[U-Boot] [PATCH] azure: Update the script to prepend PATH not override PATH
Similar to 90d3d78a1c68 ("gitlab-ci: Prepend to PATH rather than replace it") we need to prepend the PATH with our additional binaries and not replace the value fully as doing so breaks virtualenv.
Signed-off-by: Tom Rini trini@konsulko.com --- .azure-pipelines.yml | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/.azure-pipelines.yml b/.azure-pipelines.yml index 11d5a6175b0f..862cced1cc56 100644 --- a/.azure-pipelines.yml +++ b/.azure-pipelines.yml @@ -265,7 +265,7 @@ jobs: . /tmp/venv/bin/activate pip install -r test/py/requirements.txt export UBOOT_TRAVIS_BUILD_DIR=/tmp/.bm-work/${TEST_PY_BD}; - export PATH=/opt/qemu/bin:/tmp/uboot-test-hooks/bin:/usr/bin:/bin; + export PATH=/opt/qemu/bin:/tmp/uboot-test-hooks/bin:${PATH}; export PYTHONPATH=/tmp/uboot-test-hooks/py/travis-ci; if [[ "${TEST_PY_BD}" != "" ]]; then ./test/py/test.py --bd ${TEST_PY_BD} ${TEST_PY_ID} -k "${TEST_PY_TEST_SPEC:-not a_test_which_does_not_exist}" --build-dir "$UBOOT_TRAVIS_BUILD_DIR";
