[PATCH v2 0/3] Conclusive KSTR-SAMA5D27 support
Hi all,
this is v2 of the Conclusive KSTR-SAMA5D27 support series.
Patch [1/3] now also renames the EEPROM serial number function and moves its documentation from .c file to the .h. We should be fine doing that, as - to my knowledge - no other part of U-Boot seems to be using this symbol, as evidenced by the missing prototype.
Patch [2/3] is new. It is the direct result of moving i2c as a child of flexcom (see below).
Patch [3/3] now also addresses multiple dts issues. In particular, all node access is now being done through label references, unused nodes have been removed, and the i2c now goes explicitly through flexcom.
Artur Rojek (3): common: add prototype & rename populate_serial_number() arm: dts: at91: sama5: Add flexcom4 node board: Add support for Conclusive KSTR-SAMA5D27
arch/arm/dts/Makefile | 3 + arch/arm/dts/at91-kstr-sama5d27.dts | 131 ++++++++++ arch/arm/dts/sama5d2.dtsi | 20 ++ arch/arm/mach-at91/Kconfig | 13 + board/conclusive/kstr-sama5d27/Kconfig | 15 ++ board/conclusive/kstr-sama5d27/MAINTAINERS | 8 + board/conclusive/kstr-sama5d27/Makefile | 5 + .../conclusive/kstr-sama5d27/kstr-sama5d27.c | 234 ++++++++++++++++++ cmd/tlv_eeprom.c | 14 +- configs/kstr_sama5d27_defconfig | 80 ++++++ include/configs/kstr-sama5d27.h | 15 ++ include/init.h | 14 ++ 12 files changed, 539 insertions(+), 13 deletions(-) create mode 100644 arch/arm/dts/at91-kstr-sama5d27.dts create mode 100644 board/conclusive/kstr-sama5d27/Kconfig create mode 100644 board/conclusive/kstr-sama5d27/MAINTAINERS create mode 100644 board/conclusive/kstr-sama5d27/Makefile create mode 100644 board/conclusive/kstr-sama5d27/kstr-sama5d27.c create mode 100644 configs/kstr_sama5d27_defconfig create mode 100644 include/configs/kstr-sama5d27.h
Rename populate_serial_number() to a more descriptive eeprom_read_serial() and provide the missing function prototype.
This is useful for boards that wish to read their serial number from EEPROM at init.
Signed-off-by: Artur Rojek artur@conclusive.pl ---
v2: - rename the function - move function documentation from .c file to the prototype location
cmd/tlv_eeprom.c | 14 +------------- include/init.h | 14 ++++++++++++++ 2 files changed, 15 insertions(+), 13 deletions(-)
diff --git a/cmd/tlv_eeprom.c b/cmd/tlv_eeprom.c index 79796394c5c8..47c127ca4950 100644 --- a/cmd/tlv_eeprom.c +++ b/cmd/tlv_eeprom.c @@ -1088,19 +1088,7 @@ int mac_read_from_eeprom(void) return 0; }
-/** - * populate_serial_number - read the serial number from EEPROM - * - * This function reads the serial number from the EEPROM and sets the - * appropriate environment variable. - * - * The environment variable is only set if it has not been set - * already. This ensures that any user-saved variables are never - * overwritten. - * - * This function must be called after relocation. - */ -int populate_serial_number(int devnum) +int eeprom_read_serial(int devnum) { char serialstr[257]; int eeprom_index; diff --git a/include/init.h b/include/init.h index 3bf30476a2e0..f18f3b9961d8 100644 --- a/include/init.h +++ b/include/init.h @@ -283,6 +283,20 @@ void board_init_r(struct global_data *id, ulong dest_addr) int cpu_init_r(void); int last_stage_init(void); int mac_read_from_eeprom(void); + +/** + * eeprom_read_serial - read the serial number from EEPROM + * + * This function reads the serial number from the EEPROM and sets the + * appropriate environment variable. + * + * The environment variable is only set if it has not been set + * already. This ensures that any user-saved variables are never + * overwritten. + * + * This function must be called after relocation. + */ +int eeprom_read_serial(int devnum); int set_cpu_clk_info(void); int update_flash_size(int flash_size); int arch_early_init_r(void);
Set up flexcom4 for Microchip SAMA5D27 SoC and prepare it for usage in I2C mode.
v2: new patch
arch/arm/dts/sama5d2.dtsi | 20 ++++++++++++++++++++ 1 file changed, 20 insertions(+)
diff --git a/arch/arm/dts/sama5d2.dtsi b/arch/arm/dts/sama5d2.dtsi index dd6468ed96aa..819564fdd5bb 100644 --- a/arch/arm/dts/sama5d2.dtsi +++ b/arch/arm/dts/sama5d2.dtsi @@ -781,6 +781,26 @@ status = "disabled"; };
+ flx4: flexcom@fc018000 { + compatible = "atmel,sama5d2-flexcom"; + reg = <0xfc018000 0x200>; + clocks = <&flx4_clk>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xfc018000 0x800>; + status = "disabled"; + + i2c6: i2c@600 { + compatible = "atmel,sama5d2-i2c"; + reg = <0x600 0x200>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&flx4_clk>; + clock-names = "i2c6_clk"; + status = "disabled"; + }; + }; + aic: interrupt-controller@fc020000 { #interrupt-cells = <3>; compatible = "atmel,sama5d2-aic";
Introduce support for Conclusive KSTR-SAMA5D27 Single Board Computer.
Co-developed-by: Jakub Klama jakub@conclusive.pl Signed-off-by: Jakub Klama jakub@conclusive.pl Co-developed-by: Marcin Jabrzyk marcin@conclusive.pl Signed-off-by: Marcin Jabrzyk marcin@conclusive.pl Signed-off-by: Artur Rojek artur@conclusive.pl ---
v2: - remove redundant license text from at91-kstr-sama5d27.dts - when defining properties in .dts, reference nodes by labels - drop nodes for usb0 and pmic, as these aren't used by drivers - switch i2c to flexcom driver and make the necessary dts changes - sort includes in at91-kstr-sama5d27.dts alphabetically
arch/arm/dts/Makefile | 3 + arch/arm/dts/at91-kstr-sama5d27.dts | 131 ++++++++++ arch/arm/mach-at91/Kconfig | 13 + board/conclusive/kstr-sama5d27/Kconfig | 15 ++ board/conclusive/kstr-sama5d27/MAINTAINERS | 8 + board/conclusive/kstr-sama5d27/Makefile | 5 + .../conclusive/kstr-sama5d27/kstr-sama5d27.c | 234 ++++++++++++++++++ configs/kstr_sama5d27_defconfig | 80 ++++++ include/configs/kstr-sama5d27.h | 15 ++ 9 files changed, 504 insertions(+) create mode 100644 arch/arm/dts/at91-kstr-sama5d27.dts create mode 100644 board/conclusive/kstr-sama5d27/Kconfig create mode 100644 board/conclusive/kstr-sama5d27/MAINTAINERS create mode 100644 board/conclusive/kstr-sama5d27/Makefile create mode 100644 board/conclusive/kstr-sama5d27/kstr-sama5d27.c create mode 100644 configs/kstr_sama5d27_defconfig create mode 100644 include/configs/kstr-sama5d27.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 85fd5b1157b1..8e4d33c01912 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1198,6 +1198,9 @@ dtb-$(CONFIG_TARGET_SAMA5D27_SOM1_EK) += \ dtb-$(CONFIG_TARGET_SAMA5D27_WLSOM1_EK) += \ at91-sama5d27_wlsom1_ek.dtb
+dtb-$(CONFIG_TARGET_KSTR_SAMA5D27) += \ + at91-kstr-sama5d27.dtb + dtb-$(CONFIG_TARGET_SAMA5D2_ICP) += \ at91-sama5d2_icp.dtb
diff --git a/arch/arm/dts/at91-kstr-sama5d27.dts b/arch/arm/dts/at91-kstr-sama5d27.dts new file mode 100644 index 000000000000..fe9ec7e5bbc3 --- /dev/null +++ b/arch/arm/dts/at91-kstr-sama5d27.dts @@ -0,0 +1,131 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * at91-kstr-sama5d27.dts - Device Tree file for Conclusive KSTR-SAMA5D27 board + * + * Copyright (C) 2019-2023 Conclusive Engineering Sp. z o. o. + * + */ +/dts-v1/; + +#include "sama5d2.dtsi" +#include "sama5d2-pinfunc.h" +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/mfd/atmel-flexcom.h> + +/ { + model = "Conclusive KSTR-SAMA5D27"; + compatible = "conclusive,kstr-sama5d27", "atmel,sama5d2", "atmel,sama5"; + + chosen { + bootph-all; + stdout-path = &uart1; + }; +}; + +&main_xtal { + clock-frequency = <12000000>; +}; + +&sdmmc0 { + bus-width = <4>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_sdmmc0_cmd_dat_default &pinctrl_sdmmc0_ck_cd_default>; + status = "okay"; + bootph-all; +}; + +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1_default>; + status = "okay"; + bootph-all; +}; + +&macb0 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_macb0_rmii &pinctrl_macb0_phy_irq>; + phy-mode = "rmii"; + status = "okay"; + + ethernet-phy@0 { + reg = <0x0>; + reset-gpios = <&pioA 44 GPIO_ACTIVE_LOW>; + }; +}; + +&flx4 { + atmel,flexcom-mode = <ATMEL_FLEXCOM_MODE_TWI>; + status = "okay"; +}; + +&i2c6 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_flx4_i2c>; + status = "okay"; + + eeprom: eeprom@50 { + compatible = "microchip,24c32", "atmel,24c32"; + reg = <0x50>; + read-only; + pagesize = <32>; + status = "okay"; + }; +}; + +&pioA { + pinctrl { + pinctrl_uart1_default: uart1_default { + pinmux = <PIN_PD2__URXD1>, + <PIN_PD3__UTXD1>; + bias-disable; + bootph-all; + }; + + pinctrl_macb0_phy_irq: macb0_phy_irq { + pinmux = <PIN_PB13__GPIO>; + bias-disable; + bootph-all; + }; + + pinctrl_macb0_rmii: macb0_rmii { + pinmux = <PIN_PB14__GTXCK>, + <PIN_PB15__GTXEN>, + <PIN_PB16__GRXDV>, + <PIN_PB17__GRXER>, + <PIN_PB18__GRX0>, + <PIN_PB19__GRX1>, + <PIN_PB20__GTX0>, + <PIN_PB21__GTX1>, + <PIN_PB22__GMDC>, + <PIN_PB23__GMDIO>; + bias-disable; + bootph-all; + }; + + pinctrl_sdmmc0_cmd_dat_default: sdmmc0_cmd_dat_default { + pinmux = <PIN_PA1__SDMMC0_CMD>, + <PIN_PA2__SDMMC0_DAT0>, + <PIN_PA3__SDMMC0_DAT1>, + <PIN_PA4__SDMMC0_DAT2>, + <PIN_PA5__SDMMC0_DAT3>; + bias-pull-up; + bootph-all; + }; + + pinctrl_sdmmc0_ck_cd_default: sdmmc0_ck_cd_default { + pinmux = <PIN_PA0__SDMMC0_CK>, + <PIN_PA11__SDMMC0_VDDSEL>, + <PIN_PA13__SDMMC0_CD>; + bias-disable; + bootph-all; + }; + + pinctrl_flx4_i2c: flx4_i2c { + pinmux = <PIN_PC28__FLEXCOM4_IO0>, + <PIN_PC29__FLEXCOM4_IO1>; + bias-disable; + }; + }; +}; diff --git a/arch/arm/mach-at91/Kconfig b/arch/arm/mach-at91/Kconfig index 7c2e4ebbdb0f..9ab1a9339ee1 100644 --- a/arch/arm/mach-at91/Kconfig +++ b/arch/arm/mach-at91/Kconfig @@ -204,6 +204,18 @@ config TARGET_SAMA5D27_WLSOM1_EK processor-based SAMA5D2 MPU with 2 Gbit LPDDR2-SDRAM in a single package.
+config TARGET_KSTR_SAMA5D27 + bool "Conclusive KSTR-SAMA5D27 board" + select BOARD_EARLY_INIT_F + select SAMA5D2 + select BOARD_LATE_INIT + help + The KSTR-SAMA5D27 embeds SAMA5D27 SoC, together with + 256 MiB SDRAM, 10/100 Mbit/s Ethernet, 96 Mbit/s Wi-Fi b/g/n, + Bluetooth 4.1 LE, USB OTG controller w/ type-C USB connector + and stackable GPIO headers in an all-in-one SBC form factor: + https://conclusive.pl/products/kstr-sama5d27-sbc/ + config TARGET_SAMA5D2_ICP bool "SAMA5D2 Industrial Connectivity Platform (ICP)" select SAMA5D2 @@ -352,6 +364,7 @@ source "board/atmel/sama5d4_xplained/Kconfig" source "board/atmel/sama5d4ek/Kconfig" source "board/bluewater/gurnard/Kconfig" source "board/calao/usb_a9263/Kconfig" +source "board/conclusive/kstr-sama5d27/Kconfig" source "board/egnite/ethernut5/Kconfig" source "board/esd/meesc/Kconfig" source "board/gardena/smart-gateway-at91sam/Kconfig" diff --git a/board/conclusive/kstr-sama5d27/Kconfig b/board/conclusive/kstr-sama5d27/Kconfig new file mode 100644 index 000000000000..572551cfda98 --- /dev/null +++ b/board/conclusive/kstr-sama5d27/Kconfig @@ -0,0 +1,15 @@ +if TARGET_KSTR_SAMA5D27 + +config SYS_BOARD + default "kstr-sama5d27" + +config SYS_VENDOR + default "conclusive" + +config SYS_SOC + default "at91" + +config SYS_CONFIG_NAME + default "kstr-sama5d27" + +endif diff --git a/board/conclusive/kstr-sama5d27/MAINTAINERS b/board/conclusive/kstr-sama5d27/MAINTAINERS new file mode 100644 index 000000000000..cb1635cdd280 --- /dev/null +++ b/board/conclusive/kstr-sama5d27/MAINTAINERS @@ -0,0 +1,8 @@ +CONCLUSIVE KSTR-SAMA5D27 BOARD +M: Jakub Klama jakub@conclusive.pl +M: Artur Rojek artur@conclusive.pl +S: Maintained +F: board/conclusive/kstr-sama5d27 +F: include/configs/kstr-sama5d27.h +F: configs/kstr_sama5d27_defconfig +F: arch/arm/dts/at91-kstr-sama5d27.dts diff --git a/board/conclusive/kstr-sama5d27/Makefile b/board/conclusive/kstr-sama5d27/Makefile new file mode 100644 index 000000000000..edf7d1c93441 --- /dev/null +++ b/board/conclusive/kstr-sama5d27/Makefile @@ -0,0 +1,5 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2019-2023 Conclusive Engineering Sp. z o. o. + +obj-y += kstr-sama5d27.o diff --git a/board/conclusive/kstr-sama5d27/kstr-sama5d27.c b/board/conclusive/kstr-sama5d27/kstr-sama5d27.c new file mode 100644 index 000000000000..33dbb95734bb --- /dev/null +++ b/board/conclusive/kstr-sama5d27/kstr-sama5d27.c @@ -0,0 +1,234 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * kstr-sama5d27.c - Board init file for Conclusive KSTR-SAMA5D27 board + * Copyright (C) 2021-2023 Conclusive Engineering Sp. z o. o. + */ + +#include <common.h> +#include <debug_uart.h> +#include <init.h> +#include <env.h> +#include <fdt_support.h> +#include <asm/global_data.h> +#include <asm/io.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/atmel_pio4.h> +#include <asm/arch/atmel_mpddrc.h> +#include <asm/arch/atmel_sdhci.h> +#include <asm/arch/clk.h> +#include <asm/arch/gpio.h> +#include <asm/arch/sama5d2.h> +#include <linux/delay.h> + +#ifdef CONFIG_USB_GADGET_ATMEL_USBA +#include <asm/arch/atmel_usba_udc.h> +#endif + +DECLARE_GLOBAL_DATA_PTR; + +#ifdef CONFIG_DEBUG_UART_BOARD_INIT +static void board_uart1_hw_init(void) +{ + /* URXD1 */ + atmel_pio4_set_a_periph(AT91_PIO_PORTD, 2, ATMEL_PIO_PUEN_MASK); + /* UTXD1 */ + atmel_pio4_set_a_periph(AT91_PIO_PORTD, 3, 0); + at91_periph_clk_enable(ATMEL_ID_UART1); +} + +void board_debug_uart_init(void) +{ + board_uart1_hw_init(); +} +#endif + +void board_lan8720a_init(void) +{ + /* LAN8720A_nRST */ + atmel_pio4_set_pio_output(AT91_PIO_PORTB, 12, 0); + /* + * Force 0 on RXER/PHYAD0. LAN8720A chipset will latch with address 0 on + * MDIO bus. + */ + atmel_pio4_set_pio_output(AT91_PIO_PORTB, 17, 0); + /* Minimal delay of reset signal is 25 ms */ + mdelay(30); + /* LAN8720A_nRST */ + atmel_pio4_set_pio_output(AT91_PIO_PORTB, 12, 1); +} + +void board_usba_init(void) +{ +#ifdef CONFIG_USB_GADGET_ATMEL_USBA + /* USB device peripheral initialization: sama5d2_devices.c */ + at91_udp_hw_init(); + /* USB device controller drivers/usb/gadget/atmel_usba_udc.c */ + usba_udc_probe(&pdata); +#endif +} + +#ifdef CONFIG_BOARD_EARLY_INIT_F +int board_early_init_f(void) +{ +#ifdef CONFIG_DEBUG_UART + debug_uart_init(); +#endif + + return 0; +} +#endif + +int ft_board_setup(void *blob, struct bd_info *bd) +{ + char *wlanaddr = env_get("eth1addr"); + + if (wlanaddr) + do_fixup_by_compat(blob, "brcm,bcm4329-fmac", "local-mac-address", + wlanaddr, strlen(wlanaddr), 1); + else + printf("Not setting WIFI mac address. Check if EEPROM TLV is correctly set up.\n"); + + return 0; +} + +int board_init(void) +{ + /* address of boot parameters */ + gd->bd->bi_boot_params = CFG_SYS_SDRAM_BASE + 0x100; + + board_usba_init(); + board_lan8720a_init(); + + return 0; +} + +#ifdef CONFIG_BOARD_LATE_INIT +int board_late_init(void) +{ + const char *serial_number; + + eeprom_read_serial(0); + + printf("Conclusive KSTR-SAMA5D27\n"); + + serial_number = env_get("serial#"); + if (!serial_number) + printf("Warning: unknown serial number.\n"); + else + printf("Serial number %s\n", serial_number); + + return 0; +} +#endif + +#ifdef CONFIG_MISC_INIT_R +int misc_init_r(void) +{ + return 0; +} +#endif + +int dram_init(void) +{ + gd->ram_size = get_ram_size((void *)CFG_SYS_SDRAM_BASE, + CFG_SYS_SDRAM_SIZE); + return 0; +} + +/* SPL */ +#ifdef CONFIG_SPL_BUILD +void spl_board_init(void) +{ +} + +static void ddrc_conf(struct atmel_mpddrc_config *ddrc) +{ + ddrc->md = (ATMEL_MPDDRC_MD_DBW_16_BITS | ATMEL_MPDDRC_MD_DDR2_SDRAM); + + ddrc->cr = (ATMEL_MPDDRC_CR_NC_COL_10 | + ATMEL_MPDDRC_CR_NR_ROW_13 | + ATMEL_MPDDRC_CR_CAS_DDR_CAS3 | + ATMEL_MPDDRC_CR_DIC_DS | + ATMEL_MPDDRC_CR_ZQ_LONG | + ATMEL_MPDDRC_CR_NB_8BANKS | + ATMEL_MPDDRC_CR_DECOD_INTERLEAVED | + ATMEL_MPDDRC_CR_UNAL_SUPPORTED); + + ddrc->rtr = 0x511; + + ddrc->tpr0 = ((7 << ATMEL_MPDDRC_TPR0_TRAS_OFFSET) | + (3 << ATMEL_MPDDRC_TPR0_TRCD_OFFSET) | + (3 << ATMEL_MPDDRC_TPR0_TWR_OFFSET) | + (9 << ATMEL_MPDDRC_TPR0_TRC_OFFSET) | + (3 << ATMEL_MPDDRC_TPR0_TRP_OFFSET) | + (4 << ATMEL_MPDDRC_TPR0_TRRD_OFFSET) | + (4 << ATMEL_MPDDRC_TPR0_TWTR_OFFSET) | + (2 << ATMEL_MPDDRC_TPR0_TMRD_OFFSET)); + + ddrc->tpr1 = ((22 << ATMEL_MPDDRC_TPR1_TRFC_OFFSET) | + (23 << ATMEL_MPDDRC_TPR1_TXSNR_OFFSET) | + (200 << ATMEL_MPDDRC_TPR1_TXSRD_OFFSET) | + (3 << ATMEL_MPDDRC_TPR1_TXP_OFFSET)); + + ddrc->tpr2 = ((2 << ATMEL_MPDDRC_TPR2_TXARD_OFFSET) | + (8 << ATMEL_MPDDRC_TPR2_TXARDS_OFFSET) | + (4 << ATMEL_MPDDRC_TPR2_TRPA_OFFSET) | + (4 << ATMEL_MPDDRC_TPR2_TRTP_OFFSET) | + (8 << ATMEL_MPDDRC_TPR2_TFAW_OFFSET)); +} + +void mem_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + struct atmel_mpddr *mpddrc = (struct atmel_mpddr *)ATMEL_BASE_MPDDRC; + struct atmel_mpddrc_config ddrc_config; + u32 reg; + + ddrc_conf(&ddrc_config); + + at91_periph_clk_enable(ATMEL_ID_MPDDRC); + writel(AT91_PMC_DDR, &pmc->scer); + + reg = readl(&mpddrc->io_calibr); + reg &= ~ATMEL_MPDDRC_IO_CALIBR_RDIV; + reg |= ATMEL_MPDDRC_IO_CALIBR_DDR3_RZQ_55; + reg &= ~ATMEL_MPDDRC_IO_CALIBR_TZQIO; + reg |= ATMEL_MPDDRC_IO_CALIBR_TZQIO_(101); + writel(reg, &mpddrc->io_calibr); + + writel(ATMEL_MPDDRC_RD_DATA_PATH_SHIFT_ONE_CYCLE, + &mpddrc->rd_data_path); + + ddr3_init(ATMEL_BASE_MPDDRC, ATMEL_BASE_DDRCS, &ddrc_config); + + writel(0x3, &mpddrc->cal_mr4); + writel(64, &mpddrc->tim_cal); +} + +void at91_pmc_init(void) +{ + u32 tmp; + + /* + * While coming from the ROM code, we run on PLLA @ 492 MHz / 164 MHz, + * so we need to slow down and configure MCKR accordingly. + * This is why we have a special flavor of the switching function. + */ + tmp = AT91_PMC_MCKR_PLLADIV_2 | + AT91_PMC_MCKR_MDIV_3 | + AT91_PMC_MCKR_CSS_MAIN; + at91_mck_init_down(tmp); + + tmp = AT91_PMC_PLLAR_29 | + AT91_PMC_PLLXR_PLLCOUNT(0x3f) | + AT91_PMC_PLLXR_MUL(40) | + AT91_PMC_PLLXR_DIV(1); + at91_plla_init(tmp); + + tmp = AT91_PMC_MCKR_H32MXDIV | + AT91_PMC_MCKR_PLLADIV_2 | + AT91_PMC_MCKR_MDIV_3 | + AT91_PMC_MCKR_CSS_PLLA; + at91_mck_init(tmp); +} +#endif diff --git a/configs/kstr_sama5d27_defconfig b/configs/kstr_sama5d27_defconfig new file mode 100644 index 000000000000..1c8aceb9e19c --- /dev/null +++ b/configs/kstr_sama5d27_defconfig @@ -0,0 +1,80 @@ +CONFIG_ARM=y +CONFIG_ARCH_AT91=y +CONFIG_TEXT_BASE=0x26f00000 +CONFIG_SYS_LOAD_ADDR=0x24000000 +CONFIG_SYS_MONITOR_LEN=524288 +CONFIG_TARGET_KSTR_SAMA5D27=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x20003ee0 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="at91-kstr-sama5d27" +CONFIG_DISTRO_DEFAULTS=y +CONFIG_FIT=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_SYS_EXTRA_OPTIONS="SAMA5D2" +CONFIG_SD_BOOT=y +CONFIG_BOOTDELAY=3 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwait" +# CONFIG_USE_BOOTCOMMAND is not set +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_MISC_INIT_R=y +CONFIG_CMD_TLV_EEPROM=y +CONFIG_CMD_IMAGE=y +CONFIG_CMD_DM=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +# CONFIG_ISO_PARTITION is not set +CONFIG_OF_CONTROL=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_FAT=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_AT91_UTMI=y +CONFIG_AT91_H32MX=y +CONFIG_AT91_GENERIC_CLK=y +CONFIG_ATMEL_PIO4=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_AT91=y +CONFIG_I2C_EEPROM=y +CONFIG_MICROCHIP_FLEXCOM=y +CONFIG_DM_MMC=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_ATMEL=y +CONFIG_PHY_MICREL=y +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91PIO4=y +CONFIG_DM_SERIAL=y +CONFIG_ATMEL_USART=y +CONFIG_TEE=y +CONFIG_OPTEE=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_AT91=y +CONFIG_DM_RESET=y +CONFIG_RESET_AT91=y +CONFIG_TIMER=y +CONFIG_ATMEL_PIT_TIMER=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_VENDOR_NUM=0x16c0 +CONFIG_USB_GADGET_PRODUCT_NUM=0x03e9 +CONFIG_USB_GADGET_ATMEL_USBA=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_SPL_OF_LIBFDT=y +# CONFIG_EFI_LOADER is not set diff --git a/include/configs/kstr-sama5d27.h b/include/configs/kstr-sama5d27.h new file mode 100644 index 000000000000..772a073ba209 --- /dev/null +++ b/include/configs/kstr-sama5d27.h @@ -0,0 +1,15 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2021-2023 Conclusive Engineering Sp. z o. o. + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include "at91-sama5_common.h" + +/* SDRAM */ +#define CFG_SYS_SDRAM_BASE 0x20000000 +#define CFG_SYS_SDRAM_SIZE 0x10000000 + +#endif
Artur Rojek
