[PATCH] arm64: zynqmp: Update the i2c0 node for zcu1285
From: Shubhrajyoti Datta shubhrajyoti.datta@amd.com
The pca mux is not added to the i2c0 bus so remove it from the bus.
Signed-off-by: Shubhrajyoti Datta shubhrajyoti.datta@amd.com Signed-off-by: Michal Simek michal.simek@amd.com ---
arch/arm/dts/zynqmp-zcu1285-revA.dts | 174 --------------------------- 1 file changed, 174 deletions(-)
diff --git a/arch/arm/dts/zynqmp-zcu1285-revA.dts b/arch/arm/dts/zynqmp-zcu1285-revA.dts index 4f85837e64f6..38735b1ce1ac 100644 --- a/arch/arm/dts/zynqmp-zcu1285-revA.dts +++ b/arch/arm/dts/zynqmp-zcu1285-revA.dts @@ -37,26 +37,6 @@ reg = <0x0 0x0 0x0 0x80000000>; };
- ina226-u60 { - compatible = "iio-hwmon"; - io-channels = <&u60 0>, <&u60 1>, <&u60 2>, <&u60 3>; - }; - ina226-u61 { - compatible = "iio-hwmon"; - io-channels = <&u61 0>, <&u61 1>, <&u61 2>, <&u61 3>; - }; - ina226-u63 { - compatible = "iio-hwmon"; - io-channels = <&u63 0>, <&u63 1>, <&u63 2>, <&u63 3>; - }; - ina226-u65 { - compatible = "iio-hwmon"; - io-channels = <&u65 0>, <&u65 1>, <&u65 2>, <&u65 3>; - }; - ina226-u64 { - compatible = "iio-hwmon"; - io-channels = <&u64 0>, <&u64 1>, <&u64 2>, <&u64 3>; - }; };
&dcc { @@ -67,160 +47,6 @@ status = "okay"; clock-frequency = <400000>;
- i2c-mux@75 { - compatible = "nxp,pca9548"; /* u22 */ - #address-cells = <1>; - #size-cells = <0>; - reg = <0x75>; - - i2c@0 { - #address-cells = <1>; - #size-cells = <0>; - reg = <0>; - /* PMBUS */ - max20751@74 { /* u23 */ - compatible = "maxim,max20751"; - reg = <0x74>; - }; - max20751@70 { /* u89 */ - compatible = "maxim,max20751"; - reg = <0x70>; - }; - max15301@a { /* u28 */ - compatible = "maxim,max15301"; - reg = <0xa>; - }; - max15303@b { /* u48 */ - compatible = "maxim,max15303"; - reg = <0xb>; - }; - max15303@d { /* u27 */ - compatible = "maxim,max15303"; - reg = <0xd>; - }; - max15303@e { /* u11 */ - compatible = "maxim,max15303"; - reg = <0xe>; - }; - max15303@f { /* u96 */ - compatible = "maxim,max15303"; - reg = <0xf>; - }; - max15303@11 { /* u47 */ - compatible = "maxim,max15303"; - reg = <0x11>; - }; - max15303@12 { /* u24 */ - compatible = "maxim,max15303"; - reg = <0x12>; - }; - max15301@13 { /* u29 */ - compatible = "maxim,max15301"; - reg = <0x13>; - }; - max15303@14 { /* u51 */ - compatible = "maxim,max15303"; - reg = <0x14>; - }; - max15303@15 { /* u30 */ - compatible = "maxim,max15303"; - reg = <0x15>; - }; - max15303@16 { /* u102 */ - compatible = "maxim,max15303"; - reg = <0x16>; - }; - max15301@17 { /* u50 */ - compatible = "maxim,max15301"; - reg = <0x17>; - }; - max15301@18 { /* u31 */ - compatible = "maxim,max15301"; - reg = <0x18>; - }; - }; - i2c@1 { - #address-cells = <1>; - #size-cells = <0>; - reg = <1>; - /* CM_I2C */ - }; - i2c@2 { - #address-cells = <1>; - #size-cells = <0>; - reg = <2>; - /* SYS_EEPROM */ - eeprom: eeprom@54 { /* u101 */ - compatible = "atmel,24c32"; /* 24LC32A */ - reg = <0x54>; - }; - }; - i2c@3 { - #address-cells = <1>; - #size-cells = <0>; - reg = <3>; - /* FMC1 */ - }; - i2c@4 { - #address-cells = <1>; - #size-cells = <0>; - reg = <4>; - /* FMC2 */ - }; - i2c@5 { - #address-cells = <1>; - #size-cells = <0>; - reg = <5>; - /* ANALOG_PMBUS */ - u60: ina226@40 { /* u60 */ - compatible = "ti,ina226"; - #io-channel-cells = <1>; - label = "ina226-u60"; - reg = <0x40>; - shunt-resistor = <1000>; - }; - u61: ina226@41 { /* u61 */ - compatible = "ti,ina226"; - #io-channel-cells = <1>; - label = "ina226-u61"; - reg = <0x41>; - shunt-resistor = <1000>; - }; - u63: ina226@42 { /* u63 */ - compatible = "ti,ina226"; - #io-channel-cells = <1>; - label = "ina226-u63"; - reg = <0x42>; - shunt-resistor = <1000>; - }; - u65: ina226@43 { /* u65 */ - compatible = "ti,ina226"; - #io-channel-cells = <1>; - label = "ina226-u65"; - reg = <0x43>; - shunt-resistor = <1000>; - }; - u64: ina226@44 { /* u64 */ - compatible = "ti,ina226"; - #io-channel-cells = <1>; - label = "ina226-u64"; - reg = <0x44>; - shunt-resistor = <1000>; - }; - }; - i2c@6 { - #address-cells = <1>; - #size-cells = <0>; - reg = <6>; - /* ANALOG_CM_I2C */ - }; - i2c@7 { - #address-cells = <1>; - #size-cells = <0>; - reg = <7>; - /* FMC3 */ - }; - }; };
&gem1 {
ina226-u60 {
ina226-u61 {
ina226-u63 {
ina226-u65 {
ina226-u64 {
&dcc {
i2c-mux@75 {
#size-cells = <0>;
reg = <0x75>;
i2c@0 {
#size-cells = <0>;
reg = <0>;
/* PMBUS */
reg = <0x74>;
reg = <0x70>;
reg = <0xa>;
reg = <0xb>;
reg = <0xd>;
reg = <0xe>;
reg = <0xf>;
reg = <0x11>;
reg = <0x12>;
reg = <0x13>;
reg = <0x14>;
reg = <0x15>;
reg = <0x16>;
reg = <0x17>;
reg = <0x18>;
i2c@1 {
#size-cells = <0>;
reg = <1>;
/* CM_I2C */
i2c@2 {
#size-cells = <0>;
reg = <2>;
/* SYS_EEPROM */
reg = <0x54>;
i2c@3 {
#size-cells = <0>;
reg = <3>;
/* FMC1 */
i2c@4 {
#size-cells = <0>;
reg = <4>;
/* FMC2 */
i2c@5 {
#size-cells = <0>;
reg = <5>;
/* ANALOG_PMBUS */
reg = <0x40>;
reg = <0x41>;
reg = <0x42>;
reg = <0x43>;
reg = <0x44>;
i2c@6 {
#size-cells = <0>;
reg = <6>;
/* ANALOG_CM_I2C */
i2c@7 {
#size-cells = <0>;
reg = <7>;
/* FMC3 */
&gem1 {
Applied. M
Michal Simek
