[PATCH 00/20] dm: Preparation for enhanced of-platdata (part B)
This series includes some refactoring of the dtoc tool and some changes to a few drivers (particularly on x86) to reduce TPL size.
It is available at u-boot-dm/prep-working
Simon Glass (20): pinctrl: Drop post_bind() method when not needed sysreset: Use a shorter error with SPL arc: m68k: nds32: nios2: sh: xtensa: Add empty spl.h header timer: Use a shorter error in TPL test: Use a simple variable to record removed device test: Move some test drivers into their own file dtoc: Make _output_list a top-level function dtoc: Output the device in a separate function dtoc: Output the struct values in a separate function dtoc: Convert _drivers to a dict dtoc: Scan drivers for available information dtoc: Allow use of the of_match_ptr() macro x86: apl: Use const for driver operations x86: Move call64 into its own section x86: coral: Move fsp-m settings to a subnode x86: apl: Update hostbridge to remove unwanted TPL code x86: apl: Reduce size for TPL x86: pinctrl: Drop unlikely error messages from TPL x86: tpl: Remove unwanted devicetree string x86: Fix header gaurd in asm/pmu.h
arch/arc/include/asm/spl.h | 0 arch/m68k/include/asm/spl.h | 0 arch/nds32/include/asm/spl.h | 0 arch/nios2/include/asm/spl.h | 0 arch/sh/include/asm/spl.h | 0 arch/x86/cpu/apollolake/fsp_m.c | 5 +- arch/x86/cpu/apollolake/hostbridge.c | 14 +- arch/x86/cpu/apollolake/lpc.c | 13 +- arch/x86/cpu/apollolake/pch.c | 4 +- arch/x86/cpu/apollolake/pmc.c | 6 +- arch/x86/cpu/apollolake/uart.c | 4 +- arch/x86/cpu/i386/call64.S | 1 + arch/x86/cpu/intel_common/Makefile | 2 +- arch/x86/cpu/intel_common/itss.c | 4 +- arch/x86/cpu/intel_common/p2sb.c | 6 +- arch/x86/cpu/turbo.c | 5 + arch/x86/dts/chromebook_coral.dts | 5 + arch/x86/include/asm/pmu.h | 6 +- arch/x86/lib/tpl.c | 4 +- arch/xtensa/include/asm/spl.h | 0 board/google/chromebook_coral/coral.c | 4 +- drivers/gpio/intel_gpio.c | 4 +- drivers/misc/Kconfig | 9 + drivers/misc/Makefile | 1 + drivers/misc/test_drv.c | 230 ++++++++++++++++ drivers/pinctrl/intel/pinctrl.c | 11 +- drivers/pinctrl/intel/pinctrl_apl.c | 4 +- drivers/pinctrl/pinctrl-uclass.c | 4 +- drivers/power/acpi_pmc/acpi-pmc-uclass.c | 4 +- drivers/sysreset/sysreset-uclass.c | 12 +- drivers/timer/tsc_timer.c | 4 +- include/dm/test.h | 20 +- include/test/test.h | 9 + lib/time.c | 10 +- test/dm/bus.c | 107 +------- test/dm/test-fdt.c | 120 -------- tools/dtoc/dtb_platdata.py | 336 ++++++++++++++++++----- 37 files changed, 634 insertions(+), 334 deletions(-) create mode 100644 arch/arc/include/asm/spl.h create mode 100644 arch/m68k/include/asm/spl.h create mode 100644 arch/nds32/include/asm/spl.h create mode 100644 arch/nios2/include/asm/spl.h create mode 100644 arch/sh/include/asm/spl.h create mode 100644 arch/xtensa/include/asm/spl.h create mode 100644 drivers/misc/test_drv.c
This is not used with of-platdata, so remove it in that case.
drivers/pinctrl/pinctrl-uclass.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/pinctrl/pinctrl-uclass.c b/drivers/pinctrl/pinctrl-uclass.c index aba88104747..4e474cbff73 100644 --- a/drivers/pinctrl/pinctrl-uclass.c +++ b/drivers/pinctrl/pinctrl-uclass.c @@ -305,7 +305,7 @@ int pinctrl_select_state(struct udevice *dev, const char *statename) * Some device which is logical like mmc.blk, do not have * a valid ofnode. */ - if (!ofnode_valid(dev->node)) + if (!dev_has_of_node(dev)) return 0; /* * Try full-implemented pinctrl first. @@ -416,7 +416,9 @@ static int __maybe_unused pinctrl_post_bind(struct udevice *dev)
UCLASS_DRIVER(pinctrl) = { .id = UCLASS_PINCTRL, +#if !CONFIG_IS_ENABLED(OF_PLATDATA) .post_bind = pinctrl_post_bind, +#endif .flags = DM_UC_FLAG_SEQ_ALIAS, .name = "pinctrl", };
Use a minimal error message to save space. Sort the header files while we are here.
drivers/sysreset/sysreset-uclass.c | 12 ++++++++---- 1 file changed, 8 insertions(+), 4 deletions(-)
diff --git a/drivers/sysreset/sysreset-uclass.c b/drivers/sysreset/sysreset-uclass.c index 3f5414ed1f8..e69fb2255b6 100644 --- a/drivers/sysreset/sysreset-uclass.c +++ b/drivers/sysreset/sysreset-uclass.c @@ -9,12 +9,13 @@ #include <common.h> #include <command.h> #include <cpu_func.h> -#include <hang.h> -#include <log.h> -#include <sysreset.h> #include <dm.h> #include <errno.h> +#include <hang.h> +#include <log.h> #include <regmap.h> +#include <spl.h> +#include <sysreset.h> #include <dm/device-internal.h> #include <dm/lists.h> #include <dm/root.h> @@ -101,7 +102,10 @@ void sysreset_walk_halt(enum sysreset_t type) mdelay(100);
/* Still no reset? Give up */ - log_err("System reset not supported on this platform\n"); + if (spl_phase() <= PHASE_SPL) + log_err("no sysreset\n"); + else + log_err("System reset not supported on this platform\n"); hang(); }
At present it is not possible to include spl.h in on these architectures since the asm/spl.h file is not present. We want to be able to use the spl_phase() function, so add empty headers to make things build.
arch/arc/include/asm/spl.h | 0 arch/m68k/include/asm/spl.h | 0 arch/nds32/include/asm/spl.h | 0 arch/nios2/include/asm/spl.h | 0 arch/sh/include/asm/spl.h | 0 arch/xtensa/include/asm/spl.h | 0 6 files changed, 0 insertions(+), 0 deletions(-) create mode 100644 arch/arc/include/asm/spl.h create mode 100644 arch/m68k/include/asm/spl.h create mode 100644 arch/nds32/include/asm/spl.h create mode 100644 arch/nios2/include/asm/spl.h create mode 100644 arch/sh/include/asm/spl.h create mode 100644 arch/xtensa/include/asm/spl.h
diff --git a/arch/arc/include/asm/spl.h b/arch/arc/include/asm/spl.h new file mode 100644 index 00000000000..e69de29bb2d diff --git a/arch/m68k/include/asm/spl.h b/arch/m68k/include/asm/spl.h new file mode 100644 index 00000000000..e69de29bb2d diff --git a/arch/nds32/include/asm/spl.h b/arch/nds32/include/asm/spl.h new file mode 100644 index 00000000000..e69de29bb2d diff --git a/arch/nios2/include/asm/spl.h b/arch/nios2/include/asm/spl.h new file mode 100644 index 00000000000..e69de29bb2d diff --git a/arch/sh/include/asm/spl.h b/arch/sh/include/asm/spl.h new file mode 100644 index 00000000000..e69de29bb2d diff --git a/arch/xtensa/include/asm/spl.h b/arch/xtensa/include/asm/spl.h new file mode 100644 index 00000000000..e69de29bb2d
This error should not happen in normal use. Reduce the length of it to save space in the image.
Add an empty spl.h file to sh since it appears to lack this.
lib/time.c | 10 ++++++++-- 1 file changed, 8 insertions(+), 2 deletions(-)
diff --git a/lib/time.c b/lib/time.c index 88bc50405ff..cc6944ec345 100644 --- a/lib/time.c +++ b/lib/time.c @@ -9,6 +9,7 @@ #include <dm.h> #include <errno.h> #include <init.h> +#include <spl.h> #include <time.h> #include <timer.h> #include <watchdog.h> @@ -96,8 +97,13 @@ uint64_t notrace get_ticks(void) }
ret = timer_get_count(gd->timer, &count); - if (ret) - panic("Could not read count from timer (err %d)\n", ret); + if (ret) { + if (spl_phase() > PHASE_TPL) + panic("Could not read count from timer (err %d)\n", + ret); + else + panic("no timer (err %d)\n", ret); + }
return count; }
At present the entire test state is effective passed into a test driver just to record which device was removed. This is unnecessary and makes it harder to track what is going on.
Use a simple boolean instead.
Also drop the unused 'removed' member while we are here.
include/dm/test.h | 2 -- test/dm/bus.c | 14 ++++++-------- 2 files changed, 6 insertions(+), 10 deletions(-)
diff --git a/include/dm/test.h b/include/dm/test.h index b2adce730ad..cbe1b57d95f 100644 --- a/include/dm/test.h +++ b/include/dm/test.h @@ -134,14 +134,12 @@ extern struct unit_test_state global_dm_test_state; * @testdev: Test device * @force_fail_alloc: Force all memory allocs to fail * @skip_post_probe: Skip uclass post-probe processing - * @removed: Used to keep track of a device that was removed */ struct dm_test_state { struct udevice *root; struct udevice *testdev; int force_fail_alloc; int skip_post_probe; - struct udevice *removed; };
/* Declare a new driver model test */ diff --git a/test/dm/bus.c b/test/dm/bus.c index 60ddb1d6b14..b95c106f5f0 100644 --- a/test/dm/bus.c +++ b/test/dm/bus.c @@ -30,7 +30,8 @@ enum { FLAG_CHILD_REMOVED = -7, };
-static struct dm_test_state *test_state; +/* Records the last testbus device that was removed */ +static struct udevice *testbus_removed;
static int testbus_drv_probe(struct udevice *dev) { @@ -78,11 +79,9 @@ static int testbus_child_post_probe_uclass(struct udevice *dev) static int testbus_child_post_remove(struct udevice *dev) { struct dm_test_parent_data *parent_data = dev_get_parent_priv(dev); - struct dm_test_state *dms = test_state;
parent_data->flag += FLAG_CHILD_REMOVED; - if (dms) - dms->removed = dev; + testbus_removed = dev;
return 0; } @@ -335,11 +334,10 @@ DM_TEST(dm_test_bus_parent_data_uclass, static int dm_test_bus_parent_ops(struct unit_test_state *uts) { struct dm_test_parent_data *parent_data; - struct dm_test_state *dms = uts->priv; struct udevice *bus, *dev; struct uclass *uc;
- test_state = dms; + testbus_removed = NULL; ut_assertok(uclass_get_device(UCLASS_TEST_BUS, 0, &bus)); ut_assertok(uclass_get(UCLASS_TEST_FDT, &uc));
@@ -362,9 +360,9 @@ static int dm_test_bus_parent_ops(struct unit_test_state *uts) ut_asserteq(FLAG_CHILD_PROBED, parent_data->flag); ut_assertok(device_remove(dev, DM_REMOVE_NORMAL)); ut_asserteq_ptr(NULL, dev_get_parent_priv(dev)); - ut_asserteq_ptr(dms->removed, dev); + ut_asserteq_ptr(testbus_removed, dev); } - test_state = NULL; + testbus_removed = NULL;
return 0; }
At present several test drivers are part of the test file itself. Some of these are useful for of-platdata tests. Separate them out so we can use them for other things also.
A few adjustments are needed so this driver can build for sandbox_spl as well.
drivers/misc/Kconfig | 9 ++ drivers/misc/Makefile | 1 + drivers/misc/test_drv.c | 230 ++++++++++++++++++++++++++++++++++++++++ include/dm/test.h | 18 ++++ include/test/test.h | 9 ++ test/dm/bus.c | 105 +----------------- test/dm/test-fdt.c | 120 --------------------- 7 files changed, 271 insertions(+), 221 deletions(-) create mode 100644 drivers/misc/test_drv.c
diff --git a/drivers/misc/Kconfig b/drivers/misc/Kconfig index 29432ae7eb4..7d2a2997797 100644 --- a/drivers/misc/Kconfig +++ b/drivers/misc/Kconfig @@ -343,6 +343,15 @@ config TEGRA186_BPMP can make requests to the BPMP. This driver is similar to an MFD driver in the Linux kernel.
+config TEST_DRV + bool "Enable support for test drivers" + default y if SANDBOX + help + This enables drivers and uclasses that provides a way of testing the + operations of memory allocation and driver/uclass methods in driver + model. This should only be enabled for testing as it is not useful for + anything else. + config TWL4030_LED bool "Enable TWL4030 LED controller" help diff --git a/drivers/misc/Makefile b/drivers/misc/Makefile index 947bd3a647f..d7372037045 100644 --- a/drivers/misc/Makefile +++ b/drivers/misc/Makefile @@ -67,6 +67,7 @@ obj-$(CONFIG_STM32_RCC) += stm32_rcc.o obj-$(CONFIG_SYS_DPAA_QBMAN) += fsl_portals.o obj-$(CONFIG_TEGRA186_BPMP) += tegra186_bpmp.o obj-$(CONFIG_TEGRA_CAR) += tegra_car.o +obj-$(CONFIG_TEST_DRV) += test_drv.o obj-$(CONFIG_TWL4030_LED) += twl4030_led.o obj-$(CONFIG_VEXPRESS_CONFIG) += vexpress_config.o obj-$(CONFIG_WINBOND_W83627) += winbond_w83627.o diff --git a/drivers/misc/test_drv.c b/drivers/misc/test_drv.c new file mode 100644 index 00000000000..a163312b108 --- /dev/null +++ b/drivers/misc/test_drv.c @@ -0,0 +1,230 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2014 Google, Inc + */ + +#include <common.h> +#include <dm.h> +#include <dm/test.h> + +/* Records the last testbus device that was removed */ +static struct udevice *testbus_removed; + +struct udevice *testbus_get_clear_removed(void) +{ + struct udevice *removed = testbus_removed; + + testbus_removed = NULL; + + return removed; +} + +static int testbus_drv_probe(struct udevice *dev) +{ + if (!CONFIG_IS_ENABLED(OF_PLATDATA)) { + int ret; + + ret = dm_scan_fdt_dev(dev); + if (ret) + return ret; + } + + return 0; +} + +static int testbus_child_post_bind(struct udevice *dev) +{ + struct dm_test_parent_plat *plat; + + plat = dev_get_parent_plat(dev); + plat->bind_flag = 1; + plat->uclass_bind_flag = 2; + + return 0; +} + +static int testbus_child_pre_probe(struct udevice *dev) +{ + struct dm_test_parent_data *parent_data = dev_get_parent_priv(dev); + + parent_data->flag += TEST_FLAG_CHILD_PROBED; + + return 0; +} + +static int testbus_child_pre_probe_uclass(struct udevice *dev) +{ + struct dm_test_priv *priv = dev_get_priv(dev); + + priv->uclass_flag++; + + return 0; +} + +static int testbus_child_post_probe_uclass(struct udevice *dev) +{ + struct dm_test_priv *priv = dev_get_priv(dev); + + priv->uclass_postp++; + + return 0; +} + +static int testbus_child_post_remove(struct udevice *dev) +{ + struct dm_test_parent_data *parent_data = dev_get_parent_priv(dev); + + parent_data->flag += TEST_FLAG_CHILD_REMOVED; + testbus_removed = dev; + + return 0; +} + +static const struct udevice_id testbus_ids[] = { + { + .compatible = "denx,u-boot-test-bus", + .data = DM_TEST_TYPE_FIRST }, + { } +}; + +U_BOOT_DRIVER(testbus_drv) = { + .name = "testbus_drv", + .of_match = testbus_ids, + .id = UCLASS_TEST_BUS, + .probe = testbus_drv_probe, + .child_post_bind = testbus_child_post_bind, + .priv_auto = sizeof(struct dm_test_priv), + .plat_auto = sizeof(struct dm_test_pdata), + .per_child_auto = sizeof(struct dm_test_parent_data), + .per_child_plat_auto = sizeof(struct dm_test_parent_plat), + .child_pre_probe = testbus_child_pre_probe, + .child_post_remove = testbus_child_post_remove, +}; + +UCLASS_DRIVER(testbus) = { + .name = "testbus", + .id = UCLASS_TEST_BUS, + .flags = DM_UC_FLAG_SEQ_ALIAS, + .child_pre_probe = testbus_child_pre_probe_uclass, + .child_post_probe = testbus_child_post_probe_uclass, +}; + +static int testfdt_drv_ping(struct udevice *dev, int pingval, int *pingret) +{ + const struct dm_test_pdata *pdata = dev_get_plat(dev); + struct dm_test_priv *priv = dev_get_priv(dev); + + *pingret = pingval + pdata->ping_add; + priv->ping_total += *pingret; + + return 0; +} + +static const struct test_ops test_ops = { + .ping = testfdt_drv_ping, +}; + +static int testfdt_of_to_plat(struct udevice *dev) +{ + struct dm_test_pdata *pdata = dev_get_plat(dev); + + pdata->ping_add = fdtdec_get_int(gd->fdt_blob, dev_of_offset(dev), + "ping-add", -1); + pdata->base = fdtdec_get_addr(gd->fdt_blob, dev_of_offset(dev), + "ping-expect"); + + return 0; +} + +static int testfdt_drv_probe(struct udevice *dev) +{ + struct dm_test_priv *priv = dev_get_priv(dev); + + priv->ping_total += DM_TEST_START_TOTAL; + + /* + * If this device is on a bus, the uclass_flag will be set before + * calling this function. In the meantime the uclass_postp is + * initlized to a value -1. These are used respectively by + * dm_test_bus_child_pre_probe_uclass() and + * dm_test_bus_child_post_probe_uclass(). + */ + priv->uclass_total += priv->uclass_flag; + priv->uclass_postp = -1; + + return 0; +} + +static const struct udevice_id testfdt_ids[] = { + { + .compatible = "denx,u-boot-fdt-test", + .data = DM_TEST_TYPE_FIRST }, + { + .compatible = "google,another-fdt-test", + .data = DM_TEST_TYPE_SECOND }, + { } +}; + +U_BOOT_DRIVER(testfdt_drv) = { + .name = "testfdt_drv", + .of_match = testfdt_ids, + .id = UCLASS_TEST_FDT, + .of_to_plat = testfdt_of_to_plat, + .probe = testfdt_drv_probe, + .ops = &test_ops, + .priv_auto = sizeof(struct dm_test_priv), + .plat_auto = sizeof(struct dm_test_pdata), +}; + +static const struct udevice_id testfdt1_ids[] = { + { + .compatible = "denx,u-boot-fdt-test1", + .data = DM_TEST_TYPE_FIRST }, + { } +}; + +U_BOOT_DRIVER(testfdt1_drv) = { + .name = "testfdt1_drv", + .of_match = testfdt1_ids, + .id = UCLASS_TEST_FDT, + .of_to_plat = testfdt_of_to_plat, + .probe = testfdt_drv_probe, + .ops = &test_ops, + .priv_auto = sizeof(struct dm_test_priv), + .plat_auto = sizeof(struct dm_test_pdata), + .flags = DM_FLAG_PRE_RELOC, +}; + +/* From here is the testfdt uclass code */ +int testfdt_ping(struct udevice *dev, int pingval, int *pingret) +{ + const struct test_ops *ops = device_get_ops(dev); + + if (!ops->ping) + return -ENOSYS; + + return ops->ping(dev, pingval, pingret); +} + +UCLASS_DRIVER(testfdt) = { + .name = "testfdt", + .id = UCLASS_TEST_FDT, + .flags = DM_UC_FLAG_SEQ_ALIAS, +}; + +static const struct udevice_id testfdtm_ids[] = { + { .compatible = "denx,u-boot-fdtm-test" }, + { } +}; + +U_BOOT_DRIVER(testfdtm_drv) = { + .name = "testfdtm_drv", + .of_match = testfdtm_ids, + .id = UCLASS_TEST_FDT_MANUAL, +}; + +UCLASS_DRIVER(testfdtm) = { + .name = "testfdtm", + .id = UCLASS_TEST_FDT_MANUAL, + .flags = DM_UC_FLAG_SEQ_ALIAS | DM_UC_FLAG_NO_AUTO_SEQ, +}; diff --git a/include/dm/test.h b/include/dm/test.h index cbe1b57d95f..6ac6672cd6f 100644 --- a/include/dm/test.h +++ b/include/dm/test.h @@ -167,6 +167,24 @@ struct sandbox_sdl_plat { int font_size; };
+/** + * struct dm_test_parent_plat - Used to track state in bus tests + * + * @count: + * @bind_flag: Indicates that the child post-bind method was called + * @uclass_bind_flag: Also indicates that the child post-bind method was called + */ +struct dm_test_parent_plat { + int count; + int bind_flag; + int uclass_bind_flag; +}; + +enum { + TEST_FLAG_CHILD_PROBED = 10, + TEST_FLAG_CHILD_REMOVED = -7, +}; + /* Declare ping methods for the drivers */ int test_ping(struct udevice *dev, int pingval, int *pingret); int testfdt_ping(struct udevice *dev, int pingval, int *pingret); diff --git a/include/test/test.h b/include/test/test.h index 03e29290bf4..3fdaa2b5e51 100644 --- a/include/test/test.h +++ b/include/test/test.h @@ -94,6 +94,15 @@ enum { TEST_DEVRES_SIZE3 = 37, };
+/** + * testbus_get_clear_removed() - Test function to obtain removed device + * + * This is used in testbus to find out which device was removed. Calling this + * function returns a pointer to the device and then clears it back to NULL, so + * that a future test can check it. + */ +struct udevice *testbus_get_clear_removed(void); + /** * dm_test_main() - Run driver model tests * diff --git a/test/dm/bus.c b/test/dm/bus.c index b95c106f5f0..785ccfc25d1 100644 --- a/test/dm/bus.c +++ b/test/dm/bus.c @@ -19,102 +19,6 @@
DECLARE_GLOBAL_DATA_PTR;
-struct dm_test_parent_plat { - int count; - int bind_flag; - int uclass_bind_flag; -}; - -enum { - FLAG_CHILD_PROBED = 10, - FLAG_CHILD_REMOVED = -7, -}; - -/* Records the last testbus device that was removed */ -static struct udevice *testbus_removed; - -static int testbus_drv_probe(struct udevice *dev) -{ - return dm_scan_fdt_dev(dev); -} - -static int testbus_child_post_bind(struct udevice *dev) -{ - struct dm_test_parent_plat *plat; - - plat = dev_get_parent_plat(dev); - plat->bind_flag = 1; - plat->uclass_bind_flag = 2; - - return 0; -} - -static int testbus_child_pre_probe(struct udevice *dev) -{ - struct dm_test_parent_data *parent_data = dev_get_parent_priv(dev); - - parent_data->flag += FLAG_CHILD_PROBED; - - return 0; -} - -static int testbus_child_pre_probe_uclass(struct udevice *dev) -{ - struct dm_test_priv *priv = dev_get_priv(dev); - - priv->uclass_flag++; - - return 0; -} - -static int testbus_child_post_probe_uclass(struct udevice *dev) -{ - struct dm_test_priv *priv = dev_get_priv(dev); - - priv->uclass_postp++; - - return 0; -} - -static int testbus_child_post_remove(struct udevice *dev) -{ - struct dm_test_parent_data *parent_data = dev_get_parent_priv(dev); - - parent_data->flag += FLAG_CHILD_REMOVED; - testbus_removed = dev; - - return 0; -} - -static const struct udevice_id testbus_ids[] = { - { - .compatible = "denx,u-boot-test-bus", - .data = DM_TEST_TYPE_FIRST }, - { } -}; - -U_BOOT_DRIVER(testbus_drv) = { - .name = "testbus_drv", - .of_match = testbus_ids, - .id = UCLASS_TEST_BUS, - .probe = testbus_drv_probe, - .child_post_bind = testbus_child_post_bind, - .priv_auto = sizeof(struct dm_test_priv), - .plat_auto = sizeof(struct dm_test_pdata), - .per_child_auto = sizeof(struct dm_test_parent_data), - .per_child_plat_auto = sizeof(struct dm_test_parent_plat), - .child_pre_probe = testbus_child_pre_probe, - .child_post_remove = testbus_child_post_remove, -}; - -UCLASS_DRIVER(testbus) = { - .name = "testbus", - .id = UCLASS_TEST_BUS, - .flags = DM_UC_FLAG_SEQ_ALIAS, - .child_pre_probe = testbus_child_pre_probe_uclass, - .child_post_probe = testbus_child_post_probe_uclass, -}; - /* Test that we can probe for children */ static int dm_test_bus_children(struct unit_test_state *uts) { @@ -337,7 +241,7 @@ static int dm_test_bus_parent_ops(struct unit_test_state *uts) struct udevice *bus, *dev; struct uclass *uc;
- testbus_removed = NULL; + testbus_get_clear_removed(); ut_assertok(uclass_get_device(UCLASS_TEST_BUS, 0, &bus)); ut_assertok(uclass_get(UCLASS_TEST_FDT, &uc));
@@ -349,7 +253,7 @@ static int dm_test_bus_parent_ops(struct unit_test_state *uts)
ut_assertok(device_probe(dev)); parent_data = dev_get_parent_priv(dev); - ut_asserteq(FLAG_CHILD_PROBED, parent_data->flag); + ut_asserteq(TEST_FLAG_CHILD_PROBED, parent_data->flag); }
uclass_foreach_dev(dev, uc) { @@ -357,12 +261,11 @@ static int dm_test_bus_parent_ops(struct unit_test_state *uts) if (dev->parent != bus) continue; parent_data = dev_get_parent_priv(dev); - ut_asserteq(FLAG_CHILD_PROBED, parent_data->flag); + ut_asserteq(TEST_FLAG_CHILD_PROBED, parent_data->flag); ut_assertok(device_remove(dev, DM_REMOVE_NORMAL)); ut_asserteq_ptr(NULL, dev_get_parent_priv(dev)); - ut_asserteq_ptr(testbus_removed, dev); + ut_asserteq_ptr(testbus_get_clear_removed(), dev); } - testbus_removed = NULL;
return 0; } diff --git a/test/dm/test-fdt.c b/test/dm/test-fdt.c index 9e8c2906e84..633256821c2 100644 --- a/test/dm/test-fdt.c +++ b/test/dm/test-fdt.c @@ -23,126 +23,6 @@
-static int testfdt_drv_ping(struct udevice *dev, int pingval, int *pingret) -{ - const struct dm_test_pdata *pdata = dev_get_plat(dev); - struct dm_test_priv *priv = dev_get_priv(dev); - - *pingret = pingval + pdata->ping_add; - priv->ping_total += *pingret; - - return 0; -} - -static const struct test_ops test_ops = { - .ping = testfdt_drv_ping, -}; - -static int testfdt_of_to_plat(struct udevice *dev) -{ - struct dm_test_pdata *pdata = dev_get_plat(dev); - - pdata->ping_add = fdtdec_get_int(gd->fdt_blob, dev_of_offset(dev), - "ping-add", -1); - pdata->base = fdtdec_get_addr(gd->fdt_blob, dev_of_offset(dev), - "ping-expect"); - - return 0; -} - -static int testfdt_drv_probe(struct udevice *dev) -{ - struct dm_test_priv *priv = dev_get_priv(dev); - - priv->ping_total += DM_TEST_START_TOTAL; - - /* - * If this device is on a bus, the uclass_flag will be set before - * calling this function. In the meantime the uclass_postp is - * initlized to a value -1. These are used respectively by - * dm_test_bus_child_pre_probe_uclass() and - * dm_test_bus_child_post_probe_uclass(). - */ - priv->uclass_total += priv->uclass_flag; - priv->uclass_postp = -1; - - return 0; -} - -static const struct udevice_id testfdt_ids[] = { - { - .compatible = "denx,u-boot-fdt-test", - .data = DM_TEST_TYPE_FIRST }, - { - .compatible = "google,another-fdt-test", - .data = DM_TEST_TYPE_SECOND }, - { } -}; - -U_BOOT_DRIVER(testfdt_drv) = { - .name = "testfdt_drv", - .of_match = testfdt_ids, - .id = UCLASS_TEST_FDT, - .of_to_plat = testfdt_of_to_plat, - .probe = testfdt_drv_probe, - .ops = &test_ops, - .priv_auto = sizeof(struct dm_test_priv), - .plat_auto = sizeof(struct dm_test_pdata), -}; - -static const struct udevice_id testfdt1_ids[] = { - { - .compatible = "denx,u-boot-fdt-test1", - .data = DM_TEST_TYPE_FIRST }, - { } -}; - -U_BOOT_DRIVER(testfdt1_drv) = { - .name = "testfdt1_drv", - .of_match = testfdt1_ids, - .id = UCLASS_TEST_FDT, - .of_to_plat = testfdt_of_to_plat, - .probe = testfdt_drv_probe, - .ops = &test_ops, - .priv_auto = sizeof(struct dm_test_priv), - .plat_auto = sizeof(struct dm_test_pdata), - .flags = DM_FLAG_PRE_RELOC, -}; - -/* From here is the testfdt uclass code */ -int testfdt_ping(struct udevice *dev, int pingval, int *pingret) -{ - const struct test_ops *ops = device_get_ops(dev); - - if (!ops->ping) - return -ENOSYS; - - return ops->ping(dev, pingval, pingret); -} - -UCLASS_DRIVER(testfdt) = { - .name = "testfdt", - .id = UCLASS_TEST_FDT, - .flags = DM_UC_FLAG_SEQ_ALIAS, -}; - -static const struct udevice_id testfdtm_ids[] = { - { .compatible = "denx,u-boot-fdtm-test" }, - { } -}; - -U_BOOT_DRIVER(testfdtm_drv) = { - .name = "testfdtm_drv", - .of_match = testfdtm_ids, - .id = UCLASS_TEST_FDT_MANUAL, -}; - -UCLASS_DRIVER(testfdtm) = { - .name = "testfdtm", - .id = UCLASS_TEST_FDT_MANUAL, - .flags = DM_UC_FLAG_SEQ_ALIAS | DM_UC_FLAG_NO_AUTO_SEQ, -}; - struct dm_testprobe_pdata { int probe_err; };
It is annoying to have this function inside its parent since it makes the parent longer and hard to read. Move it to the top level.
tools/dtoc/dtb_platdata.py | 80 +++++++++++++++++++------------------- 1 file changed, 40 insertions(+), 40 deletions(-)
diff --git a/tools/dtoc/dtb_platdata.py b/tools/dtoc/dtb_platdata.py index 82671138a9a..be38f5876b4 100644 --- a/tools/dtoc/dtb_platdata.py +++ b/tools/dtoc/dtb_platdata.py @@ -591,51 +591,51 @@ class DtbPlatdata(object): self.out(';\n') self.out('};\n')
+ def _output_list(self, node, prop): + """Output the C code for a devicetree property that holds a list + + Args: + node (fdt.Node): Node to output + prop (fdt.Prop): Prop to output + """ + self.buf('{') + vals = [] + # For phandles, output a reference to the platform data + # of the target node. + info = self.get_phandle_argc(prop, node.name) + if info: + # Process the list as pairs of (phandle, id) + pos = 0 + for args in info.args: + phandle_cell = prop.value[pos] + phandle = fdt_util.fdt32_to_cpu(phandle_cell) + target_node = self._fdt.phandle_to_node[phandle] + arg_values = [] + for i in range(args): + arg_values.append( + str(fdt_util.fdt32_to_cpu(prop.value[pos + 1 + i]))) + pos += 1 + args + vals.append('\t{%d, {%s}}' % (target_node.idx, + ', '.join(arg_values))) + for val in vals: + self.buf('\n\t\t%s,' % val) + else: + for val in prop.value: + vals.append(get_value(prop.type, val)) + + # Put 8 values per line to avoid very long lines. + for i in range(0, len(vals), 8): + if i: + self.buf(',\n\t\t') + self.buf(', '.join(vals[i:i + 8])) + self.buf('}') + def output_node(self, node): """Output the C code for a node
Args: node (fdt.Node): node to output """ - def _output_list(node, prop): - """Output the C code for a devicetree property that holds a list - - Args: - node (fdt.Node): Node to output - prop (fdt.Prop): Prop to output - """ - self.buf('{') - vals = [] - # For phandles, output a reference to the platform data - # of the target node. - info = self.get_phandle_argc(prop, node.name) - if info: - # Process the list as pairs of (phandle, id) - pos = 0 - for args in info.args: - phandle_cell = prop.value[pos] - phandle = fdt_util.fdt32_to_cpu(phandle_cell) - target_node = self._fdt.phandle_to_node[phandle] - arg_values = [] - for i in range(args): - arg_values.append( - str(fdt_util.fdt32_to_cpu(prop.value[pos + 1 + i]))) - pos += 1 + args - vals.append('\t{%d, {%s}}' % (target_node.idx, - ', '.join(arg_values))) - for val in vals: - self.buf('\n\t\t%s,' % val) - else: - for val in prop.value: - vals.append(get_value(prop.type, val)) - - # Put 8 values per line to avoid very long lines. - for i in range(0, len(vals), 8): - if i: - self.buf(',\n\t\t') - self.buf(', '.join(vals[i:i + 8])) - self.buf('}') - struct_name, _ = self.get_normalized_compat_name(node) var_name = conv_name_to_c(node.name) self.buf('/* Node %s index %d */\n' % (node.path, node.idx)) @@ -650,7 +650,7 @@ class DtbPlatdata(object):
# Special handling for lists if isinstance(prop.value, list): - _output_list(node, prop) + self._output_list(node, prop) else: self.buf(get_value(prop.type, prop.value)) self.buf(',\n')
Reduce the length of output_node() by moving the device-output functionality into a separate function.
tools/dtoc/dtb_platdata.py | 33 ++++++++++++++++++++++----------- 1 file changed, 22 insertions(+), 11 deletions(-)
diff --git a/tools/dtoc/dtb_platdata.py b/tools/dtoc/dtb_platdata.py index be38f5876b4..b429c13ef1b 100644 --- a/tools/dtoc/dtb_platdata.py +++ b/tools/dtoc/dtb_platdata.py @@ -630,6 +630,27 @@ class DtbPlatdata(object): self.buf(', '.join(vals[i:i + 8])) self.buf('}')
+ def _declare_device(self, var_name, struct_name, node_parent): + """Add a device declaration to the output + + This declares a U_BOOT_DEVICE() for the device being processed + + Args: + var_name: C name for the node + struct_name: Name for the dt struct associated with the node + node_parent: Parent of the node (or None if none) + """ + self.buf('U_BOOT_DEVICE(%s) = {\n' % var_name) + self.buf('\t.name\t\t= "%s",\n' % struct_name) + self.buf('\t.plat\t= &%s%s,\n' % (VAL_PREFIX, var_name)) + self.buf('\t.plat_size\t= sizeof(%s%s),\n' % (VAL_PREFIX, var_name)) + idx = -1 + if node_parent and node_parent in self._valid_nodes: + idx = node_parent.idx + self.buf('\t.parent_idx\t= %d,\n' % idx) + self.buf('};\n') + self.buf('\n') + def output_node(self, node): """Output the C code for a node
@@ -656,17 +677,7 @@ class DtbPlatdata(object): self.buf(',\n') self.buf('};\n')
- # Add a device declaration - self.buf('U_BOOT_DEVICE(%s) = {\n' % var_name) - self.buf('\t.name\t\t= "%s",\n' % struct_name) - self.buf('\t.plat\t= &%s%s,\n' % (VAL_PREFIX, var_name)) - self.buf('\t.plat_size\t= sizeof(%s%s),\n' % (VAL_PREFIX, var_name)) - idx = -1 - if node.parent and node.parent in self._valid_nodes: - idx = node.parent.idx - self.buf('\t.parent_idx\t= %d,\n' % idx) - self.buf('};\n') - self.buf('\n') + self._declare_device(var_name, struct_name, node.parent)
self.out(''.join(self.get_buf()))
Reduce the length of output_node() futher by moving the struct-output functionality into a two separate functions.
tools/dtoc/dtb_platdata.py | 50 ++++++++++++++++++++++++++------------ 1 file changed, 34 insertions(+), 16 deletions(-)
diff --git a/tools/dtoc/dtb_platdata.py b/tools/dtoc/dtb_platdata.py index b429c13ef1b..aef28ac8a9d 100644 --- a/tools/dtoc/dtb_platdata.py +++ b/tools/dtoc/dtb_platdata.py @@ -651,6 +651,39 @@ class DtbPlatdata(object): self.buf('};\n') self.buf('\n')
+ def _output_prop(self, node, prop): + """Output a line containing the value of a struct member + + Args: + node: Node being output + prop: Prop object to output + """ + if prop.name in PROP_IGNORE_LIST or prop.name[0] == '#': + return + member_name = conv_name_to_c(prop.name) + self.buf('\t%s= ' % tab_to(3, '.' + member_name)) + + # Special handling for lists + if isinstance(prop.value, list): + self._output_list(node, prop) + else: + self.buf(get_value(prop.type, prop.value)) + self.buf(',\n') + + def _output_values(self, var_name, struct_name, node): + """Output the definition of a device's struct values + + Args: + var_name: C name for the node + struct_name: Name for the dt struct associated with the node + node: Node being output + """ + self.buf('static struct %s%s %s%s = {\n' % + (STRUCT_PREFIX, struct_name, VAL_PREFIX, var_name)) + for pname in sorted(node.props): + self._output_prop(node, node.props[pname]) + self.buf('};\n') + def output_node(self, node): """Output the C code for a node
@@ -660,23 +693,8 @@ class DtbPlatdata(object): struct_name, _ = self.get_normalized_compat_name(node) var_name = conv_name_to_c(node.name) self.buf('/* Node %s index %d */\n' % (node.path, node.idx)) - self.buf('static struct %s%s %s%s = {\n' % - (STRUCT_PREFIX, struct_name, VAL_PREFIX, var_name)) - for pname in sorted(node.props): - prop = node.props[pname] - if pname in PROP_IGNORE_LIST or pname[0] == '#': - continue - member_name = conv_name_to_c(prop.name) - self.buf('\t%s= ' % tab_to(3, '.' + member_name)) - - # Special handling for lists - if isinstance(prop.value, list): - self._output_list(node, prop) - else: - self.buf(get_value(prop.type, prop.value)) - self.buf(',\n') - self.buf('};\n')
+ self._output_values(var_name, struct_name, node) self._declare_device(var_name, struct_name, node.parent)
At present this member holds a simple list of driver names. Update it to be a dict of DriverInfo, with the name being the key. This will allow more information to be added about each driver, in future patches.
tools/dtoc/dtb_platdata.py | 21 +++++++++++++++++---- 1 file changed, 17 insertions(+), 4 deletions(-)
diff --git a/tools/dtoc/dtb_platdata.py b/tools/dtoc/dtb_platdata.py index aef28ac8a9d..3a04bf134eb 100644 --- a/tools/dtoc/dtb_platdata.py +++ b/tools/dtoc/dtb_platdata.py @@ -64,6 +64,17 @@ PhandleInfo = collections.namedtuple('PhandleInfo', ['max_args', 'args']) PhandleLink = collections.namedtuple('PhandleLink', ['var_node', 'dev_name'])
+class DriverInfo: + def __init__(self, name): + self.name = name + + def __eq__(self, other): + return self.name == other.name + + def __repr__(self): + return ("DriverInfo(name='%s')" % self.name) + + def conv_name_to_c(name): """Convert a device-tree name to a C identifier
@@ -155,7 +166,9 @@ class DtbPlatdata(object): _outfile: The current output file (sys.stdout or a real file) _warning_disabled: true to disable warnings about driver names not found _lines: Stashed list of output lines for outputting in the future - _drivers: List of valid driver names found in drivers/ + _drivers: Dict of valid driver names found in drivers/ + key: Driver name + value: DriverInfo for that driver _driver_aliases: Dict that holds aliases for driver names key: Driver alias declared with U_BOOT_DRIVER_ALIAS(driver_alias, driver_name) @@ -171,7 +184,7 @@ class DtbPlatdata(object): self._outfile = None self._warning_disabled = warning_disabled self._lines = [] - self._drivers = [] + self._drivers = {} self._driver_aliases = {} self._drivers_additional = drivers_additional or []
@@ -195,7 +208,7 @@ class DtbPlatdata(object): compat_list_c = get_compat_name(node)
for compat_c in compat_list_c: - if not compat_c in self._drivers: + if not compat_c in self._drivers.keys(): compat_c = self._driver_aliases.get(compat_c) if not compat_c: continue @@ -333,7 +346,7 @@ class DtbPlatdata(object): drivers = re.findall('U_BOOT_DRIVER((.*))', buff)
for driver in drivers: - self._drivers.append(driver) + self._drivers[driver] = DriverInfo(driver)
# The following re will search for driver aliases declared as # U_BOOT_DRIVER_ALIAS(alias, driver_name)
At present we simply record the name of a driver parsed from its implementation file. We also need to get the uclass and a few other things so we can instantiate devices at build time. Add support for collecting this information. This requires parsing each driver file.
tools/dtoc/dtb_platdata.py | 171 ++++++++++++++++++++++++++++++++++--- 1 file changed, 161 insertions(+), 10 deletions(-)
diff --git a/tools/dtoc/dtb_platdata.py b/tools/dtoc/dtb_platdata.py index 3a04bf134eb..0c687cb3db0 100644 --- a/tools/dtoc/dtb_platdata.py +++ b/tools/dtoc/dtb_platdata.py @@ -65,14 +65,21 @@ PhandleLink = collections.namedtuple('PhandleLink', ['var_node', 'dev_name'])
class DriverInfo: - def __init__(self, name): + def __init__(self, name, uclass_id, compat): self.name = name + self.uclass_id = uclass_id + self.compat = compat + self.priv_size = 0
def __eq__(self, other): - return self.name == other.name + return (self.name == other.name and + self.uclass_id == other.uclass_id and + self.compat == other.compat and + self.priv_size == other.priv_size)
def __repr__(self): - return ("DriverInfo(name='%s')" % self.name) + return ("DriverInfo(name='%s', uclass_id='%s', compat=%s, priv_size=%s)" % + (self.name, self.uclass_id, self.compat, self.priv_size))
def conv_name_to_c(name): @@ -174,6 +181,12 @@ class DtbPlatdata(object): U_BOOT_DRIVER_ALIAS(driver_alias, driver_name) value: Driver name declared with U_BOOT_DRIVER(driver_name) _drivers_additional: List of additional drivers to use during scanning + _of_match: Dict holding information about compatible strings + key: Name of struct udevice_id variable + value: Dict of compatible info in that variable: + key: Compatible string, e.g. 'rockchip,rk3288-grf' + value: Driver data, e,g, 'ROCKCHIP_SYSCON_GRF', or None + _compat_to_driver: Maps compatible strings to DriverInfo """ def __init__(self, dtb_fname, include_disabled, warning_disabled, drivers_additional=None): @@ -187,6 +200,8 @@ class DtbPlatdata(object): self._drivers = {} self._driver_aliases = {} self._drivers_additional = drivers_additional or [] + self._of_match = {} + self._compat_to_driver = {}
def get_normalized_compat_name(self, node): """Get a node's normalized compat name @@ -325,10 +340,148 @@ class DtbPlatdata(object): return PhandleInfo(max_args, args) return None
+ def _parse_driver(self, buff): + """Parse a C file to extract driver information contained within + + This parses U_BOOT_DRIVER() structs to obtain various pieces of useful + information. + + It updates the following members: + _drivers - updated with new DriverInfo records for each driver found + in the file + _of_match - updated with each compatible string found in the file + _compat_to_driver - Maps compatible string to DriverInfo + + Args: + buff (str): Contents of file + """ + # Dict holding information about compatible strings collected in this + # function so far + # key: Name of struct udevice_id variable + # value: Dict of compatible info in that variable: + # key: Compatible string, e.g. 'rockchip,rk3288-grf' + # value: Driver data, e,g, 'ROCKCHIP_SYSCON_GRF', or None + of_match = {} + + # Dict holding driver information collected in this function so far + # key: Driver name (C name as in U_BOOT_DRIVER(xxx)) + # value: DriverInfo + drivers = {} + + # Collect the driver name (None means not found yet) + driver_name = None + re_driver = re.compile(r'U_BOOT_DRIVER((.*))') + + # Collect the uclass ID, e.g. 'UCLASS_SPI' + uclass_id = None + re_id = re.compile(r'\s*.id\s*=\s*(UCLASS_[A-Z0-9_]+)') + + # Collect the compatible string, e.g. 'rockchip,rk3288-grf' + compat = None + re_compat = re.compile('{\s*.compatible\s*=\s*"(.*)"\s*' + '(,\s*.data\s*=\s*(.*))?\s*},') + + # This is a dict of compatible strings that were found: + # key: Compatible string, e.g. 'rockchip,rk3288-grf' + # value: Driver data, e,g, 'ROCKCHIP_SYSCON_GRF', or None + compat_dict = {} + + # Holds the var nane of the udevice_id list, e.g. + # 'rk3288_syscon_ids_noc' in + # static const struct udevice_id rk3288_syscon_ids_noc[] = { + ids_name = None + re_ids = re.compile('struct udevice_id (.*)[]\s*=') + + # Matches the references to the udevice_id list + re_of_match = re.compile('.of_match\s*=\s*([a-z0-9_]+),') + + # Matches the header/size information for priv + re_priv = re.compile('^\s*DM_PRIV((.*))$') + drv_name = None + + prefix = '' + for line in buff.splitlines(): + # Handle line continuation + if prefix: + line = prefix + line + prefix = '' + if line.endswith('\'): + prefix = line[:-1] + continue + + driver_match = re_driver.search(line) + + # If we have seen U_BOOT_DRIVER()... + if driver_name: + id_m = re_id.search(line) + id_of_match = re_of_match.search(line) + if id_m: + uclass_id = id_m.group(1) + elif id_of_match: + compat = id_of_match.group(1) + elif '};' in line: + if uclass_id and compat: + if compat not in of_match: + raise ValueError( + "%s: Unknown compatible var '%s' (found %s)" % + (fn, compat, ','.join(of_match.keys()))) + driver = DriverInfo(driver_name, uclass_id, + of_match[compat]) + drivers[driver_name] = driver + + # This needs to be deterministic, since a driver may + # have multiple compatible strings pointing to it. + # We record the one earliest in the alphabet so it + # will produce the same result on all machines. + for id in of_match[compat]: + old = self._compat_to_driver.get(id) + if not old or driver.name < old.name: + self._compat_to_driver[id] = driver + else: + # The driver does not have a uclass or compat string. + # The first is required but the second is not, so just + # ignore this. + pass + driver_name = None + uclass_id = None + ids_name = None + compat = None + compat_dict = {} + + # If we have seen U_BOOT_DRIVER()... + elif drv_name: + priv = re_priv.match(line) + if priv: + drivers[drv_name].priv_size = priv.group(1) + elif '};' in line: + drv_name = None + elif ids_name: + compat_m = re_compat.search(line) + if compat_m: + compat_dict[compat_m.group(1)] = compat_m.group(3) + elif '};' in line: + of_match[ids_name] = compat_dict + ids_name = None + elif driver_match: + driver_name = driver_match.group(1) + else: + ids_m = re_ids.search(line) + if ids_m: + ids_name = ids_m.group(1) + + # Make the updates based on what we found + self._drivers.update(drivers) + self._of_match.update(of_match) + def scan_driver(self, fname): """Scan a driver file to build a list of driver names and aliases
- This procedure will populate self._drivers and self._driver_aliases + It updates the following members: + _drivers - updated with new DriverInfo records for each driver found + in the file + _of_match - updated with each compatible string found in the file + _compat_to_driver - Maps compatible string to DriverInfo + _driver_aliases - Maps alias names to driver name
Args fname: Driver filename to scan @@ -341,12 +494,10 @@ class DtbPlatdata(object): print("Skipping file '%s' due to unicode error" % fname) return
- # The following re will search for driver names declared as - # U_BOOT_DRIVER(driver_name) - drivers = re.findall('U_BOOT_DRIVER((.*))', buff) - - for driver in drivers: - self._drivers[driver] = DriverInfo(driver) + # If this file has any U_BOOT_DRIVER() declarations, process it to + # obtain driver information + if 'U_BOOT_DRIVER' in buff: + self._parse_driver(buff)
Update the regex for the of_match member to allow of_match_ptr() so it matches both:
.of_match = apl_hostbridge_ids, and .of_match = of_match_ptr(apl_hostbridge_ids),
Without this, dtoc emits warnings and cannot find the drivers.
tools/dtoc/dtb_platdata.py | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/tools/dtoc/dtb_platdata.py b/tools/dtoc/dtb_platdata.py index 0c687cb3db0..2ea620e9628 100644 --- a/tools/dtoc/dtb_platdata.py +++ b/tools/dtoc/dtb_platdata.py @@ -393,7 +393,8 @@ class DtbPlatdata(object): re_ids = re.compile('struct udevice_id (.*)[]\s*=')
# Matches the references to the udevice_id list - re_of_match = re.compile('.of_match\s*=\s*([a-z0-9_]+),') + re_of_match = re.compile( + '.of_match\s*=\s*(of_match_ptr()?([a-z0-9_]+)())?,')
# Matches the header/size information for priv re_priv = re.compile('^\s*DM_PRIV((.*))$') @@ -418,7 +419,7 @@ class DtbPlatdata(object): if id_m: uclass_id = id_m.group(1) elif id_of_match: - compat = id_of_match.group(1) + compat = id_of_match.group(2) elif '};' in line: if uclass_id and compat: if compat not in of_match:
Update these declarations to const to ensure that the data ends up in the rodata section.
arch/x86/cpu/apollolake/pmc.c | 2 +- arch/x86/cpu/intel_common/p2sb.c | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/x86/cpu/apollolake/pmc.c b/arch/x86/cpu/apollolake/pmc.c index 290b2cb3e71..c40065ab8cf 100644 --- a/arch/x86/cpu/apollolake/pmc.c +++ b/arch/x86/cpu/apollolake/pmc.c @@ -205,7 +205,7 @@ static int apl_pmc_probe(struct udevice *dev) return 0; }
-static struct acpi_pmc_ops apl_pmc_ops = { +static const struct acpi_pmc_ops apl_pmc_ops = { .init = apl_pmc_fill_power_state, .prev_sleep_state = apl_prev_sleep_state, .disable_tco = apl_disable_tco, diff --git a/arch/x86/cpu/intel_common/p2sb.c b/arch/x86/cpu/intel_common/p2sb.c index e6edab0b056..3765eeeab0d 100644 --- a/arch/x86/cpu/intel_common/p2sb.c +++ b/arch/x86/cpu/intel_common/p2sb.c @@ -180,7 +180,7 @@ static int p2sb_child_post_bind(struct udevice *dev) return 0; }
-struct p2sb_ops p2sb_ops = { +static const struct p2sb_ops p2sb_ops = { .set_hide = intel_p2sb_set_hide, };
When this code is not used (e.g. by TPL) we want it to be excluded from the image. Put it in its own section so that this happens.
arch/x86/cpu/i386/call64.S | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/x86/cpu/i386/call64.S b/arch/x86/cpu/i386/call64.S index 275063c4af8..0ffc1006bbf 100644 --- a/arch/x86/cpu/i386/call64.S +++ b/arch/x86/cpu/i386/call64.S @@ -11,6 +11,7 @@ #include <asm/processor-flags.h>
.code32 +.section .text_call64 .globl cpu_call64 cpu_call64: /*
At present these settings are in the node for host-bridge and so are visible in TPL as well as SPL. But they are only used for SPL.
Move them to a subnode so that TPL does not included them.
arch/x86/cpu/apollolake/fsp_m.c | 5 ++++- arch/x86/dts/chromebook_coral.dts | 5 +++++ 2 files changed, 9 insertions(+), 1 deletion(-)
diff --git a/arch/x86/cpu/apollolake/fsp_m.c b/arch/x86/cpu/apollolake/fsp_m.c index cef937573b0..c6be707e4ea 100644 --- a/arch/x86/cpu/apollolake/fsp_m.c +++ b/arch/x86/cpu/apollolake/fsp_m.c @@ -32,7 +32,10 @@ int fspm_update_config(struct udevice *dev, struct fspm_upd *upd)
node = dev_ofnode(dev); if (!ofnode_valid(node)) - return log_msg_ret("fsp-m settings", -ENOENT); + return log_msg_ret("node", -ENOENT); + node = ofnode_find_subnode(node, "fsp-m"); + if (!ofnode_valid(node)) + return log_msg_ret("fspm", -ENOENT);
ret = fsp_m_update_config_from_dtb(node, cfg); if (ret) diff --git a/arch/x86/dts/chromebook_coral.dts b/arch/x86/dts/chromebook_coral.dts index d66e128ae62..3c8fdf23809 100644 --- a/arch/x86/dts/chromebook_coral.dts +++ b/arch/x86/dts/chromebook_coral.dts @@ -174,6 +174,9 @@ */ fsp_s: fsp-s { }; + fsp_m: fsp-m { + u-boot,dm-spl; + };
nhlt { intel,dmic-channels = <4>; @@ -650,7 +653,9 @@ PAD_CFG_NF(LPC_CLKRUNB, UP_20K, DEEP, NF1) /* LPC_CLKRUN_N */ PAD_CFG_NF(LPC_FRAMEB, NATIVE, DEEP, NF1) /* LPC_FRAME_N */ >; +};
+&fsp_m { fspm,package = <PACKAGE_BGA>; fspm,profile = <PROFILE_LPDDR4_2400_24_22_22>; fspm,memory-down = <MEMORY_DOWN_YES>;
At present several strings from this file appear in the TPL binary. Add preprocessor checks to drop them.
This reduces the TPL binary size by about 128 bytes.
arch/x86/cpu/apollolake/hostbridge.c | 14 +++++++++----- 1 file changed, 9 insertions(+), 5 deletions(-)
diff --git a/arch/x86/cpu/apollolake/hostbridge.c b/arch/x86/cpu/apollolake/hostbridge.c index e4674f3788a..9ec2309d086 100644 --- a/arch/x86/cpu/apollolake/hostbridge.c +++ b/arch/x86/cpu/apollolake/hostbridge.c @@ -60,6 +60,7 @@ struct apl_hostbridge_plat { pci_dev_t bdf; };
+#if CONFIG_IS_ENABLED(GENERATE_ACPI_TABLE) static const struct nhlt_format_config dmic_1ch_formats[] = { /* 48 KHz 16-bits per sample. */ { @@ -155,6 +156,7 @@ static const struct nhlt_endp_descriptor dmic_4ch_descriptors[] = { .num_formats = ARRAY_SIZE(dmic_4ch_formats), }, }; +#endif
static int apl_hostbridge_early_init_pinctrl(struct udevice *dev) { @@ -283,7 +285,7 @@ static int apl_acpi_hb_get_name(const struct udevice *dev, char *out_name) return acpi_copy_name(out_name, "RHUB"); }
-#ifdef CONFIG_GENERATE_ACPI_TABLE +#if CONFIG_IS_ENABLED(GENERATE_ACPI_TABLE) static int apl_acpi_hb_write_tables(const struct udevice *dev, struct acpi_ctx *ctx) { @@ -322,7 +324,6 @@ static int apl_acpi_hb_write_tables(const struct udevice *dev,
return 0; } -#endif
static int apl_acpi_setup_nhlt(const struct udevice *dev, struct acpi_ctx *ctx) { @@ -347,6 +348,7 @@ static int apl_acpi_setup_nhlt(const struct udevice *dev, struct acpi_ctx *ctx)
return log_msg_ret("channels", -EINVAL); } +#endif
static int apl_hostbridge_remove(struct udevice *dev) { @@ -385,21 +387,23 @@ ulong sa_get_tseg_base(struct udevice *dev)
struct acpi_ops apl_hostbridge_acpi_ops = { .get_name = apl_acpi_hb_get_name, -#ifdef CONFIG_GENERATE_ACPI_TABLE +#if CONFIG_IS_ENABLED(GENERATE_ACPI_TABLE) .write_tables = apl_acpi_hb_write_tables, -#endif .setup_nhlt = apl_acpi_setup_nhlt, +#endif };
+#if !CONFIG_IS_ENABLED(OF_PLATDATA) static const struct udevice_id apl_hostbridge_ids[] = { { .compatible = "intel,apl-hostbridge" }, { } }; +#endif
U_BOOT_DRIVER(intel_apl_hostbridge) = { .name = "intel_apl_hostbridge", .id = UCLASS_NORTHBRIDGE, - .of_match = apl_hostbridge_ids, + .of_match = of_match_ptr(apl_hostbridge_ids), .of_to_plat = apl_hostbridge_of_to_plat, .probe = apl_hostbridge_probe, .remove = apl_hostbridge_remove,
Update various drivers to use of_match_ptr() and to avoid including debug strings in TPL. Omit the WiFi driver entirely, since it is not used in TPL.
This reduces the TPL binary size by about 608 bytes.
arch/x86/cpu/apollolake/lpc.c | 13 ++++++++----- arch/x86/cpu/apollolake/pch.c | 4 +++- arch/x86/cpu/apollolake/pmc.c | 4 +++- arch/x86/cpu/apollolake/uart.c | 4 +++- arch/x86/cpu/intel_common/Makefile | 2 +- arch/x86/cpu/intel_common/itss.c | 4 +++- arch/x86/cpu/intel_common/p2sb.c | 4 +++- arch/x86/cpu/turbo.c | 5 +++++ board/google/chromebook_coral/coral.c | 4 +++- drivers/gpio/intel_gpio.c | 4 +++- drivers/pinctrl/intel/pinctrl_apl.c | 4 +++- drivers/power/acpi_pmc/acpi-pmc-uclass.c | 4 +++- drivers/timer/tsc_timer.c | 4 +++- 13 files changed, 44 insertions(+), 16 deletions(-)
diff --git a/arch/x86/cpu/apollolake/lpc.c b/arch/x86/cpu/apollolake/lpc.c index d8e05f6a8f4..e085890d638 100644 --- a/arch/x86/cpu/apollolake/lpc.c +++ b/arch/x86/cpu/apollolake/lpc.c @@ -81,10 +81,11 @@ int lpc_open_pmio_window(uint base, uint size)
lgir_reg_num = find_unused_pmio_window(); if (lgir_reg_num < 0) { - log_err("LPC: Cannot open IO window: %lx size %lx\n", - bridge_base, size - bridged_size); - log_err("No more IO windows\n"); - + if (spl_phase() > PHASE_TPL) { + log_err("LPC: Cannot open IO window: %lx size %lx\n", + bridge_base, size - bridged_size); + log_err("No more IO windows\n"); + } return -ENOSPC; } lgir_reg_offset = LPC_GENERIC_IO_RANGE(lgir_reg_num); @@ -127,15 +128,17 @@ struct acpi_ops apl_lpc_acpi_ops = { .inject_dsdt = southbridge_inject_dsdt, };
+#if !CONFIG_IS_ENABLED(OF_PLATDATA) static const struct udevice_id apl_lpc_ids[] = { { .compatible = "intel,apl-lpc" }, { } }; +#endif
/* All pads are LPC already configured by the hostbridge, so no probing here */ U_BOOT_DRIVER(intel_apl_lpc) = { .name = "intel_apl_lpc", .id = UCLASS_LPC, - .of_match = apl_lpc_ids, + .of_match = of_match_ptr(apl_lpc_ids), ACPI_OPS_PTR(&apl_lpc_acpi_ops) }; diff --git a/arch/x86/cpu/apollolake/pch.c b/arch/x86/cpu/apollolake/pch.c index d9832ff2496..39d6ad5ed49 100644 --- a/arch/x86/cpu/apollolake/pch.c +++ b/arch/x86/cpu/apollolake/pch.c @@ -23,14 +23,16 @@ static const struct pch_ops apl_pch_ops = { .set_spi_protect = apl_set_spi_protect, };
+#if !CONFIG_IS_ENABLED(OF_PLATDATA) static const struct udevice_id apl_pch_ids[] = { { .compatible = "intel,apl-pch" }, { } }; +#endif
U_BOOT_DRIVER(intel_apl_pch) = { .name = "intel_apl_pch", .id = UCLASS_PCH, - .of_match = apl_pch_ids, + .of_match = of_match_ptr(apl_pch_ids), .ops = &apl_pch_ops, }; diff --git a/arch/x86/cpu/apollolake/pmc.c b/arch/x86/cpu/apollolake/pmc.c index c40065ab8cf..e033baf1205 100644 --- a/arch/x86/cpu/apollolake/pmc.c +++ b/arch/x86/cpu/apollolake/pmc.c @@ -212,15 +212,17 @@ static const struct acpi_pmc_ops apl_pmc_ops = { .global_reset_set_enable = apl_global_reset_set_enable, };
+#if !CONFIG_IS_ENABLED(OF_PLATDATA) static const struct udevice_id apl_pmc_ids[] = { { .compatible = "intel,apl-pmc" }, { } }; +#endif
U_BOOT_DRIVER(intel_apl_pmc) = { .name = "intel_apl_pmc", .id = UCLASS_ACPI_PMC, - .of_match = apl_pmc_ids, + .of_match = of_match_ptr(apl_pmc_ids), .of_to_plat = apl_pmc_ofdata_to_uc_plat, .probe = apl_pmc_probe, .ops = &apl_pmc_ops, diff --git a/arch/x86/cpu/apollolake/uart.c b/arch/x86/cpu/apollolake/uart.c index e523d85b1b4..69e5899235b 100644 --- a/arch/x86/cpu/apollolake/uart.c +++ b/arch/x86/cpu/apollolake/uart.c @@ -118,15 +118,17 @@ static int apl_ns16550_of_to_plat(struct udevice *dev) return 0; }
+#if !CONFIG_IS_ENABLED(OF_PLATDATA) static const struct udevice_id apl_ns16550_serial_ids[] = { { .compatible = "intel,apl-ns16550" }, { }, }; +#endif
U_BOOT_DRIVER(intel_apl_ns16550) = { .name = "intel_apl_ns16550", .id = UCLASS_SERIAL, - .of_match = apl_ns16550_serial_ids, + .of_match = of_match_ptr(apl_ns16550_serial_ids), .plat_auto = sizeof(struct ns16550_plat), .priv_auto = sizeof(struct ns16550), .ops = &ns16550_serial_ops, diff --git a/arch/x86/cpu/intel_common/Makefile b/arch/x86/cpu/intel_common/Makefile index 4a5cf17e41d..8b9a810f66d 100644 --- a/arch/x86/cpu/intel_common/Makefile +++ b/arch/x86/cpu/intel_common/Makefile @@ -26,7 +26,7 @@ obj-y += cpu.o obj-y += fast_spi.o obj-y += lpc.o obj-y += lpss.o -obj-$(CONFIG_INTEL_GENERIC_WIFI) += generic_wifi.o +obj-$(CONFIG_$(SPL_)INTEL_GENERIC_WIFI) += generic_wifi.o ifndef CONFIG_TARGET_EFI_APP obj-$(CONFIG_$(SPL_TPL_)X86_32BIT_INIT) += microcode.o ifndef CONFIG_$(SPL_)X86_64 diff --git a/arch/x86/cpu/intel_common/itss.c b/arch/x86/cpu/intel_common/itss.c index e71ea029e51..6515d1f471f 100644 --- a/arch/x86/cpu/intel_common/itss.c +++ b/arch/x86/cpu/intel_common/itss.c @@ -230,15 +230,17 @@ static const struct irq_ops itss_ops = { #endif };
+#if !CONFIG_IS_ENABLED(OF_PLATDATA) static const struct udevice_id itss_ids[] = { { .compatible = "intel,itss", .data = X86_IRQT_ITSS }, { } }; +#endif
U_BOOT_DRIVER(intel_itss) = { .name = "intel_itss", .id = UCLASS_IRQ, - .of_match = itss_ids, + .of_match = of_match_ptr(itss_ids), .ops = &itss_ops, .bind = itss_bind, .of_to_plat = itss_of_to_plat, diff --git a/arch/x86/cpu/intel_common/p2sb.c b/arch/x86/cpu/intel_common/p2sb.c index 3765eeeab0d..cb901f265e2 100644 --- a/arch/x86/cpu/intel_common/p2sb.c +++ b/arch/x86/cpu/intel_common/p2sb.c @@ -184,15 +184,17 @@ static const struct p2sb_ops p2sb_ops = { .set_hide = intel_p2sb_set_hide, };
+#if !CONFIG_IS_ENABLED(OF_PLATDATA) static const struct udevice_id p2sb_ids[] = { { .compatible = "intel,p2sb" }, { } }; +#endif
U_BOOT_DRIVER(intel_p2sb) = { .name = "intel_p2sb", .id = UCLASS_P2SB, - .of_match = p2sb_ids, + .of_match = of_match_ptr(p2sb_ids), .probe = p2sb_probe, .remove = p2sb_remove, .ops = &p2sb_ops, diff --git a/arch/x86/cpu/turbo.c b/arch/x86/cpu/turbo.c index f8d85d5a339..4a73cb240da 100644 --- a/arch/x86/cpu/turbo.c +++ b/arch/x86/cpu/turbo.c @@ -35,12 +35,15 @@ static inline void set_global_turbo_state(int state) } #endif
+/* gcc 7.3 does not wwant to drop strings, so use #ifdef */ +#ifndef CONFIG_TPL_BUILD static const char *const turbo_state_desc[] = { [TURBO_UNKNOWN] = "unknown", [TURBO_UNAVAILABLE] = "unavailable", [TURBO_DISABLED] = "available but hidden", [TURBO_ENABLED] = "available and visible" }; +#endif
/* * Determine the current state of Turbo and cache it for later. @@ -76,7 +79,9 @@ int turbo_get_state(void) }
set_global_turbo_state(turbo_state); +#ifndef CONFIG_TPL_BUILD debug("Turbo is %s\n", turbo_state_desc[turbo_state]); +#endif return turbo_state; }
diff --git a/board/google/chromebook_coral/coral.c b/board/google/chromebook_coral/coral.c index b8b923c139e..34b2c2ac5d5 100644 --- a/board/google/chromebook_coral/coral.c +++ b/board/google/chromebook_coral/coral.c @@ -143,14 +143,16 @@ struct acpi_ops coral_acpi_ops = { .inject_dsdt = chromeos_acpi_gpio_generate, };
+#if !CONFIG_IS_ENABLED(OF_PLATDATA) static const struct udevice_id coral_ids[] = { { .compatible = "google,coral" }, { } }; +#endif
U_BOOT_DRIVER(coral_drv) = { .name = "coral", .id = UCLASS_SYSINFO, - .of_match = coral_ids, + .of_match = of_match_ptr(coral_ids), ACPI_OPS_PTR(&coral_acpi_ops) }; diff --git a/drivers/gpio/intel_gpio.c b/drivers/gpio/intel_gpio.c index 41540d8ebc6..eda95485c93 100644 --- a/drivers/gpio/intel_gpio.c +++ b/drivers/gpio/intel_gpio.c @@ -188,15 +188,17 @@ static const struct dm_gpio_ops gpio_intel_ops = { #endif };
+#if !CONFIG_IS_ENABLED(OF_PLATDATA) static const struct udevice_id intel_intel_gpio_ids[] = { { .compatible = "intel,gpio" }, { } }; +#endif
U_BOOT_DRIVER(intel_gpio) = { .name = "intel_gpio", .id = UCLASS_GPIO, - .of_match = intel_intel_gpio_ids, + .of_match = of_match_ptr(intel_intel_gpio_ids), .ops = &gpio_intel_ops, .of_to_plat = intel_gpio_of_to_plat, .probe = intel_gpio_probe, diff --git a/drivers/pinctrl/intel/pinctrl_apl.c b/drivers/pinctrl/intel/pinctrl_apl.c index 48b0e9a161b..4f9b56cab46 100644 --- a/drivers/pinctrl/intel/pinctrl_apl.c +++ b/drivers/pinctrl/intel/pinctrl_apl.c @@ -169,15 +169,17 @@ static int apl_pinctrl_of_to_plat(struct udevice *dev) return intel_pinctrl_of_to_plat(dev, comm, 2); }
+#if !CONFIG_IS_ENABLED(OF_PLATDATA) static const struct udevice_id apl_gpio_ids[] = { { .compatible = "intel,apl-pinctrl"}, { } }; +#endif
U_BOOT_DRIVER(intel_apl_pinctrl) = { .name = "intel_apl_pinctrl", .id = UCLASS_PINCTRL, - .of_match = apl_gpio_ids, + .of_match = of_match_ptr(apl_gpio_ids), .probe = intel_pinctrl_probe, .ops = &intel_pinctrl_ops, #if !CONFIG_IS_ENABLED(OF_PLATDATA) diff --git a/drivers/power/acpi_pmc/acpi-pmc-uclass.c b/drivers/power/acpi_pmc/acpi-pmc-uclass.c index 32a2836f0bf..34446a34e60 100644 --- a/drivers/power/acpi_pmc/acpi-pmc-uclass.c +++ b/drivers/power/acpi_pmc/acpi-pmc-uclass.c @@ -8,6 +8,7 @@ #include <common.h> #include <dm.h> #include <log.h> +#include <spl.h> #include <acpi/acpi_s3.h> #ifdef CONFIG_X86 #include <asm/intel_pinctrl.h> @@ -60,7 +61,8 @@ int pmc_gpe_init(struct udevice *dev) * are different and if they aren't, use the reset values. */ if (dw[0] == dw[1] || dw[1] == dw[2]) { - log_info("PMC: Using default GPE route"); + if (spl_phase() > PHASE_TPL) + log_info("PMC: Using default GPE route"); gpio_cfg = readl(upriv->gpe_cfg); for (i = 0; i < upriv->gpe0_count; i++) dw[i] = gpio_cfg >> gpe0_shift(upriv, i); diff --git a/drivers/timer/tsc_timer.c b/drivers/timer/tsc_timer.c index e3677704b33..706d52b830a 100644 --- a/drivers/timer/tsc_timer.c +++ b/drivers/timer/tsc_timer.c @@ -477,15 +477,17 @@ static const struct timer_ops tsc_timer_ops = { .get_count = tsc_timer_get_count, };
+#if !CONFIG_IS_ENABLED(OF_PLATDATA) static const struct udevice_id tsc_timer_ids[] = { { .compatible = "x86,tsc-timer", }, { } }; +#endif
U_BOOT_DRIVER(x86_tsc_timer) = { .name = "x86_tsc_timer", .id = UCLASS_TIMER, - .of_match = tsc_timer_ids, + .of_match = of_match_ptr(tsc_timer_ids), .probe = tsc_timer_probe, .ops = &tsc_timer_ops, };
These errors are only really for development purposes. Drop them to reduce the size of TPL. The error numbers are still reported.
This reduces the TPL binary size on coral by about 160 bytes.
drivers/pinctrl/intel/pinctrl.c | 11 ++++++++--- 1 file changed, 8 insertions(+), 3 deletions(-)
diff --git a/drivers/pinctrl/intel/pinctrl.c b/drivers/pinctrl/intel/pinctrl.c index 9f96505dd5a..987a56b715e 100644 --- a/drivers/pinctrl/intel/pinctrl.c +++ b/drivers/pinctrl/intel/pinctrl.c @@ -274,7 +274,9 @@ static int pinctrl_configure_itss(struct udevice *dev, irq = pcr_read32(dev, PAD_CFG1_OFFSET(pad_cfg_offset)); irq &= PAD_CFG1_IRQ_MASK; if (!irq) { - log_err("GPIO %u doesn't support APIC routing\n", cfg->pad); + if (spl_phase() > PHASE_TPL) + log_err("GPIO %u doesn't support APIC routing\n", + cfg->pad);
return -EPROTONOSUPPORT; } @@ -314,7 +316,8 @@ static int pinctrl_pad_reset_config_override(const struct pad_community *comm, return config_value; } } - log_err("Logical-to-Chipset mapping not found\n"); + if (spl_phase() > PHASE_TPL) + log_err("Logical-to-Chipset mapping not found\n");
return -ENOENT; } @@ -620,7 +623,9 @@ int intel_pinctrl_of_to_plat(struct udevice *dev, struct intel_pinctrl_priv *priv = dev_get_priv(dev);
if (!comm) { - log_err("Cannot find community for pid %d\n", pplat->pid); + if (spl_phase() > PHASE_TPL) + log_err("Cannot find community for pid %d\n", + pplat->pid); return -EDOM; } priv->comm = comm;
Update this driver to use of_match_ptr().
This reduces the TPL binary size by about 32 bytes.
arch/x86/lib/tpl.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/arch/x86/lib/tpl.c b/arch/x86/lib/tpl.c index 15b0212d190..04ff32277fd 100644 --- a/arch/x86/lib/tpl.c +++ b/arch/x86/lib/tpl.c @@ -133,14 +133,16 @@ void spl_board_init(void) * for devices, so the TPL BARs continue to be used. Once U-Boot starts it does * the auto allocation (after relocation). */ +#if !CONFIG_IS_ENABLED(OF_PLATDATA) static const struct udevice_id tpl_fake_pci_ids[] = { { .compatible = "pci-x86" }, { } }; +#endif
U_BOOT_DRIVER(pci_x86) = { .name = "pci_x86", .id = UCLASS_SIMPLE_BUS, - .of_match = tpl_fake_pci_ids, + .of_match = of_match_ptr(tpl_fake_pci_ids), }; #endif
This has the wrong name. Fix it.
arch/x86/include/asm/pmu.h | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/x86/include/asm/pmu.h b/arch/x86/include/asm/pmu.h index b76bdf64a30..818e80881ec 100644 --- a/arch/x86/include/asm/pmu.h +++ b/arch/x86/include/asm/pmu.h @@ -2,9 +2,9 @@ /* * Copyright (c) 2017 Intel Corporation */ -#ifndef _X86_ASM_PMU_IPC_H_ -#define _X86_ASM_PMU_IPC_H_ +#ifndef _X86_ASM_PMU_H_ +#define _X86_ASM_PMU_H_
int pmu_turn_power(unsigned int lss, bool on);
-#endif /* _X86_ASM_PMU_IPC_H_ */ +#endif /* _X86_ASM_PMU_H_ */
