[U-Boot] [PATCH] i2c:zynq: I2C multi-bus support on Zynq
Zynq PS has two I2C bus masters (called 'I2C0' and 'I2C1'):
Implement 'i2c_set_bus_num' routine to select from these.
Support I2C devices which do not use internal addresses:
Handle case of 'alen == 0' in 'i2c_read', 'i2c_write'.
This supports PCA9548 bus multiplexer on Xilinx ZC702 board. Tested cases of 'alen == 0' and 'alen == 1' on this board. Further minor corrections:
Write 'address' register before 'data' register. Write 'transfer_size' register before 'address' register.
Signed-off-by: Michael Burr michael.burr@logicpd.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Heiko Schocher hs@denx.de Cc: Michal Simek monstr@monstr.eu --- drivers/i2c/zynq_i2c.c | 87 ++++++++++++++++++++++++++++++------------------ 1 file changed, 55 insertions(+), 32 deletions(-)
diff --git a/drivers/i2c/zynq_i2c.c b/drivers/i2c/zynq_i2c.c index ce2d23f..1c9ae30 100644 --- a/drivers/i2c/zynq_i2c.c +++ b/drivers/i2c/zynq_i2c.c @@ -7,7 +7,7 @@ * * Copyright (c) 2012-2013 Xilinx, Michal Simek * - * SPDX-License-Identifier: GPL-2.0+ + * SPDX-License-Identifier: GPL-2.0+ */
#include <common.h> @@ -64,18 +64,19 @@ struct zynq_i2c_registers { #define ZYNQ_I2C_FIFO_DEPTH 16 #define ZYNQ_I2C_TRANSFERT_SIZE_MAX 255 /* Controller transfer limit */
-#if defined(CONFIG_ZYNQ_I2C0) -# define ZYNQ_I2C_BASE ZYNQ_I2C_BASEADDR0 -#else -# define ZYNQ_I2C_BASE ZYNQ_I2C_BASEADDR1 +#ifdef CONFIG_I2C_MULTI_BUS +static unsigned int current_bus; #endif - -static struct zynq_i2c_registers *zynq_i2c = - (struct zynq_i2c_registers *)ZYNQ_I2C_BASE; +static struct zynq_i2c_registers *zynq_i2c;
/* I2C init called by cmd_i2c when doing 'i2c reset'. */ void i2c_init(int requested_speed, int slaveadd) { +#ifdef CONFIG_I2C_MULTI_BUS + current_bus = 0; +#endif + zynq_i2c = (struct zynq_i2c_registers *)ZYNQ_I2C_BASEADDR0; + /* 111MHz / ( (3 * 17) * 22 ) = ~100KHz */ writel((16 << ZYNQ_I2C_CONTROL_DIV_B_SHIFT) | (2 << ZYNQ_I2C_CONTROL_DIV_A_SHIFT), &zynq_i2c->control); @@ -187,26 +188,29 @@ int i2c_read(u8 dev, uint addr, int alen, u8 *data, int length) * Temporarily disable restart (by clearing hold) * It doesn't seem to work. */ - clrbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_RW | - ZYNQ_I2C_CONTROL_HOLD); + clrbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_HOLD); + writel(0xFF, &zynq_i2c->interrupt_status); - while (alen--) - writel(addr >> (8*alen), &zynq_i2c->data); - writel(dev, &zynq_i2c->address); + if (alen) { + clrbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_RW); + writel(dev, &zynq_i2c->address); + while (alen--) + writel(addr >> (8*alen), &zynq_i2c->data);
- /* Wait for the address to be sent */ - if (!zynq_i2c_wait(ZYNQ_I2C_INTERRUPT_COMP)) { - /* Release the bus */ - clrbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_HOLD); - return -ETIMEDOUT; + /* Wait for the address to be sent */ + if (!zynq_i2c_wait(ZYNQ_I2C_INTERRUPT_COMP)) { + /* Release the bus */ + clrbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_HOLD); + return -ETIMEDOUT; + } + debug("Device acked address\n"); } - debug("Device acked address\n");
setbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_CLR_FIFO | ZYNQ_I2C_CONTROL_RW); /* Start reading data */ - writel(dev, &zynq_i2c->address); writel(length, &zynq_i2c->transfer_size); + writel(dev, &zynq_i2c->address);
/* Wait for data */ do { @@ -244,17 +248,18 @@ int i2c_write(u8 dev, uint addr, int alen, u8 *data, int length) ZYNQ_I2C_CONTROL_HOLD); clrbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_RW); writel(0xFF, &zynq_i2c->interrupt_status); - while (alen--) - writel(addr >> (8*alen), &zynq_i2c->data); - /* Start the tranfer */ writel(dev, &zynq_i2c->address); - if (!zynq_i2c_wait(ZYNQ_I2C_INTERRUPT_COMP)) { - /* Release the bus */ - clrbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_HOLD); - return -ETIMEDOUT; + if (alen) { + while (alen--) + writel(addr >> (8*alen), &zynq_i2c->data); + /* Start the tranfer */ + if (!zynq_i2c_wait(ZYNQ_I2C_INTERRUPT_COMP)) { + /* Release the bus */ + clrbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_HOLD); + return -ETIMEDOUT; + } + debug("Device acked address\n"); } - - debug("Device acked address\n"); while (length--) { writel(*(cur_data++), &zynq_i2c->data); if (readl(&zynq_i2c->transfer_size) == ZYNQ_I2C_FIFO_DEPTH) { @@ -277,14 +282,32 @@ int i2c_write(u8 dev, uint addr, int alen, u8 *data, int length)
int i2c_set_bus_num(unsigned int bus) { - /* Only support bus 0 */ - if (bus > 0) + if (bus >= CONFIG_SYS_MAX_I2C_BUS) return -1; + + switch (bus) { + case 0: + zynq_i2c = (struct zynq_i2c_registers *)ZYNQ_I2C_BASEADDR0; + break; +#ifdef CONFIG_I2C_MULTI_BUS + case 1: + zynq_i2c = (struct zynq_i2c_registers *)ZYNQ_I2C_BASEADDR1; + break; +#endif + default: + return -1; + } +#ifdef CONFIG_I2C_MULTI_BUS + current_bus = bus; +#endif return 0; }
unsigned int i2c_get_bus_num(void) { - /* Only support bus 0 */ +#ifdef CONFIG_I2C_MULTI_BUS + return current_bus; +#else return 0; +#endif }
Hello Michael,
a "How to send patches", Jagan Teki responded to you, so I only comment your patch ...
Am 17.09.2013 19:29, schrieb Michael Burr:
Signed-off-by: Michael Burrmichael.burr@logicpd.com Cc: Albert Aribaudalbert.u.boot@aribaud.net Cc: Heiko Schocherhs@denx.de Cc: Michal Simekmonstr@monstr.eu
Thanks for your work!
But please use the new i2c multibus/multiadapter framework for adding multibus support for this driver. Currently 4 i2c drivers are ported to this new framework, see:
http://git.denx.de/?p=u-boot.git;a=commitdiff;h=880540decfb855e96bc14ac84ac7... http://git.denx.de/?p=u-boot.git;a=commitdiff;h=1f2ba722ac06393d6abe6d473482... http://git.denx.de/?p=u-boot.git;a=commitdiff;h=00f792e0df9ae942427e44595a0f... http://git.denx.de/?p=u-boot.git;a=commitdiff;h=ea818dbbcd59300b56014ac2d677...
You can use them as a base for your work
bye, Heiko
Thanks for the feedback, Heiko!
I will take a look at the new framework...
Michael Burr // Software Engineer II
Logic PD T // 612.436.7273 NOTICE: Important disclaimers and limitations apply to this email. Please see this web page for our disclaimers and limitations: http://logicpd.com/email-disclaimer/
-----Original Message----- From: Heiko Schocher [mailto:hs@denx.de] Sent: Wednesday, September 18, 2013 2:14 AM To: Michael Burr Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] [PATCH] i2c:zynq: I2C multi-bus support on Zynq
Hello Michael,
bye, Heiko
Heiko Schocher
Michael Burr
