[U-Boot] [PATCH] ARM: imx6logic: Stop overwriting fdt_file if manually set
The board file uses the processor type to determine what dtb file is set. Unfortunately, if the user wants to manually set this, it get gets overwritten upon boot. This patch adds a check to see if the value is already set and only changes it if the value is empty.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/board/logicpd/imx6/imx6logic.c b/board/logicpd/imx6/imx6logic.c index b17a3b1d39..53e609e15c 100644 --- a/board/logicpd/imx6/imx6logic.c +++ b/board/logicpd/imx6/imx6logic.c @@ -152,7 +152,8 @@ int board_late_init(void)
if (is_mx6dq()) { env_set("board_rev", "MX6DQ"); - env_set("fdt_file", "imx6q-logicpd.dtb"); + if (!env_get("fdt_file")) + env_set("fdt_file", "imx6q-logicpd.dtb"); }
Gentle nudge to try and get this into the next release.
thanks
adam
env_set("fdt_file", "imx6q-logicpd.dtb"); } return 0;
-- 2.17.1
The board file uses the processor type to determine what dtb file is set. Unfortunately, if the user wants to manually set this, it get gets overwritten upon boot. This patch adds a check to see if the value is already set and only changes it if the value is empty. Signed-off-by: Adam Ford aford173@gmail.com diff --git a/board/logicpd/imx6/imx6logic.c b/board/logicpd/imx6/imx6logic.c index b17a3b1d39..53e609e15c 100644 --- a/board/logicpd/imx6/imx6logic.c +++ b/board/logicpd/imx6/imx6logic.c @@ -152,7 +152,8 @@ int board_late_init(void)
Best regards, Stefano Babic
Adam Ford
sbabic@denx.de
