <&_vcc_reg>; + PVDD_D-supply = <&_vcc_reg>; + + port@0 { + tas_speaker: endpoint { + dai-format = "i2s"; + remote-endpoint = <&i2s_hpcmout1>; + }; + }; + }; + eeprom@50 { compatible = "st,24c64", "atmel,24c64", "i2c-eeprom"; reg = <0x50>; @@ -69,6 +149,17 @@ status = "okay"; };
+ð { + status = "okay"; + phy-handle = <ðphy>; +}; + +&mdio { + ethphy: ethphy@1 { + reg = <1>; + }; +}; + &nand { status = "okay"; }; diff --git a/arch/arm/dts/uniphier-ld11-ref.dts b/arch/arm/dts/uniphier-ld11-ref.dts index 54c5317..b8f6273 100644 --- a/arch/arm/dts/uniphier-ld11-ref.dts +++ b/arch/arm/dts/uniphier-ld11-ref.dts @@ -1,11 +1,9 @@ -/* - * Device Tree Source for UniPhier LD11 Reference Board - * - * Copyright (C) 2016 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: (GPL-2.0+ OR MIT) - */ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +// +// Device Tree Source for UniPhier LD11 Reference Board +// +// Copyright (C) 2016 Socionext Inc. +// Author: Masahiro Yamada yamada.masahiro@socionext.com
/dts-v1/; #include "uniphier-ld11.dtsi" @@ -70,3 +68,14 @@ &usb2 { status = "okay"; }; + +ð { + status = "okay"; + phy-handle = <ðphy>; +}; + +&mdio { + ethphy: ethphy@1 { + reg = <1>; + }; +}; diff --git a/arch/arm/dts/uniphier-ld11.dtsi b/arch/arm/dts/uniphier-ld11.dtsi index 8b5b363..bf3118e 100644 --- a/arch/arm/dts/uniphier-ld11.dtsi +++ b/arch/arm/dts/uniphier-ld11.dtsi @@ -1,11 +1,9 @@ -/* - * Device Tree Source for UniPhier LD11 SoC - * - * Copyright (C) 2016 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: (GPL-2.0+ OR MIT) - */ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +// +// Device Tree Source for UniPhier LD11 SoC +// +// Copyright (C) 2016 Socionext Inc. +// Author: Masahiro Yamada yamada.masahiro@socionext.com
#include <dt-bindings/gpio/gpio.h> #include <dt-bindings/gpio/uniphier-gpio.h> @@ -191,6 +189,92 @@ <21 217 3>; };
+ audio@56000000 { + compatible = "socionext,uniphier-ld11-aio"; + reg = <0x56000000 0x80000>; + interrupts = <0 144 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_aout1>, + <&pinctrl_aoutiec1>; + clock-names = "aio"; + clocks = <&sys_clk 40>; + reset-names = "aio"; + resets = <&sys_rst 40>; + #sound-dai-cells = <1>; + socionext,syscon = <&soc_glue>; + + i2s_port0: port@0 { + i2s_hdmi: endpoint { + }; + }; + + i2s_port1: port@1 { + i2s_pcmin2: endpoint { + }; + }; + + i2s_port2: port@2 { + i2s_line: endpoint { + dai-format = "i2s"; + remote-endpoint = <&evea_line>; + }; + }; + + i2s_port3: port@3 { + i2s_hpcmout1: endpoint { + }; + }; + + i2s_port4: port@4 { + i2s_hp: endpoint { + dai-format = "i2s"; + remote-endpoint = <&evea_hp>; + }; + }; + + spdif_port0: port@5 { + spdif_hiecout1: endpoint { + }; + }; + + src_port0: port@6 { + i2s_epcmout2: endpoint { + }; + }; + + src_port1: port@7 { + i2s_epcmout3: endpoint { + }; + }; + + comp_spdif_port0: port@8 { + comp_spdif_hiecout1: endpoint { + }; + }; + }; + + codec@57900000 { + compatible = "socionext,uniphier-evea"; + reg = <0x57900000 0x1000>; + clock-names = "evea", "exiv"; + clocks = <&sys_clk 41>, <&sys_clk 42>; + reset-names = "evea", "exiv", "adamv"; + resets = <&sys_rst 41>, <&sys_rst 42>, <&adamv_rst 0>; + #sound-dai-cells = <1>; + + port@0 { + evea_line: endpoint { + remote-endpoint = <&i2s_line>; + }; + }; + + port@1 { + evea_hp: endpoint { + remote-endpoint = <&i2s_hp>; + }; + }; + }; + adamv@57920000 { compatible = "socionext,uniphier-ld11-adamv", "simple-mfd", "syscon"; @@ -400,7 +484,7 @@ }; };
- soc-glue@5f800000 { + soc_glue: soc-glue@5f800000 { compatible = "socionext,uniphier-ld11-soc-glue", "simple-mfd", "syscon"; reg = <0x5f800000 0x2000>; @@ -464,6 +548,22 @@ }; };
+ eth: ethernet@65000000 { + compatible = "socionext,uniphier-ld11-ave4"; + status = "disabled"; + reg = <0x65000000 0x8500>; + interrupts = <0 66 4>; + clocks = <&sys_clk 6>; + resets = <&sys_rst 6>; + phy-mode = "rmii"; + local-mac-address = [00 00 00 00 00 00]; + + mdio: mdio { + #address-cells = <1>; + #size-cells = <0>; + }; + }; + nand: nand@68000000 { compatible = "socionext,uniphier-denali-nand-v5b"; status = "disabled"; @@ -479,3 +579,12 @@ };
#include "uniphier-pinctrl.dtsi" + +&pinctrl_aoutiec1 { + drive-strength = <4>; /* default: 4mA */ + + ao1arc { + pins = "AO1ARC"; + drive-strength = <8>; /* 8mA */ + }; +}; diff --git a/arch/arm/dts/uniphier-ld20-global.dts b/arch/arm/dts/uniphier-ld20-global.dts index fc2bc9d..fe6608e 100644 --- a/arch/arm/dts/uniphier-ld20-global.dts +++ b/arch/arm/dts/uniphier-ld20-global.dts @@ -1,14 +1,13 @@ -/* - * Device Tree Source for UniPhier LD20 Global Board - * - * Copyright (C) 2015-2017 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com - * Kunihiko Hayashi hayashi.kunihiko@socionext.com - * - * SPDX-License-Identifier: (GPL-2.0+ OR MIT) - */ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +// +// Device Tree Source for UniPhier LD20 Global Board +// +// Copyright (C) 2015-2017 Socionext Inc. +// Author: Masahiro Yamada yamada.masahiro@socionext.com +// Kunihiko Hayashi hayashi.kunihiko@socionext.com
/dts-v1/; +#include <dt-bindings/gpio/uniphier-gpio.h> #include "uniphier-ld20.dtsi"
/ { @@ -37,6 +36,53 @@ device_type = "memory"; reg = <0 0x80000000 0 0xc0000000>; }; + + dvdd_reg: reg-fixed { + compatible = "regulator-fixed"; + regulator-name = "DVDD"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + amp_vcc_reg: reg-fixed { + compatible = "regulator-fixed"; + regulator-name = "AMP_VCC"; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + }; + + sound { + compatible = "audio-graph-card"; + label = "UniPhier LD20"; + widgets = "Headphone", "Headphone Jack"; + dais = <&i2s_port2 + &i2s_port3 + &i2s_port4 + &spdif_port0 + &comp_spdif_port0>; + }; + + spdif-out { + compatible = "linux,spdif-dit"; + #sound-dai-cells = <0>; + + port@0 { + spdif_tx: endpoint { + remote-endpoint = <&spdif_hiecout1>; + }; + }; + }; + + comp-spdif-out { + compatible = "linux,spdif-dit"; + #sound-dai-cells = <0>; + + port@0 { + comp_spdif_tx: endpoint { + remote-endpoint = <&comp_spdif_hiecout1>; + }; + }; + }; };
&serial0 { @@ -47,8 +93,55 @@ status = "okay"; };
+&i2s_hpcmout1 { + dai-format = "i2s"; + remote-endpoint = <&tas_speaker>; +}; + +&spdif_hiecout1 { + remote-endpoint = <&spdif_tx>; +}; + +&comp_spdif_hiecout1 { + remote-endpoint = <&comp_spdif_tx>; +}; + &i2c0 { status = "okay"; + + tas5707@1b { + compatible = "ti,tas5711"; + reg = <0x1b>; + reset-gpios = <&gpio UNIPHIER_GPIO_PORT(0, 0) GPIO_ACTIVE_LOW>; + pdn-gpios = <&gpio UNIPHIER_GPIO_PORT(0, 1) GPIO_ACTIVE_LOW>; + #sound-dai-cells = <0>; + AVDD-supply = <&dvdd_reg>; + DVDD-supply = <&dvdd_reg>; + PVDD_A-supply = <&_vcc_reg>; + PVDD_B-supply = <&_vcc_reg>; + PVDD_C-supply = <&_vcc_reg>; + PVDD_D-supply = <&_vcc_reg>; + + port@0 { + tas_speaker: endpoint { + dai-format = "i2s"; + remote-endpoint = <&i2s_hpcmout1>; + }; + }; + }; +}; + +ð { + status = "okay"; + phy-mode = "rmii"; + pinctrl-0 = <&pinctrl_ether_rmii>; + phy-handle = <ðphy>; +}; + +&mdio { + ethphy: ethphy@1 { + reg = <1>; + }; };
&nand { diff --git a/arch/arm/dts/uniphier-ld20-ref.dts b/arch/arm/dts/uniphier-ld20-ref.dts index 6933710..2c1a92f 100644 --- a/arch/arm/dts/uniphier-ld20-ref.dts +++ b/arch/arm/dts/uniphier-ld20-ref.dts @@ -1,11 +1,9 @@ -/* - * Device Tree Source for UniPhier LD20 Reference Board - * - * Copyright (C) 2015-2016 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: (GPL-2.0+ OR MIT) - */ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +// +// Device Tree Source for UniPhier LD20 Reference Board +// +// Copyright (C) 2015-2016 Socionext Inc. +// Author: Masahiro Yamada yamada.masahiro@socionext.com
/dts-v1/; #include "uniphier-ld20.dtsi" @@ -58,3 +56,14 @@ &i2c0 { status = "okay"; }; + +ð { + status = "okay"; + phy-handle = <ðphy>; +}; + +&mdio { + ethphy: ethphy@0 { + reg = <0>; + }; +}; diff --git a/arch/arm/dts/uniphier-ld20.dtsi b/arch/arm/dts/uniphier-ld20.dtsi index 4d8655e..d40a14c 100644 --- a/arch/arm/dts/uniphier-ld20.dtsi +++ b/arch/arm/dts/uniphier-ld20.dtsi @@ -1,11 +1,9 @@ -/* - * Device Tree Source for UniPhier LD20 SoC - * - * Copyright (C) 2015-2016 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: (GPL-2.0+ OR MIT) - */ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +// +// Device Tree Source for UniPhier LD20 SoC +// +// Copyright (C) 2015-2016 Socionext Inc. +// Author: Masahiro Yamada yamada.masahiro@socionext.com
#include <dt-bindings/gpio/gpio.h> #include <dt-bindings/gpio/uniphier-gpio.h> @@ -291,6 +289,92 @@ <21 217 3>; };
+ audio@56000000 { + compatible = "socionext,uniphier-ld20-aio"; + reg = <0x56000000 0x80000>; + interrupts = <0 144 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_aout1>, + <&pinctrl_aoutiec1>; + clock-names = "aio"; + clocks = <&sys_clk 40>; + reset-names = "aio"; + resets = <&sys_rst 40>; + #sound-dai-cells = <1>; + socionext,syscon = <&soc_glue>; + + i2s_port0: port@0 { + i2s_hdmi: endpoint { + }; + }; + + i2s_port1: port@1 { + i2s_pcmin2: endpoint { + }; + }; + + i2s_port2: port@2 { + i2s_line: endpoint { + dai-format = "i2s"; + remote-endpoint = <&evea_line>; + }; + }; + + i2s_port3: port@3 { + i2s_hpcmout1: endpoint { + }; + }; + + i2s_port4: port@4 { + i2s_hp: endpoint { + dai-format = "i2s"; + remote-endpoint = <&evea_hp>; + }; + }; + + spdif_port0: port@5 { + spdif_hiecout1: endpoint { + }; + }; + + src_port0: port@6 { + i2s_epcmout2: endpoint { + }; + }; + + src_port1: port@7 { + i2s_epcmout3: endpoint { + }; + }; + + comp_spdif_port0: port@8 { + comp_spdif_hiecout1: endpoint { + }; + }; + }; + + codec@57900000 { + compatible = "socionext,uniphier-evea"; + reg = <0x57900000 0x1000>; + clock-names = "evea", "exiv"; + clocks = <&sys_clk 41>, <&sys_clk 42>; + reset-names = "evea", "exiv", "adamv"; + resets = <&sys_rst 41>, <&sys_rst 42>, <&adamv_rst 0>; + #sound-dai-cells = <1>; + + port@0 { + evea_line: endpoint { + remote-endpoint = <&i2s_line>; + }; + }; + + port@1 { + evea_hp: endpoint { + remote-endpoint = <&i2s_hp>; + }; + }; + }; + adamv@57920000 { compatible = "socionext,uniphier-ld20-adamv", "simple-mfd", "syscon"; @@ -460,7 +544,7 @@ cap-sd-highspeed; };
- soc-glue@5f800000 { + soc_glue: soc-glue@5f800000 { compatible = "socionext,uniphier-ld20-soc-glue", "simple-mfd", "syscon"; reg = <0x5f800000 0x2000>; @@ -549,6 +633,24 @@ }; };
+ eth: ethernet@65000000 { + compatible = "socionext,uniphier-ld20-ave4"; + status = "disabled"; + reg = <0x65000000 0x8500>; + interrupts = <0 66 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ether_rgmii>; + clocks = <&sys_clk 6>; + resets = <&sys_rst 6>; + phy-mode = "rgmii"; + local-mac-address = [00 00 00 00 00 00]; + + mdio: mdio { + #address-cells = <1>; + #size-cells = <0>; + }; + }; + nand: nand@68000000 { compatible = "socionext,uniphier-denali-nand-v5b"; status = "disabled"; @@ -564,3 +666,21 @@ };
#include "uniphier-pinctrl.dtsi" + +&pinctrl_aout1 { + drive-strength = <4>; /* default: 3.5mA */ + + ao1dacck { + pins = "AO1DACCK"; + drive-strength = <5>; /* 5mA */ + }; +}; + +&pinctrl_aoutiec1 { + drive-strength = <4>; /* default: 3.5mA */ + + ao1arc { + pins = "AO1ARC"; + drive-strength = <11>; /* 11mA */ + }; +}; diff --git a/arch/arm/dts/uniphier-ld4-ref.dts b/arch/arm/dts/uniphier-ld4-ref.dts index 6097878..3aaca10 100644 --- a/arch/arm/dts/uniphier-ld4-ref.dts +++ b/arch/arm/dts/uniphier-ld4-ref.dts @@ -1,11 +1,9 @@ -/* - * Device Tree Source for UniPhier LD4 Reference Board - * - * Copyright (C) 2015-2016 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: (GPL-2.0+ OR MIT) - */ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +// +// Device Tree Source for UniPhier LD4 Reference Board +// +// Copyright (C) 2015-2016 Socionext Inc. +// Author: Masahiro Yamada yamada.masahiro@socionext.com
/dts-v1/; #include "uniphier-ld4.dtsi" diff --git a/arch/arm/dts/uniphier-ld4.dtsi b/arch/arm/dts/uniphier-ld4.dtsi index 0393bce..5e43a92 100644 --- a/arch/arm/dts/uniphier-ld4.dtsi +++ b/arch/arm/dts/uniphier-ld4.dtsi @@ -1,11 +1,9 @@ -/* - * Device Tree Source for UniPhier LD4 SoC - * - * Copyright (C) 2015-2016 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: (GPL-2.0+ OR MIT) - */ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +// +// Device Tree Source for UniPhier LD4 SoC +// +// Copyright (C) 2015-2016 Socionext Inc. +// Author: Masahiro Yamada yamada.masahiro@socionext.com
diff --git a/arch/arm/dts/uniphier-ld6b-ref.dts b/arch/arm/dts/uniphier-ld6b-ref.dts index 1703d8f..2596b30 100644 --- a/arch/arm/dts/uniphier-ld6b-ref.dts +++ b/arch/arm/dts/uniphier-ld6b-ref.dts @@ -1,11 +1,9 @@ -/* - * Device Tree Source for UniPhier LD6b Reference Board - * - * Copyright (C) 2015-2016 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: (GPL-2.0+ OR MIT) - */ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +// +// Device Tree Source for UniPhier LD6b Reference Board +// +// Copyright (C) 2015-2016 Socionext Inc. +// Author: Masahiro Yamada yamada.masahiro@socionext.com
/dts-v1/; #include "uniphier-ld6b.dtsi" @@ -79,6 +77,17 @@ status = "okay"; };
+ð { + status = "okay"; + phy-handle = <ðphy>; +}; + +&mdio { + ethphy: ethphy@0 { + reg = <0>; + }; +}; + &nand { status = "okay"; }; diff --git a/arch/arm/dts/uniphier-ld6b.dtsi b/arch/arm/dts/uniphier-ld6b.dtsi index 9a7b25c..4d07a94 100644 --- a/arch/arm/dts/uniphier-ld6b.dtsi +++ b/arch/arm/dts/uniphier-ld6b.dtsi @@ -1,11 +1,9 @@ -/* - * Device Tree Source for UniPhier LD6b SoC - * - * Copyright (C) 2015-2016 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: (GPL-2.0+ OR MIT) - */ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +// +// Device Tree Source for UniPhier LD6b SoC +// +// Copyright (C) 2015-2016 Socionext Inc. +// Author: Masahiro Yamada yamada.masahiro@socionext.com
/* * LD6b consists of two silicon dies: D-chip and A-chip. diff --git a/arch/arm/dts/uniphier-pinctrl.dtsi b/arch/arm/dts/uniphier-pinctrl.dtsi index d4f78c2..9dd9d49 100644 --- a/arch/arm/dts/uniphier-pinctrl.dtsi +++ b/arch/arm/dts/uniphier-pinctrl.dtsi @@ -1,11 +1,9 @@ -/* - * Device Tree Source for UniPhier SoCs default pinctrl settings - * - * Copyright (C) 2015-2017 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: (GPL-2.0+ OR MIT) - */ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +// +// Device Tree Source for UniPhier SoCs default pinctrl settings +// +// Copyright (C) 2015-2017 Socionext Inc. +// Author: Masahiro Yamada yamada.masahiro@socionext.com
&pinctrl { pinctrl_aout: aout { @@ -13,6 +11,46 @@ function = "aout"; };
+ pinctrl_ain1: ain1 { + groups = "ain1"; + function = "ain1"; + }; + + pinctrl_ain2: ain2 { + groups = "ain2"; + function = "ain2"; + }; + + pinctrl_ainiec1: ainiec1 { + groups = "ainiec1"; + function = "ainiec1"; + }; + + pinctrl_aout1: aout1 { + groups = "aout1"; + function = "aout1"; + }; + + pinctrl_aout2: aout2 { + groups = "aout2"; + function = "aout2"; + }; + + pinctrl_aout3: aout3 { + groups = "aout3"; + function = "aout3"; + }; + + pinctrl_aoutiec1: aoutiec1 { + groups = "aoutiec1"; + function = "aoutiec1"; + }; + + pinctrl_aoutiec2: aoutiec2 { + groups = "aoutiec2"; + function = "aoutiec2"; + }; + pinctrl_emmc: emmc { groups = "emmc", "emmc_dat8"; function = "emmc"; @@ -38,6 +76,16 @@ function = "ether_rmii"; };
+ pinctrl_ether1_rgmii: ether1-rgmii { + groups = "ether1_rgmii"; + function = "ether1_rgmii"; + }; + + pinctrl_ether1_rmii: ether1-rmii { + groups = "ether1_rmii"; + function = "ether1_rmii"; + }; + pinctrl_i2c0: i2c0 { groups = "i2c0"; function = "i2c0"; diff --git a/arch/arm/dts/uniphier-pro4-ace.dts b/arch/arm/dts/uniphier-pro4-ace.dts index 60a8c33..c6c4d23 100644 --- a/arch/arm/dts/uniphier-pro4-ace.dts +++ b/arch/arm/dts/uniphier-pro4-ace.dts @@ -1,11 +1,9 @@ -/* - * Device Tree Source for UniPhier Pro4 Ace Board - * - * Copyright (C) 2016 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: (GPL-2.0+ OR MIT) - */ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +// +// Device Tree Source for UniPhier Pro4 Ace Board +// +// Copyright (C) 2016 Socionext Inc. +// Author: Masahiro Yamada yamada.masahiro@socionext.com
/dts-v1/; #include "uniphier-pro4.dtsi" @@ -90,3 +88,14 @@ &usb3 { status = "okay"; }; + +ð { + status = "okay"; + phy-handle = <ðphy>; +}; + +&mdio { + ethphy: ethphy@1 { + reg = <1>; + }; +}; diff --git a/arch/arm/dts/uniphier-pro4-ref.dts b/arch/arm/dts/uniphier-pro4-ref.dts index c2466cd..9d79a26 100644 --- a/arch/arm/dts/uniphier-pro4-ref.dts +++ b/arch/arm/dts/uniphier-pro4-ref.dts @@ -1,11 +1,9 @@ -/* - * Device Tree Source for UniPhier Pro4 Reference Board - * - * Copyright (C) 2015-2016 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: (GPL-2.0+ OR MIT) - */ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +// +// Device Tree Source for UniPhier Pro4 Reference Board +// +// Copyright (C) 2015-2016 Socionext Inc. +// Author: Masahiro Yamada yamada.masahiro@socionext.com
/dts-v1/; #include "uniphier-pro4.dtsi" @@ -92,6 +90,17 @@ status = "okay"; };
+ð { + status = "okay"; + phy-handle = <ðphy>; +}; + +&mdio { + ethphy: ethphy@0 { + reg = <0>; + }; +}; + &nand { status = "okay"; }; diff --git a/arch/arm/dts/uniphier-pro4-sanji.dts b/arch/arm/dts/uniphier-pro4-sanji.dts index 950f47a..24f4333 100644 --- a/arch/arm/dts/uniphier-pro4-sanji.dts +++ b/arch/arm/dts/uniphier-pro4-sanji.dts @@ -1,11 +1,9 @@ -/* - * Device Tree Source for UniPhier Pro4 Sanji Board - * - * Copyright (C) 2016 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: (GPL-2.0+ OR MIT) - */ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +// +// Device Tree Source for UniPhier Pro4 Sanji Board +// +// Copyright (C) 2016 Socionext Inc. +// Author: Masahiro Yamada yamada.masahiro@socionext.com
/dts-v1/; #include "uniphier-pro4.dtsi" @@ -85,3 +83,14 @@ &usb3 { status = "okay"; }; + +ð { + status = "okay"; + phy-handle = <ðphy>; +}; + +&mdio { + ethphy: ethphy@1 { + reg = <1>; + }; +}; diff --git a/arch/arm/dts/uniphier-pro4.dtsi b/arch/arm/dts/uniphier-pro4.dtsi index e9d3a3d..6f2b813 100644 --- a/arch/arm/dts/uniphier-pro4.dtsi +++ b/arch/arm/dts/uniphier-pro4.dtsi @@ -1,11 +1,9 @@ -/* - * Device Tree Source for UniPhier Pro4 SoC - * - * Copyright (C) 2015-2016 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: (GPL-2.0+ OR MIT) - */ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +// +// Device Tree Source for UniPhier Pro4 SoC +// +// Copyright (C) 2015-2016 Socionext Inc. +// Author: Masahiro Yamada yamada.masahiro@socionext.com
@@ -458,6 +456,24 @@ }; };
+ eth: ethernet@65000000 { + compatible = "socionext,uniphier-pro4-ave4"; + status = "disabled"; + reg = <0x65000000 0x8500>; + interrupts = <0 66 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ether_rgmii>; + clocks = <&sys_clk 6>; + resets = <&sys_rst 6>; + phy-mode = "rgmii"; + local-mac-address = [00 00 00 00 00 00]; + + mdio: mdio { + #address-cells = <1>; + #size-cells = <0>; + }; + }; + nand: nand@68000000 { compatible = "socionext,uniphier-denali-nand-v5a"; status = "disabled"; diff --git a/arch/arm/dts/uniphier-pro5.dtsi b/arch/arm/dts/uniphier-pro5.dtsi index a4de9b8..32debf5 100644 --- a/arch/arm/dts/uniphier-pro5.dtsi +++ b/arch/arm/dts/uniphier-pro5.dtsi @@ -1,11 +1,9 @@ -/* - * Device Tree Source for UniPhier Pro5 SoC - * - * Copyright (C) 2015-2016 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: (GPL-2.0+ OR MIT) - */ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +// +// Device Tree Source for UniPhier Pro5 SoC +// +// Copyright (C) 2015-2016 Socionext Inc. +// Author: Masahiro Yamada yamada.masahiro@socionext.com
/ { compatible = "socionext,uniphier-pro5"; diff --git a/arch/arm/dts/uniphier-pxs2-gentil.dts b/arch/arm/dts/uniphier-pxs2-gentil.dts index 4397714..f4a2398 100644 --- a/arch/arm/dts/uniphier-pxs2-gentil.dts +++ b/arch/arm/dts/uniphier-pxs2-gentil.dts @@ -1,11 +1,9 @@ -/* - * Device Tree Source for UniPhier PXs2 Gentil Board - * - * Copyright (C) 2015-2016 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: (GPL-2.0+ OR MIT) - */ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +// +// Device Tree Source for UniPhier PXs2 Gentil Board +// +// Copyright (C) 2015-2016 Socionext Inc. +// Author: Masahiro Yamada yamada.masahiro@socionext.com
/dts-v1/; #include "uniphier-pxs2.dtsi" @@ -34,6 +32,12 @@ device_type = "memory"; reg = <0x80000000 0x80000000>; }; + + sound { + compatible = "audio-graph-card"; + label = "UniPhier PXs2"; + dais = <&i2s_port2>; + }; };
&serial2 { @@ -51,8 +55,26 @@ }; };
+&i2s_aux { + dai-format = "i2s"; + remote-endpoint = <&wm_speaker>; +}; + &i2c2 { status = "okay"; + + wm8960@1a { + compatible = "wlf,wm8960"; + reg = <0x1a>; + #sound-dai-cells = <0>; + + port@0 { + wm_speaker: endpoint { + dai-format = "i2s"; + remote-endpoint = <&i2s_aux>; + }; + }; + }; };
&emmc { @@ -66,3 +88,14 @@ &usb1 { status = "okay"; }; + +ð { + status = "okay"; + phy-handle = <ðphy>; +}; + +&mdio { + ethphy: ethphy@1 { + reg = <1>; + }; +}; diff --git a/arch/arm/dts/uniphier-pxs2-vodka.dts b/arch/arm/dts/uniphier-pxs2-vodka.dts index d29096f..d11eef5 100644 --- a/arch/arm/dts/uniphier-pxs2-vodka.dts +++ b/arch/arm/dts/uniphier-pxs2-vodka.dts @@ -1,11 +1,9 @@ -/* - * Device Tree Source for UniPhier PXs2 Vodka Board - * - * Copyright (C) 2015-2016 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: (GPL-2.0+ OR MIT) - */ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +// +// Device Tree Source for UniPhier PXs2 Vodka Board +// +// Copyright (C) 2015-2016 Socionext Inc. +// Author: Masahiro Yamada yamada.masahiro@socionext.com
/dts-v1/; #include "uniphier-pxs2.dtsi" @@ -32,12 +30,49 @@ device_type = "memory"; reg = <0x80000000 0x80000000>; }; + + sound { + compatible = "audio-graph-card"; + label = "UniPhier PXs2"; + dais = <&spdif_port0 + &comp_spdif_port0>; + }; + + spdif-out { + compatible = "linux,spdif-dit"; + #sound-dai-cells = <0>; + + port@0 { + spdif_tx: endpoint { + remote-endpoint = <&spdif_hiecout1>; + }; + }; + }; + + comp-spdif-out { + compatible = "linux,spdif-dit"; + #sound-dai-cells = <0>; + + port@0 { + comp_spdif_tx: endpoint { + remote-endpoint = <&comp_spdif_hiecout1>; + }; + }; + }; };
&serial2 { status = "okay"; };
+&spdif_hiecout1 { + remote-endpoint = <&spdif_tx>; +}; + +&comp_spdif_hiecout1 { + remote-endpoint = <&comp_spdif_tx>; +}; + &i2c0 { status = "okay"; }; @@ -49,3 +84,14 @@ &usb0 { status = "okay"; }; + +ð { + status = "okay"; + phy-handle = <ðphy>; +}; + +&mdio { + ethphy: ethphy@1 { + reg = <1>; + }; +}; diff --git a/arch/arm/dts/uniphier-pxs2.dtsi b/arch/arm/dts/uniphier-pxs2.dtsi index 7822c9e..f0b129f 100644 --- a/arch/arm/dts/uniphier-pxs2.dtsi +++ b/arch/arm/dts/uniphier-pxs2.dtsi @@ -1,11 +1,9 @@ -/* - * Device Tree Source for UniPhier PXs2 SoC - * - * Copyright (C) 2015-2016 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: (GPL-2.0+ OR MIT) - */ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +// +// Device Tree Source for UniPhier PXs2 SoC +// +// Copyright (C) 2015-2016 Socionext Inc. +// Author: Masahiro Yamada yamada.masahiro@socionext.com
#include <dt-bindings/gpio/uniphier-gpio.h> #include <dt-bindings/thermal/thermal.h> @@ -231,6 +229,61 @@ <21 217 3>; };
+ audio@56000000 { + compatible = "socionext,uniphier-pxs2-aio"; + reg = <0x56000000 0x80000>; + interrupts = <0 144 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ain1>, + <&pinctrl_ain2>, + <&pinctrl_ainiec1>, + <&pinctrl_aout2>, + <&pinctrl_aout3>, + <&pinctrl_aoutiec1>, + <&pinctrl_aoutiec2>; + clock-names = "aio"; + clocks = <&sys_clk 40>; + reset-names = "aio"; + resets = <&sys_rst 40>; + #sound-dai-cells = <1>; + socionext,syscon = <&soc_glue>; + + i2s_port0: port@0 { + i2s_hdmi: endpoint { + }; + }; + + i2s_port1: port@1 { + i2s_line: endpoint { + }; + }; + + i2s_port2: port@2 { + i2s_aux: endpoint { + }; + }; + + spdif_port0: port@3 { + spdif_hiecout1: endpoint { + }; + }; + + spdif_port1: port@4 { + spdif_iecout1: endpoint { + }; + }; + + comp_spdif_port0: port@5 { + comp_spdif_hiecout1: endpoint { + }; + }; + + comp_spdif_port1: port@6 { + comp_spdif_iecout1: endpoint { + }; + }; + }; + i2c0: i2c@58780000 { compatible = "socionext,uniphier-fi2c"; status = "disabled"; @@ -405,7 +458,7 @@ sd-uhs-sdr50; };
- soc-glue@5f800000 { + soc_glue: soc-glue@5f800000 { compatible = "socionext,uniphier-pxs2-soc-glue", "simple-mfd", "syscon"; reg = <0x5f800000 0x2000>; @@ -521,6 +574,24 @@ }; };
+ eth: ethernet@65000000 { + compatible = "socionext,uniphier-pxs2-ave4"; + status = "disabled"; + reg = <0x65000000 0x8500>; + interrupts = <0 66 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ether_rgmii>; + clocks = <&sys_clk 6>; + resets = <&sys_rst 6>; + phy-mode = "rgmii"; + local-mac-address = [00 00 00 00 00 00]; + + mdio: mdio { + #address-cells = <1>; + #size-cells = <0>; + }; + }; + nand: nand@68000000 { compatible = "socionext,uniphier-denali-nand-v5b"; status = "disabled"; diff --git a/arch/arm/dts/uniphier-pxs3-ref.dts b/arch/arm/dts/uniphier-pxs3-ref.dts index 0463a8f..9cfe7d9 100644 --- a/arch/arm/dts/uniphier-pxs3-ref.dts +++ b/arch/arm/dts/uniphier-pxs3-ref.dts @@ -1,11 +1,9 @@ -/* - * Device Tree Source for UniPhier PXs3 Reference Board - * - * Copyright (C) 2017 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: (GPL-2.0+ OR MIT) - */ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +// +// Device Tree Source for UniPhier PXs3 Reference Board +// +// Copyright (C) 2017 Socionext Inc. +// Author: Masahiro Yamada yamada.masahiro@socionext.com
/dts-v1/; #include "uniphier-pxs3.dtsi" @@ -85,6 +83,28 @@ status = "okay"; };
+ð0 { + status = "okay"; + phy-handle = <ðphy0>; +}; + +&mdio0 { + ethphy0: ethphy@0 { + reg = <0>; + }; +}; + +ð1 { + status = "okay"; + phy-handle = <ðphy1>; +}; + +&mdio1 { + ethphy1: ethphy@0 { + reg = <0>; + }; +}; + &nand { status = "okay"; }; diff --git a/arch/arm/dts/uniphier-pxs3.dtsi b/arch/arm/dts/uniphier-pxs3.dtsi index 87ab5e7..cd0c430 100644 --- a/arch/arm/dts/uniphier-pxs3.dtsi +++ b/arch/arm/dts/uniphier-pxs3.dtsi @@ -1,11 +1,9 @@ -/* - * Device Tree Source for UniPhier PXs3 SoC - * - * Copyright (C) 2017 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: (GPL-2.0+ OR MIT) - */ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +// +// Device Tree Source for UniPhier PXs3 SoC +// +// Copyright (C) 2017 Socionext Inc. +// Author: Masahiro Yamada yamada.masahiro@socionext.com
#include <dt-bindings/gpio/gpio.h> #include <dt-bindings/gpio/uniphier-gpio.h> @@ -361,7 +359,7 @@ cap-sd-highspeed; };
- soc-glue@5f800000 { + soc_glue: soc-glue@5f800000 { compatible = "socionext,uniphier-pxs3-soc-glue", "simple-mfd", "syscon"; reg = <0x5f800000 0x2000>; @@ -461,6 +459,42 @@ }; };
+ eth0: ethernet@65000000 { + compatible = "socionext,uniphier-pxs3-ave4"; + status = "disabled"; + reg = <0x65000000 0x8500>; + interrupts = <0 66 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ether_rgmii>; + clocks = <&sys_clk 6>; + resets = <&sys_rst 6>; + phy-mode = "rgmii"; + local-mac-address = [00 00 00 00 00 00]; + + mdio0: mdio { + #address-cells = <1>; + #size-cells = <0>; + }; + }; + + eth1: ethernet@65200000 { + compatible = "socionext,uniphier-pxs3-ave4"; + status = "disabled"; + reg = <0x65200000 0x8500>; + interrupts = <0 67 4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ether1_rgmii>; + clocks = <&sys_clk 7>; + resets = <&sys_rst 7>; + phy-mode = "rgmii"; + local-mac-address = [00 00 00 00 00 00]; + + mdio1: mdio { + #address-cells = <1>; + #size-cells = <0>; + }; + }; + nand: nand@68000000 { compatible = "socionext,uniphier-denali-nand-v5b"; status = "disabled"; diff --git a/arch/arm/dts/uniphier-ref-daughter.dtsi b/arch/arm/dts/uniphier-ref-daughter.dtsi index 78eccfd..9240a31 100644 --- a/arch/arm/dts/uniphier-ref-daughter.dtsi +++ b/arch/arm/dts/uniphier-ref-daughter.dtsi @@ -1,11 +1,9 @@ -/* - * Device Tree Source for UniPhier Reference Daughter Board - * - * Copyright (C) 2015-2017 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: (GPL-2.0+ OR MIT) - */ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +// +// Device Tree Source for UniPhier Reference Daughter Board +// +// Copyright (C) 2015-2017 Socionext Inc. +// Author: Masahiro Yamada yamada.masahiro@socionext.com
&i2c0 { eeprom@50 { diff --git a/arch/arm/dts/uniphier-sld8-ref.dts b/arch/arm/dts/uniphier-sld8-ref.dts index 8fae1ed..01bf94c 100644 --- a/arch/arm/dts/uniphier-sld8-ref.dts +++ b/arch/arm/dts/uniphier-sld8-ref.dts @@ -1,11 +1,9 @@ -/* - * Device Tree Source for UniPhier sLD8 Reference Board - * - * Copyright (C) 2015-2016 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: (GPL-2.0+ OR MIT) - */ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +// +// Device Tree Source for UniPhier sLD8 Reference Board +// +// Copyright (C) 2015-2016 Socionext Inc. +// Author: Masahiro Yamada yamada.masahiro@socionext.com
/dts-v1/; #include "uniphier-sld8.dtsi" diff --git a/arch/arm/dts/uniphier-sld8.dtsi b/arch/arm/dts/uniphier-sld8.dtsi index fc7585b..67d6977 100644 --- a/arch/arm/dts/uniphier-sld8.dtsi +++ b/arch/arm/dts/uniphier-sld8.dtsi @@ -1,11 +1,9 @@ -/* - * Device Tree Source for UniPhier sLD8 SoC - * - * Copyright (C) 2015-2016 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: (GPL-2.0+ OR MIT) - */ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +// +// Device Tree Source for UniPhier sLD8 SoC +// +// Copyright (C) 2015-2016 Socionext Inc. +// Author: Masahiro Yamada yamada.masahiro@socionext.com
diff --git a/arch/arm/dts/uniphier-support-card.dtsi b/arch/arm/dts/uniphier-support-card.dtsi index e4e7e1b..bf441c2 100644 --- a/arch/arm/dts/uniphier-support-card.dtsi +++ b/arch/arm/dts/uniphier-support-card.dtsi @@ -1,11 +1,9 @@ -/* - * Device Tree Source for UniPhier Support Card (Expansion Board) - * - * Copyright (C) 2015-2017 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com - * - * SPDX-License-Identifier: (GPL-2.0+ OR MIT) - */ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +// +// Device Tree Source for UniPhier Support Card (Expansion Board) +// +// Copyright (C) 2015-2017 Socionext Inc. +// Author: Masahiro Yamada yamada.masahiro@socionext.com
&system_bus { status = "okay";
2018-04-16 12:35 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
Applied to u-boot-uniphier.
Masahiro Yamada
