[U-Boot] [PATCH] ppc4xx: Sequoia: Add chip_config command
This patch removes the Sequoia "bootstrap" command and replaces it with the now common command "chip_config".
Please note that the patches with the dynamic PCI sync clock configuration have to be applied, before this one should go in. This is because Sequoia has 2 different bootstrap EEPROMs, and the old bootstrap command configured different values depending on the detected PCI async clock (33 vs. 66MHz). With the PCI sync clock patches, this is not necessary anymore. The PCI sync clock will be configured correctly on-the-fly now.
Signed-off-by: Stefan Roese sr@denx.de --- board/amcc/sequoia/Makefile | 4 +- board/amcc/sequoia/chip_config.c | 122 ++++++++++++++++++++ board/amcc/sequoia/cmd_sequoia.c | 231 -------------------------------------- include/configs/sequoia.h | 6 + 4 files changed, 131 insertions(+), 232 deletions(-) create mode 100644 board/amcc/sequoia/chip_config.c delete mode 100644 board/amcc/sequoia/cmd_sequoia.c
diff --git a/board/amcc/sequoia/Makefile b/board/amcc/sequoia/Makefile index a5d5010..8da3bd5 100644 --- a/board/amcc/sequoia/Makefile +++ b/board/amcc/sequoia/Makefile @@ -25,9 +25,11 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(BOARD).a
-COBJS = $(BOARD).o cmd_sequoia.o sdram.o +COBJS-y = $(BOARD).o sdram.o +COBJS-$(CONFIG_CMD_CHIP_CONFIG) += chip_config.o SOBJS = init.o
+COBJS := $(COBJS-y) SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) SOBJS := $(addprefix $(obj),$(SOBJS)) diff --git a/board/amcc/sequoia/chip_config.c b/board/amcc/sequoia/chip_config.c new file mode 100644 index 0000000..036de9f --- /dev/null +++ b/board/amcc/sequoia/chip_config.c @@ -0,0 +1,122 @@ +/* + * (C) Copyright 2009 + * Stefan Roese, DENX Software Engineering, sr@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ + +#include <common.h> +#include <asm/ppc4xx_config.h> + +struct ppc4xx_config ppc4xx_config_val[] = { + { + "333-133-nor", "NOR CPU: 333 PLB: 133 OPB: 66 EBC: 66", + { + 0x84, 0x70, 0xa2, 0xa6, 0x05, 0x57, 0xa0, 0x10, + 0x40, 0x08, 0x23, 0x50, 0x0d, 0x05, 0x00, 0x00 + } + }, + { + "333-166-nor", "NOR CPU: 333 PLB: 166 OPB: 83 EBC: 55", + { + 0xc7, 0x78, 0xf3, 0x4e, 0x05, 0xd7, 0xa0, 0x30, + 0x40, 0x08, 0x23, 0x50, 0x0d, 0x05, 0x00, 0x00 + } + }, + { + "333-166-nand", "NAND CPU: 333 PLB: 166 OPB: 83 EBC: 55", + { + 0xc7, 0x78, 0xf3, 0x4e, 0x05, 0xd7, 0xd0, 0x30, + 0xa0, 0x68, 0x23, 0x58, 0x0d, 0x05, 0x00, 0x00 + } + }, + { + "400-133-nor", "NOR CPU: 400 PLB: 133 OPB: 66 EBC: 66", + { + 0x86, 0x78, 0xc2, 0xc6, 0x05, 0x57, 0xa0, 0x30, + 0x40, 0x08, 0x23, 0x50, 0x0d, 0x05, 0x00, 0x00 + } + }, + { + "400-160-nor", "NOR CPU: 400 PLB: 160 OPB: 80 EBC: 53", + { + 0x86, 0x78, 0xc2, 0xa6, 0x05, 0xd7, 0xa0, 0x10, + 0x40, 0x08, 0x23, 0x50, 0x0d, 0x05, 0x00, 0x00 + } + }, + { + "416-166-nor", "NOR CPU: 416 PLB: 166 OPB: 83 EBC: 55", + { + 0xc6, 0x78, 0x52, 0xa6, 0x05, 0xd7, 0xa0, 0x10, + 0x40, 0x08, 0x23, 0x50, 0x0d, 0x05, 0x00, 0x00 + } + }, + { + "416-166-nand", "NAND CPU: 416 PLB: 166 OPB: 83 EBC: 55", + { + 0xc6, 0x78, 0x52, 0xa6, 0x05, 0xd7, 0xd0, 0x10, + 0xa0, 0x68, 0x23, 0x58, 0x0d, 0x05, 0x00, 0x00 + } + }, + { + "500-166-nor", "NOR CPU: 500 PLB: 166 OPB: 83 EBC: 55", + { + 0xc7, 0x78, 0x52, 0xc6, 0x05, 0xd7, 0xa0, 0x30, + 0x40, 0x08, 0x23, 0x50, 0x0d, 0x05, 0x00, 0x00 + } + }, + { + "500-166-nand", "NAND CPU: 500 PLB: 166 OPB: 83 EBC: 55", + { + 0xc7, 0x78, 0x52, 0xc6, 0x05, 0xd7, 0xd0, 0x30, + 0xa0, 0x68, 0x23, 0x58, 0x0d, 0x05, 0x00, 0x00 + } + }, + { + "533-133-nor", "NOR CPU: 533 PLB: 133 OPB: 66 EBC: 66", + { + 0x87, 0x78, 0x82, 0x52, 0x09, 0x57, 0xa0, 0x30, + 0x40, 0x08, 0x23, 0x50, 0x0d, 0x05, 0x00, 0x00 + } + }, + { + "667-133-nor", "NOR CPU: 667 PLB: 133 OPB: 66 EBC: 66", + { + 0x87, 0x78, 0xa2, 0x56, 0x09, 0x57, 0xa0, 0x30, + 0x40, 0x08, 0x23, 0x50, 0x0d, 0x05, 0x00, 0x00 + } + }, + { + "667-166-nor", "NOR CPU: 667 PLB: 166 OPB: 83 EBC: 55", + { + 0x87, 0x78, 0xa2, 0x52, 0x09, 0xd7, 0xa0, 0x30, + 0x40, 0x08, 0x23, 0x50, 0x0d, 0x05, 0x00, 0x00 + } + }, + { + "667-166-nand", "NAND CPU: 667 PLB: 166 OPB: 83 EBC: 55", + { + 0x87, 0x78, 0xa2, 0x52, 0x09, 0xd7, 0xd0, 0x30, + 0xa0, 0x68, 0x23, 0x58, 0x0d, 0x05, 0x00, 0x00 + } + }, +}; + +int ppc4xx_config_count = ARRAY_SIZE(ppc4xx_config_val); diff --git a/board/amcc/sequoia/cmd_sequoia.c b/board/amcc/sequoia/cmd_sequoia.c deleted file mode 100644 index 01dd97c..0000000 --- a/board/amcc/sequoia/cmd_sequoia.c +++ /dev/null @@ -1,231 +0,0 @@ -/* - * (C) Copyright 2007 - * Stefan Roese, DENX Software Engineering, sr@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - * - */ - -#include <common.h> -#include <command.h> -#include <i2c.h> -#include <asm/io.h> - -/* - * There are 2 versions of production Sequoia & Rainier platforms. - * The primary difference is the reference clock. Those with - * 33333333 reference clocks will also have 667MHz rated - * processors. Not enough differences to have unique clock - * settings. - * - * NOR and NAND boot options change bytes 6, 7, 8, 9, 11. The - * values are independent of the rest of the clock settings. - * - * All Sequoias & Rainiers select from two possible EEPROMs in Boot - * Config F. One for 33MHz PCI, one for 66MHz PCI. The following - * values are for the 33MHz PCI configuration. Byte 5 (0 base) is - * the only value affected for a 33MHz PCI and simply needs a | 0x08. - */ - -#define NAND_COMPATIBLE 0x01 -#define NOR_COMPATIBLE 0x02 - -/* check with Stefan on CONFIG_SYS_I2C_EEPROM_ADDR */ -#define I2C_EEPROM_ADDR 0x52 - -static char *config_labels[] = { - "CPU: 333 PLB: 133 OPB: 66 EBC: 66", - "CPU: 333 PLB: 166 OPB: 83 EBC: 55", - "CPU: 400 PLB: 133 OPB: 66 EBC: 66", - "CPU: 400 PLB: 160 OPB: 80 EBC: 53", - "CPU: 416 PLB: 166 OPB: 83 EBC: 55", - "CPU: 500 PLB: 166 OPB: 83 EBC: 55", - "CPU: 533 PLB: 133 OPB: 66 EBC: 66", - "CPU: 667 PLB: 133 OPB: 66 EBC: 66", - "CPU: 667 PLB: 166 OPB: 83 EBC: 55", - NULL -}; - -static u8 boot_configs[][17] = { - { - (NOR_COMPATIBLE), - 0x84, 0x70, 0xa2, 0xa6, 0x05, 0x57, 0xa0, 0x10, 0x40, - 0x08, 0x23, 0x50, 0x0d, 0x05, 0x00, 0x00 - }, - { - (NAND_COMPATIBLE | NOR_COMPATIBLE), - 0xc7, 0x78, 0xf3, 0x4e, 0x05, 0xd7, 0xa0, 0x30, 0x40, - 0x08, 0x23, 0x50, 0x0d, 0x05, 0x00, 0x00 - }, - { - (NOR_COMPATIBLE), - 0x86, 0x78, 0xc2, 0xc6, 0x05, 0x57, 0xa0, 0x30, 0x40, - 0x08, 0x23, 0x50, 0x0d, 0x05, 0x00, 0x00 - }, - { - (NOR_COMPATIBLE), - 0x86, 0x78, 0xc2, 0xa6, 0x05, 0xd7, 0xa0, 0x10, 0x40, - 0x08, 0x23, 0x50, 0x0d, 0x05, 0x00, 0x00 - }, - { - (NAND_COMPATIBLE | NOR_COMPATIBLE), - 0xc6, 0x78, 0x52, 0xa6, 0x05, 0xd7, 0xa0, 0x10, 0x40, - 0x08, 0x23, 0x50, 0x0d, 0x05, 0x00, 0x00 - }, - { - (NAND_COMPATIBLE | NOR_COMPATIBLE), - 0xc7, 0x78, 0x52, 0xc6, 0x05, 0xd7, 0xa0, 0x30, 0x40, - 0x08, 0x23, 0x50, 0x0d, 0x05, 0x00, 0x00 - }, - { - (NOR_COMPATIBLE), - 0x87, 0x78, 0x82, 0x52, 0x09, 0x57, 0xa0, 0x30, 0x40, - 0x08, 0x23, 0x50, 0x0d, 0x05, 0x00, 0x00 - }, - { - (NOR_COMPATIBLE), - 0x87, 0x78, 0xa2, 0x56, 0x09, 0x57, 0xa0, 0x30, 0x40, - 0x08, 0x23, 0x50, 0x0d, 0x05, 0x00, 0x00 - }, - { - (NAND_COMPATIBLE | NOR_COMPATIBLE), - 0x87, 0x78, 0xa2, 0x52, 0x09, 0xd7, 0xa0, 0x30, 0x40, - 0x08, 0x23, 0x50, 0x0d, 0x05, 0x00, 0x00 - }, - { - 0, - 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 - } -}; - -/* - * Bytes 6,8,9,11 change for NAND boot - */ -static u8 nand_boot[] = { - 0xd0, 0xa0, 0x68, 0x58 -}; - -static int do_bootstrap(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) -{ - u8 *buf, bNAND; - int x, y, nbytes, selcfg; - extern char console_buffer[]; - - if (argc < 2) { - cmd_usage(cmdtp); - return 1; - } - - if ((strcmp(argv[1], "nor") != 0) && - (strcmp(argv[1], "nand") != 0)) { - printf("Unsupported boot-device - only nor|nand support\n"); - return 1; - } - - /* set the nand flag based on provided input */ - if ((strcmp(argv[1], "nand") == 0)) - bNAND = 1; - else - bNAND = 0; - - printf("Available configurations: \n\n"); - - if (bNAND) { - for(x = 0, y = 0; boot_configs[x][0] != 0; x++) { - /* filter on nand compatible */ - if (boot_configs[x][0] & NAND_COMPATIBLE) { - printf(" %d - %s\n", (y+1), config_labels[x]); - y++; - } - } - } else { - for(x = 0, y = 0; boot_configs[x][0] != 0; x++) { - /* filter on nor compatible */ - if (boot_configs[x][0] & NOR_COMPATIBLE) { - printf(" %d - %s\n", (y+1), config_labels[x]); - y++; - } - } - } - - do { - nbytes = readline(" Selection [1-x / quit]: "); - - if (nbytes) { - if (strcmp(console_buffer, "quit") == 0) - return 0; - selcfg = simple_strtol(console_buffer, NULL, 10); - if ((selcfg < 1) || (selcfg > y)) - nbytes = 0; - } - } while (nbytes == 0); - - - y = (selcfg - 1); - - for (x = 0; boot_configs[x][0] != 0; x++) { - if (bNAND) { - if (boot_configs[x][0] & NAND_COMPATIBLE) { - if (y > 0) - y--; - else if (y < 1) - break; - } - } else { - if (boot_configs[x][0] & NOR_COMPATIBLE) { - if (y > 0) - y--; - else if (y < 1) - break; - } - } - } - - buf = &boot_configs[x][1]; - - if (bNAND) { - buf[6] = nand_boot[0]; - buf[8] = nand_boot[1]; - buf[9] = nand_boot[2]; - buf[11] = nand_boot[3]; - } - - /* check CPLD register +5 for PCI 66MHz flag */ - if ((in_8((void *)(CONFIG_SYS_BCSR_BASE + 5)) & CONFIG_SYS_BCSR5_PCI66EN) == 0) - /* - * PLB-to-PCI divisor = 3 for 33MHz sync PCI - * instead of 2 for 66MHz systems - */ - buf[5] |= 0x08; - - if (i2c_write(I2C_EEPROM_ADDR, 0, 1, buf, 16) != 0) - printf("Error writing to EEPROM at address 0x%x\n", I2C_EEPROM_ADDR); - udelay(CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS * 1000); - - printf("Done\n"); - printf("Please power-cycle the board for the changes to take effect\n"); - - return 0; -} - -U_BOOT_CMD( - bootstrap, 2, 0, do_bootstrap, - "program the I2C bootstrap EEPROM", - "<nand|nor> - strap to boot from NAND or NOR flash" -); diff --git a/include/configs/sequoia.h b/include/configs/sequoia.h index 89acacc..9605ce2 100644 --- a/include/configs/sequoia.h +++ b/include/configs/sequoia.h @@ -243,6 +243,11 @@ #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10
+/* I2C bootstrap EEPROM */ +#define CONFIG_4xx_CONFIG_I2C_EEPROM_ADDR 0x52 +#define CONFIG_4xx_CONFIG_I2C_EEPROM_OFFSET 0 +#define CONFIG_4xx_CONFIG_BLOCKSIZE 16 + /* I2C SYSMON (LM75, AD7414 is almost compatible) */ #define CONFIG_DTT_LM75 1 /* ON Semi's LM75 */ #define CONFIG_DTT_AD7414 1 /* use AD7414 */ @@ -300,6 +305,7 @@ /* * Commands additional to the ones defined in amcc-common.h */ +#define CONFIG_CMD_CHIP_CONFIG #define CONFIG_CMD_DTT #define CONFIG_CMD_FAT #define CONFIG_CMD_NAND
Applied to u-boot-ppc4xx/master. Thanks.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Stefan Roese
