[U-Boot] [PATCH] mpc512x: remove dead code
The prt_mpc512x_clks() function isn't referenced anywhere and its prototype is wrong. Remove it.
Signed-off-by: Anatolij Gustschin agust@denx.de --- arch/powerpc/cpu/mpc512x/speed.c | 6 ------ include/common.h | 3 --- 2 files changed, 0 insertions(+), 9 deletions(-)
diff --git a/arch/powerpc/cpu/mpc512x/speed.c b/arch/powerpc/cpu/mpc512x/speed.c index 9a8f315..6761877 100644 --- a/arch/powerpc/cpu/mpc512x/speed.c +++ b/arch/powerpc/cpu/mpc512x/speed.c @@ -151,9 +151,3 @@ U_BOOT_CMD(clocks, 1, 0, do_clocks, "print clock configuration", " clocks" ); - -int prt_mpc512x_clks (void) -{ - do_clocks (NULL, 0, 0, NULL); - return (0); -} diff --git a/include/common.h b/include/common.h index 69eeea4..96e3504 100644 --- a/include/common.h +++ b/include/common.h @@ -631,9 +631,6 @@ int prt_8260_clks (void); #elif defined(CONFIG_MPC5xxx) int prt_mpc5xxx_clks (void); #endif -#if defined(CONFIG_MPC512X) -int prt_mpc512xxx_clks (void); -#endif #if defined(CONFIG_MPC8220) int prt_mpc8220_clks (void); #endif
Dear Anatolij Gustschin,
Applied, thanks.
Anatolij Gustschin
