[GIT PULL] clk changes for v2023.01
The following changes since commit d3ccdc0fce206c1d54fbdc607333de6184e19e75:
Merge tag 'efi-2022-10-rc6' of https://source.denx.de/u-boot/custodians/u-boot-efi (2022-09-30 08:30:38 -0400)
https://source.denx.de/u-boot/custodians/u-boot-clk.git tags/clk-2023.01
for you to fetch changes up to 19fb40a5e7ee815a703ffdcc7c0fdb7933762256:
clk: update clk_clean_rate_cache to use private clk struct (2022-10-19 12:28:30 -0400)
---------------------------------------------------------------- Clock patches for 2023.01
This contains various fixes (some long overdue) for the next release.
---------------------------------------------------------------- Michal Suchanek (2): clk: change return type of clk_get_parent_rate from long long to ulong rockchip: clk: pll: Fix constant typo
Patrick Delaunay (1): clk: update clk_clean_rate_cache to use private clk struct
drivers/clk/clk-uclass.c | 20 ++++++++++++++++++-- drivers/clk/rockchip/clk_pll.c | 6 +++--- include/clk.h | 4 ++-- 3 files changed, 23 insertions(+), 7 deletions(-)
Sean Anderson
