[PATCH 1/1] watchdog: cannot select CONFIG_CONFIG_MPC8xx_WATCHDOG
There is no configuration option CONFIG_CONFIG_MPC8xx_WATCHDOG. So we should not try to select it.
The select statement was introduced in a patch that was meant to only sort config options without changing them.
Fixes: b3134ffbd944 ("watchdog: Kconfig: Sort entry alphabetically") Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- drivers/watchdog/Kconfig | 1 - 1 file changed, 1 deletion(-)
diff --git a/drivers/watchdog/Kconfig b/drivers/watchdog/Kconfig index 2b8064dfae..8b65b5a88c 100644 --- a/drivers/watchdog/Kconfig +++ b/drivers/watchdog/Kconfig @@ -103,7 +103,6 @@ config WDT_CDNS config WDT_MPC8xx bool "MPC8xx watchdog timer support" depends on WDT && MPC8xx - select CONFIG_MPC8xx_WATCHDOG help Select this to enable mpc8xx watchdog timer
-- 2.24.1
A bit of looking in 'git log' and I think f3729ba6e7b2dff9a6f6e72e8839d99c2e3dbb03 was incomplete, probably due to using 'select CONFIG_...' here rather than just 'select MPC8xx_WATCHDOG'. Can you please finish the migration of things here? Thanks!
