[U-Boot] [PATCH v3 1/2] sun50i: h5: Add initial Orangepi Zero Plus 2 support
Orangepi Zero Plus 2 is an open-source single-board computer using the Allwinner h5 SOC.
H5 Orangepi Zero Plus 2 has - Quad-core Cortex-A53 - 512MB DDR3 - micrSD slot and 8GB eMMC - Debug TTL UART - HDMI - Wifi + BT - OTG+power supply
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Tested-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v3: - Drop memory node - Remove /soc under regulator - Tested on board Changes for v2: - Drop CONSOLE_MUX - Add emmc node
arch/arm/dts/Makefile | 3 +- arch/arm/dts/sun50i-h5-orangepi-zero-plus2.dts | 97 ++++++++++++++++++++++++++ board/sunxi/MAINTAINERS | 5 ++ configs/orangepi_zero_plus2_defconfig | 18 +++++ 4 files changed, 122 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/sun50i-h5-orangepi-zero-plus2.dts create mode 100644 configs/orangepi_zero_plus2_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index ae55f78..a0b3704 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -320,7 +320,8 @@ dtb-$(CONFIG_MACH_SUN8I_V3S) += \ sun8i-v3s-licheepi-zero.dtb dtb-$(CONFIG_MACH_SUN50I_H5) += \ sun50i-h5-orangepi-pc2.dtb \ - sun50i-h5-orangepi-prime.dtb + sun50i-h5-orangepi-prime.dtb \ + sun50i-h5-orangepi-zero-plus2.dtb dtb-$(CONFIG_MACH_SUN50I) += \ sun50i-a64-bananapi-m64.dtb \ sun50i-a64-pine64-plus.dtb \ diff --git a/arch/arm/dts/sun50i-h5-orangepi-zero-plus2.dts b/arch/arm/dts/sun50i-h5-orangepi-zero-plus2.dts new file mode 100644 index 0000000..3f4baba --- /dev/null +++ b/arch/arm/dts/sun50i-h5-orangepi-zero-plus2.dts @@ -0,0 +1,97 @@ +/* + * Copyright (C) 2017 Jagan Teki jteki@openedev.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This library is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This library is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; + +#include "sun50i-h5.dtsi" + +#include <dt-bindings/gpio/gpio.h> + + +/ { + model = "OrangePi Zero Plus2"; + compatible = "xunlong,orangepi-zero-plus2", "allwinner,sun50i-h5"; + + aliases { + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + reg_vcc3v3: vcc3v3 { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; +}; + +&mmc0 { + compatible = "allwinner,sun50i-h5-mmc", + "allwinner,sun50i-a64-mmc", + "allwinner,sun5i-a13-mmc"; + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin>; + vmmc-supply = <®_vcc3v3>; + bus-width = <4>; + cd-gpios = <&pio 5 6 GPIO_ACTIVE_HIGH>; + cd-inverted; + status = "okay"; +}; + +&mmc2 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc2_8bit_pins>; + vmmc-supply = <®_vcc3v3>; + bus-width = <8>; + non-removable; + cap-mmc-hw-reset; + status = "okay"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pins_a>; + status = "okay"; +}; diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index 4fffe52..314aee3 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -272,6 +272,11 @@ M: Icenowy Zheng icenowy@aosc.xyz S: Maintained F: configs/orangepi_zero_defconfig
+ORANGEPI ZERO PLUS 2 BOARD +M: Jagan Teki jagan@amarulasolutions.com +S: Maintained +F: configs/orangepi_zero_plus2_defconfig + ORANGEPI PC 2 BOARD M: Andre Przywara andre.przywara@arm.com S: Maintained diff --git a/configs/orangepi_zero_plus2_defconfig b/configs/orangepi_zero_plus2_defconfig new file mode 100644 index 0000000..e3776f6 --- /dev/null +++ b/configs/orangepi_zero_plus2_defconfig @@ -0,0 +1,18 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_MACH_SUN50I_H5=y +CONFIG_DRAM_CLK=672 +CONFIG_DRAM_ZQ=3881977 +CONFIG_MMC0_CD_PIN="PH13" +CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_DEFAULT_DEVICE_TREE="sun50i-h5-orangepi-zero-plus2" +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL=y +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_SUN8I_EMAC=y +CONFIG_USB_EHCI_HCD=y
Orangepi Win/WinPlus is an open-source single-board computer using the Allwinner A64 SOC.
A64 Orangepi Win/WinPlus has - A64 Quad-core Cortex-A53 64bit - 1GB(Win)/2GB(Win Plus) DDR3 SDRAM - Debug TTL UART - Four USB 2.0 - HDMI - LCD - Audio and MIC - Wifi + BT - IR receiver - 5V DC power supply
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Tested-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v3: - Drop memory node - Remove /soc under regulator - Tested on board Changes for v2: - Drop CONSOLE_MUX - Add SPL_SPI
arch/arm/dts/Makefile | 1 + arch/arm/dts/sun50i-a64-orangepi-win.dts | 95 ++++++++++++++++++++++++++++++++ board/sunxi/MAINTAINERS | 5 ++ configs/orangepi_win_defconfig | 16 ++++++ 4 files changed, 117 insertions(+) create mode 100644 arch/arm/dts/sun50i-a64-orangepi-win.dts create mode 100644 configs/orangepi_win_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index a0b3704..a6eab75 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -324,6 +324,7 @@ dtb-$(CONFIG_MACH_SUN50I_H5) += \ sun50i-h5-orangepi-zero-plus2.dtb dtb-$(CONFIG_MACH_SUN50I) += \ sun50i-a64-bananapi-m64.dtb \ + sun50i-a64-orangepi-win.dtb \ sun50i-a64-pine64-plus.dtb \ sun50i-a64-pine64.dtb dtb-$(CONFIG_MACH_SUN9I) += \ diff --git a/arch/arm/dts/sun50i-a64-orangepi-win.dts b/arch/arm/dts/sun50i-a64-orangepi-win.dts new file mode 100644 index 0000000..1f39e1c --- /dev/null +++ b/arch/arm/dts/sun50i-a64-orangepi-win.dts @@ -0,0 +1,95 @@ +/* + * Copyright (C) 2017 Jagan Teki jteki@openedev.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This library is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This library is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; + +#include "sun50i-a64.dtsi" + +#include <dt-bindings/gpio/gpio.h> + +/ { + model = "OrangePi Win/Win Plus"; + compatible = "xunlong,orangepi-win", "allwinner,sun50i-a64"; + + aliases { + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + reg_vcc3v3: vcc3v3 { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; +}; + +&ehci1 { + status = "okay"; +}; + +&mmc0 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins>; + vmmc-supply = <®_vcc3v3>; + cd-gpios = <&pio 5 6 GPIO_ACTIVE_HIGH>; + cd-inverted; + status = "okay"; +}; + +&ohci1 { + status = "okay"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pins_a>; + status = "okay"; +}; + +&usbphy { + status = "okay"; +}; + diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index 314aee3..77d8d17 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -267,6 +267,11 @@ M: FUKAUMI Naoki naobsd@gmail.com S: Maintained F: configs/Nintendo_NES_Classic_Edition_defconfig
+ORANGEPI WIN/WIN PLUS BOARD +M: Jagan Teki jagan@amarulasolutions.com +S: Maintained +F: configs/orangepi_win_defconfig + ORANGEPI ZERO BOARD M: Icenowy Zheng icenowy@aosc.xyz S: Maintained diff --git a/configs/orangepi_win_defconfig b/configs/orangepi_win_defconfig new file mode 100644 index 0000000..85d8fa4 --- /dev/null +++ b/configs/orangepi_win_defconfig @@ -0,0 +1,16 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_MACH_SUN50I=y +CONFIG_RESERVE_ALLWINNER_BOOT0_HEADER=y +CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-orangepi-win" +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL=y +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_SPL_SPI_SUNXI=y +CONFIG_SUN8I_EMAC=y +CONFIG_USB_EHCI_HCD=y
- Debug TTL UART
- Four USB 2.0
- HDMI
- LCD
- Audio and MIC
- Wifi + BT
- IR receiver
Applied to u-boot-sunxi/master
thanks!
- 512MB DDR3
- Debug TTL UART
- HDMI
- Wifi + BT
- OTG+power supply
thanks!
Jagan Teki
