[PATCH] board_f: Relocate fdt if SKIP_RELOC and fdt is in bss
There are cases that the devicetree blob is placed after _end, such as fdt_find_separate() returns _end. This is in bss area cleared before relocation.
When GD_FLG_SKIP_RELOC is set, the blob is still in bss, but will be cleared. As a result, the devicetree become invalid.
To avoid this issue, should relocate it to the new fdt area using the latter condition in reloc_fdt().
Signed-off-by: Kunihiko Hayashi hayashi.kunihiko@socionext.com --- common/board_f.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/common/board_f.c b/common/board_f.c index 51d2f3c365e9..9a245872d190 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -622,7 +622,8 @@ static int init_post(void) static int reloc_fdt(void) { if (!IS_ENABLED(CONFIG_OF_EMBED)) { - if (gd->flags & GD_FLG_SKIP_RELOC) + if (gd->flags & GD_FLG_SKIP_RELOC && + gd->fdt_blob != &_end) return 0; if (gd->new_fdt) { memcpy(gd->new_fdt, gd->fdt_blob,
Hi Kunihiko,
On Thu, 8 Jun 2023 at 07:53, Kunihiko Hayashi hayashi.kunihiko@socionext.com wrote:
!IS_ENABLED(CONFIG_OF_EMBED) == IS_ENABLED(CONFIG_OF_SEPARATE)
reloc_fdt() is only called by U-Boot (not SP)
So the FDT was found by fdt_find_separate() and gd->fdt_blob == &_end
So, is there any case where:
gd->flags & GD_FLG_SKIP_RELO is true gd->fdt_blob != &_end is true
I can't think of one.
If that is the case, then you could add a comment to this effect and unconditionally relocate if !CONFIG_OF_EMBED.
Of course the down size is that you would probably rather relocate it to just after BSS (rather than to the top of memory) but it doesn't much matter, I suspect.
-- 2.25.1
Hi Simon,
Thank you for your comment.
On 2023/06/13 6:17, Simon Glass wrote:
Hi Kunihiko,
Yes. But in fact, if (gd->flags & GD_FLG_SKIP_RELOC is true) and (gd->fdt_blob overlaps .bss section), the fdt should be relocated because clear_bss() will clear the fdt after that.
I'm not sure if it is possible to unconditionally relocate the fdt, I think we need to know if the fdt overlaps .bss section.
Thank you,
--- Best Regards Kunihiko Hayashi
Hi Kunihiko,
On Fri, 16 Jun 2023 at 00:59, Kunihiko Hayashi hayashi.kunihiko@socionext.com wrote:
Hi Simon,
Hi Kunihiko,
I misstated my point. I am wondering if gd(->fdt_blob != &_end) is ever false? If not, then we can always relocate.
What is the down-side of always relocating, and when would the fdt not overlap the .bss section?
Note that OF_EMBED is not to be used in production boards. That is violated by a few things at present, but IMO always relocating should be safe.
Thank you,
Hi Simon,
On 2023/06/19 21:36, Simon Glass wrote:
Hi Kunihiko,
Hi Simon,
Hi Kunihiko,
When CONFIG_OF_SEPARATE is true, it seems that (gd->fdt_blob != &_end) is always false because the fdt file is concatinated to the end of the image file in Makefile.
The fdt always overlaps the .bss section, so it should be relocated even if (gd->flags & GL_FLG_SKIP_RELOC) is true.
Yes, I undestand. I delete the condition in v2, and change to always relocate the fdt in case of !OF_EMBED.
Thank you,
Kunihiko Hayashi
