[PATCH 0/2] sunxi: H616: Add LPDDR3 DRAM type
At the moment, the driver only supports DDR3 memory. Add support for a new type DRAM. These changes have been successfully tested by me with tvbox tra###eed t98-h2b-lp3.
iuncuim (2): sunxi: H616: add DRAM type selection sunxi: H616: add LPDDR3 DRAM support
.../include/asm/arch-sunxi/dram_sun50i_h616.h | 1 + arch/arm/mach-sunxi/Kconfig | 18 +- arch/arm/mach-sunxi/dram_sun50i_h616.c | 215 ++++++++++++------ arch/arm/mach-sunxi/dram_timings/Makefile | 4 +- .../arm/mach-sunxi/dram_timings/h616_lpddr3.c | 95 ++++++++ configs/orangepi_zero2_defconfig | 1 + configs/x96_mate_defconfig | 1 + 7 files changed, 266 insertions(+), 69 deletions(-) create mode 100644 arch/arm/mach-sunxi/dram_timings/h616_lpddr3.c
Allwinner H616 SoC supports several types of DRAM memory. To further integrate other types of memory, we need to add this delimitation. --- arch/arm/mach-sunxi/Kconfig | 12 ++++++++++-- arch/arm/mach-sunxi/dram_timings/Makefile | 3 +-- configs/orangepi_zero2_defconfig | 1 + configs/x96_mate_defconfig | 1 + 4 files changed, 13 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index 6dcbb096f7..3ad37ef6ba 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -442,7 +442,7 @@ config ARM_BOOT_HOOK_RMR This allows both the SPL and the U-Boot proper to be entered in either mode and switch to AArch64 if needed.
-if SUNXI_DRAM_DW || DRAM_SUN50I_H6 +if SUNXI_DRAM_DW || DRAM_SUN50I_H6 || DRAM_SUN50I_H616 config SUNXI_DRAM_DDR3 bool
@@ -487,6 +487,14 @@ config SUNXI_DRAM_H6_DDR3_1333 This option is the DDR3 timing used by the boot0 on H6 TV boxes which use a DDR3-1333 timing.
+config SUNXI_DRAM_H616_DDR3_1333 + bool "DDR3-1333 boot0 timings on the H616 DRAM controller" + select SUNXI_DRAM_DDR3 + depends on DRAM_SUN50I_H616 + ---help--- + This option is the DDR3 timing used by the boot0 on H616 TV boxes + which use a DDR3-1333 timing. + config SUNXI_DRAM_DDR2_V3S bool "DDR2 found in V3s chip" select SUNXI_DRAM_DDR2 @@ -1075,4 +1083,4 @@ config CHIP_DIP_SCAN select W1_GPIO select W1_EEPROM select W1_EEPROM_DS24XXX - select CMD_EXTENSION + select CMD_EXTENSION \ No newline at end of file diff --git a/arch/arm/mach-sunxi/dram_timings/Makefile b/arch/arm/mach-sunxi/dram_timings/Makefile index 39a8756c29..4d78c04c9a 100644 --- a/arch/arm/mach-sunxi/dram_timings/Makefile +++ b/arch/arm/mach-sunxi/dram_timings/Makefile @@ -3,5 +3,4 @@ obj-$(CONFIG_SUNXI_DRAM_LPDDR3_STOCK) += lpddr3_stock.o obj-$(CONFIG_SUNXI_DRAM_DDR2_V3S) += ddr2_v3s.o obj-$(CONFIG_SUNXI_DRAM_H6_LPDDR3) += h6_lpddr3.o obj-$(CONFIG_SUNXI_DRAM_H6_DDR3_1333) += h6_ddr3_1333.o -# currently only DDR3 is supported on H616 -obj-$(CONFIG_MACH_SUN50I_H616) += h616_ddr3_1333.o +obj-$(CONFIG_SUNXI_DRAM_H616_DDR3_1333) += h616_ddr3_1333.o diff --git a/configs/orangepi_zero2_defconfig b/configs/orangepi_zero2_defconfig index 6cb942f511..e38cc20ac7 100644 --- a/configs/orangepi_zero2_defconfig +++ b/configs/orangepi_zero2_defconfig @@ -7,6 +7,7 @@ CONFIG_DRAM_SUN50I_H616_DX_DRI=0x0e0e0e0e CONFIG_DRAM_SUN50I_H616_CA_DRI=0x0e0e CONFIG_DRAM_SUN50I_H616_TPR10=0xf83438 CONFIG_MACH_SUN50I_H616=y +CONFIG_SUNXI_DRAM_H616_DDR3_1333=y CONFIG_R_I2C_ENABLE=y CONFIG_SPL_SPI_SUNXI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/x96_mate_defconfig b/configs/x96_mate_defconfig index aedb327702..2a326bf202 100644 --- a/configs/x96_mate_defconfig +++ b/configs/x96_mate_defconfig @@ -11,6 +11,7 @@ CONFIG_DRAM_SUN50I_H616_TPR10=0x2f0007 CONFIG_DRAM_SUN50I_H616_TPR11=0xffffdddd CONFIG_DRAM_SUN50I_H616_TPR12=0xfedf7557 CONFIG_MACH_SUN50I_H616=y +CONFIG_SUNXI_DRAM_H616_DDR3_1333=y CONFIG_R_I2C_ENABLE=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C=y
On Sat, 3 Jun 2023 16:55:05 +0300 Mikhail Kalashnikov iuncuim@gmail.com wrote:
Hi Mikhail,
I realised that the patches are missing your Signed-off-by, which signify that your contributions comply with "the rules": https://u-boot.readthedocs.io/en/latest/develop/process.html#review-process-...
Can you please reply to both of your own patches and add this line after the commit message (like this text here)? I cannot merge the patches otherwise.
Thanks, Andre
- bool "DDR3-1333 boot0 timings on the H616 DRAM controller"
- select SUNXI_DRAM_DDR3
- depends on DRAM_SUN50I_H616
- ---help---
- This option is the DDR3 timing used by the boot0 on H616 TV boxes
- which use a DDR3-1333 timing.
Signed-off-by: Mikhail Kalashnikov iuncuim@gmail.com
сб, 3 июн. 2023 г. в 16:55, Mikhail Kalashnikov iuncuim@gmail.com:
---help---
\ No newline at end of file diff --git a/arch/arm/mach-sunxi/dram_timings/Makefile b/arch/arm/mach-sunxi/dram_timings/Makefile index 39a8756c29..4d78c04c9a 100644 --- a/arch/arm/mach-sunxi/dram_timings/Makefile +++ b/arch/arm/mach-sunxi/dram_timings/Makefile @@ -3,5 +3,4 @@ obj-$(CONFIG_SUNXI_DRAM_LPDDR3_STOCK) += lpddr3_stock.o obj-$(CONFIG_SUNXI_DRAM_DDR2_V3S) += ddr2_v3s.o obj-$(CONFIG_SUNXI_DRAM_H6_LPDDR3) += h6_lpddr3.o obj-$(CONFIG_SUNXI_DRAM_H6_DDR3_1333) += h6_ddr3_1333.o -# currently only DDR3 is supported on H616 -obj-$(CONFIG_MACH_SUN50I_H616) += h616_ddr3_1333.o +obj-$(CONFIG_SUNXI_DRAM_H616_DDR3_1333) += h616_ddr3_1333.o diff --git a/configs/orangepi_zero2_defconfig b/configs/orangepi_zero2_defconfig index 6cb942f511..e38cc20ac7 100644 --- a/configs/orangepi_zero2_defconfig +++ b/configs/orangepi_zero2_defconfig @@ -7,6 +7,7 @@ CONFIG_DRAM_SUN50I_H616_DX_DRI=0x0e0e0e0e CONFIG_DRAM_SUN50I_H616_CA_DRI=0x0e0e CONFIG_DRAM_SUN50I_H616_TPR10=0xf83438 CONFIG_MACH_SUN50I_H616=y +CONFIG_SUNXI_DRAM_H616_DDR3_1333=y CONFIG_R_I2C_ENABLE=y CONFIG_SPL_SPI_SUNXI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/x96_mate_defconfig b/configs/x96_mate_defconfig index aedb327702..2a326bf202 100644 --- a/configs/x96_mate_defconfig +++ b/configs/x96_mate_defconfig @@ -11,6 +11,7 @@ CONFIG_DRAM_SUN50I_H616_TPR10=0x2f0007 CONFIG_DRAM_SUN50I_H616_TPR11=0xffffdddd CONFIG_DRAM_SUN50I_H616_TPR12=0xfedf7557 CONFIG_MACH_SUN50I_H616=y +CONFIG_SUNXI_DRAM_H616_DDR3_1333=y CONFIG_R_I2C_ENABLE=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C=y -- 2.40.1
The H616 SoC has support for several types of DRAM: DDR3, LPDDR3, DDR4 and LPDDR4. At the moment, the driver only supports DDR3 memory. Let's extend the driver to support the LPDDR3 memory. All "magic" values obtained from the boot0. --- .../include/asm/arch-sunxi/dram_sun50i_h616.h | 1 + arch/arm/mach-sunxi/Kconfig | 10 +- arch/arm/mach-sunxi/dram_sun50i_h616.c | 215 ++++++++++++------ arch/arm/mach-sunxi/dram_timings/Makefile | 1 + .../arm/mach-sunxi/dram_timings/h616_lpddr3.c | 95 ++++++++ 5 files changed, 255 insertions(+), 67 deletions(-) create mode 100644 arch/arm/mach-sunxi/dram_timings/h616_lpddr3.c
diff --git a/arch/arm/include/asm/arch-sunxi/dram_sun50i_h616.h b/arch/arm/include/asm/arch-sunxi/dram_sun50i_h616.h index 6db869c098..bf4188fa89 100644 --- a/arch/arm/include/asm/arch-sunxi/dram_sun50i_h616.h +++ b/arch/arm/include/asm/arch-sunxi/dram_sun50i_h616.h @@ -148,6 +148,7 @@ check_member(sunxi_mctl_ctl_reg, unk_0x4240, 0x4240); struct dram_para { u32 clk; enum sunxi_dram_type type; + u8 phy_init[27]; u8 cols; u8 rows; u8 ranks; diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index 3ad37ef6ba..5ce82a955c 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -487,6 +487,14 @@ config SUNXI_DRAM_H6_DDR3_1333 This option is the DDR3 timing used by the boot0 on H6 TV boxes which use a DDR3-1333 timing.
+config SUNXI_DRAM_H616_LPDDR3 + bool "LPDDR3 DRAM chips on the H616 DRAM controller" + select SUNXI_DRAM_LPDDR3 + depends on DRAM_SUN50I_H616 + ---help--- + This option is the LPDDR3 timing used by the stock boot0 by + Allwinner. + config SUNXI_DRAM_H616_DDR3_1333 bool "DDR3-1333 boot0 timings on the H616 DRAM controller" select SUNXI_DRAM_DDR3 @@ -1083,4 +1091,4 @@ config CHIP_DIP_SCAN select W1_GPIO select W1_EEPROM select W1_EEPROM_DS24XXX - select CMD_EXTENSION \ No newline at end of file + select CMD_EXTENSION diff --git a/arch/arm/mach-sunxi/dram_sun50i_h616.c b/arch/arm/mach-sunxi/dram_sun50i_h616.c index 1f9416d6ea..d34b218ee5 100644 --- a/arch/arm/mach-sunxi/dram_sun50i_h616.c +++ b/arch/arm/mach-sunxi/dram_sun50i_h616.c @@ -227,13 +227,6 @@ static void mctl_set_addrmap(struct dram_para *para) mctl_ctl->addrmap[8] = 0x3F3F; }
-static const u8 phy_init[] = { - 0x07, 0x0b, 0x02, 0x16, 0x0d, 0x0e, 0x14, 0x19, - 0x0a, 0x15, 0x03, 0x13, 0x04, 0x0c, 0x10, 0x06, - 0x0f, 0x11, 0x1a, 0x01, 0x12, 0x17, 0x00, 0x08, - 0x09, 0x05, 0x18 -}; - static void mctl_phy_configure_odt(struct dram_para *para) { unsigned int val; @@ -263,19 +256,31 @@ static void mctl_phy_configure_odt(struct dram_para *para) writel_relaxed(val, SUNXI_DRAM_PHY0_BASE + 0x34c);
val = para->dx_odt & 0x1f; - writel_relaxed(val, SUNXI_DRAM_PHY0_BASE + 0x380); + if (para->type == SUNXI_DRAM_TYPE_LPDDR3) + writel_relaxed(0, SUNXI_DRAM_PHY0_BASE + 0x380); + else + writel_relaxed(val, SUNXI_DRAM_PHY0_BASE + 0x380); writel_relaxed(val, SUNXI_DRAM_PHY0_BASE + 0x384);
val = (para->dx_odt >> 8) & 0x1f; - writel_relaxed(val, SUNXI_DRAM_PHY0_BASE + 0x3c0); + if (para->type == SUNXI_DRAM_TYPE_LPDDR3) + writel_relaxed(0, SUNXI_DRAM_PHY0_BASE + 0x3c0); + else + writel_relaxed(val, SUNXI_DRAM_PHY0_BASE + 0x3c0); writel_relaxed(val, SUNXI_DRAM_PHY0_BASE + 0x3c4);
val = (para->dx_odt >> 16) & 0x1f; - writel_relaxed(val, SUNXI_DRAM_PHY0_BASE + 0x400); + if (para->type == SUNXI_DRAM_TYPE_LPDDR3) + writel_relaxed(0, SUNXI_DRAM_PHY0_BASE + 0x400); + else + writel_relaxed(val, SUNXI_DRAM_PHY0_BASE + 0x400); writel_relaxed(val, SUNXI_DRAM_PHY0_BASE + 0x404);
val = (para->dx_odt >> 24) & 0x1f; - writel_relaxed(val, SUNXI_DRAM_PHY0_BASE + 0x440); + if (para->type == SUNXI_DRAM_TYPE_LPDDR3) + writel_relaxed(0, SUNXI_DRAM_PHY0_BASE + 0x440); + else + writel_relaxed(val, SUNXI_DRAM_PHY0_BASE + 0x440); writel_relaxed(val, SUNXI_DRAM_PHY0_BASE + 0x444);
dmb(); @@ -793,31 +798,47 @@ static void mctl_phy_ca_bit_delay_compensation(struct dram_para *para) writel(val, SUNXI_DRAM_PHY0_BASE + 0x7e0); writel(val, SUNXI_DRAM_PHY0_BASE + 0x7f4);
- /* following configuration is DDR3 specific */ - val = (para->tpr10 >> 7) & 0x1e; - if (para->tpr2 & 1) { - writel(val, SUNXI_DRAM_PHY0_BASE + 0x794); - if (para->ranks == 2) { - val = (para->tpr10 >> 11) & 0x1e; - writel(val, SUNXI_DRAM_PHY0_BASE + 0x7e4); - } - if (para->tpr0 & BIT(31)) { - val = (para->tpr0 << 1) & 0x3e; - writel(val, SUNXI_DRAM_PHY0_BASE + 0x790); - writel(val, SUNXI_DRAM_PHY0_BASE + 0x7b8); - writel(val, SUNXI_DRAM_PHY0_BASE + 0x7cc); - } - } else { - writel(val, SUNXI_DRAM_PHY0_BASE + 0x7d4); - if (para->ranks == 2) { - val = (para->tpr10 >> 11) & 0x1e; - writel(val, SUNXI_DRAM_PHY0_BASE + 0x79c); + if (para->type == SUNXI_DRAM_TYPE_DDR3) { + val = (para->tpr10 >> 7) & 0x1e; + if (para->tpr2 & 1) { + writel(val, SUNXI_DRAM_PHY0_BASE + 0x794); + if (para->ranks == 2) { + val = (para->tpr10 >> 11) & 0x1e; + writel(val, SUNXI_DRAM_PHY0_BASE + 0x7e4); + } + if (para->tpr0 & BIT(31)) { + val = (para->tpr0 << 1) & 0x3e; + writel(val, SUNXI_DRAM_PHY0_BASE + 0x790); + writel(val, SUNXI_DRAM_PHY0_BASE + 0x7b8); + writel(val, SUNXI_DRAM_PHY0_BASE + 0x7cc); + } + } else { + writel(val, SUNXI_DRAM_PHY0_BASE + 0x7d4); + if (para->ranks == 2) { + val = (para->tpr10 >> 11) & 0x1e; + writel(val, SUNXI_DRAM_PHY0_BASE + 0x79c); + } + if (para->tpr0 & BIT(31)) { + val = (para->tpr0 << 1) & 0x3e; + writel(val, SUNXI_DRAM_PHY0_BASE + 0x78c); + writel(val, SUNXI_DRAM_PHY0_BASE + 0x7a4); + writel(val, SUNXI_DRAM_PHY0_BASE + 0x7b8); + } } - if (para->tpr0 & BIT(31)) { - val = (para->tpr0 << 1) & 0x3e; - writel(val, SUNXI_DRAM_PHY0_BASE + 0x78c); - writel(val, SUNXI_DRAM_PHY0_BASE + 0x7a4); - writel(val, SUNXI_DRAM_PHY0_BASE + 0x7b8); + } else if (para->type == SUNXI_DRAM_TYPE_LPDDR3) { + val = (para->tpr10 >> 7) & 0x1e; + if (para->tpr2 & 1) { + writel(val, SUNXI_DRAM_PHY0_BASE + 0x7a0); + if (para->ranks == 2) { + val = (para->tpr10 >> 11) & 0x1e; + writel(val, SUNXI_DRAM_PHY0_BASE + 0x79c); + } + } else { + writel(val, SUNXI_DRAM_PHY0_BASE + 0x7e8); + if (para->ranks == 2) { + val = (para->tpr10 >> 11) & 0x1e; + writel(val, SUNXI_DRAM_PHY0_BASE + 0x7f8); + } } } } @@ -838,11 +859,22 @@ static bool mctl_phy_init(struct dram_para *para) clrsetbits_le32(SUNXI_DRAM_PHY0_BASE + 0x3c, 0xf, val);
if (para->tpr2 & 0x100) { - val = 9; - val2 = 7; + if (para->type == SUNXI_DRAM_TYPE_DDR3) { + val = 9; + val2 = 7; + } else if (para->type == SUNXI_DRAM_TYPE_LPDDR3) { + // FIXME: don't know that values in this case, so fill the same + val = 14; + val2 = 8; + } } else { - val = 13; - val2 = 9; + if (para->type == SUNXI_DRAM_TYPE_DDR3) { + val = 13; + val2 = 9; + } else if (para->type == SUNXI_DRAM_TYPE_LPDDR3) { + val = 14; + val2 = 8; + } }
writel(val, SUNXI_DRAM_PHY0_BASE + 0x14); @@ -861,18 +893,26 @@ static bool mctl_phy_init(struct dram_para *para) writel(val2, SUNXI_DRAM_PHY0_BASE + 0x37c);
ptr = (u32 *)(SUNXI_DRAM_PHY0_BASE + 0xc0); - for (i = 0; i < ARRAY_SIZE(phy_init); i++) - writel(phy_init[i], &ptr[i]); + for (i = 0; i < ARRAY_SIZE(para->phy_init); i++) + writel(para->phy_init[i], &ptr[i]);
if (para->tpr10 & TPR10_CA_BIT_DELAY) mctl_phy_ca_bit_delay_compensation(para);
- writel(0x80, SUNXI_DRAM_PHY0_BASE + 0x3dc); - writel(0x80, SUNXI_DRAM_PHY0_BASE + 0x45c); + if (para->type == SUNXI_DRAM_TYPE_DDR3) + val = 0x80; + else if (para->type == SUNXI_DRAM_TYPE_LPDDR3) + val = 0xc0; + writel(val, SUNXI_DRAM_PHY0_BASE + 0x3dc); + writel(val, SUNXI_DRAM_PHY0_BASE + 0x45c);
mctl_phy_configure_odt(para);
- clrsetbits_le32(SUNXI_DRAM_PHY0_BASE + 4, 7, 0xa); + if (para->type == SUNXI_DRAM_TYPE_DDR3) { + clrsetbits_le32(SUNXI_DRAM_PHY0_BASE + 4, 7, 0xa); + } else if (para->type == SUNXI_DRAM_TYPE_LPDDR3) { + clrsetbits_le32(SUNXI_DRAM_PHY0_BASE + 4, 7, 0xb); + }
if (para->clk <= 672) writel(0xf, SUNXI_DRAM_PHY0_BASE + 0x20); @@ -922,21 +962,39 @@ static bool mctl_phy_init(struct dram_para *para) mr2 = 0x20; }
- writel(mr0, &mctl_ctl->mrctrl1); - writel(0x80000030, &mctl_ctl->mrctrl0); - mctl_await_completion(&mctl_ctl->mrctrl0, BIT(31), 0); - - writel(4, &mctl_ctl->mrctrl1); - writel(0x80001030, &mctl_ctl->mrctrl0); - mctl_await_completion(&mctl_ctl->mrctrl0, BIT(31), 0); - - writel(mr2, &mctl_ctl->mrctrl1); - writel(0x80002030, &mctl_ctl->mrctrl0); - mctl_await_completion(&mctl_ctl->mrctrl0, BIT(31), 0); - - writel(0, &mctl_ctl->mrctrl1); - writel(0x80003030, &mctl_ctl->mrctrl0); - mctl_await_completion(&mctl_ctl->mrctrl0, BIT(31), 0); + if (para->type == SUNXI_DRAM_TYPE_DDR3) { + writel(mr0, &mctl_ctl->mrctrl1); + writel(0x80000030, &mctl_ctl->mrctrl0); + mctl_await_completion(&mctl_ctl->mrctrl0, BIT(31), 0); + + writel(4, &mctl_ctl->mrctrl1); + writel(0x80001030, &mctl_ctl->mrctrl0); + mctl_await_completion(&mctl_ctl->mrctrl0, BIT(31), 0); + + writel(mr2, &mctl_ctl->mrctrl1); + writel(0x80002030, &mctl_ctl->mrctrl0); + mctl_await_completion(&mctl_ctl->mrctrl0, BIT(31), 0); + + writel(0, &mctl_ctl->mrctrl1); + writel(0x80003030, &mctl_ctl->mrctrl0); + mctl_await_completion(&mctl_ctl->mrctrl0, BIT(31), 0); + } else if (para->type == SUNXI_DRAM_TYPE_LPDDR3) { + writel(mr0, &mctl_ctl->mrctrl1); + writel(0x800000f0, &mctl_ctl->mrctrl0); + mctl_await_completion(&mctl_ctl->mrctrl0, BIT(31), 0); + + writel(4, &mctl_ctl->mrctrl1); + writel(0x800000f0, &mctl_ctl->mrctrl0); + mctl_await_completion(&mctl_ctl->mrctrl0, BIT(31), 0); + + writel(mr2, &mctl_ctl->mrctrl1); + writel(0x800000f0, &mctl_ctl->mrctrl0); + mctl_await_completion(&mctl_ctl->mrctrl0, BIT(31), 0); + + writel(0x301, &mctl_ctl->mrctrl1); + writel(0x800000f0, &mctl_ctl->mrctrl0); + mctl_await_completion(&mctl_ctl->mrctrl0, BIT(31), 0); + }
writel(0, SUNXI_DRAM_PHY0_BASE + 0x54);
@@ -1011,7 +1069,10 @@ static bool mctl_ctrl_init(struct dram_para *para) setbits_le32(&mctl_com->unk_0x008, 0xff00);
reg_val = MSTR_BURST_LENGTH(8) | MSTR_ACTIVE_RANKS(para->ranks); - reg_val |= MSTR_DEVICETYPE_DDR3 | MSTR_2TMODE; + if (para->type == SUNXI_DRAM_TYPE_DDR3) + reg_val |= MSTR_DEVICETYPE_DDR3 | MSTR_2TMODE; + else if (para->type == SUNXI_DRAM_TYPE_LPDDR3) + reg_val |= MSTR_DEVICETYPE_LPDDR3; if (para->bus_full_width) reg_val |= MSTR_BUSWIDTH_FULL; else @@ -1023,10 +1084,14 @@ static bool mctl_ctrl_init(struct dram_para *para) else writel(0x0201, &mctl_ctl->odtmap);
- writel(0x06000400, &mctl_ctl->odtcfg); - writel(0x06000400, &mctl_ctl->unk_0x2240); - writel(0x06000400, &mctl_ctl->unk_0x3240); - writel(0x06000400, &mctl_ctl->unk_0x4240); + if (para->type == SUNXI_DRAM_TYPE_DDR3) + reg_val = 0x06000400; + else if (para->type == SUNXI_DRAM_TYPE_LPDDR3) + reg_val = 0x09020400; + writel(reg_val, &mctl_ctl->odtcfg); + writel(reg_val, &mctl_ctl->unk_0x2240); + writel(reg_val, &mctl_ctl->unk_0x3240); + writel(reg_val, &mctl_ctl->unk_0x4240);
writel(BIT(31), &mctl_com->cr);
@@ -1155,13 +1220,31 @@ static unsigned long mctl_calc_size(struct dram_para *para) return (1ULL << (para->cols + para->rows + 3)) * width * para->ranks; }
+#define SUN50I_H616_DDR3_PHY_INIT \ + { 0x07, 0x0b, 0x02, 0x16, 0x0d, 0x0e, 0x14, 0x19, \ + 0x0a, 0x15, 0x03, 0x13, 0x04, 0x0c, 0x10, 0x06, \ + 0x0f, 0x11, 0x1a, 0x01, 0x12, 0x17, 0x00, 0x08, \ + 0x09, 0x05, 0x18 } + +#define SUN50I_H616_LPDDR3_PHY_INIT \ + { 0x18, 0x06, 0x00, 0x05, 0x04, 0x03, 0x09, 0x02, \ + 0x08, 0x01, 0x0a, 0x0b, 0x0c, 0x0d, 0x0e, 0x0f, \ + 0x10, 0x11, 0x12, 0x13, 0x14, 0x15, 0x16, 0x07, \ + 0x17, 0x19, 0x1a } + unsigned long sunxi_dram_init(void) { struct sunxi_prcm_reg *const prcm = (struct sunxi_prcm_reg *)SUNXI_PRCM_BASE; struct dram_para para = { - .clk = CONFIG_DRAM_CLK, +#ifdef CONFIG_SUNXI_DRAM_H616_DDR3_1333 .type = SUNXI_DRAM_TYPE_DDR3, + .phy_init = SUN50I_H616_DDR3_PHY_INIT, +#elif defined(CONFIG_SUNXI_DRAM_H616_LPDDR3) + .type = SUNXI_DRAM_TYPE_LPDDR3, + .phy_init = SUN50I_H616_LPDDR3_PHY_INIT, +#endif + .clk = CONFIG_DRAM_CLK, .dx_odt = CONFIG_DRAM_SUN50I_H616_DX_ODT, .dx_dri = CONFIG_DRAM_SUN50I_H616_DX_DRI, .ca_dri = CONFIG_DRAM_SUN50I_H616_CA_DRI, @@ -1187,4 +1270,4 @@ unsigned long sunxi_dram_init(void) mctl_set_master_priority();
return size; -}; +}; \ No newline at end of file diff --git a/arch/arm/mach-sunxi/dram_timings/Makefile b/arch/arm/mach-sunxi/dram_timings/Makefile index 4d78c04c9a..8bfd99448a 100644 --- a/arch/arm/mach-sunxi/dram_timings/Makefile +++ b/arch/arm/mach-sunxi/dram_timings/Makefile @@ -4,3 +4,4 @@ obj-$(CONFIG_SUNXI_DRAM_DDR2_V3S) += ddr2_v3s.o obj-$(CONFIG_SUNXI_DRAM_H6_LPDDR3) += h6_lpddr3.o obj-$(CONFIG_SUNXI_DRAM_H6_DDR3_1333) += h6_ddr3_1333.o obj-$(CONFIG_SUNXI_DRAM_H616_DDR3_1333) += h616_ddr3_1333.o +obj-$(CONFIG_SUNXI_DRAM_H616_LPDDR3) += h616_lpddr3.o diff --git a/arch/arm/mach-sunxi/dram_timings/h616_lpddr3.c b/arch/arm/mach-sunxi/dram_timings/h616_lpddr3.c new file mode 100644 index 0000000000..dcd504cae4 --- /dev/null +++ b/arch/arm/mach-sunxi/dram_timings/h616_lpddr3.c @@ -0,0 +1,95 @@ +/* + * sun50i H616 LPDDR3 timings, as programmed by Allwinner's boot0 + * + * The chips are probably able to be driven by a faster clock, but boot0 + * uses a more conservative timing (as usual). + * + * (C) Copyright 2020 Jernej Skrabec jernej.skrabec@siol.net + * Based on H6 DDR3 timings: + * (C) Copyright 2018,2019 Arm Ltd. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/dram.h> +#include <asm/arch/cpu.h> + +void mctl_set_timing_params(struct dram_para *para) +{ + struct sunxi_mctl_ctl_reg * const mctl_ctl = + (struct sunxi_mctl_ctl_reg *)SUNXI_DRAM_CTL0_BASE; + + u8 tccd = 2; + u8 tfaw = ns_to_t(50); + u8 trrd = max(ns_to_t(6), 4); + u8 trcd = ns_to_t(24); + u8 trc = ns_to_t(70); + u8 txp = max(ns_to_t(8), 3); + u8 trtp = max(ns_to_t(8), 2); + u8 trp = ns_to_t(27); + u8 tras = ns_to_t(41); + u16 trefi = ns_to_t(7800) / 64; + u16 trfc = ns_to_t(210); + u16 txsr = 88; + + u8 tmrw = 5; + u8 tmrd = 5; + u8 tmod = max(ns_to_t(15), 12); + u8 tcke = max(ns_to_t(6), 3); + u8 tcksrx = max(ns_to_t(12), 4); + u8 tcksre = max(ns_to_t(12), 4); + u8 tckesr = tcke + 2; + u8 trasmax = (para->clk / 2) / 16; + u8 txs = ns_to_t(360) / 32; + u8 txsdll = 16; + u8 txsabort = 4; + u8 txsfast = 4; + u8 tcl = 7; + u8 tcwl = 4; + u8 t_rdata_en = 12; + u8 t_wr_lat = 6; + + u8 twtp = 16; + u8 twr2rd = trtp + 9; + u8 trd2wr = 13; + + /* DRAM timing grabbed from tvbox with LPDDR3 memory */ + writel((twtp << 24) | (tfaw << 16) | (trasmax << 8) | tras, + &mctl_ctl->dramtmg[0]); + writel((txp << 16) | (trtp << 8) | trc, &mctl_ctl->dramtmg[1]); + writel((tcwl << 24) | (tcl << 16) | (trd2wr << 8) | twr2rd, + &mctl_ctl->dramtmg[2]); + writel((tmrw << 20) | (tmrd << 12) | tmod, &mctl_ctl->dramtmg[3]); + writel((trcd << 24) | (tccd << 16) | (trrd << 8) | trp, + &mctl_ctl->dramtmg[4]); + writel((tcksrx << 24) | (tcksre << 16) | (tckesr << 8) | tcke, + &mctl_ctl->dramtmg[5]); + /* Value suggested by ZynqMP manual and used by libdram */ + writel((txp + 2) | 0x02020000, &mctl_ctl->dramtmg[6]); + writel((txsfast << 24) | (txsabort << 16) | (txsdll << 8) | txs, + &mctl_ctl->dramtmg[8]); + writel(0x00020208, &mctl_ctl->dramtmg[9]); + writel(0xE0C05, &mctl_ctl->dramtmg[10]); + writel(0x440C021C, &mctl_ctl->dramtmg[11]); + writel(8, &mctl_ctl->dramtmg[12]); + writel(0xA100002, &mctl_ctl->dramtmg[13]); + writel(txsr, &mctl_ctl->dramtmg[14]); + + writel(0x4f0112, &mctl_ctl->init[0]); + writel(0x420000, &mctl_ctl->init[1]); + writel(0xd05, &mctl_ctl->init[2]); + writel(0x83001c, &mctl_ctl->init[3]); + writel(0x00010000, &mctl_ctl->init[4]); + + writel(0, &mctl_ctl->dfimisc); + clrsetbits_le32(&mctl_ctl->rankctl, 0xff0, 0x660); + + /* Configure DFI timing */ + writel(t_wr_lat | 0x2000000 | (t_rdata_en << 16) | 0x808000, + &mctl_ctl->dfitmg0); + writel(0x100202, &mctl_ctl->dfitmg1); + + /* set refresh timing */ + writel((trefi << 16) | trfc, &mctl_ctl->rfshtmg); +}
On Sat, 3 Jun 2023 16:55:06 +0300 Mikhail Kalashnikov iuncuim@gmail.com wrote:
- u8 phy_init[27]; u8 cols; u8 rows; u8 ranks;
- bool "LPDDR3 DRAM chips on the H616 DRAM controller"
- select SUNXI_DRAM_LPDDR3
- ---help---
- This option is the LPDDR3 timing used by the stock boot0 by
- Allwinner.
- 0x09, 0x05, 0x18
So apart from the already existing code size problem mentioned in my cover letter reply, pulling this into struct dram_para also grows the code. Just #ifdef-ing this here for the two types helped: #ifdef CONFIG_SUNXI_DRAM_H616_DDR3_1333 static const u8 phy_init[] = { ... #elif defined(CONFIG_SUNXI_DRAM_H616_LPDDR3) static const u8 phy_init[] = { ... #endif
I think we can live with #ifdef's here, since this is clearly separated and is actually just data.
else
else
else
else
dmb();
- } else {
- if (para->type == SUNXI_DRAM_TYPE_DDR3) {
} else {
- } else if (para->type == SUNXI_DRAM_TYPE_LPDDR3) {
} else {
val = 9;
val2 = 7;
val = 9;
val2 = 7;
val = 14;
val2 = 8;
} else {}
val = 13;
val2 = 9;
val = 13;
val2 = 9;
val = 14;
val2 = 8;
val = 0x80;
val = 0xc0;
- else if (para->type == SUNXI_DRAM_TYPE_LPDDR3)
if (para->bus_full_width) reg_val |= MSTR_BUSWIDTH_FULL; elsereg_val |= MSTR_DEVICETYPE_LPDDR3;
- { 0x07, 0x0b, 0x02, 0x16, 0x0d, 0x0e, 0x14, 0x19, \
0x09, 0x05, 0x18 }
- { 0x18, 0x06, 0x00, 0x05, 0x04, 0x03, 0x09, 0x02, \
0x17, 0x19, 0x1a }
.dx_odt = CONFIG_DRAM_SUN50I_H616_DX_ODT, .dx_dri = CONFIG_DRAM_SUN50I_H616_DX_DRI, .ca_dri = CONFIG_DRAM_SUN50I_H616_CA_DRI,.clk = CONFIG_DRAM_CLK,
- sun50i H616 LPDDR3 timings, as programmed by Allwinner's boot0
Can you say what the frequency is you clock those chips with? I understand we maybe don't want to name some JEDEC speed bin here, since typically the used timings deviate from the standard anyway, but it would be good to know whether this is for higher or lower clocked chips.
In general it would be good to also have a user in the tree, to test compilation.
Cheers, Andre
- The chips are probably able to be driven by a faster clock, but boot0
- uses a more conservative timing (as usual).
- (C) Copyright 2020 Jernej Skrabec jernej.skrabec@siol.net
- Based on H6 DDR3 timings:
- (C) Copyright 2018,2019 Arm Ltd.
- struct sunxi_mctl_ctl_reg * const mctl_ctl =
- u8 tccd = 2;
- u8 tfaw = ns_to_t(50);
- u8 trrd = max(ns_to_t(6), 4);
- u8 trcd = ns_to_t(24);
- u8 trc = ns_to_t(70);
- u8 txp = max(ns_to_t(8), 3);
- u8 trtp = max(ns_to_t(8), 2);
- u8 trp = ns_to_t(27);
- u8 tras = ns_to_t(41);
- u16 trefi = ns_to_t(7800) / 64;
- u16 trfc = ns_to_t(210);
- u16 txsr = 88;
- u8 tmrw = 5;
- u8 tmrd = 5;
- u8 tmod = max(ns_to_t(15), 12);
- u8 tcke = max(ns_to_t(6), 3);
- u8 tcksrx = max(ns_to_t(12), 4);
- u8 tcksre = max(ns_to_t(12), 4);
- u8 tckesr = tcke + 2;
- u8 trasmax = (para->clk / 2) / 16;
- u8 txs = ns_to_t(360) / 32;
- u8 txsdll = 16;
- u8 txsabort = 4;
- u8 txsfast = 4;
- u8 tcl = 7;
- u8 tcwl = 4;
- u8 t_rdata_en = 12;
- u8 t_wr_lat = 6;
- u8 twtp = 16;
- u8 twr2rd = trtp + 9;
- u8 trd2wr = 13;
- /* DRAM timing grabbed from tvbox with LPDDR3 memory */
- writel((twtp << 24) | (tfaw << 16) | (trasmax << 8) | tras,
- writel((txp << 16) | (trtp << 8) | trc, &mctl_ctl->dramtmg[1]);
- writel((tcwl << 24) | (tcl << 16) | (trd2wr << 8) | twr2rd,
- writel((tmrw << 20) | (tmrd << 12) | tmod, &mctl_ctl->dramtmg[3]);
- writel((trcd << 24) | (tccd << 16) | (trrd << 8) | trp,
- writel((tcksrx << 24) | (tcksre << 16) | (tckesr << 8) | tcke,
- /* Value suggested by ZynqMP manual and used by libdram */
- writel((txp + 2) | 0x02020000, &mctl_ctl->dramtmg[6]);
- writel((txsfast << 24) | (txsabort << 16) | (txsdll << 8) | txs,
- writel(0x00020208, &mctl_ctl->dramtmg[9]);
- writel(0xE0C05, &mctl_ctl->dramtmg[10]);
- writel(0x440C021C, &mctl_ctl->dramtmg[11]);
- writel(8, &mctl_ctl->dramtmg[12]);
- writel(0xA100002, &mctl_ctl->dramtmg[13]);
- writel(txsr, &mctl_ctl->dramtmg[14]);
- writel(0x4f0112, &mctl_ctl->init[0]);
- writel(0x420000, &mctl_ctl->init[1]);
- writel(0xd05, &mctl_ctl->init[2]);
- writel(0x83001c, &mctl_ctl->init[3]);
- writel(0x00010000, &mctl_ctl->init[4]);
- writel(0, &mctl_ctl->dfimisc);
- clrsetbits_le32(&mctl_ctl->rankctl, 0xff0, 0x660);
- /* Configure DFI timing */
- writel(t_wr_lat | 0x2000000 | (t_rdata_en << 16) | 0x808000,
- writel(0x100202, &mctl_ctl->dfitmg1);
- /* set refresh timing */
- writel((trefi << 16) | trfc, &mctl_ctl->rfshtmg);
---help---
Allwinner.
0x09, 0x05, 0x18
else
writel_relaxed(val, SUNXI_DRAM_PHY0_BASE + 0x380); writel_relaxed(val, SUNXI_DRAM_PHY0_BASE + 0x384); val = (para->dx_odt >> 8) & 0x1f;
else
writel_relaxed(val, SUNXI_DRAM_PHY0_BASE + 0x3c0); writel_relaxed(val, SUNXI_DRAM_PHY0_BASE + 0x3c4); val = (para->dx_odt >> 16) & 0x1f;
else
writel_relaxed(val, SUNXI_DRAM_PHY0_BASE + 0x400); writel_relaxed(val, SUNXI_DRAM_PHY0_BASE + 0x404); val = (para->dx_odt >> 24) & 0x1f;
else
writel_relaxed(val, SUNXI_DRAM_PHY0_BASE + 0x440); writel_relaxed(val, SUNXI_DRAM_PHY0_BASE + 0x444); dmb();
} else {
} else {
} else {
val = 9;
val2 = 7;
val = 9;
val2 = 7;
fill the same
val = 14;
val2 = 8;
} } else {
val = 13;
val2 = 9;
val = 13;
val2 = 9;
val = 14;
val2 = 8;
} } writel(val, SUNXI_DRAM_PHY0_BASE + 0x14);
writel(para->phy_init[i], &ptr[i]); if (para->tpr10 & TPR10_CA_BIT_DELAY) mctl_phy_ca_bit_delay_compensation(para);
val = 0x80;
val = 0xc0;
writel(val, SUNXI_DRAM_PHY0_BASE + 0x45c); mctl_phy_configure_odt(para);
} if (para->clk <= 672) writel(0xf, SUNXI_DRAM_PHY0_BASE + 0x20);
} writel(0, SUNXI_DRAM_PHY0_BASE + 0x54);
writel(reg_val, &mctl_ctl->unk_0x4240); writel(BIT(31), &mctl_com->cr);
0x09, 0x05, 0x18 }
0x17, 0x19, 0x1a }
return size;
u8 tccd = 2;
u16 txsr = 88;
u8 tmrw = 5;
u8 tmrd = 5;
u8 txsdll = 16;
u8 txsabort = 4;
u8 txsfast = 4;
u8 tcl = 7;
u8 tcwl = 4;
u8 t_rdata_en = 12;
u8 t_wr_lat = 6;
u8 twtp = 16;
u8 trd2wr = 13;
2.40.1
On Sat, 3 Jun 2023 16:55:04 +0300 Mikhail Kalashnikov iuncuim@gmail.com wrote:
Hi Mikhail,
Ah, many thanks for sending this! This looks very good, in general. There is one newline issue introduced in patch 1, which gets fixed in patch 2, but that's just a small thing.
There is one bigger problem, though: The code size grows by a bit, when compiling for the OrangePi Zero2: $ size spl/arch/arm/mach-sunxi/dram_sun50i_h616.o text data bss dec hex filename 7463 0 0 7463 1d27 dram_sun50i_h616_before.o 8155 0 0 8155 1fdb dram_sun50i_h616_after.o
This is somewhat surprising, given that the DRAM type is known at compile time, so the compiler wouldn't need to include the other case in the binary.
Looking a bit closer at the disassembly, I saw that the constant propagation isn't really working as we would hope for. I suspect it's due to struct dram_para having both fixed, but also dynamic members, so the compiler avoids optimising this further. Just marking the fixed members as "const" in the struct declaration didn't change anything, unfortunately, again I believe the constant propagation is conservative here. I then went ahead and split struct dram_para up into two structures: one which is always constant, and one dynamic, with just cols, rows, banks, and full_bus_width in it. Then putting "const" into the right places in the function prototypes *and* moving the struct dram_para definition outside of the sunxi_dram_init() function, resulted in quite a drop in code size: for current mainline (without your patches) the size of the DRAM driver goes down from the above mentioned 7463 bytes to 5723 bytes. Adding your patches on top then didn't change the size at all, as expected.
So I will send out those changes soonish, and will put your rebased patches on top.
Cheers, Andre
Andre Przywara
Iun Cuim
Mikhail Kalashnikov
