[U-Boot] [PATCH] pinctrl: remove duplicated (SPL_)PINCONF_RECURSIVE entries
PINCONF_RECURSIVE and SPL_PINCONF_RECURSIVE are duplicated, remove them.
Signed-off-by: Anatolij Gustschin agust@denx.de --- drivers/pinctrl/Kconfig | 25 ------------------------- 1 file changed, 25 deletions(-)
diff --git a/drivers/pinctrl/Kconfig b/drivers/pinctrl/Kconfig index 6b41f66a86..deee92411c 100644 --- a/drivers/pinctrl/Kconfig +++ b/drivers/pinctrl/Kconfig @@ -75,22 +75,6 @@ config PINCONF_RECURSIVE configuration; you can save memory footprint when this feature is no needed.
-config PINCONF_RECURSIVE - bool "Support recursive binding for pin configuration nodes" - depends on PINCTRL_FULL - default n if ARCH_STM32MP - default y - help - In the Linux pinctrl binding, the pin configuration nodes need not be - direct children of the pin controller device (may be grandchildren for - example). It is define is each individual pin controller device. - Say Y here if you want to keep this behavior with the pinconfig - u-class: all sub are recursivelly bounded. - If the option is disabled, this behavior is deactivated and only - the direct children of pin controller will be assumed as pin - configuration; you can save memory footprint when this feature is - no needed. - config SPL_PINCTRL bool "Support pin controllers in SPL" depends on SPL && SPL_DM @@ -145,15 +129,6 @@ config SPL_PINCONF_RECURSIVE This option is an SPL-variant of the PINCONF_RECURSIVE option. See the help of PINCONF_RECURSIVE for details.
-config SPL_PINCONF_RECURSIVE - bool "Support recursive binding for pin configuration nodes in SPL" - depends on SPL_PINCTRL_FULL - default n if ARCH_STM32MP - default y - help - This option is an SPL-variant of the PINCONF_RECURSIVE option. - See the help of PINCONF_RECURSIVE for details. - if PINCTRL || SPL_PINCTRL
config PINCTRL_AR933X
Anatolij Gustschin
