[U-Boot] [PATCH] arm: Tegra: Fix Harmony and Ventana builds
Signed-off-by: Tom Warren twarren@nvidia.com
BUG=none TEST=built all 3 (Harmony, Seaboard and Ventana) and tested Seaboard --- board/nvidia/harmony/Makefile | 1 - board/nvidia/ventana/Makefile | 3 +-- include/configs/ventana.h | 3 +++ 3 files changed, 4 insertions(+), 3 deletions(-)
diff --git a/board/nvidia/harmony/Makefile b/board/nvidia/harmony/Makefile index f6599de..b6efa1c 100644 --- a/board/nvidia/harmony/Makefile +++ b/board/nvidia/harmony/Makefile @@ -31,7 +31,6 @@ endif LIB = $(obj)lib$(BOARD).o
COBJS := $(BOARD).o -COBJS += ../common/board.o
SRCS := $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/nvidia/ventana/Makefile b/board/nvidia/ventana/Makefile index 9e5a87f..b4ab79a 100644 --- a/board/nvidia/ventana/Makefile +++ b/board/nvidia/ventana/Makefile @@ -30,8 +30,7 @@ endif
-COBJS += ../seaboard/seaboard.o -COBJS += ../common/board.o +COBJS = ../seaboard/seaboard.o
SRCS := $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/include/configs/ventana.h b/include/configs/ventana.h index afd6ff6..acc9b43 100644 --- a/include/configs/ventana.h +++ b/include/configs/ventana.h @@ -52,4 +52,7 @@ #define CONFIG_EFI_PARTITION #define CONFIG_CMD_EXT2 #define CONFIG_CMD_FAT + +/* Environment not stored */ +#define CONFIG_ENV_IS_NOWHERE #endif /* __CONFIG_H */
Tom Warren wrote at Monday, December 19, 2011 4:09 PM:
Tom,
I'm a little confused by this. The patch removes ../common/board.o from COBJS for Harmony and Ventana, but not from Seaboard, and at least in u-boot-tegra/ next, Seaboard still references that file.
Also, applying this patch causes Harmony and Ventana to fail to build (link) due to undefined symbols typically provided by common/board.o.
What branch is the patch targeted at, and what build problems is it solving?
Hi all,
Signed-off-by: Tom Warrentwarren@nvidia.com
Tom,
Plus, I would suggest making the commit message less cryptic; I can make no heads or tails of these "BUG=" and "TEST=" lines.
Amicalement,
Sorry, folks. Please ignore u-boot-tegra/next for now. It's in transition.
u-boot-tegra/master has some new patches (getting ready for a pull request) that changed the Seaboard Makefile but not the Harmony or Ventana ones. The fix-it patch I submitted should've had a line that said it applies against u-boot-tegra/master (which really should be 'next', I guess).
The BUG= and TEST= lines are required for ChromeOS U-Boot submissions - I just got into the habit of always applying them to commit messages. I'll remove 'em, add some more info about where exactly this patch applies, and resubmit.
Thanks for catching all this,
Tom
-----Original Message----- From: Albert ARIBAUD [mailto:albert.u.boot@aribaud.net] Sent: Monday, December 19, 2011 11:56 PM To: Stephen Warren Cc: Tom Warren; u-boot@lists.denx.de; sjg@chromium.org; wd@denx.de; Tom Warren Subject: Re: [PATCH] arm: Tegra: Fix Harmony and Ventana builds
Hi all,
Tom,
Amicalement,
Albert.
----------------------------------------------------------------------------------- This email message is for the sole use of the intended recipient(s) and may contain confidential information. Any unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient, please contact the sender by reply email and destroy all copies of the original message. -----------------------------------------------------------------------------------
Albert ARIBAUD
Stephen Warren
Tom Warren
Tom Warren
