[U-Boot] [PATCH 0/5] Add basic support for Rockchip RV1108 SOC
RV1108 is embedded with an ARM Cortex-A7 single core and a DSP core from Rockchip. It is designed for varies application scenario such as car DVR, sports DV, secure camera and UAV camera.
This patchset adds basic support for it to boot an evb board to u-boot console. Other functions such as Ethernet / SFC (SPI Flash controller) will be added later by other people.
Andy Yan (5): rockchip: mkimage: Add support for RV1108 rockchip: pinctrl: Add rv1108 pinctrl driver rockchip: clk: Add rv1108 clock driver rockchip: Add core Soc start-up code for rv1108 rockchip: Add basic support for evb-rv1108 board
arch/arm/dts/Makefile | 3 +- arch/arm/dts/rv1108-evb.dts | 54 +++ arch/arm/dts/rv1108.dtsi | 479 ++++++++++++++++++++++ arch/arm/include/asm/arch-rockchip/cru_rv1108.h | 111 ++++++ arch/arm/include/asm/arch-rockchip/grf_rv1108.h | 509 ++++++++++++++++++++++++ arch/arm/include/asm/arch-rockchip/periph.h | 1 + arch/arm/mach-rockchip/Kconfig | 8 + arch/arm/mach-rockchip/Makefile | 1 + arch/arm/mach-rockchip/rv1108/Kconfig | 28 ++ arch/arm/mach-rockchip/rv1108/Makefile | 11 + arch/arm/mach-rockchip/rv1108/clk_rv1108.c | 32 ++ arch/arm/mach-rockchip/rv1108/rv1108.c | 15 + arch/arm/mach-rockchip/rv1108/syscon_rv1108.c | 21 + board/rockchip/evb_rv1108/Kconfig | 15 + board/rockchip/evb_rv1108/MAINTAINERS | 6 + board/rockchip/evb_rv1108/Makefile | 7 + board/rockchip/evb_rv1108/README | 47 +++ board/rockchip/evb_rv1108/evb_rv1108.c | 52 +++ configs/evb-rv1108_defconfig | 40 ++ drivers/clk/rockchip/Makefile | 1 + drivers/clk/rockchip/clk_rv1108.c | 223 +++++++++++ drivers/pinctrl/Kconfig | 10 + drivers/pinctrl/rockchip/Makefile | 1 + drivers/pinctrl/rockchip/pinctrl_rv1108.c | 184 +++++++++ drivers/sysreset/Makefile | 1 + drivers/sysreset/sysreset_rv1108.c | 46 +++ include/configs/evb_rv1108.h | 26 ++ include/configs/rv1108_common.h | 33 ++ include/dt-bindings/clock/rv1108-cru.h | 269 +++++++++++++ tools/rkcommon.c | 1 + 30 files changed, 2234 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/rv1108-evb.dts create mode 100644 arch/arm/dts/rv1108.dtsi create mode 100644 arch/arm/include/asm/arch-rockchip/cru_rv1108.h create mode 100644 arch/arm/include/asm/arch-rockchip/grf_rv1108.h create mode 100644 arch/arm/mach-rockchip/rv1108/Kconfig create mode 100644 arch/arm/mach-rockchip/rv1108/Makefile create mode 100644 arch/arm/mach-rockchip/rv1108/clk_rv1108.c create mode 100644 arch/arm/mach-rockchip/rv1108/rv1108.c create mode 100644 arch/arm/mach-rockchip/rv1108/syscon_rv1108.c create mode 100644 board/rockchip/evb_rv1108/Kconfig create mode 100644 board/rockchip/evb_rv1108/MAINTAINERS create mode 100644 board/rockchip/evb_rv1108/Makefile create mode 100644 board/rockchip/evb_rv1108/README create mode 100644 board/rockchip/evb_rv1108/evb_rv1108.c create mode 100644 configs/evb-rv1108_defconfig create mode 100644 drivers/clk/rockchip/clk_rv1108.c create mode 100644 drivers/pinctrl/rockchip/pinctrl_rv1108.c create mode 100644 drivers/sysreset/sysreset_rv1108.c create mode 100644 include/configs/evb_rv1108.h create mode 100644 include/configs/rv1108_common.h create mode 100644 include/dt-bindings/clock/rv1108-cru.h
Add support to mkimage for rv1108 soc, the max spl code size for rv1108 is 6kb, and the spl code should be packed by rksd, wether boot from emmc or spi nor flash.
Signed-off-by: Andy Yan andy.yan@rock-chips.com ---
tools/rkcommon.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/tools/rkcommon.c b/tools/rkcommon.c index 42547aa..fd95abc 100644 --- a/tools/rkcommon.c +++ b/tools/rkcommon.c @@ -77,6 +77,7 @@ static struct spl_info spl_infos[] = { { "rk3288", "RK32", 0x8000, false, false }, { "rk3328", "RK32", 0x8000 - 0x1000, false, false }, { "rk3399", "RK33", 0x20000, false, true }, + { "rv1108", "RK11", 0x1800, false, false}, };
static unsigned char rc4_key[16] = {
- { "rv1108", "RK11", 0x1800, false, false},
So the RV1108 does not use the BOOT0 hook… now our previous discussion from this morning makes sense ;-)
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
2.7.4
Applied to u-boot-rockchip, thanks!
Add pinctrl support for Rockchip rv1108 soc
arch/arm/include/asm/arch-rockchip/grf_rv1108.h | 509 ++++++++++++++++++++++++ drivers/pinctrl/Kconfig | 10 + drivers/pinctrl/rockchip/Makefile | 1 + drivers/pinctrl/rockchip/pinctrl_rv1108.c | 184 +++++++++ 4 files changed, 704 insertions(+) create mode 100644 arch/arm/include/asm/arch-rockchip/grf_rv1108.h create mode 100644 drivers/pinctrl/rockchip/pinctrl_rv1108.c
diff --git a/arch/arm/include/asm/arch-rockchip/grf_rv1108.h b/arch/arm/include/asm/arch-rockchip/grf_rv1108.h new file mode 100644 index 0000000..c816a5b --- /dev/null +++ b/arch/arm/include/asm/arch-rockchip/grf_rv1108.h @@ -0,0 +1,509 @@ +/* + * (C) Copyright 2016 Rockchip Electronics Co., Ltd + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#ifndef _ASM_ARCH_GRF_RV1108_H +#define _ASM_ARCH_GRF_RV1108_H + +#include <common.h> + +struct rv1108_grf { + u32 reserved[4]; + u32 gpio1a_iomux; + u32 gpio1b_iomux; + u32 gpio1c_iomux; + u32 gpio1d_iomux; + u32 gpio2a_iomux; + u32 gpio2b_iomux; + u32 gpio2c_iomux; + u32 gpio2d_iomux; + u32 gpio3a_iomux; + u32 gpio3b_iomux; + u32 gpio3c_iomux; + u32 gpio3d_iomux; + u32 reserved1[52]; + u32 gpio1a_pull; + u32 gpio1b_pull; + u32 gpio1c_pull; + u32 gpio1d_pull; + u32 gpio2a_pull; + u32 gpio2b_pull; + u32 gpio2c_pull; + u32 gpio2d_pull; + u32 gpio3a_pull; + u32 gpio3b_pull; + u32 gpio3c_pull; + u32 gpio3d_pull; + u32 reserved2[52]; + u32 gpio1a_drv; + u32 gpio1b_drv; + u32 gpio1c_drv; + u32 gpio1d_drv; + u32 gpio2a_drv; + u32 gpio2b_drv; + u32 gpio2c_drv; + u32 gpio2d_drv; + u32 gpio3a_drv; + u32 gpio3b_drv; + u32 gpio3c_drv; + u32 gpio3d_drv; + u32 reserved3[50]; + u32 gpio1l_sr; + u32 gpio1h_sr; + u32 gpio2l_sr; + u32 gpio2h_sr; + u32 gpio3l_sr; + u32 gpio3h_sr; + u32 reserved4[26]; + u32 gpio1l_smt; + u32 gpio1h_smt; + u32 gpio2l_smt; + u32 gpio2h_smt; + u32 gpio3l_smt; + u32 gpio3h_smt; + u32 reserved5[24]; + u32 soc_con0; + u32 soc_con1; + u32 soc_con2; + u32 soc_con3; + u32 soc_con4; + u32 soc_con5; + u32 soc_con6; + u32 soc_con7; + u32 soc_con8; + u32 soc_con9; + u32 soc_con10; + u32 soc_con11; + u32 reserved6[20]; + u32 soc_status0; + u32 soc_status1; + u32 reserved7[30]; + u32 cpu_con0; + u32 cpu_con1; + u32 reserved8[30]; + u32 os_reg0; + u32 os_reg1; + u32 os_reg2; + u32 os_reg3; + u32 reserved9[29]; + u32 ddr_status; + u32 reserved10[30]; + u32 sig_det_con; + u32 reserved11[3]; + u32 sig_det_status; + u32 reserved12[3]; + u32 sig_det_clr; + u32 reserved13[23]; + u32 host_con0; + u32 host_con1; + u32 reserved14[2]; + u32 dma_con0; + u32 dma_con1; + u32 reserved15[539]; + u32 uoc_status; + u32 host_status; + u32 gmac_con0; + u32 chip_id; +}; +check_member(rv1108_grf, chip_id, 0xf90); + +/* GRF_GPIO1B_IOMUX */ +enum { + GPIO1B7_SHIFT = 14, + GPIO1B7_MASK = 3 << GPIO1B7_SHIFT, + GPIO1B7_GPIO = 0, + GPIO1B7_LCDC_D12, + GPIO1B7_I2S_SDIO2_M0, + GPIO1B7_GMAC_RXDV, + + GPIO1B6_SHIFT = 12, + GPIO1B6_MASK = 3 << GPIO1B6_SHIFT, + GPIO1B6_GPIO = 0, + GPIO1B6_LCDC_D13, + GPIO1B6_I2S_LRCLKTX_M0, + GPIO1B6_GMAC_RXD1, + + GPIO1B5_SHIFT = 10, + GPIO1B5_MASK = 3 << GPIO1B5_SHIFT, + GPIO1B5_GPIO = 0, + GPIO1B5_LCDC_D14, + GPIO1B5_I2S_SDIO1_M0, + GPIO1B5_GMAC_RXD0, + + GPIO1B4_SHIFT = 8, + GPIO1B4_MASK = 3 << GPIO1B4_SHIFT, + GPIO1B4_GPIO = 0, + GPIO1B4_LCDC_D15, + GPIO1B4_I2S_MCLK_M0, + GPIO1B4_GMAC_TXEN, + + GPIO1B3_SHIFT = 6, + GPIO1B3_MASK = 3 << GPIO1B3_SHIFT, + GPIO1B3_GPIO = 0, + GPIO1B3_LCDC_D16, + GPIO1B3_I2S_SCLK_M0, + GPIO1B3_GMAC_TXD1, + + GPIO1B2_SHIFT = 4, + GPIO1B2_MASK = 3 << GPIO1B2_SHIFT, + GPIO1B2_GPIO = 0, + GPIO1B2_LCDC_D17, + GPIO1B2_I2S_SDIO_M0, + GPIO1B2_GMAC_TXD0, + + GPIO1B1_SHIFT = 2, + GPIO1B1_MASK = 3 << GPIO1B1_SHIFT, + GPIO1B1_GPIO = 0, + GPIO1B1_LCDC_D9, + GPIO1B1_PWM7, + + GPIO1B0_SHIFT = 0, + GPIO1B0_MASK = 3, + GPIO1B0_GPIO = 0, + GPIO1B0_LCDC_D8, + GPIO1B0_PWM6, +}; + +/* GRF_GPIO1C_IOMUX */ +enum { + GPIO1C7_SHIFT = 14, + GPIO1C7_MASK = 3 << GPIO1C7_SHIFT, + GPIO1C7_GPIO = 0, + GPIO1C7_CIF_D5, + GPIO1C7_I2S_SDIO2_M1, + + GPIO1C6_SHIFT = 12, + GPIO1C6_MASK = 3 << GPIO1C6_SHIFT, + GPIO1C6_GPIO = 0, + GPIO1C6_CIF_D4, + GPIO1C6_I2S_LRCLKTX_M1, + + GPIO1C5_SHIFT = 10, + GPIO1C5_MASK = 3 << GPIO1C5_SHIFT, + GPIO1C5_GPIO = 0, + GPIO1C5_LCDC_CLK, + GPIO1C5_GMAC_CLK, + + GPIO1C4_SHIFT = 8, + GPIO1C4_MASK = 3 << GPIO1C4_SHIFT, + GPIO1C4_GPIO = 0, + GPIO1C4_LCDC_HSYNC, + GPIO1C4_GMAC_MDC, + + GPIO1C3_SHIFT = 6, + GPIO1C3_MASK = 3 << GPIO1C3_SHIFT, + GPIO1C3_GPIO = 0, + GPIO1C3_LCDC_VSYNC, + GPIO1C3_GMAC_MDIO, + + GPIO1C2_SHIFT = 4, + GPIO1C2_MASK = 3 << GPIO1C2_SHIFT, + GPIO1C2_GPIO = 0, + GPIO1C2_LCDC_EN, + GPIO1C2_I2S_SDIO3_M0, + GPIO1C2_GMAC_RXER, + + GPIO1C1_SHIFT = 2, + GPIO1C1_MASK = 3 << GPIO1C1_SHIFT, + GPIO1C1_GPIO = 0, + GPIO1C1_LCDC_D10, + GPIO1C1_I2S_SDI_M0, + GPIO1C1_PWM4, + + GPIO1C0_SHIFT = 0, + GPIO1C0_MASK = 3, + GPIO1C0_GPIO = 0, + GPIO1C0_LCDC_D11, + GPIO1C0_I2S_LRCLKRX_M0, +}; + +/* GRF_GPIO1D_OIMUX */ +enum { + GPIO1D7_SHIFT = 14, + GPIO1D7_MASK = 3 << GPIO1D7_SHIFT, + GPIO1D7_GPIO = 0, + GPIO1D7_HDMI_CEC, + GPIO1D7_DSP_RTCK, + + GPIO1D6_SHIFT = 12, + GPIO1D6_MASK = 1 << GPIO1D6_SHIFT, + GPIO1D6_GPIO = 0, + GPIO1D6_HDMI_HPD_M0, + + GPIO1D5_SHIFT = 10, + GPIO1D5_MASK = 3 << GPIO1D5_SHIFT, + GPIO1D5_GPIO = 0, + GPIO1D5_UART2_RTSN, + GPIO1D5_HDMI_SDA_M0, + + GPIO1D4_SHIFT = 8, + GPIO1D4_MASK = 3 << GPIO1D4_SHIFT, + GPIO1D4_GPIO = 0, + GPIO1D4_UART2_CTSN, + GPIO1D4_HDMI_SCL_M0, + + GPIO1D3_SHIFT = 6, + GPIO1D3_MASK = 3 << GPIO1D3_SHIFT, + GPIO1D3_GPIO = 0, + GPIO1D3_UART0_SOUT, + GPIO1D3_SPI_TXD_M0, + + GPIO1D2_SHIFT = 4, + GPIO1D2_MASK = 3 << GPIO1D2_SHIFT, + GPIO1D2_GPIO = 0, + GPIO1D2_UART0_SIN, + GPIO1D2_SPI_RXD_M0, + GPIO1D2_DSP_TDI, + + GPIO1D1_SHIFT = 2, + GPIO1D1_MASK = 3 << GPIO1D1_SHIFT, + GPIO1D1_GPIO = 0, + GPIO1D1_UART0_RTSN, + GPIO1D1_SPI_CSN0_M0, + GPIO1D1_DSP_TMS, + + GPIO1D0_SHIFT = 0, + GPIO1D0_MASK = 3, + GPIO1D0_GPIO = 0, + GPIO1D0_UART0_CTSN, + GPIO1D0_SPI_CLK_M0, + GPIO1D0_DSP_TCK, +}; + +/* GRF_GPIO2A_IOMUX */ +enum { + GPIO2A7_SHIFT = 14, + GPIO2A7_MASK = 3 << GPIO2A7_SHIFT, + GPIO2A7_GPIO = 0, + GPIO2A7_FLASH_D7, + GPIO2A7_EMMC_D7, + + GPIO2A6_SHIFT = 12, + GPIO2A6_MASK = 3 << GPIO2A6_SHIFT, + GPIO2A6_GPIO = 0, + GPIO2A6_FLASH_D6, + GPIO2A6_EMMC_D6, + + GPIO2A5_SHIFT = 10, + GPIO2A5_MASK = 3 << GPIO2A5_SHIFT, + GPIO2A5_GPIO = 0, + GPIO2A5_FLASH_D5, + GPIO2A5_EMMC_D5, + + GPIO2A4_SHIFT = 8, + GPIO2A4_MASK = 3 << GPIO2A4_SHIFT, + GPIO2A4_GPIO = 0, + GPIO2A4_FLASH_D4, + GPIO2A4_EMMC_D4, + + GPIO2A3_SHIFT = 6, + GPIO2A3_MASK = 3 << GPIO2A3_SHIFT, + GPIO2A3_GPIO = 0, + GPIO2A3_FLASH_D3, + GPIO2A3_EMMC_D3, + GPIO2A3_SFC_HOLD_IO3, + + GPIO2A2_SHIFT = 4, + GPIO2A2_MASK = 3 << GPIO2A2_SHIFT, + GPIO2A2_GPIO = 0, + GPIO2A2_FLASH_D2, + GPIO2A2_EMMC_D2, + GPIO2A2_SFC_WP_IO2, + + GPIO2A1_SHIFT = 2, + GPIO2A1_MASK = 3 << GPIO2A1_SHIFT, + GPIO2A1_GPIO = 0, + GPIO2A1_FLASH_D1, + GPIO2A1_EMMC_D1, + GPIO2A1_SFC_SO_IO1, + + GPIO2A0_SHIFT = 0, + GPIO2A0_MASK = 3 << GPIO2A0_SHIFT, + GPIO2A0_GPIO = 0, + GPIO2A0_FLASH_D0, + GPIO2A0_EMMC_D0, + GPIO2A0_SFC_SI_IO0, +}; + +/* GRF_GPIO2D_IOMUX */ +enum { + GPIO2B7_SHIFT = 14, + GPIO2B7_MASK = 3 << GPIO2B7_SHIFT, + GPIO2B7_GPIO = 0, + GPIO2B7_FLASH_CS1, + GPIO2B7_SFC_CLK, + + GPIO2B6_SHIFT = 12, + GPIO2B6_MASK = 1 << GPIO2B6_SHIFT, + GPIO2B6_GPIO = 0, + GPIO2B6_EMMC_CLKO, + + GPIO2B5_SHIFT = 10, + GPIO2B5_MASK = 1 << GPIO2B5_SHIFT, + GPIO2B5_GPIO = 0, + GPIO2B5_FLASH_CS0, + + GPIO2B4_SHIFT = 8, + GPIO2B4_MASK = 3 << GPIO2B4_SHIFT, + GPIO2B4_GPIO = 0, + GPIO2B4_FLASH_RDY, + GPIO2B4_EMMC_CMD, + GPIO2B4_SFC_CSN0, + + GPIO2B3_SHIFT = 6, + GPIO2B3_MASK = 1 << GPIO2B3_SHIFT, + GPIO2B3_GPIO = 0, + GPIO2B3_FLASH_RDN, + + GPIO2B2_SHIFT = 4, + GPIO2B2_MASK = 1 << GPIO2B2_SHIFT, + GPIO2B2_GPIO = 0, + GPIO2B2_FLASH_WRN, + + GPIO2B1_SHIFT = 2, + GPIO2B1_MASK = 1 << GPIO2B1_SHIFT, + GPIO2B1_GPIO = 0, + GPIO2B1_FLASH_CLE, + + GPIO2B0_SHIFT = 0, + GPIO2B0_MASK = 1 << GPIO2B0_SHIFT, + GPIO2B0_GPIO = 0, + GPIO2B0_FLASH_ALE, +}; + +/* GRF_GPIO2D_IOMUX */ +enum { + GPIO2D7_SHIFT = 14, + GPIO2D7_MASK = 1 << GPIO2D7_SHIFT, + GPIO2D7_GPIO = 0, + GPIO2D7_SDIO_D0, + + GPIO2D6_SHIFT = 12, + GPIO2D6_MASK = 1 << GPIO2D6_SHIFT, + GPIO2D6_GPIO = 0, + GPIO2D6_SDIO_CMD, + + GPIO2D5_SHIFT = 10, + GPIO2D5_MASK = 1 << GPIO2D5_SHIFT, + GPIO2D5_GPIO = 0, + GPIO2D5_SDIO_CLKO, + + GPIO2D4_SHIFT = 8, + GPIO2D4_MASK = 1 << GPIO2D4_SHIFT, + GPIO2D4_GPIO = 0, + GPIO2D4_I2C1_SCL, + + GPIO2D3_SHIFT = 6, + GPIO2D3_MASK = 1 << GPIO2D3_SHIFT, + GPIO2D3_GPIO = 0, + GPIO2D3_I2C1_SDA, + + GPIO2D2_SHIFT = 4, + GPIO2D2_MASK = 3 << GPIO2D2_SHIFT, + GPIO2D2_GPIO = 0, + GPIO2D2_UART2_SOUT_M0, + GPIO2D2_JTAG_TCK, + + GPIO2D1_SHIFT = 2, + GPIO2D1_MASK = 3 << GPIO2D1_SHIFT, + GPIO2D1_GPIO = 0, + GPIO2D1_UART2_SIN_M0, + GPIO2D1_JTAG_TMS, + GPIO2D1_DSP_TMS, + + GPIO2D0_SHIFT = 0, + GPIO2D0_MASK = 3, + GPIO2D0_GPIO = 0, + GPIO2D0_UART0_CTSN, + GPIO2D0_SPI_CLK_M0, + GPIO2D0_DSP_TCK, +}; + +/* GRF_GPIO3A_IOMUX */ +enum { + GPIO3A7_SHIFT = 14, + GPIO3A7_MASK = 1 << GPIO3A7_SHIFT, + GPIO3A7_GPIO = 0, + + GPIO3A6_SHIFT = 12, + GPIO3A6_MASK = 1 << GPIO3A6_SHIFT, + GPIO3A6_GPIO = 0, + GPIO3A6_UART1_SOUT, + + GPIO3A5_SHIFT = 10, + GPIO3A5_MASK = 1 << GPIO3A5_SHIFT, + GPIO3A5_GPIO = 0, + GPIO3A5_UART1_SIN, + + GPIO3A4_SHIFT = 8, + GPIO3A4_MASK = 1 << GPIO3A4_SHIFT, + GPIO3A4_GPIO = 0, + GPIO3A4_UART1_CTSN, + + GPIO3A3_SHIFT = 6, + GPIO3A3_MASK = 1 << GPIO3A3_SHIFT, + GPIO3A3_GPIO = 0, + GPIO3A3_UART1_RTSN, + + GPIO3A2_SHIFT = 4, + GPIO3A2_MASK = 1 << GPIO3A2_SHIFT, + GPIO3A2_GPIO = 0, + GPIO3A2_SDIO_D3, + + GPIO3A1_SHIFT = 2, + GPIO3A1_MASK = 1 << GPIO3A1_SHIFT, + GPIO3A1_GPIO = 0, + GPIO3A1_SDIO_D2, + + GPIO3A0_SHIFT = 0, + GPIO3A0_MASK = 1, + GPIO3A0_GPIO = 0, + GPIO3A0_SDIO_D1, +}; + +/* GRF_GPIO3C_IOMUX */ +enum { + GPIO3C7_SHIFT = 14, + GPIO3C7_MASK = 1 << GPIO3C7_SHIFT, + GPIO3C7_GPIO = 0, + GPIO3C7_CIF_CLKI, + + GPIO3C6_SHIFT = 12, + GPIO3C6_MASK = 1 << GPIO3C6_SHIFT, + GPIO3C6_GPIO = 0, + GPIO3C6_CIF_VSYNC, + + GPIO3C5_SHIFT = 10, + GPIO3C5_MASK = 1 << GPIO3C5_SHIFT, + GPIO3C5_GPIO = 0, + GPIO3C5_SDMMC_CMD, + + GPIO3C4_SHIFT = 8, + GPIO3C4_MASK = 1 << GPIO3C4_SHIFT, + GPIO3C4_GPIO = 0, + GPIO3C4_SDMMC_CLKO, + + GPIO3C3_SHIFT = 6, + GPIO3C3_MASK = 3 << GPIO3C3_SHIFT, + GPIO3C3_GPIO = 0, + GPIO3C3_SDMMC_D0, + GPIO3C3_UART2_SOUT_M1, + + GPIO3C2_SHIFT = 4, + GPIO3C2_MASK = 3 << GPIO3C2_SHIFT, + GPIO3C2_GPIO = 0, + GPIO3C2_SDMMC_D1, + GPIO3C2_UART2_SIN_M1, + + GPIOC1_SHIFT = 2, + GPIOC1_MASK = 1 << GPIOC1_SHIFT, + GPIOC1_GPIO = 0, + GPIOC1_SDMMC_D2, + + GPIOC0_SHIFT = 0, + GPIOC0_MASK = 1, + GPIO3C0_GPIO = 0, + GPIO3C0_SDMMC_D3, +}; +#endif diff --git a/drivers/pinctrl/Kconfig b/drivers/pinctrl/Kconfig index 79249e0..150c68d 100644 --- a/drivers/pinctrl/Kconfig +++ b/drivers/pinctrl/Kconfig @@ -217,6 +217,16 @@ config PINCTRL_ROCKCHIP_RK3399 the GPIO definitions and pin control functions for each available multiplex function.
+config PINCTRL_ROCKCHIP_RV1108 + bool "Rockchip rv1108 pin control driver" + depends on DM + help + Support pin multiplexing control on Rockchip rv1108 SoC. + + The driver is controlled by a device tree node which contains + both the GPIO definitions and pin control functions for each + available multiplex function. + config PINCTRL_SANDBOX bool "Sandbox pinctrl driver" depends on SANDBOX diff --git a/drivers/pinctrl/rockchip/Makefile b/drivers/pinctrl/rockchip/Makefile index 7b7c470..a1c655d 100644 --- a/drivers/pinctrl/rockchip/Makefile +++ b/drivers/pinctrl/rockchip/Makefile @@ -11,3 +11,4 @@ obj-$(CONFIG_PINCTRL_ROCKCHIP_RK3288) += pinctrl_rk3288.o obj-$(CONFIG_PINCTRL_ROCKCHIP_RK3328) += pinctrl_rk3328.o obj-$(CONFIG_PINCTRL_ROCKCHIP_RK3368) += pinctrl_rk3368.o obj-$(CONFIG_PINCTRL_ROCKCHIP_RK3399) += pinctrl_rk3399.o +obj-$(CONFIG_PINCTRL_ROCKCHIP_RV1108) += pinctrl_rv1108.o diff --git a/drivers/pinctrl/rockchip/pinctrl_rv1108.c b/drivers/pinctrl/rockchip/pinctrl_rv1108.c new file mode 100644 index 0000000..d98ec81 --- /dev/null +++ b/drivers/pinctrl/rockchip/pinctrl_rv1108.c @@ -0,0 +1,184 @@ +/* + * (C) Copyright 2016 Rockchip Electronics Co., Ltd + * Author: Andy Yan andy.yan@rock-chips.com + * SPDX-License-Identifier: GPL-2.0+ + */ +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <syscon.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/grf_rv1108.h> +#include <asm/arch/hardware.h> +#include <asm/arch/periph.h> +#include <dm/pinctrl.h> + +DECLARE_GLOBAL_DATA_PTR; + +struct rv1108_pinctrl_priv { + struct rv1108_grf *grf; +}; + +static void pinctrl_rv1108_uart_config(struct rv1108_grf *grf, int uart_id) +{ + switch (uart_id) { + case PERIPH_ID_UART0: + rk_clrsetreg(&grf->gpio3a_iomux, + GPIO3A6_MASK | GPIO3A5_MASK, + GPIO3A6_UART1_SOUT << GPIO3A6_SHIFT | + GPIO3A5_UART1_SIN << GPIO3A5_SHIFT); + break; + case PERIPH_ID_UART1: + rk_clrsetreg(&grf->gpio1d_iomux, + GPIO1D3_MASK | GPIO1D2_MASK | GPIO1D1_MASK | + GPIO1D0_MASK, + GPIO1D3_UART0_SOUT << GPIO1D3_SHIFT | + GPIO1D2_UART0_SIN << GPIO1D2_SHIFT | + GPIO1D1_UART0_RTSN << GPIO1D1_SHIFT | + GPIO1D0_UART0_CTSN << GPIO1D0_SHIFT); + break; + case PERIPH_ID_UART2: + rk_clrsetreg(&grf->gpio2d_iomux, + GPIO2D2_MASK | GPIO2D1_MASK, + GPIO2D2_UART2_SOUT_M0 << GPIO2D2_SHIFT | + GPIO2D1_UART2_SIN_M0 << GPIO2D1_SHIFT); + break; + } +} + +static void pinctrl_rv1108_gmac_config(struct rv1108_grf *grf, int func) +{ + rk_clrsetreg(&grf->gpio1b_iomux, + GPIO1B7_MASK | GPIO1B6_MASK | GPIO1B5_MASK | + GPIO1B4_MASK | GPIO1B3_MASK | GPIO1B2_MASK, + GPIO1B7_GMAC_RXDV << GPIO1B7_SHIFT | + GPIO1B6_GMAC_RXD1 << GPIO1B6_SHIFT | + GPIO1B5_GMAC_RXD0 << GPIO1B5_SHIFT | + GPIO1B4_GMAC_TXEN << GPIO1B4_SHIFT | + GPIO1B3_GMAC_TXD1 << GPIO1B3_SHIFT | + GPIO1B2_GMAC_TXD0 << GPIO1B2_SHIFT); + rk_clrsetreg(&grf->gpio1c_iomux, + GPIO1C5_MASK | GPIO1C4_MASK | + GPIO1C3_MASK | GPIO1C2_MASK, + GPIO1C5_GMAC_CLK << GPIO1C5_SHIFT | + GPIO1C4_GMAC_MDC << GPIO1C4_SHIFT | + GPIO1C3_GMAC_MDIO << GPIO1C3_SHIFT | + GPIO1C2_GMAC_RXER << GPIO1C2_SHIFT); + writel(0xffff57f5, &grf->gpio1b_drv); +} + +static void pinctrl_rv1108_sfc_config(struct rv1108_grf *grf) +{ + rk_clrsetreg(&grf->gpio2a_iomux, GPIO2A3_MASK | GPIO2A2_MASK | + GPIO2A1_MASK | GPIO2A0_MASK, + GPIO2A3_SFC_HOLD_IO3 << GPIO2A3_SHIFT | + GPIO2A2_SFC_WP_IO2 << GPIO2A2_SHIFT | + GPIO2A1_SFC_SO_IO1 << GPIO2A1_SHIFT | + GPIO2A0_SFC_SI_IO0 << GPIO2A0_SHIFT); + rk_clrsetreg(&grf->gpio2b_iomux, GPIO2B7_MASK | GPIO2B4_MASK, + GPIO2B7_SFC_CLK << GPIO2B7_SHIFT | + GPIO2B4_SFC_CSN0 << GPIO2B4_SHIFT); +} + +static int rv1108_pinctrl_request(struct udevice *dev, int func, int flags) +{ + struct rv1108_pinctrl_priv *priv = dev_get_priv(dev); + + switch (func) { + case PERIPH_ID_UART0: + case PERIPH_ID_UART1: + case PERIPH_ID_UART2: + pinctrl_rv1108_uart_config(priv->grf, func); + break; + case PERIPH_ID_GMAC: + pinctrl_rv1108_gmac_config(priv->grf, func); + case PERIPH_ID_SFC: + pinctrl_rv1108_sfc_config(priv->grf); + default: + return -EINVAL; + } + + return 0; +} + +static int rv1108_pinctrl_get_periph_id(struct udevice *dev, + struct udevice *periph) +{ + u32 cell[3]; + int ret; + + ret = fdtdec_get_int_array(gd->fdt_blob, periph->of_offset, + "interrupts", cell, ARRAY_SIZE(cell)); + if (ret < 0) + return -EINVAL; + + switch (cell[1]) { + case 11: + return PERIPH_ID_SDCARD; + case 13: + return PERIPH_ID_EMMC; + case 19: + return PERIPH_ID_GMAC; + case 30: + return PERIPH_ID_I2C0; + case 31: + return PERIPH_ID_I2C1; + case 32: + return PERIPH_ID_I2C2; + case 39: + return PERIPH_ID_PWM0; + case 44: + return PERIPH_ID_UART0; + case 45: + return PERIPH_ID_UART1; + case 46: + return PERIPH_ID_UART2; + case 56: + return PERIPH_ID_SFC; + } + + return -ENOENT; +} + +static int rv1108_pinctrl_set_state_simple(struct udevice *dev, + struct udevice *periph) +{ + int func; + + func = rv1108_pinctrl_get_periph_id(dev, periph); + if (func < 0) + return func; + + return rv1108_pinctrl_request(dev, func, 0); +} + +static struct pinctrl_ops rv1108_pinctrl_ops = { + .set_state_simple = rv1108_pinctrl_set_state_simple, + .request = rv1108_pinctrl_request, + .get_periph_id = rv1108_pinctrl_get_periph_id, +}; + +static int rv1108_pinctrl_probe(struct udevice *dev) +{ + struct rv1108_pinctrl_priv *priv = dev_get_priv(dev); + + priv->grf = syscon_get_first_range(ROCKCHIP_SYSCON_GRF); + + return 0; +} + +static const struct udevice_id rv1108_pinctrl_ids[] = { + {.compatible = "rockchip,rv1108-pinctrl" }, + { } +}; + +U_BOOT_DRIVER(pinctrl_rv1108) = { + .name = "pinctrl_rv1108", + .id = UCLASS_PINCTRL, + .of_match = rv1108_pinctrl_ids, + .priv_auto_alloc_size = sizeof(struct rv1108_pinctrl_priv), + .ops = &rv1108_pinctrl_ops, + .bind = dm_scan_fdt_dev, + .probe = rv1108_pinctrl_probe, +};
Add clock driver support for Rockchip rv1108 soc
arch/arm/include/asm/arch-rockchip/cru_rv1108.h | 111 ++++++++++ arch/arm/include/asm/arch-rockchip/periph.h | 1 + drivers/clk/rockchip/Makefile | 1 + drivers/clk/rockchip/clk_rv1108.c | 223 ++++++++++++++++++++ include/dt-bindings/clock/rv1108-cru.h | 269 ++++++++++++++++++++++++ 5 files changed, 605 insertions(+) create mode 100644 arch/arm/include/asm/arch-rockchip/cru_rv1108.h create mode 100644 drivers/clk/rockchip/clk_rv1108.c create mode 100644 include/dt-bindings/clock/rv1108-cru.h
diff --git a/arch/arm/include/asm/arch-rockchip/cru_rv1108.h b/arch/arm/include/asm/arch-rockchip/cru_rv1108.h new file mode 100644 index 0000000..2a1ae69 --- /dev/null +++ b/arch/arm/include/asm/arch-rockchip/cru_rv1108.h @@ -0,0 +1,111 @@ +/* + * (C) Copyright 2016 Rockchip Electronics Co., Ltd + * Author: Andy Yan andy.yan@rock-chips.com + * SPDX-License-Identifier: GPL-2.0+ + */ +#ifndef _ASM_ARCH_CRU_RV1108_H +#define _ASM_ARCH_CRU_RV1108_H + +#include <common.h> + +#define OSC_HZ (24 * 1000 * 1000) + +#define APLL_HZ (600 * 1000000) +#define GPLL_HZ (594 * 1000000) + +struct rv1108_clk_priv { + struct rv1108_cru *cru; + ulong rate; +}; + +struct rv1108_cru { + struct rv1108_pll { + unsigned int con0; + unsigned int con1; + unsigned int con2; + unsigned int con3; + unsigned int con4; + unsigned int con5; + unsigned int reserved[2]; + } pll[3]; + unsigned int clksel_con[46]; + unsigned int reserved1[2]; + unsigned int clkgate_con[20]; + unsigned int reserved2[4]; + unsigned int softrst_con[13]; + unsigned int reserved3[3]; + unsigned int glb_srst_fst_val; + unsigned int glb_srst_snd_val; + unsigned int glb_cnt_th; + unsigned int misc_con; + unsigned int glb_rst_con; + unsigned int glb_rst_st; + unsigned int sdmmc_con[2]; + unsigned int sdio_con[2]; + unsigned int emmc_con[2]; +}; +check_member(rv1108_cru, emmc_con[1], 0x01ec); + +struct pll_div { + u32 refdiv; + u32 fbdiv; + u32 postdiv1; + u32 postdiv2; + u32 frac; +}; + +enum { + /* PLL CON0 */ + FBDIV_MASK = 0xfff, + FBDIV_SHIFT = 0, + + /* PLL CON1 */ + POSTDIV2_SHIFT = 12, + POSTDIV2_MASK = 7 << POSTDIV2_SHIFT, + POSTDIV1_SHIFT = 8, + POSTDIV1_MASK = 7 << POSTDIV1_SHIFT, + REFDIV_MASK = 0x3f, + REFDIV_SHIFT = 0, + + /* PLL CON2 */ + LOCK_STA_SHIFT = 31, + LOCK_STA_MASK = 1 << LOCK_STA_SHIFT, + FRACDIV_MASK = 0xffffff, + FRACDIV_SHIFT = 0, + + /* PLL CON3 */ + WORK_MODE_SHIFT = 8, + WORK_MODE_MASK = 1 << WORK_MODE_SHIFT, + WORK_MODE_SLOW = 0, + WORK_MODE_NORMAL = 1, + DSMPD_SHIFT = 3, + DSMPD_MASK = 1 << DSMPD_SHIFT, + + /* CLKSEL0_CON */ + CORE_PLL_SEL_SHIFT = 8, + CORE_PLL_SEL_MASK = 3 << CORE_PLL_SEL_SHIFT, + CORE_PLL_SEL_APLL = 0, + CORE_PLL_SEL_GPLL = 1, + CORE_PLL_SEL_DPLL = 2, + CORE_CLK_DIV_SHIFT = 0, + CORE_CLK_DIV_MASK = 0x1f << CORE_CLK_DIV_SHIFT, + + /* CLKSEL24_CON */ + MAC_PLL_SEL_SHIFT = 12, + MAC_PLL_SEL_MASK = 1 << MAC_PLL_SEL_SHIFT, + MAC_PLL_SEL_APLL = 0, + MAC_PLL_SEL_GPLL = 1, + RMII_EXTCLK_SEL_SHIFT = 8, + RMII_EXTCLK_SEL_MASK = 1 << RMII_EXTCLK_SEL_SHIFT, + MAC_CLK_DIV_MASK = 0x1f, + MAC_CLK_DIV_SHIFT = 0, + + /* CLKSEL27_CON */ + SFC_PLL_SEL_SHIFT = 7, + SFC_PLL_SEL_MASK = 1 << SFC_PLL_SEL_SHIFT, + SFC_PLL_SEL_DPLL = 0, + SFC_PLL_SEL_GPLL = 1, + SFC_CLK_DIV_SHIFT = 0, + SFC_CLK_DIV_MASK = 0x3f << SFC_CLK_DIV_SHIFT, +}; +#endif diff --git a/arch/arm/include/asm/arch-rockchip/periph.h b/arch/arm/include/asm/arch-rockchip/periph.h index 8018d47..9f4bc2e 100644 --- a/arch/arm/include/asm/arch-rockchip/periph.h +++ b/arch/arm/include/asm/arch-rockchip/periph.h @@ -42,6 +42,7 @@ enum periph_id { PERIPH_ID_SDMMC2, PERIPH_ID_HDMI, PERIPH_ID_GMAC, + PERIPH_ID_SFC,
PERIPH_ID_COUNT,
diff --git a/drivers/clk/rockchip/Makefile b/drivers/clk/rockchip/Makefile index 8dc60f8..e404c0c 100644 --- a/drivers/clk/rockchip/Makefile +++ b/drivers/clk/rockchip/Makefile @@ -10,3 +10,4 @@ obj-$(CONFIG_ROCKCHIP_RK3288) += clk_rk3288.o obj-$(CONFIG_ROCKCHIP_RK3328) += clk_rk3328.o obj-$(CONFIG_ROCKCHIP_RK3368) += clk_rk3368.o obj-$(CONFIG_ROCKCHIP_RK3399) += clk_rk3399.o +obj-$(CONFIG_ROCKCHIP_RV1108) += clk_rv1108.o diff --git a/drivers/clk/rockchip/clk_rv1108.c b/drivers/clk/rockchip/clk_rv1108.c new file mode 100644 index 0000000..0946dab --- /dev/null +++ b/drivers/clk/rockchip/clk_rv1108.c @@ -0,0 +1,223 @@ +/* + * (C) Copyright 2016 Rockchip Electronics Co., Ltd + * Author: Andy Yan andy.yan@rock-chips.com + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm.h> +#include <errno.h> +#include <syscon.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/cru_rv1108.h> +#include <asm/arch/hardware.h> +#include <dm/lists.h> +#include <dt-bindings/clock/rv1108-cru.h> + +DECLARE_GLOBAL_DATA_PTR; + +enum { + VCO_MAX_HZ = 2400U * 1000000, + VCO_MIN_HZ = 600 * 1000000, + OUTPUT_MAX_HZ = 2400U * 1000000, + OUTPUT_MIN_HZ = 24 * 1000000, +}; + +#define RATE_TO_DIV(input_rate, output_rate) \ + ((input_rate) / (output_rate) - 1); + +#define DIV_TO_RATE(input_rate, div) ((input_rate) / ((div) + 1)) + +#define PLL_DIVISORS(hz, _refdiv, _postdiv1, _postdiv2) {\ + .refdiv = _refdiv,\ + .fbdiv = (u32)((u64)hz * _refdiv * _postdiv1 * _postdiv2 / OSC_HZ),\ + .postdiv1 = _postdiv1, .postdiv2 = _postdiv2};\ + _Static_assert(((u64)hz * _refdiv * _postdiv1 * _postdiv2 / OSC_HZ) *\ + OSC_HZ / (_refdiv * _postdiv1 * _postdiv2) == hz,\ + #hz "Hz cannot be hit with PLL "\ + "divisors on line " __stringify(__LINE__)); + +/* use interge mode*/ +static const struct pll_div apll_init_cfg = PLL_DIVISORS(APLL_HZ, 1, 3, 1); +static const struct pll_div gpll_init_cfg = PLL_DIVISORS(GPLL_HZ, 2, 2, 1); + +static inline int rv1108_pll_id(enum rk_clk_id clk_id) +{ + int id = 0; + + switch (clk_id) { + case CLK_ARM: + case CLK_DDR: + id = clk_id - 1; + break; + case CLK_GENERAL: + id = 2; + break; + default: + printf("invalid pll id:%d\n", clk_id); + id = -1; + break; + } + + return id; +} + +static uint32_t rkclk_pll_get_rate(struct rv1108_cru *cru, + enum rk_clk_id clk_id) +{ + uint32_t refdiv, fbdiv, postdiv1, postdiv2; + uint32_t con0, con1, con3; + int pll_id = rv1108_pll_id(clk_id); + struct rv1108_pll *pll = &cru->pll[pll_id]; + uint32_t freq; + + con3 = readl(&pll->con3); + + if (con3 & WORK_MODE_MASK) { + con0 = readl(&pll->con0); + con1 = readl(&pll->con1); + fbdiv = (con0 >> FBDIV_SHIFT) & FBDIV_MASK; + postdiv1 = (con1 & POSTDIV1_MASK) >> POSTDIV1_SHIFT; + postdiv2 = (con1 & POSTDIV2_MASK) >> POSTDIV2_SHIFT; + refdiv = (con1 & REFDIV_MASK) >> REFDIV_SHIFT; + freq = (24 * fbdiv / (refdiv * postdiv1 * postdiv2)) * 1000000; + } else { + freq = OSC_HZ; + } + + return freq; +} + +static int rv1108_mac_set_clk(struct rv1108_cru *cru, ulong rate) +{ + uint32_t con = readl(&cru->clksel_con[24]); + ulong pll_rate; + uint8_t div; + + if ((con >> MAC_PLL_SEL_SHIFT) & MAC_PLL_SEL_GPLL) + pll_rate = rkclk_pll_get_rate(cru, CLK_GENERAL); + else + pll_rate = rkclk_pll_get_rate(cru, CLK_ARM); + + /*default set 50MHZ for gmac*/ + if (!rate) + rate = 50000000; + + div = DIV_ROUND_UP(pll_rate, rate) - 1; + if (div <= 0x1f) + rk_clrsetreg(&cru->clksel_con[24], MAC_CLK_DIV_MASK, + div << MAC_CLK_DIV_SHIFT); + else + debug("Unsupported div for gmac:%d\n", div); + + return DIV_TO_RATE(pll_rate, div); +} + +static int rv1108_sfc_set_clk(struct rv1108_cru *cru, uint rate) +{ + u32 con = readl(&cru->clksel_con[27]); + u32 pll_rate; + u32 div; + + if ((con >> SFC_PLL_SEL_SHIFT) && SFC_PLL_SEL_GPLL) + pll_rate = rkclk_pll_get_rate(cru, CLK_GENERAL); + else + pll_rate = rkclk_pll_get_rate(cru, CLK_DDR); + + div = DIV_ROUND_UP(pll_rate, rate) - 1; + if (div <= 0x3f) + rk_clrsetreg(&cru->clksel_con[27], SFC_CLK_DIV_MASK, + div << SFC_CLK_DIV_SHIFT); + else + debug("Unsupported sfc clk rate:%d\n", rate); + + return DIV_TO_RATE(pll_rate, div); +} + +static ulong rv1108_clk_get_rate(struct clk *clk) +{ + struct rv1108_clk_priv *priv = dev_get_priv(clk->dev); + + switch (clk->id) { + case 0 ... 63: + return rkclk_pll_get_rate(priv->cru, clk->id); + default: + return -ENOENT; + } +} + +static ulong rv1108_clk_set_rate(struct clk *clk, ulong rate) +{ + struct rv1108_clk_priv *priv = dev_get_priv(clk->dev); + ulong new_rate; + + switch (clk->id) { + case SCLK_MAC: + new_rate = rv1108_mac_set_clk(priv->cru, rate); + break; + case SCLK_SFC: + new_rate = rv1108_sfc_set_clk(priv->cru, rate); + break; + default: + return -ENOENT; + } + + return new_rate; +} + +static const struct clk_ops rv1108_clk_ops = { + .get_rate = rv1108_clk_get_rate, + .set_rate = rv1108_clk_set_rate, +}; + +static void rkclk_init(struct rv1108_cru *cru) +{ + unsigned int apll = rkclk_pll_get_rate(cru, CLK_ARM); + unsigned int dpll = rkclk_pll_get_rate(cru, CLK_DDR); + unsigned int gpll = rkclk_pll_get_rate(cru, CLK_GENERAL); + + rk_clrsetreg(&cru->clksel_con[0], CORE_CLK_DIV_MASK, + 0 << MAC_CLK_DIV_SHIFT); + + printf("APLL: %d DPLL:%d GPLL:%d\n", apll, dpll, gpll); +} + +static int rv1108_clk_probe(struct udevice *dev) +{ + struct rv1108_clk_priv *priv = dev_get_priv(dev); + + priv->cru = (struct rv1108_cru *)dev_get_addr(dev); + + rkclk_init(priv->cru); + + return 0; +} + +static int rv1108_clk_bind(struct udevice *dev) +{ + int ret; + + /* The reset driver does not have a device node, so bind it here */ + ret = device_bind_driver(gd->dm_root, "rv1108_sysreset", "reset", &dev); + if (ret) + error("No Rv1108 reset driver: ret=%d\n", ret); + + return 0; +} + +static const struct udevice_id rv1108_clk_ids[] = { + { .compatible = "rockchip,rv1108-cru" }, + { } +}; + +U_BOOT_DRIVER(clk_rv1108) = { + .name = "clk_rv1108", + .id = UCLASS_CLK, + .of_match = rv1108_clk_ids, + .priv_auto_alloc_size = sizeof(struct rv1108_clk_priv), + .ops = &rv1108_clk_ops, + .bind = rv1108_clk_bind, + .probe = rv1108_clk_probe, +}; diff --git a/include/dt-bindings/clock/rv1108-cru.h b/include/dt-bindings/clock/rv1108-cru.h new file mode 100644 index 0000000..d2ad3bb --- /dev/null +++ b/include/dt-bindings/clock/rv1108-cru.h @@ -0,0 +1,269 @@ +/* + * Copyright (c) 2017 Rockchip Electronics Co. Ltd. + * Author: Shawn Lin shawn.lin@rock-chips.com + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RV1108_H +#define _DT_BINDINGS_CLK_ROCKCHIP_RV1108_H + +/* pll id */ +#define PLL_APLL 0 +#define PLL_DPLL 1 +#define PLL_GPLL 2 +#define ARMCLK 3 + +/* sclk gates (special clocks) */ +#define SCLK_MAC 64 +#define SCLK_SPI0 65 +#define SCLK_NANDC 67 +#define SCLK_SDMMC 68 +#define SCLK_SDIO 69 +#define SCLK_EMMC 71 +#define SCLK_UART0 72 +#define SCLK_UART1 73 +#define SCLK_UART2 74 +#define SCLK_I2S0 75 +#define SCLK_I2S1 76 +#define SCLK_I2S2 77 +#define SCLK_TIMER0 78 +#define SCLK_TIMER1 79 +#define SCLK_SFC 80 +#define SCLK_SDMMC_DRV 81 +#define SCLK_SDIO_DRV 82 +#define SCLK_EMMC_DRV 83 +#define SCLK_SDMMC_SAMPLE 84 +#define SCLK_SDIO_SAMPLE 85 +#define SCLK_EMMC_SAMPLE 86 +#define SCLK_MAC_RX 87 +#define SCLK_MAC_TX 88 +#define SCLK_MACREF 89 +#define SCLK_MACREF_OUT 90 + + +/* aclk gates */ +#define ACLK_DMAC 192 +#define ACLK_PRE 193 +#define ACLK_CORE 194 +#define ACLK_ENMCORE 195 +#define ACLK_GMAC 196 + + +/* pclk gates */ +#define PCLK_GPIO1 256 +#define PCLK_GPIO2 257 +#define PCLK_GPIO3 258 +#define PCLK_GRF 259 +#define PCLK_I2C1 260 +#define PCLK_I2C2 261 +#define PCLK_I2C3 262 +#define PCLK_SPI 263 +#define PCLK_SFC 264 +#define PCLK_UART0 265 +#define PCLK_UART1 266 +#define PCLK_UART2 267 +#define PCLK_TSADC 268 +#define PCLK_PWM 269 +#define PCLK_TIMER 270 +#define PCLK_PERI 271 +#define PCLK_GMAC 272 + +/* hclk gates */ +#define HCLK_I2S0_8CH 320 +#define HCLK_I2S1_8CH 321 +#define HCLK_I2S2_2CH 322 +#define HCLK_NANDC 323 +#define HCLK_SDMMC 324 +#define HCLK_SDIO 325 +#define HCLK_EMMC 326 +#define HCLK_PERI 327 +#define HCLK_SFC 328 + +#define CLK_NR_CLKS (HCLK_SFC + 1) + +/* reset id */ +#define SRST_CORE_PO_AD 0 +#define SRST_CORE_AD 1 +#define SRST_L2_AD 2 +#define SRST_CPU_NIU_AD 3 +#define SRST_CORE_PO 4 +#define SRST_CORE 5 +#define SRST_L2 6 +#define SRST_CORE_DBG 8 +#define PRST_DBG 9 +#define RST_DAP 10 +#define PRST_DBG_NIU 11 +#define ARST_STRC_SYS_AD 15 + +#define SRST_DDRPHY_CLKDIV 16 +#define SRST_DDRPHY 17 +#define PRST_DDRPHY 18 +#define PRST_HDMIPHY 19 +#define PRST_VDACPHY 20 +#define PRST_VADCPHY 21 +#define PRST_MIPI_CSI_PHY 22 +#define PRST_MIPI_DSI_PHY 23 +#define PRST_ACODEC 24 +#define ARST_BUS_NIU 25 +#define PRST_TOP_NIU 26 +#define ARST_INTMEM 27 +#define HRST_ROM 28 +#define ARST_DMAC 29 +#define SRST_MSCH_NIU 30 +#define PRST_MSCH_NIU 31 + +#define PRST_DDRUPCTL 32 +#define NRST_DDRUPCTL 33 +#define PRST_DDRMON 34 +#define HRST_I2S0_8CH 35 +#define MRST_I2S0_8CH 36 +#define HRST_I2S1_2CH 37 +#define MRST_IS21_2CH 38 +#define HRST_I2S2_2CH 39 +#define MRST_I2S2_2CH 40 +#define HRST_CRYPTO 41 +#define SRST_CRYPTO 42 +#define PRST_SPI 43 +#define SRST_SPI 44 +#define PRST_UART0 45 +#define PRST_UART1 46 +#define PRST_UART2 47 + +#define SRST_UART0 48 +#define SRST_UART1 49 +#define SRST_UART2 50 +#define PRST_I2C1 51 +#define PRST_I2C2 52 +#define PRST_I2C3 53 +#define SRST_I2C1 54 +#define SRST_I2C2 55 +#define SRST_I2C3 56 +#define PRST_PWM1 58 +#define SRST_PWM1 60 +#define PRST_WDT 61 +#define PRST_GPIO1 62 +#define PRST_GPIO2 63 + +#define PRST_GPIO3 64 +#define PRST_GRF 65 +#define PRST_EFUSE 66 +#define PRST_EFUSE512 67 +#define PRST_TIMER0 68 +#define SRST_TIMER0 69 +#define SRST_TIMER1 70 +#define PRST_TSADC 71 +#define SRST_TSADC 72 +#define PRST_SARADC 73 +#define SRST_SARADC 74 +#define HRST_SYSBUS 75 +#define PRST_USBGRF 76 + +#define ARST_PERIPH_NIU 80 +#define HRST_PERIPH_NIU 81 +#define PRST_PERIPH_NIU 82 +#define HRST_PERIPH 83 +#define HRST_SDMMC 84 +#define HRST_SDIO 85 +#define HRST_EMMC 86 +#define HRST_NANDC 87 +#define NRST_NANDC 88 +#define HRST_SFC 89 +#define SRST_SFC 90 +#define ARST_GMAC 91 +#define HRST_OTG 92 +#define SRST_OTG 93 +#define SRST_OTG_ADP 94 +#define HRST_HOST0 95 + +#define HRST_HOST0_AUX 96 +#define HRST_HOST0_ARB 97 +#define SRST_HOST0_EHCIPHY 98 +#define SRST_HOST0_UTMI 99 +#define SRST_USBPOR 100 +#define SRST_UTMI0 101 +#define SRST_UTMI1 102 + +#define ARST_VIO0_NIU 102 +#define ARST_VIO1_NIU 103 +#define HRST_VIO_NIU 104 +#define PRST_VIO_NIU 105 +#define ARST_VOP 106 +#define HRST_VOP 107 +#define DRST_VOP 108 +#define ARST_IEP 109 +#define HRST_IEP 110 +#define ARST_RGA 111 +#define HRST_RGA 112 +#define SRST_RGA 113 +#define PRST_CVBS 114 +#define PRST_HDMI 115 +#define SRST_HDMI 116 +#define PRST_MIPI_DSI 117 + +#define ARST_ISP_NIU 118 +#define HRST_ISP_NIU 119 +#define HRST_ISP 120 +#define SRST_ISP 121 +#define ARST_VIP0 122 +#define HRST_VIP0 123 +#define PRST_VIP0 124 +#define ARST_VIP1 125 +#define HRST_VIP1 126 +#define PRST_VIP1 127 +#define ARST_VIP2 128 +#define HRST_VIP2 129 +#define PRST_VIP2 120 +#define ARST_VIP3 121 +#define HRST_VIP3 122 +#define PRST_VIP4 123 + +#define PRST_CIF1TO4 124 +#define SRST_CVBS_CLK 125 +#define HRST_CVBS 126 + +#define ARST_VPU_NIU 140 +#define HRST_VPU_NIU 141 +#define ARST_VPU 142 +#define HRST_VPU 143 +#define ARST_RKVDEC_NIU 144 +#define HRST_RKVDEC_NIU 145 +#define ARST_RKVDEC 146 +#define HRST_RKVDEC 147 +#define SRST_RKVDEC_CABAC 148 +#define SRST_RKVDEC_CORE 149 +#define ARST_RKVENC_NIU 150 +#define HRST_RKVENC_NIU 151 +#define ARST_RKVENC 152 +#define HRST_RKVENC 153 +#define SRST_RKVENC_CORE 154 + +#define SRST_DSP_CORE 156 +#define SRST_DSP_SYS 157 +#define SRST_DSP_GLOBAL 158 +#define SRST_DSP_OECM 159 +#define PRST_DSP_IOP_NIU 160 +#define ARST_DSP_EPP_NIU 161 +#define ARST_DSP_EDP_NIU 162 +#define PRST_DSP_DBG_NIU 163 +#define PRST_DSP_CFG_NIU 164 +#define PRST_DSP_GRF 165 +#define PRST_DSP_MAILBOX 166 +#define PRST_DSP_INTC 167 +#define PRST_DSP_PFM_MON 169 +#define SRST_DSP_PFM_MON 170 +#define ARST_DSP_EDAP_NIU 171 + +#define SRST_PMU 172 +#define SRST_PMU_I2C0 173 +#define PRST_PMU_I2C0 174 +#define PRST_PMU_GPIO0 175 +#define PRST_PMU_INTMEM 176 +#define PRST_PMU_PWM0 177 +#define SRST_PMU_PWM0 178 +#define PRST_PMU_GRF 179 +#define SRST_PMU_NIU 180 +#define SRST_PMU_PVTM 181 +#define ARST_DSP_EDP_PERF 184 +#define ARST_DSP_EPP_PERF 185 + +#endif /* _DT_BINDINGS_CLK_ROCKCHIP_RV1108_H */
arch/arm/mach-rockchip/Kconfig | 8 +++++ arch/arm/mach-rockchip/Makefile | 1 + arch/arm/mach-rockchip/rv1108/Kconfig | 9 ++++++ arch/arm/mach-rockchip/rv1108/Makefile | 11 +++++++ arch/arm/mach-rockchip/rv1108/clk_rv1108.c | 32 +++++++++++++++++++ arch/arm/mach-rockchip/rv1108/rv1108.c | 15 +++++++++ arch/arm/mach-rockchip/rv1108/syscon_rv1108.c | 21 ++++++++++++ drivers/sysreset/Makefile | 1 + drivers/sysreset/sysreset_rv1108.c | 46 +++++++++++++++++++++++++++ include/configs/rv1108_common.h | 33 +++++++++++++++++++ 10 files changed, 177 insertions(+) create mode 100644 arch/arm/mach-rockchip/rv1108/Kconfig create mode 100644 arch/arm/mach-rockchip/rv1108/Makefile create mode 100644 arch/arm/mach-rockchip/rv1108/clk_rv1108.c create mode 100644 arch/arm/mach-rockchip/rv1108/rv1108.c create mode 100644 arch/arm/mach-rockchip/rv1108/syscon_rv1108.c create mode 100644 drivers/sysreset/sysreset_rv1108.c create mode 100644 include/configs/rv1108_common.h
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index a8d745a..9b2ef29 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -79,6 +79,13 @@ config ROCKCHIP_RK3399 and video codec support. Peripherals include Gigabit Ethernet, USB2 host and OTG, SDIO, I2S, UARTs, SPI, I2C and PWMs.
+config ROCKCHIP_RV1108 + bool "Support Rockchip RV1108" + select CPU_V7 + help + The Rockchip RV1108 is a ARM-based SoC with a single-core Cortex-A7 + and a DSP. + config ROCKCHIP_SPL_BACK_TO_BROM bool "SPL returns to bootrom" default y if ROCKCHIP_RK3036 @@ -108,4 +115,5 @@ source "arch/arm/mach-rockchip/rk3288/Kconfig" source "arch/arm/mach-rockchip/rk3328/Kconfig" source "arch/arm/mach-rockchip/rk3368/Kconfig" source "arch/arm/mach-rockchip/rk3399/Kconfig" +source "arch/arm/mach-rockchip/rv1108/Kconfig" endif diff --git a/arch/arm/mach-rockchip/Makefile b/arch/arm/mach-rockchip/Makefile index 5ed19c9..87d2019 100644 --- a/arch/arm/mach-rockchip/Makefile +++ b/arch/arm/mach-rockchip/Makefile @@ -33,3 +33,4 @@ obj-$(CONFIG_ROCKCHIP_RK3288) += rk3288/ obj-$(CONFIG_ROCKCHIP_RK3328) += rk3328/ obj-$(CONFIG_ROCKCHIP_RK3368) += rk3368/ obj-$(CONFIG_ROCKCHIP_RK3399) += rk3399/ +obj-$(CONFIG_ROCKCHIP_RV1108) += rv1108/ diff --git a/arch/arm/mach-rockchip/rv1108/Kconfig b/arch/arm/mach-rockchip/rv1108/Kconfig new file mode 100644 index 0000000..40237bb --- /dev/null +++ b/arch/arm/mach-rockchip/rv1108/Kconfig @@ -0,0 +1,9 @@ +if ROCKCHIP_RV1108 + +config SYS_SOC + default "rockchip" + +config SYS_MALLOC_F_LEN + default 0x400 + +endif diff --git a/arch/arm/mach-rockchip/rv1108/Makefile b/arch/arm/mach-rockchip/rv1108/Makefile new file mode 100644 index 0000000..9035a1a --- /dev/null +++ b/arch/arm/mach-rockchip/rv1108/Makefile @@ -0,0 +1,11 @@ +# +# (C) Copyright 2016 Rockchip Electronics Co., Ltd +# +# SPDX-License-Identifier: GPL-2.0+ +# + +ifndef CONFIG_SPL_BUILD +obj-y += syscon_rv1108.o +endif +obj-y += rv1108.o +obj-y += clk_rv1108.o diff --git a/arch/arm/mach-rockchip/rv1108/clk_rv1108.c b/arch/arm/mach-rockchip/rv1108/clk_rv1108.c new file mode 100644 index 0000000..968c356 --- /dev/null +++ b/arch/arm/mach-rockchip/rv1108/clk_rv1108.c @@ -0,0 +1,32 @@ +/* + * (C) Copyright 2016 Rockchip Electronics Co., Ltd + * Author: Andy Yan andy.yan@rock-chips.com + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <dm.h> +#include <syscon.h> +#include <asm/arch/clock.h> +#include <asm/arch/cru_rv1108.h> + +int rockchip_get_clk(struct udevice **devp) +{ + return uclass_get_device_by_driver(UCLASS_CLK, + DM_GET_DRIVER(clk_rv1108), devp); +} + +void *rockchip_get_cru(void) +{ + struct rv1108_clk_priv *priv; + struct udevice *dev; + int ret; + + ret = rockchip_get_clk(&dev); + if (ret) + return ERR_PTR(ret); + + priv = dev_get_priv(dev); + + return priv->cru; +} diff --git a/arch/arm/mach-rockchip/rv1108/rv1108.c b/arch/arm/mach-rockchip/rv1108/rv1108.c new file mode 100644 index 0000000..868cdd5 --- /dev/null +++ b/arch/arm/mach-rockchip/rv1108/rv1108.c @@ -0,0 +1,15 @@ +/* + * (C) Copyright 2016 Rockchip Electronics Co., Ltd + * Author: Andy Yan andy.yan@rock-chips.com + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> + +#ifndef CONFIG_SYS_DCACHE_OFF +void enable_caches(void) +{ + /* Enable D-cache. I-cache is already enabled in start.S */ + dcache_enable(); +} +#endif diff --git a/arch/arm/mach-rockchip/rv1108/syscon_rv1108.c b/arch/arm/mach-rockchip/rv1108/syscon_rv1108.c new file mode 100644 index 0000000..8bb0ab8 --- /dev/null +++ b/arch/arm/mach-rockchip/rv1108/syscon_rv1108.c @@ -0,0 +1,21 @@ +/* + * (C) Copyright 2016 Rockchip Electronics Co., Ltd + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <syscon.h> +#include <asm/arch/clock.h> + +static const struct udevice_id rv1108_syscon_ids[] = { + { .compatible = "rockchip,rv1108-grf", .data = ROCKCHIP_SYSCON_GRF }, + { } +}; + +U_BOOT_DRIVER(syscon_rv1108) = { + .name = "rv1108_syscon", + .id = UCLASS_SYSCON, + .of_match = rv1108_syscon_ids, +}; diff --git a/drivers/sysreset/Makefile b/drivers/sysreset/Makefile index 1944f31..38287f5 100644 --- a/drivers/sysreset/Makefile +++ b/drivers/sysreset/Makefile @@ -16,6 +16,7 @@ obj-$(CONFIG_ROCKCHIP_RK3288) += sysreset_rk3288.o obj-$(CONFIG_ROCKCHIP_RK3328) += sysreset_rk3328.o obj-$(CONFIG_ROCKCHIP_RK3368) += sysreset_rk3368.o obj-$(CONFIG_ROCKCHIP_RK3399) += sysreset_rk3399.o +obj-$(CONFIG_ROCKCHIP_RV1108) += sysreset_rv1108.o obj-$(CONFIG_SANDBOX) += sysreset_sandbox.o obj-$(CONFIG_ARCH_SNAPDRAGON) += sysreset_snapdragon.o obj-$(CONFIG_ARCH_STI) += sysreset_sti.o diff --git a/drivers/sysreset/sysreset_rv1108.c b/drivers/sysreset/sysreset_rv1108.c new file mode 100644 index 0000000..9d8e9f7 --- /dev/null +++ b/drivers/sysreset/sysreset_rv1108.c @@ -0,0 +1,46 @@ +/* + * (C) Copyright 2015 Rockchip Electronics Co., Ltd + * Author: Andy Yan andy.yan@rock-chips.com + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <sysreset.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/cru_rv1108.h> +#include <asm/arch/hardware.h> +#include <linux/err.h> + +int rv1108_sysreset_request(struct udevice *dev, enum sysreset_t type) +{ + struct rv1108_cru *cru = rockchip_get_cru(); + + if (IS_ERR(cru)) + return PTR_ERR(cru); + + switch (type) { + case SYSRESET_WARM: + writel(0xeca8, &cru->glb_srst_snd_val); + break; + case SYSRESET_COLD: + writel(0xfdb9, &cru->glb_srst_fst_val); + break; + default: + return -EPROTONOSUPPORT; + } + + return -EINPROGRESS; +} + +static struct sysreset_ops rv1108_sysreset = { + .request = rv1108_sysreset_request, +}; + +U_BOOT_DRIVER(sysreset_rv1108) = { + .name = "rv1108_sysreset", + .id = UCLASS_SYSRESET, + .ops = &rv1108_sysreset, +}; diff --git a/include/configs/rv1108_common.h b/include/configs/rv1108_common.h new file mode 100644 index 0000000..52750cb --- /dev/null +++ b/include/configs/rv1108_common.h @@ -0,0 +1,33 @@ +/* + * (C) Copyright 2016 Rockchip Electronics Co., Ltd + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#ifndef __CONFIG_RV1108_COMMON_H +#define __CONFIG_RV1108_COMMON_H + +#include <asm/arch/hardware.h> +#include "rockchip-common.h" + +#define CONFIG_ENV_IS_NOWHERE +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_MALLOC_LEN (32 << 20) +#define CONFIG_SYS_CBSIZE 1024 +#define CONFIG_SKIP_LOWLEVEL_INIT + +#define CONFIG_SYS_TIMER_RATE (24 * 1000 * 1000) +/* TIMER1,initialized by ddr initialize code */ +#define CONFIG_SYS_TIMER_BASE 0x10350020 +#define CONFIG_SYS_TIMER_COUNTER (CONFIG_SYS_TIMER_BASE + 8) + +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_MEM32 + +#define CONFIG_SYS_SDRAM_BASE 0x60000000 +#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_SYS_TEXT_BASE CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_TEXT_BASE + 0x100000) +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x2000000) + +#endif
Add basic support for rv1108 evb, whith this patch we can boot into u-boot console.
arch/arm/dts/Makefile | 3 +- arch/arm/dts/rv1108-evb.dts | 54 ++++ arch/arm/dts/rv1108.dtsi | 479 +++++++++++++++++++++++++++++++++ arch/arm/mach-rockchip/rv1108/Kconfig | 19 ++ board/rockchip/evb_rv1108/Kconfig | 15 ++ board/rockchip/evb_rv1108/MAINTAINERS | 6 + board/rockchip/evb_rv1108/Makefile | 7 + board/rockchip/evb_rv1108/README | 47 ++++ board/rockchip/evb_rv1108/evb_rv1108.c | 52 ++++ configs/evb-rv1108_defconfig | 40 +++ include/configs/evb_rv1108.h | 26 ++ 11 files changed, 747 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/rv1108-evb.dts create mode 100644 arch/arm/dts/rv1108.dtsi create mode 100644 board/rockchip/evb_rv1108/Kconfig create mode 100644 board/rockchip/evb_rv1108/MAINTAINERS create mode 100644 board/rockchip/evb_rv1108/Makefile create mode 100644 board/rockchip/evb_rv1108/README create mode 100644 board/rockchip/evb_rv1108/evb_rv1108.c create mode 100644 configs/evb-rv1108_defconfig create mode 100644 include/configs/evb_rv1108.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 4621c6f..a777384 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -46,7 +46,8 @@ dtb-$(CONFIG_ARCH_ROCKCHIP) += \ rk3368-px5-evb.dtb \ rk3399-evb.dtb \ rk3399-firefly.dtb \ - rk3399-puma.dtb + rk3399-puma.dtb \ + rv1108-evb.dtb dtb-$(CONFIG_ARCH_MESON) += \ meson-gxbb-odroidc2.dtb dtb-$(CONFIG_TEGRA) += tegra20-harmony.dtb \ diff --git a/arch/arm/dts/rv1108-evb.dts b/arch/arm/dts/rv1108-evb.dts new file mode 100644 index 0000000..0128dd8 --- /dev/null +++ b/arch/arm/dts/rv1108-evb.dts @@ -0,0 +1,54 @@ +/* + * (C) Copyright 2016 Rockchip Electronics Co., Ltd + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; + +#include "rv1108.dtsi" + +/ { + model = "Rockchip RV1108 Evaluation board"; + compatible = "rockchip,rv1108-evb", "rockchip,rv1108"; + + memory@60000000 { + device_type = "memory"; + reg = <0x60000000 0x08000000>; + }; + + chosen { + stdout-path = "serial2:1500000n8"; + }; +}; + +&gmac { + status = "okay"; + clock_in_out = <0>; + snps,reset-active-low; + snps,reset-delays-us = <0 10000 1000000>; + snps,reset-gpio = <&gpio1 RK_PC1 GPIO_ACTIVE_LOW>; +}; + +&sfc { + status = "okay"; + flash@0 { + compatible = "gd25q256","spi-flash"; + reg = <0>; + spi-tx-bus-width = <1>; + spi-rx-bus-width = <1>; + spi-max-frequency = <96000000>; + }; +}; + +&uart0 { + status = "okay"; +}; + +&uart1 { + status = "okay"; +}; + +&uart2 { + status = "okay"; +}; diff --git a/arch/arm/dts/rv1108.dtsi b/arch/arm/dts/rv1108.dtsi new file mode 100644 index 0000000..77ca24e --- /dev/null +++ b/arch/arm/dts/rv1108.dtsi @@ -0,0 +1,479 @@ +/* + * (C) Copyright 2016 Rockchip Electronics Co., Ltd + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/clock/rv1108-cru.h> +#include <dt-bindings/pinctrl/rockchip.h> +/ { + #address-cells = <1>; + #size-cells = <1>; + + compatible = "rockchip,rv1108"; + + interrupt-parent = <&gic>; + + aliases { + serial0 = &uart0; + serial1 = &uart1; + serial2 = &uart2; + spi0 = &sfc; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu0: cpu@f00 { + device_type = "cpu"; + compatible = "arm,cortex-a7"; + reg = <0xf00>; + }; + }; + + arm-pmu { + compatible = "arm,cortex-a7-pmu"; + interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>; + }; + + timer { + compatible = "arm,armv7-timer"; + interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(1) | IRQ_TYPE_LEVEL_HIGH)>, + <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(1) | IRQ_TYPE_LEVEL_HIGH)>; + clock-frequency = <24000000>; + }; + + xin24m: oscillator { + compatible = "fixed-clock"; + clock-frequency = <24000000>; + clock-output-names = "xin24m"; + #clock-cells = <0>; + }; + + amba { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + pdma: pdma@102a0000 { + compatible = "arm,pl330", "arm,primecell"; + reg = <0x102a0000 0x4000>; + interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>; + #dma-cells = <1>; + arm,pl330-broken-no-flushp; + clocks = <&cru ACLK_DMAC>; + clock-names = "apb_pclk"; + }; + }; + + bus_intmem@10080000 { + compatible = "mmio-sram"; + reg = <0x10080000 0x2000>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x10080000 0x2000>; + }; + + uart2: serial@10210000 { + compatible = "rockchip,rv1108-uart", "snps,dw-apb-uart"; + reg = <0x10210000 0x100>; + interrupts = <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + clock-frequency = <24000000>; + clocks = <&cru SCLK_UART2>, <&cru PCLK_UART2>; + clock-names = "baudclk", "apb_pclk"; + pinctrl-names = "default"; + pinctrl-0 = <&uart2m0_xfer>; + status = "disabled"; + }; + + uart1: serial@10220000 { + compatible = "rockchip,rv1108-uart", "snps,dw-apb-uart"; + reg = <0x10220000 0x100>; + interrupts = <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + clock-frequency = <24000000>; + clocks = <&cru SCLK_UART1>, <&cru PCLK_UART1>; + clock-names = "baudclk", "apb_pclk"; + pinctrl-names = "default"; + pinctrl-0 = <&uart1_xfer>; + status = "disabled"; + }; + + uart0: serial@10230000 { + compatible = "rockchip,rv1108-uart", "snps,dw-apb-uart"; + reg = <0x10230000 0x100>; + interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + clock-frequency = <24000000>; + clocks = <&cru SCLK_UART0>, <&cru PCLK_UART0>; + clock-names = "baudclk", "apb_pclk"; + pinctrl-names = "default"; + pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>; + status = "disabled"; + }; + + grf: syscon@10300000 { + compatible = "rockchip,rv1108-grf", "syscon"; + reg = <0x10300000 0x1000>; + }; + + pmugrf: syscon@20060000 { + compatible = "rockchip,rv1108-pmugrf", "syscon"; + reg = <0x20060000 0x1000>; + }; + + cru: clock-controller@20200000 { + compatible = "rockchip,rv1108-cru"; + reg = <0x20200000 0x1000>; + rockchip,grf = <&grf>; + #clock-cells = <1>; + #reset-cells = <1>; + }; + + emmc: dwmmc@30110000 { + compatible = "rockchip,rv1108-dw-mshc", "rockchip,rk3288-dw-mshc"; + clock-freq-min-max = <400000 150000000>; + clocks = <&cru HCLK_EMMC>, <&cru SCLK_EMMC>, + <&cru SCLK_EMMC_DRV>, <&cru SCLK_EMMC_SAMPLE>; + clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; + fifo-depth = <0x100>; + interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x30110000 0x4000>; + status = "disabled"; + }; + + sdio: dwmmc@30120000 { + compatible = "rockchip,rv1108-dw-mshc", "rockchip,rk3288-dw-mshc"; + clock-freq-min-max = <400000 150000000>; + clocks = <&cru HCLK_SDIO>, <&cru SCLK_SDIO>, + <&cru SCLK_SDIO_DRV>, <&cru SCLK_SDIO_SAMPLE>; + clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; + fifo-depth = <0x100>; + interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x30120000 0x4000>; + status = "disabled"; + }; + + sdmmc: dwmmc@30130000 { + compatible = "rockchip,rv1108-dw-mshc", "rockchip,rk3288-dw-mshc"; + clock-freq-min-max = <400000 100000000>; + clocks = <&cru HCLK_SDMMC>, <&cru SCLK_SDMMC>, + <&cru SCLK_SDMMC_DRV>, <&cru SCLK_SDMMC_SAMPLE>; + clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; + fifo-depth = <0x100>; + interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x30130000 0x4000>; + status = "disabled"; + }; + + sfc: sfc@301c0000 { + compatible = "rockchip,sfc"; + reg = <0x301c0000 0x200>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru SCLK_SFC>, <&cru HCLK_SFC>; + clock-names = "clk_sfc", "hclk_sfc"; + pinctrl-0 = <&sfc_pins>; + pinctrl-names = "default"; + status = "disabled"; + }; + + gmac: ethernet@30200000 { + compatible = "rockchip,rv1108-gmac"; + reg = <0x30200000 0x10000>; + interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "macirq"; + rockchip,grf = <&grf>; + clocks = <&cru SCLK_MAC>, + <&cru SCLK_MAC_RX>, <&cru SCLK_MAC_TX>, + <&cru SCLK_MACREF>, <&cru SCLK_MACREF_OUT>, + <&cru ACLK_GMAC>, <&cru PCLK_GMAC>; + clock-names = "stmmaceth", + "mac_clk_rx", "mac_clk_tx", + "clk_mac_ref", "clk_mac_refout", + "aclk_mac", "pclk_mac"; + pinctrl-names = "default"; + pinctrl-0 = <&rmii_pins>; + phy-mode = "rmii"; + max-speed = <100>; + status = "disabled"; + }; + + gic: interrupt-controller@32010000 { + compatible = "arm,gic-400"; + interrupt-controller; + #interrupt-cells = <3>; + #address-cells = <0>; + + reg = <0x32011000 0x1000>, + <0x32012000 0x1000>, + <0x32014000 0x2000>, + <0x32016000 0x2000>; + interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(1) | IRQ_TYPE_LEVEL_HIGH)>; + }; + + pinctrl: pinctrl { + compatible = "rockchip,rv1108-pinctrl"; + rockchip,grf = <&grf>; + rockchip,pmu = <&pmugrf>; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + gpio0: gpio0@20030000 { + compatible = "rockchip,gpio-bank"; + reg = <0x20030000 0x100>; + interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&xin24m>; + + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio1: gpio1@10310000 { + compatible = "rockchip,gpio-bank"; + reg = <0x10310000 0x100>; + interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&xin24m>; + + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio2: gpio2@10320000 { + compatible = "rockchip,gpio-bank"; + reg = <0x10320000 0x100>; + interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&xin24m>; + + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio3: gpio3@10330000 { + compatible = "rockchip,gpio-bank"; + reg = <0x10330000 0x100>; + interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&xin24m>; + + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + pcfg_pull_up: pcfg-pull-up { + bias-pull-up; + }; + + pcfg_pull_down: pcfg-pull-down { + bias-pull-down; + }; + + pcfg_pull_none: pcfg-pull-none { + bias-disable; + }; + + pcfg_pull_none_drv_8ma: pcfg-pull-none-drv-8ma { + drive-strength = <8>; + }; + + pcfg_pull_none_drv_12ma: pcfg-pull-none-drv-12ma { + drive-strength = <12>; + }; + + pcfg_pull_up_drv_8ma: pcfg-pull-up-drv-8ma { + bias-pull-up; + drive-strength = <8>; + }; + + pcfg_pull_none_drv_4ma: pcfg-pull-none-drv-4ma { + drive-strength = <4>; + }; + + pcfg_pull_up_drv_4ma: pcfg-pull-up-drv-4ma { + bias-pull-up; + drive-strength = <4>; + }; + + pcfg_output_high: pcfg-output-high { + output-high; + }; + + pcfg_output_low: pcfg-output-low { + output-low; + }; + + pcfg_input_high: pcfg-input-high { + bias-pull-up; + input-enable; + }; + + gmac { + rmii_pins: rmii-pins { + rockchip,pins = <1 RK_PC5 RK_FUNC_2 &pcfg_pull_none>, + <1 RK_PC3 RK_FUNC_2 &pcfg_pull_none>, + <1 RK_PC4 RK_FUNC_2 &pcfg_pull_none>, + <1 RK_PB2 RK_FUNC_3 &pcfg_pull_none_drv_12ma>, + <1 RK_PB3 RK_FUNC_3 &pcfg_pull_none_drv_12ma>, + <1 RK_PB4 RK_FUNC_3 &pcfg_pull_none_drv_12ma>, + <1 RK_PB5 RK_FUNC_3 &pcfg_pull_none>, + <1 RK_PB6 RK_FUNC_3 &pcfg_pull_none>, + <1 RK_PB7 RK_FUNC_3 &pcfg_pull_none>, + <1 RK_PC2 RK_FUNC_3 &pcfg_pull_none>; + }; + }; + + i2c1 { + i2c1_xfer: i2c1-xfer { + rockchip,pins = <2 RK_PD3 RK_FUNC_1 &pcfg_pull_up>, + <2 RK_PD4 RK_FUNC_1 &pcfg_pull_up>; + }; + }; + + i2c2m1 { + i2c2m1_xfer: i2c2m1-xfer { + rockchip,pins = <0 RK_PC2 RK_FUNC_2 &pcfg_pull_none>, + <0 RK_PC6 RK_FUNC_3 &pcfg_pull_none>; + }; + + i2c2m1_gpio: i2c2m1-gpio { + rockchip,pins = <0 RK_PC2 RK_FUNC_GPIO &pcfg_pull_none>, + <0 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + i2c2m05v { + i2c2m05v_xfer: i2c2m05v-xfer { + rockchip,pins = <1 RK_PD5 RK_FUNC_2 &pcfg_pull_none>, + <1 RK_PD4 RK_FUNC_2 &pcfg_pull_none>; + }; + + i2c2m05v_gpio: i2c2m05v-gpio { + rockchip,pins = <1 RK_PD5 RK_FUNC_GPIO &pcfg_pull_none>, + <1 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + i2c3 { + i2c3_xfer: i2c3-xfer { + rockchip,pins = <0 RK_PB6 RK_FUNC_1 &pcfg_pull_none>, + <0 RK_PC4 RK_FUNC_2 &pcfg_pull_none>; + }; + }; + + sfc { + sfc_pins: sfc-pins { + rockchip,pins = <2 RK_PA3 RK_FUNC_3 &pcfg_pull_none>, + <2 RK_PA2 RK_FUNC_3 &pcfg_pull_none>, + <2 RK_PA1 RK_FUNC_3 &pcfg_pull_none>, + <2 RK_PA0 RK_FUNC_3 &pcfg_pull_none>, + <2 RK_PB7 RK_FUNC_2 &pcfg_pull_none>, + <2 RK_PB4 RK_FUNC_3 &pcfg_pull_none>; + }; + }; + + sdmmc { + sdmmc_clk: sdmmc-clk { + rockchip,pins = <3 RK_PC4 RK_FUNC_1 &pcfg_pull_none_drv_4ma>; + }; + + sdmmc_cmd: sdmmc-cmd { + rockchip,pins = <3 RK_PC5 RK_FUNC_1 &pcfg_pull_up_drv_4ma>; + }; + + sdmmc_cd: sdmmc-cd { + rockchip,pins = <0 RK_PA1 RK_FUNC_1 &pcfg_pull_up_drv_4ma>; + }; + + sdmmc_bus1: sdmmc-bus1 { + rockchip,pins = <3 RK_PC3 RK_FUNC_1 &pcfg_pull_up_drv_4ma>; + }; + + sdmmc_bus4: sdmmc-bus4 { + rockchip,pins = <3 RK_PC3 RK_FUNC_1 &pcfg_pull_up_drv_4ma>, + <3 RK_PC2 RK_FUNC_1 &pcfg_pull_up_drv_4ma>, + <3 RK_PC1 RK_FUNC_1 &pcfg_pull_up_drv_4ma>, + <3 RK_PC0 RK_FUNC_1 &pcfg_pull_up_drv_4ma>; + }; + }; + + uart0 { + uart0_xfer: uart0-xfer { + rockchip,pins = <3 RK_PA6 RK_FUNC_1 &pcfg_pull_up>, + <3 RK_PA5 RK_FUNC_1 &pcfg_pull_none>; + }; + + uart0_cts: uart0-cts { + rockchip,pins = <3 RK_PA4 RK_FUNC_1 &pcfg_pull_none>; + }; + + uart0_rts: uart0-rts { + rockchip,pins = <3 RK_PA3 RK_FUNC_1 &pcfg_pull_none>; + }; + + uart0_rts_gpio: uart0-rts-gpio { + rockchip,pins = <3 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + uart1 { + uart1_xfer: uart1-xfer { + rockchip,pins = <1 RK_PD3 RK_FUNC_1 &pcfg_pull_up>, + <1 RK_PD2 RK_FUNC_1 &pcfg_pull_none>; + }; + + uart1_cts: uart1-cts { + rockchip,pins = <1 RK_PD0 RK_FUNC_1 &pcfg_pull_none>; + }; + + uart01rts: uart1-rts { + rockchip,pins = <1 RK_PD1 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + uart2m0 { + uart2m0_xfer: uart2m0-xfer { + rockchip,pins = <2 RK_PD2 RK_FUNC_1 &pcfg_pull_up>, + <2 RK_PD1 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + uart2m1 { + uart2m1_xfer: uart2m1-xfer { + rockchip,pins = <3 RK_PC3 RK_FUNC_2 &pcfg_pull_up>, + <3 RK_PC2 RK_FUNC_2 &pcfg_pull_none>; + }; + }; + + uart2_5v { + uart2_5v_cts: uart2_5v-cts { + rockchip,pins = <1 RK_PD4 RK_FUNC_1 &pcfg_pull_none>; + }; + + uart2_5v_rts: uart2_5v-rts { + rockchip,pins = <1 RK_PD5 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + }; +}; diff --git a/arch/arm/mach-rockchip/rv1108/Kconfig b/arch/arm/mach-rockchip/rv1108/Kconfig index 40237bb..e6cba66 100644 --- a/arch/arm/mach-rockchip/rv1108/Kconfig +++ b/arch/arm/mach-rockchip/rv1108/Kconfig @@ -1,9 +1,28 @@ if ROCKCHIP_RV1108
+config TARGET_EVB_RV1108 + bool "EVB_RV1108" + help + RV1108 EVB is a evaluation board for Rockchp RV1108. + + Key features of the board include: + * one macro USB OTG port + * one USB HOST port + * one RS232 to USB port route to UART2 as debug port + * MIPI screen with resolution 720 x 1280 + * 128M DDR3 + * 64M SPI Nor Flash + * macro SD card interface + * HDMI output + * 10/100 Mbps Ethernet + * camera interface compatible with imx323 / ov2710 / ov4689 + config SYS_SOC default "rockchip"
config SYS_MALLOC_F_LEN default 0x400
+source board/rockchip/evb_rv1108/Kconfig + endif diff --git a/board/rockchip/evb_rv1108/Kconfig b/board/rockchip/evb_rv1108/Kconfig new file mode 100644 index 0000000..4a76e0b --- /dev/null +++ b/board/rockchip/evb_rv1108/Kconfig @@ -0,0 +1,15 @@ +if TARGET_EVB_RV1108 + +config SYS_BOARD + default "evb_rv1108" + +config SYS_VENDOR + default "rockchip" + +config SYS_CONFIG_NAME + default "evb_rv1108" + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + +endif diff --git a/board/rockchip/evb_rv1108/MAINTAINERS b/board/rockchip/evb_rv1108/MAINTAINERS new file mode 100644 index 0000000..94def32 --- /dev/null +++ b/board/rockchip/evb_rv1108/MAINTAINERS @@ -0,0 +1,6 @@ +EVB-RV1108 +M: Andy Yan andy.yan@rock-chips.com +S: Maintained +F: board/rockchip/evb_rv1108 +F: include/configs/evb_rv1108.h +F: configs/evb-rv1108_defconfig diff --git a/board/rockchip/evb_rv1108/Makefile b/board/rockchip/evb_rv1108/Makefile new file mode 100644 index 0000000..dd99054 --- /dev/null +++ b/board/rockchip/evb_rv1108/Makefile @@ -0,0 +1,7 @@ +# +# (C) Copyright 2016 Rockchip Electronics Co., Ltd +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += evb_rv1108.o diff --git a/board/rockchip/evb_rv1108/README b/board/rockchip/evb_rv1108/README new file mode 100644 index 0000000..5889596 --- /dev/null +++ b/board/rockchip/evb_rv1108/README @@ -0,0 +1,47 @@ +Here is the step-by-step to boot U-Boot on rv1108 evb. + +Get ddr init binary +============================================================================== + > git clone https://github.com/rockchip-linux/rkbin.git + > dd if=./rkbin/rv1x/rv1108ddr.bin of=ddr.bin bs=4 skip=1 + +Compile U-Boot +=========================== + > make CROSS_COMPILE=arm-linux-gnueabi- evb-rv1108_defconfig all + > ./tools/mkimage -n rv1108 -T rksd -d ddr.bin spl.bin + > cat spl.bin u-boot.bin > u-boot.img + +Flash the image by rkdeveloptool +================================ +rkdeveloptool can get from https://github.com/rockchip-linux/rkdeveloptool.git + +Power on(or reset with RESET KEY) with MASKROM KEY preesed, and then: + > rkdeveloptool db ./rkbin/rv1x/RV1108_usb_boot.bin + > rkdeveloptool wl 0x40 u-boot.img + > rkdeveloptool RD + +You should be able to get U-Boot log message from boot console: + +DDR Version V1.02 20170220 +In +400MHz +DDR3 +Bus Width=16 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=512MB +mach:2 +OUT + + +U-Boot 2017.05-00693-g3a5b171 (Jun 01 2017 - 17:37:53 +0800) + +Model: Rockchip RV1108 Evaluation board +DRAM: 128 MiB +APLL: 600000000 DPLL:792000000 GPLL:384000000 +MMC: +Using default environment + +In: serial@10210000 +Out: serial@10210000 +Err: serial@10210000 +Net: No ethernet found. +Hit any key to stop autoboot: 0 +=> diff --git a/board/rockchip/evb_rv1108/evb_rv1108.c b/board/rockchip/evb_rv1108/evb_rv1108.c new file mode 100644 index 0000000..fe37eac --- /dev/null +++ b/board/rockchip/evb_rv1108/evb_rv1108.c @@ -0,0 +1,52 @@ +/* + * (C)Copyright 2016 Rockchip Electronics Co., Ltd + * Authors: Andy Yan andy.yan@rock-chips.com + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <fdtdec.h> +#include <asm/arch/grf_rv1108.h> +#include <asm/arch/hardware.h> + +DECLARE_GLOBAL_DATA_PTR; + +int mach_cpu_init(void) +{ + int node; + struct rv1108_grf *grf; + + node = fdt_node_offset_by_compatible(gd->fdt_blob, -1, "rockchip,rv1108-grf"); + grf = (struct rv1108_grf *)fdtdec_get_addr(gd->fdt_blob, node, "reg"); + + /*evb board use UART2 m0 for debug*/ + rk_clrsetreg(&grf->gpio2d_iomux, + GPIO2D2_MASK | GPIO2D1_MASK, + GPIO2D2_UART2_SOUT_M0 << GPIO2D2_SHIFT | + GPIO2D1_UART2_SIN_M0 << GPIO2D1_SHIFT); + rk_clrreg(&grf->gpio3c_iomux, GPIO3C3_MASK | GPIO3C2_MASK); + + return 0; +} + + +int board_init(void) +{ + return 0; +} + +int dram_init(void) +{ + gd->ram_size = 0x8000000; + + return 0; +} + +int dram_init_banksize(void) +{ + gd->bd->bi_dram[0].start = 0x60000000; + gd->bd->bi_dram[0].size = 0x8000000; + + return 0; +} diff --git a/configs/evb-rv1108_defconfig b/configs/evb-rv1108_defconfig new file mode 100644 index 0000000..3fa1ae8 --- /dev/null +++ b/configs/evb-rv1108_defconfig @@ -0,0 +1,40 @@ +CONFIG_ARM=y +CONFIG_ARCH_ROCKCHIP=y +CONFIG_ROCKCHIP_RV1108=y +CONFIG_TARGET_EVB_RV1108=y +CONFIG_DEFAULT_DEVICE_TREE="rv1108-evb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_HUSH_PARSER=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_SF=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_REGMAP=y +CONFIG_SYSCON=y +CONFIG_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_ROCKCHIP_RV1108=y +CONFIG_RAM=y +CONFIG_BAUDRATE=1500000 +# CONFIG_SPL_SERIAL_PRESENT is not set +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_BASE=0x10210000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYSRESET=y +CONFIG_ERRNO_STR=y diff --git a/include/configs/evb_rv1108.h b/include/configs/evb_rv1108.h new file mode 100644 index 0000000..ff3531b --- /dev/null +++ b/include/configs/evb_rv1108.h @@ -0,0 +1,26 @@ +/* + * (C) Copyright 2016 Rockchip Electronics Co., Ltd + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <configs/rv1108_common.h> + +/* + * Default environment settings + */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "netdev=eth0\0" \ + "ipaddr=172.16.12.50\0" \ + "serverip=172.16.12.69\0" \ + "" +#define CONFIG_BOOTCOMMAND \ + "sf probe;" \ + "sf read 0x62000000 0x140800 0x500000;" \ + "dcache off;" \ + "go 0x62000000" + +#endif
Signed-off-by: Andy Yan andy.yan@rock-chips.com
Applied to u-boot-rockchip, thanks!
Andy Yan
Dr. Philipp Tomsich
sjg@google.com
