[U-Boot] please pull u-boot-samsung master
Dear Tom,
The following changes since commit 19ce924ff914f315dc2fdf79f357825c513aed6e:
Prepare v2016.07 (2016-07-11 15:01:01 -0400)
git://git.denx.de/u-boot-samsung master
for you to fetch changes up to 3537ee879e0428587621a2cafbad2d9982bc082b:
mmc: exynos_dw_mmc: support the Driver mode for Exynos (2016-07-12 14:29:10 +0900)
---------------------------------------------------------------- Jaehoon Chung (7): ARM: exynos4: dts: add the prefix '/' for aliases nodes mmc: exynos_dw_mmc: remove the unused function mmc: exynos_dw_mmc: remove #ifdef for OF_CONTROL mmc: exynos_dw_mmc: add the error control for checking index mmc: exynos_dw_mmc: clean the unused and unnecessary codes mmc: exynos_dw_mmc: use the 4bit bus-width by default mmc: exynos_dw_mmc: support the Driver mode for Exynos
arch/arm/dts/exynos4210-origen.dts | 2 +- arch/arm/dts/exynos4210-trats.dts | 4 +-- arch/arm/dts/exynos4210-universal_c210.dts | 4 +-- arch/arm/dts/exynos4412-odroid.dts | 4 +-- arch/arm/dts/exynos4412-trats2.dts | 6 ++--- arch/arm/mach-exynos/include/mach/dwmmc.h | 1 - drivers/mmc/exynos_dw_mmc.c | 148 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++-------------------------------------------- 7 files changed, 95 insertions(+), 74 deletions(-)
On Fri, Jul 15, 2016 at 01:17:14PM +0900, Minkyu Kang wrote:
Dear Tom,
Minkyu Kang
