[U-Boot] [PATCH v2] tegra: fdt: sort dts files
Sort nodes in dts files according the the following rules:
1) Any nodes that already exist in any /include/d file, in the order they appear in the /include/d file.
2) Any nodes with a reg property, in order of their address.
3) Any nodes without a reg property, alphabetically by node name.
Signed-off-by: Allen Martin amartin@nvidia.com Signed-off-by: Tom Warren twarren@nvidia.com --- v2: Added back host1x node that got dropped from seaboard by mistake. As an added precaution I verified each file touched by this patch by running it through "sort" before and after the patch and confirmed they are identical minus blank lines that were fixed up.
v1: split this out from SPI driver series --- arch/arm/dts/tegra20.dtsi | 377 +++++++++++++++--------------- board/avionic-design/dts/tegra20-tec.dts | 22 +- board/compal/dts/tegra20-paz00.dts | 22 +- board/nvidia/dts/tegra20-harmony.dts | 20 +- board/nvidia/dts/tegra20-seaboard.dts | 119 +++++----- 5 files changed, 279 insertions(+), 281 deletions(-)
diff --git a/arch/arm/dts/tegra20.dtsi b/arch/arm/dts/tegra20.dtsi index cc086b1..46e3785 100644 --- a/arch/arm/dts/tegra20.dtsi +++ b/arch/arm/dts/tegra20.dtsi @@ -4,10 +4,102 @@ compatible = "nvidia,tegra20"; interrupt-parent = <&intc>;
- tegra_car: clock@60006000 { - compatible = "nvidia,tegra20-car"; - reg = <0x60006000 0x1000>; - #clock-cells = <1>; + host1x { + compatible = "nvidia,tegra20-host1x", "simple-bus"; + reg = <0x50000000 0x00024000>; + interrupts = <0 65 0x04 /* mpcore syncpt */ + 0 67 0x04>; /* mpcore general */ + status = "disabled"; + + #address-cells = <1>; + #size-cells = <1>; + + ranges = <0x54000000 0x54000000 0x04000000>; + + /* video-encoding/decoding */ + mpe { + reg = <0x54040000 0x00040000>; + interrupts = <0 68 0x04>; + status = "disabled"; + }; + + /* video input */ + vi { + reg = <0x54080000 0x00040000>; + interrupts = <0 69 0x04>; + status = "disabled"; + }; + + /* EPP */ + epp { + reg = <0x540c0000 0x00040000>; + interrupts = <0 70 0x04>; + status = "disabled"; + }; + + /* ISP */ + isp { + reg = <0x54100000 0x00040000>; + interrupts = <0 71 0x04>; + status = "disabled"; + }; + + /* 2D engine */ + gr2d { + reg = <0x54140000 0x00040000>; + interrupts = <0 72 0x04>; + status = "disabled"; + }; + + /* 3D engine */ + gr3d { + reg = <0x54180000 0x00040000>; + status = "disabled"; + }; + + /* display controllers */ + dc@54200000 { + compatible = "nvidia,tegra20-dc"; + reg = <0x54200000 0x00040000>; + interrupts = <0 73 0x04>; + status = "disabled"; + + rgb { + status = "disabled"; + }; + }; + + dc@54240000 { + compatible = "nvidia,tegra20-dc"; + reg = <0x54240000 0x00040000>; + interrupts = <0 74 0x04>; + status = "disabled"; + + rgb { + status = "disabled"; + }; + }; + + /* outputs */ + hdmi { + compatible = "nvidia,tegra20-hdmi"; + reg = <0x54280000 0x00040000>; + interrupts = <0 75 0x04>; + status = "disabled"; + }; + + tvo { + compatible = "nvidia,tegra20-tvo"; + reg = <0x542c0000 0x00040000>; + interrupts = <0 76 0x04>; + status = "disabled"; + }; + + dsi { + compatible = "nvidia,tegra20-dsi"; + reg = <0x54300000 0x00040000>; + status = "disabled"; + }; };
intc: interrupt-controller@50041000 { @@ -18,44 +110,33 @@ < 0x50040100 0x0100 >; };
- i2c@7000c000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "nvidia,tegra20-i2c"; - reg = <0x7000C000 0x100>; - interrupts = < 70 >; - /* PERIPH_ID_I2C1, PLL_P_OUT3 */ - clocks = <&tegra_car 12>, <&tegra_car 124>; + tegra_car: clock@60006000 { + compatible = "nvidia,tegra20-car"; + reg = <0x60006000 0x1000>; + #clock-cells = <1>; };
- i2c@7000c400 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "nvidia,tegra20-i2c"; - reg = <0x7000C400 0x100>; - interrupts = < 116 >; - /* PERIPH_ID_I2C2, PLL_P_OUT3 */ - clocks = <&tegra_car 54>, <&tegra_car 124>; + gpio: gpio@6000d000 { + compatible = "nvidia,tegra20-gpio"; + reg = < 0x6000d000 0x1000 >; + interrupts = < 64 65 66 67 87 119 121 >; + #gpio-cells = <2>; + gpio-controller; };
- i2c@7000c500 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "nvidia,tegra20-i2c"; - reg = <0x7000C500 0x100>; - interrupts = < 124 >; - /* PERIPH_ID_I2C3, PLL_P_OUT3 */ - clocks = <&tegra_car 67>, <&tegra_car 124>; + pinmux: pinmux@70000000 { + compatible = "nvidia,tegra20-pinmux"; + reg = < 0x70000014 0x10 /* Tri-state registers */ + 0x70000080 0x20 /* Mux registers */ + 0x700000a0 0x14 /* Pull-up/down registers */ + 0x70000868 0xa8 >; /* Pad control registers */ };
- i2c@7000d000 { + das@70000c00 { #address-cells = <1>; #size-cells = <0>; - compatible = "nvidia,tegra20-i2c-dvc"; - reg = <0x7000D000 0x200>; - interrupts = < 85 >; - /* PERIPH_ID_DVC_I2C, PLL_P_OUT3 */ - clocks = <&tegra_car 47>, <&tegra_car 124>; + compatible = "nvidia,tegra20-das"; + reg = <0x70000c00 0x80>; };
i2s@70002800 { @@ -76,29 +157,6 @@ dma-channel = < 1 >; };
- das@70000c00 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "nvidia,tegra20-das"; - reg = <0x70000c00 0x80>; - }; - - gpio: gpio@6000d000 { - compatible = "nvidia,tegra20-gpio"; - reg = < 0x6000d000 0x1000 >; - interrupts = < 64 65 66 67 87 119 121 >; - #gpio-cells = <2>; - gpio-controller; - }; - - pinmux: pinmux@70000000 { - compatible = "nvidia,tegra20-pinmux"; - reg = < 0x70000014 0x10 /* Tri-state registers */ - 0x70000080 0x20 /* Mux registers */ - 0x700000a0 0x14 /* Pull-up/down registers */ - 0x70000868 0xa8 >; /* Pad control registers */ - }; - serial@70006000 { compatible = "nvidia,tegra20-uart"; reg = <0x70006000 0x40>; @@ -134,28 +192,69 @@ interrupts = < 123 >; };
- sdhci@c8000000 { - compatible = "nvidia,tegra20-sdhci"; - reg = <0xc8000000 0x200>; - interrupts = < 46 >; + nand: nand-controller@70008000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "nvidia,tegra20-nand"; + reg = <0x70008000 0x100>; };
- sdhci@c8000200 { - compatible = "nvidia,tegra20-sdhci"; - reg = <0xc8000200 0x200>; - interrupts = < 47 >; + pwm: pwm@7000a000 { + compatible = "nvidia,tegra20-pwm"; + reg = <0x7000a000 0x100>; + #pwm-cells = <2>; };
- sdhci@c8000400 { - compatible = "nvidia,tegra20-sdhci"; - reg = <0xc8000400 0x200>; - interrupts = < 51 >; + i2c@7000c000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "nvidia,tegra20-i2c"; + reg = <0x7000C000 0x100>; + interrupts = < 70 >; + /* PERIPH_ID_I2C1, PLL_P_OUT3 */ + clocks = <&tegra_car 12>, <&tegra_car 124>; };
- sdhci@c8000600 { - compatible = "nvidia,tegra20-sdhci"; - reg = <0xc8000600 0x200>; - interrupts = < 63 >; + i2c@7000c400 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "nvidia,tegra20-i2c"; + reg = <0x7000C400 0x100>; + interrupts = < 116 >; + /* PERIPH_ID_I2C2, PLL_P_OUT3 */ + clocks = <&tegra_car 54>, <&tegra_car 124>; + }; + + i2c@7000c500 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "nvidia,tegra20-i2c"; + reg = <0x7000C500 0x100>; + interrupts = < 124 >; + /* PERIPH_ID_I2C3, PLL_P_OUT3 */ + clocks = <&tegra_car 67>, <&tegra_car 124>; + }; + + i2c@7000d000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "nvidia,tegra20-i2c-dvc"; + reg = <0x7000D000 0x200>; + interrupts = < 85 >; + /* PERIPH_ID_DVC_I2C, PLL_P_OUT3 */ + clocks = <&tegra_car 47>, <&tegra_car 124>; + }; + + kbc@7000e200 { + compatible = "nvidia,tegra20-kbc"; + reg = <0x7000e200 0x0078>; + }; + + emc@7000f400 { + #address-cells = < 1 >; + #size-cells = < 0 >; + compatible = "nvidia,tegra20-emc"; + reg = <0x7000f400 0x200>; };
usb@c5000000 { @@ -183,127 +282,27 @@ clocks = <&tegra_car 59>; /* PERIPH_ID_USB3 */ };
- emc@7000f400 { - #address-cells = < 1 >; - #size-cells = < 0 >; - compatible = "nvidia,tegra20-emc"; - reg = <0x7000f400 0x200>; - }; - - kbc@7000e200 { - compatible = "nvidia,tegra20-kbc"; - reg = <0x7000e200 0x0078>; + sdhci@c8000000 { + compatible = "nvidia,tegra20-sdhci"; + reg = <0xc8000000 0x200>; + interrupts = < 46 >; };
- nand: nand-controller@70008000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "nvidia,tegra20-nand"; - reg = <0x70008000 0x100>; + sdhci@c8000200 { + compatible = "nvidia,tegra20-sdhci"; + reg = <0xc8000200 0x200>; + interrupts = < 47 >; };
- pwm: pwm@7000a000 { - compatible = "nvidia,tegra20-pwm"; - reg = <0x7000a000 0x100>; - #pwm-cells = <2>; + sdhci@c8000400 { + compatible = "nvidia,tegra20-sdhci"; + reg = <0xc8000400 0x200>; + interrupts = < 51 >; };
- host1x { - compatible = "nvidia,tegra20-host1x", "simple-bus"; - reg = <0x50000000 0x00024000>; - interrupts = <0 65 0x04 /* mpcore syncpt */ - 0 67 0x04>; /* mpcore general */ - status = "disabled"; - - #address-cells = <1>; - #size-cells = <1>; - - ranges = <0x54000000 0x54000000 0x04000000>; - - /* video-encoding/decoding */ - mpe { - reg = <0x54040000 0x00040000>; - interrupts = <0 68 0x04>; - status = "disabled"; - }; - - /* video input */ - vi { - reg = <0x54080000 0x00040000>; - interrupts = <0 69 0x04>; - status = "disabled"; - }; - - /* EPP */ - epp { - reg = <0x540c0000 0x00040000>; - interrupts = <0 70 0x04>; - status = "disabled"; - }; - - /* ISP */ - isp { - reg = <0x54100000 0x00040000>; - interrupts = <0 71 0x04>; - status = "disabled"; - }; - - /* 2D engine */ - gr2d { - reg = <0x54140000 0x00040000>; - interrupts = <0 72 0x04>; - status = "disabled"; - }; - - /* 3D engine */ - gr3d { - reg = <0x54180000 0x00040000>; - status = "disabled"; - }; - - /* display controllers */ - dc@54200000 { - compatible = "nvidia,tegra20-dc"; - reg = <0x54200000 0x00040000>; - interrupts = <0 73 0x04>; - status = "disabled"; - - rgb { - status = "disabled"; - }; - }; - - dc@54240000 { - compatible = "nvidia,tegra20-dc"; - reg = <0x54240000 0x00040000>; - interrupts = <0 74 0x04>; - status = "disabled"; - - rgb { - status = "disabled"; - }; - }; - - /* outputs */ - hdmi { - compatible = "nvidia,tegra20-hdmi"; - reg = <0x54280000 0x00040000>; - interrupts = <0 75 0x04>; - status = "disabled"; - }; - - tvo { - compatible = "nvidia,tegra20-tvo"; - reg = <0x542c0000 0x00040000>; - interrupts = <0 76 0x04>; - status = "disabled"; - }; - - dsi { - compatible = "nvidia,tegra20-dsi"; - reg = <0x54300000 0x00040000>; - status = "disabled"; - }; + sdhci@c8000600 { + compatible = "nvidia,tegra20-sdhci"; + reg = <0xc8000600 0x200>; + interrupts = < 63 >; }; - }; diff --git a/board/avionic-design/dts/tegra20-tec.dts b/board/avionic-design/dts/tegra20-tec.dts index 8135eeb..bf3ff1d 100644 --- a/board/avionic-design/dts/tegra20-tec.dts +++ b/board/avionic-design/dts/tegra20-tec.dts @@ -31,6 +31,17 @@ clock-frequency = <216000000>; };
+ nand-controller@70008000 { + nvidia,wp-gpios = <&gpio 23 0>; /* PC7 */ + nvidia,width = <8>; + nvidia,timing = <26 100 20 80 20 10 12 10 70>; + + nand@0 { + reg = <0>; + compatible = "hynix,hy27uf4g2b", "nand-flash"; + }; + }; + i2c@7000c000 { status = "disabled"; }; @@ -55,17 +66,6 @@ status = "disabled"; };
- nand-controller@70008000 { - nvidia,wp-gpios = <&gpio 23 0>; /* PC7 */ - nvidia,width = <8>; - nvidia,timing = <26 100 20 80 20 10 12 10 70>; - - nand@0 { - reg = <0>; - compatible = "hynix,hy27uf4g2b", "nand-flash"; - }; - }; - lcd_panel: panel { clock = <33260000>; xres = <800>; diff --git a/board/compal/dts/tegra20-paz00.dts b/board/compal/dts/tegra20-paz00.dts index 0fef713..31b064d 100644 --- a/board/compal/dts/tegra20-paz00.dts +++ b/board/compal/dts/tegra20-paz00.dts @@ -14,6 +14,17 @@ reg = <0x00000000 0x20000000>; };
+ host1x { + status = "okay"; + dc@54200000 { + status = "okay"; + rgb { + status = "okay"; + nvidia,panel = <&lcd_panel>; + }; + }; + }; + serial@70006000 { clock-frequency = < 216000000 >; }; @@ -42,17 +53,6 @@ status = "disabled"; };
- host1x { - status = "okay"; - dc@54200000 { - status = "okay"; - rgb { - status = "okay"; - nvidia,panel = <&lcd_panel>; - }; - }; - }; - lcd_panel: panel { /* PAZ00 has 1024x600 */ clock = <54030000>; diff --git a/board/nvidia/dts/tegra20-harmony.dts b/board/nvidia/dts/tegra20-harmony.dts index b456406..aeda3a1 100644 --- a/board/nvidia/dts/tegra20-harmony.dts +++ b/board/nvidia/dts/tegra20-harmony.dts @@ -19,6 +19,16 @@ clock-frequency = < 216000000 >; };
+ nand-controller@70008000 { + nvidia,wp-gpios = <&gpio 23 0>; /* PC7 */ + nvidia,width = <8>; + nvidia,timing = <26 100 20 80 20 10 12 10 70>; + nand@0 { + reg = <0>; + compatible = "hynix,hy27uf4g2b", "nand-flash"; + }; + }; + i2c@7000c000 { status = "disabled"; }; @@ -42,14 +52,4 @@ usb@c5004000 { nvidia,phy-reset-gpio = <&gpio 169 0>; /* gpio PV1 */ }; - - nand-controller@70008000 { - nvidia,wp-gpios = <&gpio 23 0>; /* PC7 */ - nvidia,width = <8>; - nvidia,timing = <26 100 20 80 20 10 12 10 70>; - nand@0 { - reg = <0>; - compatible = "hynix,hy27uf4g2b", "nand-flash"; - }; - }; }; diff --git a/board/nvidia/dts/tegra20-seaboard.dts b/board/nvidia/dts/tegra20-seaboard.dts index 5fd8ae2..527a296 100644 --- a/board/nvidia/dts/tegra20-seaboard.dts +++ b/board/nvidia/dts/tegra20-seaboard.dts @@ -27,6 +27,17 @@ reg = < 0x00000000 0x40000000 >; };
+ host1x { + status = "okay"; + dc@54200000 { + status = "okay"; + rgb { + status = "okay"; + nvidia,panel = <&lcd_panel>; + }; + }; + }; + /* This is not used in U-Boot, but is expected to be in kernel .dts */ i2c@7000d000 { clock-frequency = <100000>; @@ -49,23 +60,14 @@ clock-frequency = < 216000000 >; };
- sdhci@c8000400 { - cd-gpios = <&gpio 69 0>; /* gpio PI5 */ - wp-gpios = <&gpio 57 0>; /* gpio PH1 */ - power-gpios = <&gpio 70 0>; /* gpio PI6 */ - }; - - sdhci@c8000600 { - support-8bit; - }; - - usb@c5000000 { - nvidia,vbus-gpio = <&gpio 24 0>; /* PD0 */ - dr_mode = "otg"; - }; - - usb@c5004000 { - status = "disabled"; + nand-controller@70008000 { + nvidia,wp-gpios = <&gpio 59 0>; /* PH3 */ + nvidia,width = <8>; + nvidia,timing = <26 100 20 80 20 10 12 10 70>; + nand@0 { + reg = <0>; + compatible = "hynix,hy27uf4g2b", "nand-flash"; + }; };
i2c@7000c000 { @@ -80,6 +82,33 @@ clock-frequency = <100000>; };
+ kbc@7000e200 { + linux,keymap = <0x00020011 0x0003001f 0x0004001e 0x0005002c + 0x000701d0 0x0107007d 0x02060064 0x02070038 0x03000006 + 0x03010005 0x03020013 0x03030012 0x03040021 0x03050020 + 0x0306002d 0x04000008 0x04010007 0x04020014 0x04030023 + 0x04040022 0x0405002f 0x0406002e 0x04070039 0x0500000a + 0x05010009 0x05020016 0x05030015 0x05040024 0x05050031 + 0x05060030 0x0507002b 0x0600000c 0x0601000b 0x06020018 + 0x06030017 0x06040026 0x06050025 0x06060033 0x06070032 + 0x0701000d 0x0702001b 0x0703001c 0x0707008b 0x08040036 + 0x0805002a 0x09050061 0x0907001d 0x0b00001a 0x0b010019 + 0x0b020028 0x0b030027 0x0b040035 0x0b050034 0x0c000044 + 0x0c010043 0x0c02000e 0x0c030004 0x0c040003 0x0c050067 + 0x0c0600d2 0x0c070077 0x0d00006e 0x0d01006f 0x0d030068 + 0x0d04006d 0x0d05006a 0x0d06006c 0x0d070069 0x0e000057 + 0x0e010058 0x0e020042 0x0e030010 0x0e04003e 0x0e05003d + 0x0e060002 0x0e070041 0x0f000001 0x0f010029 0x0f02003f + 0x0f03000f 0x0f04003b 0x0f05003c 0x0f06003a 0x0f070040 + 0x14000047 0x15000049 0x15010048 0x1502004b 0x1504004f + 0x16010062 0x1602004d 0x1603004c 0x16040051 0x16050050 + 0x16070052 0x1b010037 0x1b03004a 0x1b04004e 0x1b050053 + 0x1c050073 0x1d030066 0x1d04006b 0x1d0500e0 0x1d060072 + 0x1d0700e1 0x1e000045 0x1e010046 0x1e020071 + 0x1f04008a>; + linux,fn-keymap = <0x05040002>; + }; + emc@7000f400 { emc-table@190000 { reg = < 190000 >; @@ -117,52 +146,23 @@ }; };
- kbc@7000e200 { - linux,keymap = <0x00020011 0x0003001f 0x0004001e 0x0005002c - 0x000701d0 0x0107007d 0x02060064 0x02070038 0x03000006 - 0x03010005 0x03020013 0x03030012 0x03040021 0x03050020 - 0x0306002d 0x04000008 0x04010007 0x04020014 0x04030023 - 0x04040022 0x0405002f 0x0406002e 0x04070039 0x0500000a - 0x05010009 0x05020016 0x05030015 0x05040024 0x05050031 - 0x05060030 0x0507002b 0x0600000c 0x0601000b 0x06020018 - 0x06030017 0x06040026 0x06050025 0x06060033 0x06070032 - 0x0701000d 0x0702001b 0x0703001c 0x0707008b 0x08040036 - 0x0805002a 0x09050061 0x0907001d 0x0b00001a 0x0b010019 - 0x0b020028 0x0b030027 0x0b040035 0x0b050034 0x0c000044 - 0x0c010043 0x0c02000e 0x0c030004 0x0c040003 0x0c050067 - 0x0c0600d2 0x0c070077 0x0d00006e 0x0d01006f 0x0d030068 - 0x0d04006d 0x0d05006a 0x0d06006c 0x0d070069 0x0e000057 - 0x0e010058 0x0e020042 0x0e030010 0x0e04003e 0x0e05003d - 0x0e060002 0x0e070041 0x0f000001 0x0f010029 0x0f02003f - 0x0f03000f 0x0f04003b 0x0f05003c 0x0f06003a 0x0f070040 - 0x14000047 0x15000049 0x15010048 0x1502004b 0x1504004f - 0x16010062 0x1602004d 0x1603004c 0x16040051 0x16050050 - 0x16070052 0x1b010037 0x1b03004a 0x1b04004e 0x1b050053 - 0x1c050073 0x1d030066 0x1d04006b 0x1d0500e0 0x1d060072 - 0x1d0700e1 0x1e000045 0x1e010046 0x1e020071 - 0x1f04008a>; - linux,fn-keymap = <0x05040002>; + usb@c5000000 { + nvidia,vbus-gpio = <&gpio 24 0>; /* PD0 */ + dr_mode = "otg"; };
- nand-controller@70008000 { - nvidia,wp-gpios = <&gpio 59 0>; /* PH3 */ - nvidia,width = <8>; - nvidia,timing = <26 100 20 80 20 10 12 10 70>; - nand@0 { - reg = <0>; - compatible = "hynix,hy27uf4g2b", "nand-flash"; - }; + usb@c5004000 { + status = "disabled"; };
- host1x { - status = "okay"; - dc@54200000 { - status = "okay"; - rgb { - status = "okay"; - nvidia,panel = <&lcd_panel>; - }; - }; + sdhci@c8000400 { + cd-gpios = <&gpio 69 0>; /* gpio PI5 */ + wp-gpios = <&gpio 57 0>; /* gpio PH1 */ + power-gpios = <&gpio 70 0>; /* gpio PI6 */ + }; + + sdhci@c8000600 { + support-8bit; };
lcd_panel: panel { @@ -185,5 +185,4 @@ nvidia,panel-vdd-gpios = <&gpio 22 0>; /* PC6 */ nvidia,panel-timings = <400 4 203 17 15>; }; - };
Allen Martin
