[U-Boot] [PULL] u-boot-atmel/master -> u-boot/master
Hi Tom,
here are some fixes for sama5d2 and a new sama5d2 board for 2016.05.
The following changes since commit 58abb988ce24525474f0d515d2a36c1b3acf893f:
mx6ul_evk: Remove CONFIG_SUPPORT_EMMC_BOOT (2016-05-02 21:04:36 -0400)
git://git.denx.de/u-boot-atmel.git master
for you to fetch changes up to 0b5940e2b24043a7f4c07cca4b11a13522063e02:
ARM: sama5d2: Implement boot device autodetection (2016-05-03 13:31:28 +0200)
---------------------------------------------------------------- Marek Vasut (2): ARM: atmel: Enable FIT image support for SAMA5Dx ARM: sama5d2: Implement boot device autodetection
Wenyou Yang (6): ARM: at91: sama5d2: add macro & field definitions board: atmel: add SAMA5D2 PTC Engineering board board: atmel: sama5d2_xplained: fix the missing pin config of SDMMC0 ARM: at91: clock: fix the GCK's clock source ARM: at91: clock: complete the GCK's clock sources board: sama5d2_xplained: change SDHCI GCK's clock source to UPLL
arch/arm/mach-at91/Kconfig | 6 + arch/arm/mach-at91/Makefile | 2 +- arch/arm/mach-at91/armv7/clock.c | 11 + arch/arm/mach-at91/bootparams_atmel.S | 18 ++ arch/arm/mach-at91/include/mach/clk.h | 2 + arch/arm/mach-at91/include/mach/sama5_sfr.h | 24 ++ arch/arm/mach-at91/include/mach/sama5d2.h | 17 ++ arch/arm/mach-at91/spl.c | 36 +++ board/atmel/sama5d2_ptc/Kconfig | 15 ++ board/atmel/sama5d2_ptc/MAINTAINERS | 7 + board/atmel/sama5d2_ptc/Makefile | 8 + board/atmel/sama5d2_ptc/sama5d2_ptc.c | 285 ++++++++++++++++++++++++ board/atmel/sama5d2_xplained/sama5d2_xplained.c | 5 +- configs/sama5d2_ptc_nandflash_defconfig | 12 + configs/sama5d2_ptc_spiflash_defconfig | 12 + configs/sama5d2_xplained_mmc_defconfig | 1 + configs/sama5d2_xplained_spiflash_defconfig | 1 + configs/sama5d3_xplained_mmc_defconfig | 1 + configs/sama5d3_xplained_nandflash_defconfig | 1 + configs/sama5d3xek_mmc_defconfig | 1 + configs/sama5d3xek_nandflash_defconfig | 1 + configs/sama5d3xek_spiflash_defconfig | 1 + configs/sama5d4_xplained_mmc_defconfig | 1 + configs/sama5d4_xplained_nandflash_defconfig | 1 + configs/sama5d4_xplained_spiflash_defconfig | 1 + configs/sama5d4ek_mmc_defconfig | 1 + configs/sama5d4ek_nandflash_defconfig | 1 + configs/sama5d4ek_spiflash_defconfig | 1 + include/configs/sama5d2_ptc.h | 155 +++++++++++++ 29 files changed, 625 insertions(+), 3 deletions(-) create mode 100644 arch/arm/mach-at91/bootparams_atmel.S create mode 100644 board/atmel/sama5d2_ptc/Kconfig create mode 100644 board/atmel/sama5d2_ptc/MAINTAINERS create mode 100644 board/atmel/sama5d2_ptc/Makefile create mode 100644 board/atmel/sama5d2_ptc/sama5d2_ptc.c create mode 100644 configs/sama5d2_ptc_nandflash_defconfig create mode 100644 configs/sama5d2_ptc_spiflash_defconfig create mode 100644 include/configs/sama5d2_ptc.h
Regards,
Andreas
On Tue, May 03, 2016 at 01:35:07PM +0200, Andreas Bießmann wrote:
Hi Tom,
We're less than a week out from release. Are any of these important bugfixes that can't wait? Thanks!
Hi Tom,
Hi Tom,
As I understand these are fixes to get the MMC working in U-Boot and make the config aligned to Linux:
* board: atmel: sama5d2_xplained: fix the missing pin config of SDMMC0 * ARM: at91: clock: fix the GCK's clock source * ARM: at91: clock: complete the GCK's clock sources * board: sama5d2_xplained: change SDHCI GCK's clock source to UPLL
But I do not own such a board and could not test the state before nor after.
You'r right, it is really late for this release. So lets shift it to the next one unless Wenyou says that that board is unusable without this fix. If so I could prepare another pull request with just the required patches.
Is that ok for you?
Andreas
On Tue, May 03, 2016 at 02:33:06PM +0200, Andreas Bießmann wrote:
Hi Tom,
Hi Tom,
- board: atmel: sama5d2_xplained: fix the missing pin config of SDMMC0
- ARM: at91: clock: fix the GCK's clock source
- ARM: at91: clock: complete the GCK's clock sources
- board: sama5d2_xplained: change SDHCI GCK's clock source to UPLL
Is that ok for you?
Works for me, thanks!
Andreas Bießmann
