[U-Boot] [PATCH 1/1] imximage: header.length of 4 is valid
Signed-off-by: Troy Kisky troy.kisky@boundarydevices.com --- tools/imximage.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/tools/imximage.c b/tools/imximage.c index 97a6880..7c21922 100644 --- a/tools/imximage.c +++ b/tools/imximage.c @@ -396,8 +396,8 @@ static void print_hdr_v2(struct imx_header *imx_hdr) dcd_v2_t *dcd_v2 = &hdr_v2->dcd_table; uint32_t size, version;
- size = be16_to_cpu(dcd_v2->header.length) - 8; - if (size > (MAX_HW_CFG_SIZE_V2 * sizeof(dcd_addr_data_t))) { + size = be16_to_cpu(dcd_v2->header.length); + if (size > (MAX_HW_CFG_SIZE_V2 * sizeof(dcd_addr_data_t)) + 8) { fprintf(stderr, "Error: Image corrupt DCD size %d exceed maximum %d\n", (uint32_t)(size / sizeof(dcd_addr_data_t)),
- size = be16_to_cpu(dcd_v2->header.length);
- if (size > (MAX_HW_CFG_SIZE_V2 * sizeof(dcd_addr_data_t)) + 8) { fprintf(stderr, "Error: Image corrupt DCD size %d exceed maximum %d\n", (uint32_t)(size / sizeof(dcd_addr_data_t)),
Hi Stefano,
Are there outstanding concerns about applying this patch and then applying
imximage: fix commands other than write_data
Where you replied "This patch breaks building boards with SPL:
Building current source for 85 boards (6 threads, 1 job per thread) arm: + colibri_vf_dtb +Error: Image corrupt DCD size 536870911 exceed maximum 220 +make[2]: *** [u-boot-dtb.imx] Error 1 +make[1]: *** [u-boot-dtb.imx] Error 2 +make: *** [sub-make] Error 2 arm: + mx6sabresd_spl +Error: Image corrupt DCD size 536870911 exceed maximum 220 "
Or would you rather that I squash them together?
Thanks Troy
Hi Troy,
Am 06.10.2015 um 00:17 schrieb Troy Kisky:
Hi Stefano,
Yes, please do it - I would like to avoid issues by git bisect.
Thanks, Stefano
On 10/6/2015 4:30 AM, stefano babic wrote:
Hi Troy,
Hi Stefano,
That is not an issue if you apply "imximage: header.length of 4 is valid" first.
Would you still like it squashed, or a new series, or just use the previous patches ?
Troy
Hi Troy,
Hi Troy,
Hi Stefano,
Sorry, you're right, of course !
No, I apply both patches.
Regards, Stefano
Applied to u-boot-imx (fix), thanks !
Best regards, Stefano Babic
Stefano Babic
stefano babic
Troy Kisky
