[U-Boot] [PATCH V4] OMAP3: Various: Future-proof serial platdata
A few boards still use ns16550_platdata structures, but assume the structure is going to be in a specific order. By explicitly naming each entry, this should also help 'future-proof' in the event the structure changes.
Tested on the Logic PD Torpedo + Wireless.
I only changed a handful of devices that used the same syntax as the Logic board. Appologies if I missed one or stepped on toes. Thanks to Derald Woods and Alexander Graf.
Signed-off-by: Adam Ford aford173@gmail.com
V4: Fix subject heading
V3: Remove reg_offset out in all the structs. It was reverted out, and and if it did exist, it would get initialized to 0 by default.
V2: I hastily copy-pasted the boards without looking at the UART number. This addresses 3 boards that use UART3 and not UART1. --- board/isee/igep00x0/igep00x0.c | 6 +++--- board/logicpd/omap3som/omap3logic.c | 6 +++--- board/logicpd/zoom1/zoom1.c | 6 +++--- board/overo/overo.c | 6 +++--- board/quipos/cairo/cairo.c | 6 +++--- board/ti/beagle/beagle.c | 6 +++--- board/timll/devkit8000/devkit8000.c | 6 +++--- 7 files changed, 21 insertions(+), 21 deletions(-)
diff --git a/board/isee/igep00x0/igep00x0.c b/board/isee/igep00x0/igep00x0.c index e2fce50..d1a6a6f 100644 --- a/board/isee/igep00x0/igep00x0.c +++ b/board/isee/igep00x0/igep00x0.c @@ -34,9 +34,9 @@ static const u32 gpmc_lan_config[] = { #endif
static const struct ns16550_platdata igep_serial = { - OMAP34XX_UART3, - 2, - V_NS16550_CLK + .base = OMAP34XX_UART3, + .reg_shift = 2, + .clock = V_NS16550_CLK };
U_BOOT_DEVICE(igep_uart) = { diff --git a/board/logicpd/omap3som/omap3logic.c b/board/logicpd/omap3som/omap3logic.c index 668f684..51d2987 100644 --- a/board/logicpd/omap3som/omap3logic.c +++ b/board/logicpd/omap3som/omap3logic.c @@ -47,9 +47,9 @@ DECLARE_GLOBAL_DATA_PTR; */
static const struct ns16550_platdata omap3logic_serial = { - OMAP34XX_UART1, - 2, - V_NS16550_CLK + .base = OMAP34XX_UART1, + .reg_shift = 2, + .clock = V_NS16550_CLK };
U_BOOT_DEVICE(omap3logic_uart) = { diff --git a/board/logicpd/zoom1/zoom1.c b/board/logicpd/zoom1/zoom1.c index 4040114..982619c 100644 --- a/board/logicpd/zoom1/zoom1.c +++ b/board/logicpd/zoom1/zoom1.c @@ -44,9 +44,9 @@ static const u32 gpmc_lab_enet[] = { };
static const struct ns16550_platdata zoom1_serial = { - OMAP34XX_UART3, - 2, - V_NS16550_CLK + .base = OMAP34XX_UART3, + .reg_shift = 2, + .clock = V_NS16550_CLK };
U_BOOT_DEVICE(zoom1_uart) = { diff --git a/board/overo/overo.c b/board/overo/overo.c index a38b959..40f13e5 100644 --- a/board/overo/overo.c +++ b/board/overo/overo.c @@ -68,9 +68,9 @@ static struct { } expansion_config = {0x0};
static const struct ns16550_platdata overo_serial = { - OMAP34XX_UART3, - 2, - V_NS16550_CLK + .base = OMAP34XX_UART3, + .reg_shift = 2, + .clock = V_NS16550_CLK };
U_BOOT_DEVICE(overo_uart) = { diff --git a/board/quipos/cairo/cairo.c b/board/quipos/cairo/cairo.c index 21793e8..77e4482 100644 --- a/board/quipos/cairo/cairo.c +++ b/board/quipos/cairo/cairo.c @@ -91,9 +91,9 @@ void get_board_mem_timings(struct board_sdrc_timings *timings) #endif
static const struct ns16550_platdata cairo_serial = { - OMAP34XX_UART2, - 2, - V_NS16550_CLK + .base = OMAP34XX_UART2, + .reg_shift = 2, + .clock = V_NS16550_CLK };
U_BOOT_DEVICE(cairo_uart) = { diff --git a/board/ti/beagle/beagle.c b/board/ti/beagle/beagle.c index ff317ef..0ed4f52 100644 --- a/board/ti/beagle/beagle.c +++ b/board/ti/beagle/beagle.c @@ -73,9 +73,9 @@ static struct { } expansion_config;
static const struct ns16550_platdata beagle_serial = { - OMAP34XX_UART3, - 2, - V_NS16550_CLK + .base = OMAP34XX_UART3, + .reg_shift = 2, + .clock = V_NS16550_CLK };
U_BOOT_DEVICE(beagle_uart) = { diff --git a/board/timll/devkit8000/devkit8000.c b/board/timll/devkit8000/devkit8000.c index 1a447c7..965252f 100644 --- a/board/timll/devkit8000/devkit8000.c +++ b/board/timll/devkit8000/devkit8000.c @@ -46,9 +46,9 @@ static u32 gpmc_net_config[GPMC_MAX_REG] = { };
static const struct ns16550_platdata devkit8000_serial = { - OMAP34XX_UART3, - 2, - V_NS16550_CLK + .base = OMAP34XX_UART3, + .reg_shift = 2, + .clock = V_NS16550_CLK };
U_BOOT_DEVICE(devkit8000_uart) = {
Looks to me like you didn't catch all boards out there. I don't think it makes sense to limit yourself to OMAP3, otherwise different boards (that people may not realize are broken that fast) break next time...
arch/arm/cpu/arm926ejs/lpc32xx/devices.c arch/arm/cpu/armv7/am33xx/board.c arch/arm/mach-tegra/board.c board/isee/igep00x0/igep00x0.c board/lge/sniper/sniper.c board/logicpd/omap3som/omap3logic.c board/logicpd/zoom1/zoom1.c board/overo/overo.c board/quipos/cairo/cairo.c board/ti/beagle/beagle.c board/timll/devkit8000/devkit8000.c
Alex
I can only test OMAP3, and I tried to state that in the patch. I grepped for the platdata structure and not that manu boards aooeared. I didn't want to just fix the board that affects me, but I didn't want to go beyond the platform for fear of breaking something and not being able to test it. On Mar 1, 2016 6:01 PM, "Alexander Graf" agraf@suse.de wrote:
structure
Logic
Woods
and Alexander Graf.
and if
Alex
I think in this case the change is simple enough that code review should catch issues quickly.
I really don't think it's a good idea to convert 80% of the code base and leave 20% for some random point in time later. It's a great recipe for disaster :). Let's just get rid of all unnamed struct field initializers for the serial port and call it a day.
Alex
I will fix and CC its maintainer.
These boards already have a pending patch from TI.
Already in git master.
I my patch
The rest should have all been included in my original patch, so I think they are addressed. Does that address your concern? If so, I'll push another revision that adds arch/arm/cpu/arm926ejs/lpc32xx/devices.c.
adam
Alex
Am 02.03.2016 um 12:29 schrieb Adam Ford aford173@gmail.com:
On 02.03.16 00:23, Adam Ford wrote: A few boards still use ns16550_platdata structures, but assume the structure is going to be in a specific order. By explicitly naming each entry, this should also help 'future-proof' in the event the structure changes.
I my patch
Yes, thanks a lot!
Alex
structure
changes.
Logic
Derald Woods
and Alexander Graf.
and and if
number.
it
(that
I my patch
Yes, thanks a lot!
No problem. After discussing it with Mugunthan, I will add the am33xx into the patch, but I won't be able to get to it until this weekend. My house is undergoing some minor updates at the moment and I can use the computer.
Alex
Adam Ford
Alexander Graf
