[U-Boot] [PATCH v3 1/5] mtd: Use default mtdparts/mtids when not defined in the environment
U-boot provides a mean to define default values for mtdids and mtdparts when they're not defined in the environment. Patch mtd_probe_devices() to use those default values when env_get("mtdparts") or env_get("mtdids") return NULL.
This implementation is based on the logic found in cmd/mtdparts.c.
Fixes: 5db66b3aee6f ("cmd: mtd: add 'mtd' command") Reported-by: Stefan Roese sr@denx.de Signed-off-by: Boris Brezillon boris.brezillon@bootlin.com Tested-by: Stefan Roese sr@denx.de Reviewed-by: Lukasz Majewski lukma@denx.de --- Changes in v3: - Fix env_get_f() call - Add Lukasz R-b
Changes in v2: - none --- drivers/mtd/mtd_uboot.c | 62 +++++++++++++++++++++++++++++++++++++++-- 1 file changed, 60 insertions(+), 2 deletions(-)
diff --git a/drivers/mtd/mtd_uboot.c b/drivers/mtd/mtd_uboot.c index 7d7a11c990d6..5ca560c96879 100644 --- a/drivers/mtd/mtd_uboot.c +++ b/drivers/mtd/mtd_uboot.c @@ -92,12 +92,70 @@ static void mtd_probe_uclass_mtd_devs(void) { } #endif
#if defined(CONFIG_MTD_PARTITIONS) +extern void board_mtdparts_default(const char **mtdids, + const char **mtdparts); + +static const char *get_mtdids(void) +{ + __maybe_unused const char *mtdparts = NULL; + const char *mtdids = env_get("mtdids"); + + if (mtdids) + return mtdids; + +#if defined(CONFIG_SYS_MTDPARTS_RUNTIME) + board_mtdparts_default(&mtdids, &mtdparts); +#elif defined(MTDIDS_DEFAULT) + mtdids = MTDIDS_DEFAULT; +#elif defined(CONFIG_MTDIDS_DEFAULT) + mtdids = CONFIG_MTDIDS_DEFAULT; +#endif + + if (mtdids) + env_set("mtdids", mtdids); + + return mtdids; +} + +#define MTDPARTS_MAXLEN 512 + +static const char *get_mtdparts(void) +{ + __maybe_unused const char *mtdids = NULL; + static char tmp_parts[MTDPARTS_MAXLEN]; + static bool use_defaults = true; + const char *mtdparts = NULL; + + if (gd->flags & GD_FLG_ENV_READY) + mtdparts = env_get("mtdparts"); + else if (env_get_f("mtdparts", tmp_parts, sizeof(tmp_parts)) != -1) + mtdparts = tmp_parts; + + if (mtdparts || !use_defaults) + return mtdparts; + +#if defined(CONFIG_SYS_MTDPARTS_RUNTIME) + board_mtdparts_default(&mtdids, &mtdparts); +#elif defined(MTDPARTS_DEFAULT) + mtdparts = MTDPARTS_DEFAULT; +#elif defined(CONFIG_MTDPARTS_DEFAULT) + mtdparts = CONFIG_MTDPARTS_DEFAULT; +#endif + + if (mtdparts) + env_set("mtdparts", mtdparts); + + use_defaults = false; + + return mtdparts; +} + int mtd_probe_devices(void) { static char *old_mtdparts; static char *old_mtdids; - const char *mtdparts = env_get("mtdparts"); - const char *mtdids = env_get("mtdids"); + const char *mtdparts = get_mtdparts(); + const char *mtdids = get_mtdids(); bool remaining_partitions = true; struct mtd_info *mtd;
dfu_fill_entity_nand() uses find_dev_and_part() and mtdparts_init() which are provided by cmd/mtdparts.c.
Add the dependency to avoid build failures when CMD_MTDPARTS is not selected.
Reported-by: Jagan Teki jagan@amarulasolutions.com Fixes: 6828e602b722d ("dfu: Migrate to Kconfig") Signed-off-by: Boris Brezillon boris.brezillon@bootlin.com Reviewed-by: Lukasz Majewski lukma@denx.de --- Changes in v3: - Add Lujasz R-b
Changes in v2: - Moved ealier in the series to avoid introducing a build failure --- drivers/dfu/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/dfu/Kconfig b/drivers/dfu/Kconfig index 51ab484c2a49..4692736c9d24 100644 --- a/drivers/dfu/Kconfig +++ b/drivers/dfu/Kconfig @@ -30,6 +30,7 @@ config DFU_MMC
config DFU_NAND bool "NAND back end for DFU" + depends on CMD_MTDPARTS help This option enables using DFU to read and write to NAND based storage.
gwventana configs are relying on CMD_UBI to select CMD_MTDPARTS, which is then making {MTDIDS,MTDPARTS}_DEFAULT options available.
We are about to remove the 'select CMD_MTDPARTS' statement in the CMD_UBI entry, but if we do that without first making sure {MTDIDS,MTDPARTS}_DEFAULT are visible, we end up with a build failure when building gwventana configs.
Address that by adding a depends on MTD_PARTITIONS to {MTDIDS,MTDPARTS}_DEFAULT which does the trick since CMD_UBI selects MTD_UBI which in turn selects MTD_PARTITIONS.
We also get rid of the depends on CMD_MTD, since CMD_MTD also selects MTD_PARTITIONS.
Reported-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: Boris Brezillon boris.brezillon@bootlin.com Reviewed-by: Lukasz Majewski lukma@denx.de --- Changes in v3: - Add Lujasz R-b
Changes in v2: - Moved ealier in the series to avoid introducing a build failure --- cmd/Kconfig | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index d66f710ad0f8..9310a8bdb2b7 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1728,14 +1728,14 @@ config CMD_MTDPARTS
config MTDIDS_DEFAULT string "Default MTD IDs" - depends on CMD_MTD || CMD_MTDPARTS || CMD_NAND || CMD_FLASH + depends on MTD_PARTITIONS || CMD_MTDPARTS || CMD_NAND || CMD_FLASH help Defines a default MTD IDs list for use with MTD partitions in the Linux MTD command line partitions format.
config MTDPARTS_DEFAULT string "Default MTD partition scheme" - depends on CMD_MTD || CMD_MTDPARTS || CMD_NAND || CMD_FLASH + depends on MTD_PARTITIONS || CMD_MTDPARTS || CMD_NAND || CMD_FLASH help Defines a default MTD partitioning scheme in the Linux MTD command line partitions format
Commit c58fb2cdb3e4 ("cmd: ubi: clean the partition handling") introduced a call to mtd_probe_devices() in the ubi_attach() path and this function takes care of parsing mtdparts/mtdids and creating/registering the associated mtd partitions.
The mtdparts_init() call in the ubi_detach() path is not only unnecessary but can sometimes print error messages even when things work properly (that's the case with SPI NAND devices that have not been probed with 'mtd list'), which is misleading.
Remove this call to mtdparts_init() and drop the dependency on CMD_MTDPARTS.
Fixes: c58fb2cdb3e4 ("cmd: ubi: clean the partition handling") Reported-by: Stefan Roese sr@denx.de Signed-off-by: Boris Brezillon boris.brezillon@bootlin.com Tested-by: Stefan Roese sr@denx.de Reviewed-by: Lukasz Majewski lukma@denx.de --- Changes in v3: - Add Lujasz R-b
Changes in v2: - Moved after the patches reworking the Kconfig deps --- cmd/Kconfig | 1 - cmd/ubi.c | 5 ----- 2 files changed, 6 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 9310a8bdb2b7..ad14c9ce7124 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1856,7 +1856,6 @@ endmenu
config CMD_UBI tristate "Enable UBI - Unsorted block images commands" - select CMD_MTDPARTS select CRC32 select MTD_UBI help diff --git a/cmd/ubi.c b/cmd/ubi.c index 767a4a453640..2b74a9814463 100644 --- a/cmd/ubi.c +++ b/cmd/ubi.c @@ -417,11 +417,6 @@ static int ubi_dev_scan(struct mtd_info *info, const char *vid_header_offset)
int ubi_detach(void) { - if (mtdparts_init() != 0) { - printf("Error initializing mtdparts!\n"); - return 1; - } - #ifdef CONFIG_CMD_UBIFS /* * Automatically unmount UBIFS partition when user
Commit 9c5b00973bce ("Convert CONFIG_MTD_PARTITIONS et al to Kconfig") introduced a publicly visible Kconfig entry for the CONFIG_MTD_PARTITIONS option, while the rework on MTD partitioning was in progress, and we somehow did not notice that the same Kconfig entry was added by commit 4048a5c519a8 ("mtd: declare MTD_PARTITIONS symbol in Kconfig"), but this time as an invisible entry (this can only be selected by other options).
Keep the non-visible version of this symbol, since MTD_PARTITIONS is not something the user should be able to enable/disable directly.
Fixes: 4048a5c519a8 ("mtd: declare MTD_PARTITIONS symbol in Kconfig") Signed-off-by: Boris Brezillon boris.brezillon@bootlin.com Reviewed-by: Lukasz Majewski lukma@denx.de --- Changes in v3: - Add Lujasz R-b
Changes in v2: - Moved after the patches reworking the Kconfig deps --- drivers/mtd/Kconfig | 6 ------ 1 file changed, 6 deletions(-)
diff --git a/drivers/mtd/Kconfig b/drivers/mtd/Kconfig index 11cf12bb5599..0050fb2b9bf1 100644 --- a/drivers/mtd/Kconfig +++ b/drivers/mtd/Kconfig @@ -22,12 +22,6 @@ config MTD_DEVICE Adds the MTD device infrastructure from the Linux kernel. Needed for mtdparts command support.
-config MTD_PARTITIONS - bool "Add MTD Partioning infrastructure" - help - Adds the MTD partitioning infrastructure from the Linux - kernel. Needed for UBI support. - config FLASH_CFI_DRIVER bool "Enable CFI Flash driver" help
Changes in v3:
- Add Lukasz R-b
Changes in v2:
- none
Why is there this extern ? This should use a prototype of function defined in a header file. Once someone changes the prototype and forgets to update this location, it'll be a disaster.
- __maybe_unused const char *mtdparts = NULL;
- if (mtdids)
return mtdids;
- board_mtdparts_default(&mtdids, &mtdparts);
- mtdids = MTDIDS_DEFAULT;
- mtdids = CONFIG_MTDIDS_DEFAULT;
- if (mtdids)
- return mtdids;
- __maybe_unused const char *mtdids = NULL;
- static char tmp_parts[MTDPARTS_MAXLEN];
- static bool use_defaults = true;
- const char *mtdparts = NULL;
- if (gd->flags & GD_FLG_ENV_READY)
- else if (env_get_f("mtdparts", tmp_parts, sizeof(tmp_parts)) != -1)
- if (mtdparts || !use_defaults)
return mtdparts;
- mtdparts = MTDPARTS_DEFAULT;
- mtdparts = CONFIG_MTDPARTS_DEFAULT;
- if (mtdparts)
- use_defaults = false;
- return mtdparts;
- const char *mtdparts = get_mtdparts();
- const char *mtdids = get_mtdids(); bool remaining_partitions = true; struct mtd_info *mtd;
Hi Marek,
Changes in v3:
- Add Lukasz R-b
Changes in v2:
- none
extern is not needed indeed.
When I provide a fix I try to avoid dependencies on changes that are not absolutely required hence the decision to keep this function prototype locally defined.
It seems you don't want this series to be queued for the v2018.11. That's your choice, and that's also your responsibility since you're blocking something that is fixing another known bug. I clearly won't fight for that, just know that the fix was posted 2 weeks ago, and until Saturday I had no news. Once Jagan reported the build failure, I came up with a fix in less than a day. You found a bug today, and I posted a new version right away. So I think I did everything I could to get this addressed in time.
Regards,
Boris
On Tue, Nov 13, 2018 at 01:39:51PM +0100, Boris Brezillon wrote:
Hi Marek,
Changes in v3:
- Add Lukasz R-b
Changes in v2:
- none
Towards the end of a release cycle (regardless of how long it is), we should aim for being more conservative in our code changes towards the end. At this particular point in time, doing it this way is fine. Thanks!
On 11/13/2018 01:39 PM, Boris Brezillon wrote:
Hi Marek,
Changes in v3:
- Add Lukasz R-b
Changes in v2:
- none
I am also expecting a patch which cleans this up then. I think __weak function would be appropriate.
Please stop guessing what I do or do not want. What I do not want is having patches with obvious and known bugs being queued, I think that is a reasonable requirement ?
Hi Marek,
Changes in v3:
- Add Lukasz R-b
Changes in v2:
- none
I don't think that's worth it. We have exactly one user of this fixup and weak functions do grow the binaries.
It's true that none of us can read minds. But at this point in this patch series cycle, no, you're not talking about "known bugs". Yes, externs should always be in header files. But a quick and simple git grep shows 171 .c files with extern in them. So I hardly think this is a critical must change thing right now. Deserving of a spot on the TODO list? Yes.
Hi Marek,
Changes in v3:
- Add Lukasz R-b
Changes in v2:
- none
Well, I think the best would be to get rid of this function. It's only implemented by board/isee/igep00x0/igep00x0.c, and we might be able to use CONFIG_{MTDPARTS,MTDIDS}_DEFAULT to replace it:
CONFIG_MTDPARTS_DEFAULT "omap2-nand:Xk(SPL),-(UBI);omap2-onenand:Yk(SPL),-(UBI)" CONFIG_MTDIDS_DEFAULT "nand0=omap2-nand,onenand0=omap2-onenand"
This assumes we know the eraseblock size of the NAND and OneNAND devices of course (X and Y in the above def).
Hi Marek,
Changes in v3:
- Add Lukasz R-b
Changes in v2:
- none
I'm not sure, I think it's doing run-time checks to see if we're on the NAND or OneNAND variant.
Hi Marek,
Changes in v3:
- Add Lukasz R-b
Changes in v2:
- none
Yes, but by having both of them defined in the mtdids/mtdparts defaults we solve this problem. The only problem we might have is if they those boards use NAND/OneNAND parts exposing different eraseblock size.
Hi Marek,
Changes in v3:
- Add Lukasz R-b
Changes in v2:
- none
Fine by me , and yes, that can be put on ToDo.
Boris Brezillon
