[U-Boot] pull request: u-boot-uniphier/misc
Hi Tom,
Here is a new tool that helps us move CONFIG options easily.
The following changes since commit 9bea236b3402a262772b66d055ec6431cbd3ba87:
Merge branch 'master' of git://www.denx.de/git/u-boot-imx (2015-05-26 10:38:01 -0400)
git://git.denx.de/u-boot-uniphier.git misc
for you to fetch changes up to 2e2ce6c0c8d3d0d2a86d2464d201aecd9aef693d:
moveconfig: Print status about the processed defconfigs (2015-05-27 08:39:16 +0900)
---------------------------------------------------------------- Joe Hershberger (9): moveconfig: Always run savedefconfig on the moved config moveconfig: Ignore duplicate configs when moving moveconfig: Add a parameter to accept a list to build moveconfig: Add a switch to only cleanup headers moveconfig: Cleanup headers in arch and board moveconfig: Output a list of failed boards moveconfig: Print a message for missing compiler moveconfig: Add a switch to enable printing errors moveconfig: Print status about the processed defconfigs
Masahiro Yamada (1): tools: moveconfig: a tool to move CONFIGs from headers to defconfigs
scripts/Makefile.autoconf | 3 +- tools/moveconfig.py | 918 +++++++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 920 insertions(+), 1 deletion(-) create mode 100755 tools/moveconfig.py
On Wed, May 27, 2015 at 08:47:02AM +0900, Masahiro Yamada wrote:
Hi Tom,
Masahiro Yamada
