[U-Boot] [PATCH] ppc44x: Unification of virtex5 pp440 boards v3
This patch provides an unificated way of handling xilinx v5 ppc440 boards.
It unificates 3 different things:
1) Source code A new board called ppc440-generic has been created. This board includes a generic tlb initialization (Maps the whole memory into virtual) and defines board_pre_init, checkboard, initdram and get_sys_info weakly, so, they can be replaced by specific functions.
If a new board needs to redefine any of the previous functions (specific initialization) it can create a new directory with the specific initializations needed. (see the example ml507 board).
2) Configuration file Common configurations are located under configs/xilinx-ppc440.h, this header file interpretes the xparameters file generated by EDK and configurates u-boot in correspondence. Example: if there is a Temac, allows CMD_CONFIG_NET Specific configuration are located under specific configuration file. (see the example ml507 board)
3) Makefile Some work has been done in order to not duplicate work in the Main Makefile. Please see the attached code.
In order to support new boards they can be implemented in the next way:
a) Simple Generic Board (90% of the time) Using EDK generates a new xparameters.h file, replace ppc440-generic/xparameters.h and run make xilinx-ppc440-generic_config && make
b) Simple Boards with special u-boot parameters (9 % of the time) Create a new file under configs for it (use ml507.h as example) and change your paramaters. Create a new Makefile paragraph and compile
c) Complex boards (1% of the time) Create a new folder for the board, like the ml507
Finally, it adds support for the Avnet FX30T Evaluation board, following the new generic structure:
Cheap board by Avnet for evaluating the Virtex5 FX technology.
This patch adds support for: - UartLite - 16MB Flash - 64MB RAM
Prior using U-boot in this board, read carefully the ERRATA by Avnet to solve some memory initialization issues.
v2 diff: - Code Styling (Michal Simek) - Remove unnecesary xparameters lines (Michal Simek) - Avnet board documentation in patch
v3 diff: - Description changed (wdenx) - Copyright issues - RFC->Patch Propossal
Signed-off-by: Ricardo Ribalda Delgado ricardo.ribalda@uam.es --- CREDITS | 3 +- MAINTAINERS | 2 + MAKEALL | 4 + Makefile | 58 +++++++-- board/avnet/v5fx30teval/.gitignore | 3 + board/avnet/v5fx30teval/Makefile | 27 ++++ board/avnet/v5fx30teval/v5fx30teval.c | 28 ++++ board/avnet/v5fx30teval/xparameters.h | 33 +++++ board/xilinx/ml507/.gitignore | 3 + board/xilinx/ml507/Makefile | 41 +----- board/xilinx/ml507/config.mk | 27 ---- board/xilinx/ml507/init.S | 53 ------- board/xilinx/ml507/ml507.c | 21 +--- board/xilinx/ml507/u-boot-ram.lds | 134 ------------------ board/xilinx/ml507/u-boot-rom.lds | 144 -------------------- board/xilinx/ml507/xparameters.h | 17 +-- board/xilinx/ppc440-generic/.gitignore | 3 + board/xilinx/ppc440-generic/Makefile | 62 +++++++++ board/xilinx/ppc440-generic/init.S | 45 ++++++ board/xilinx/ppc440-generic/u-boot-ram.lds | 134 ++++++++++++++++++ board/xilinx/ppc440-generic/u-boot-rom.lds | 144 ++++++++++++++++++++ .../xilinx/ppc440-generic/xilinx_ppc440_generic.c | 52 +++++++ board/xilinx/ppc440-generic/xparameters.h | 34 +++++ include/configs/ml507.h | 91 ++----------- include/configs/v5fx30teval.h | 49 +++++++ include/configs/xilinx-ppc440-generic.h | 49 +++++++ include/configs/xilinx-ppc440.h | 106 ++++++++++++++ 27 files changed, 851 insertions(+), 516 deletions(-) create mode 100644 board/avnet/v5fx30teval/.gitignore create mode 100644 board/avnet/v5fx30teval/Makefile create mode 100644 board/avnet/v5fx30teval/v5fx30teval.c create mode 100644 board/avnet/v5fx30teval/xparameters.h create mode 100644 board/xilinx/ml507/.gitignore delete mode 100644 board/xilinx/ml507/config.mk delete mode 100644 board/xilinx/ml507/init.S delete mode 100644 board/xilinx/ml507/u-boot-ram.lds delete mode 100644 board/xilinx/ml507/u-boot-rom.lds create mode 100644 board/xilinx/ppc440-generic/.gitignore create mode 100644 board/xilinx/ppc440-generic/Makefile create mode 100644 board/xilinx/ppc440-generic/init.S create mode 100644 board/xilinx/ppc440-generic/u-boot-ram.lds create mode 100644 board/xilinx/ppc440-generic/u-boot-rom.lds create mode 100644 board/xilinx/ppc440-generic/xilinx_ppc440_generic.c create mode 100644 board/xilinx/ppc440-generic/xparameters.h create mode 100644 include/configs/v5fx30teval.h create mode 100644 include/configs/xilinx-ppc440-generic.h create mode 100644 include/configs/xilinx-ppc440.h
diff --git a/CREDITS b/CREDITS index 4fe4e63..3767322 100644 --- a/CREDITS +++ b/CREDITS @@ -405,7 +405,8 @@ D: Atmel AT91CAP9ADK support
N: Ricardo Ribalda Delgado E: ricardo.ribalda@uam.es -D: PPC440x5 (Virtex5), ML507 Board, eeprom_simul, adt7460 +D: PPC440x5 (Virtex5), ML507 Board, eeprom_simul, adt7460, v5fx30teval +D: Virtex ppc440 generic architecture W: http://www.ii.uam.es/~rribalda
N: Stefan Roese diff --git a/MAINTAINERS b/MAINTAINERS index 31493c2..47220e2 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -318,6 +318,8 @@ Daniel Poirot dan.poirot@windriver.com Ricardo Ribalda ricardo.ribalda@uam.es
ml507 PPC440x5 + v5fx30teval PPC440x5 + xilinx-pp440-generic PPC440x5
Stefan Roese sr@denx.de
diff --git a/MAKEALL b/MAKEALL index edfee90..6aa1723 100755 --- a/MAKEALL +++ b/MAKEALL @@ -231,12 +231,16 @@ LIST_4xx=" \ sequoia_nand \ taihu \ taishan \ + v5fx30teval \ + v5fx30teval_flash \ VOH405 \ VOM405 \ W7OLMC \ W7OLMG \ walnut \ WUH405 \ + xilinx-ppc440-generic \ + xilinx-ppc440-generic_flash \ XPEDITE1K \ yellowstone \ yosemite \ diff --git a/Makefile b/Makefile index 8c90dab..84b5dab 100644 --- a/Makefile +++ b/Makefile @@ -1351,16 +1351,19 @@ ML2_config: unconfig ml300_config: unconfig @$(MKCONFIG) $(@:_config=) ppc ppc4xx ml300 xilinx
-ml507_flash_config: unconfig - @mkdir -p $(obj)include $(obj)board/xilinx/ml507 - @cp $(obj)board/xilinx/ml507/u-boot-rom.lds $(obj)board/xilinx/ml507/u-boot.lds - @echo "TEXT_BASE = 0xFE360000" > $(obj)board/xilinx/ml507/config.tmp - @$(MKCONFIG) $(@:_flash_config=) ppc ppc4xx ml507 xilinx - -ml507_config: unconfig - @mkdir -p $(obj)include $(obj)board/xilinx/ml507 - @cp $(obj)board/xilinx/ml507/u-boot-ram.lds $(obj)board/xilinx/ml507/u-boot.lds - @$(MKCONFIG) $(@:_config=) ppc ppc4xx ml507 xilinx +ml507_flash_config: unconfig + BOARD_DIR=$(obj)board/xilinx/ml507 \ + TEXT_BASE=0xFE360000 \ + LINK_SCRIPT=$(obj)board/xilinx/ppc440-generic/u-boot-rom.lds \ + CONFIG_SCRIPT="ml507 ppc ppc4xx ml507 xilinx" \ + $(MAKE) xilinx_ppc440 + +ml507_config: unconfig + BOARD_DIR=$(obj)board/xilinx/ml507 \ + TEXT_BASE=0x04000000 \ + LINK_SCRIPT=$(obj)board/xilinx/ppc440-generic/u-boot-ram.lds \ + CONFIG_SCRIPT="ml507 ppc ppc4xx ml507 xilinx" \ + $(MAKE) xilinx_ppc440
ocotea_config: unconfig @$(MKCONFIG) $(@:_config=) ppc ppc4xx ocotea amcc @@ -1456,6 +1459,20 @@ taihu_config: unconfig taishan_config: unconfig @$(MKCONFIG) $(@:_config=) ppc ppc4xx taishan amcc
+v5fx30teval_config: unconfig + BOARD_DIR=$(obj)board/avnet/v5fx30teval \ + TEXT_BASE=0x03000000 \ + LINK_SCRIPT=$(obj)board/xilinx/ppc440-generic/u-boot-ram.lds \ + CONFIG_SCRIPT="v5fx30teval ppc ppc4xx v5fx30teval avnet" \ + $(MAKE) xilinx_ppc440 + +v5fx30teval_flash_config: unconfig + BOARD_DIR=$(obj)board/avnet/v5fx30teval \ + TEXT_BASE=0xFF1C0000 \ + LINK_SCRIPT=$(obj)board/xilinx/ppc440-generic/u-boot-rom.lds \ + CONFIG_SCRIPT="v5fx30teval ppc ppc4xx v5fx30teval avnet" \ + $(MAKE) xilinx_ppc440 + VOH405_config: unconfig @$(MKCONFIG) $(@:_config=) ppc ppc4xx voh405 esd
@@ -1474,6 +1491,27 @@ sycamore_config: unconfig WUH405_config: unconfig @$(MKCONFIG) $(@:_config=) ppc ppc4xx wuh405 esd
+xilinx-ppc440-generic_flash_config: + BOARD_DIR=$(obj)board/xilinx/ppc440-generic \ + TEXT_BASE=0xFE360000 \ + LINK_SCRIPT=$(obj)board/xilinx/ppc440-generic/u-boot-ram.lds \ + CONFIG_SCRIPT="xilinx-ppc440-generic ppc ppc4xx ppc440-generic xilinx" \ + $(MAKE) xilinx_ppc440 + +xilinx-ppc440-generic_config: + BOARD_DIR=$(obj)board/xilinx/ppc440-generic \ + TEXT_BASE=0x04000000 \ + LINK_SCRIPT=$(obj)board/xilinx/ppc440-generic/u-boot-ram.lds \ + CONFIG_SCRIPT="xilinx-ppc440-generic ppc ppc4xx ppc440-generic xilinx" \ + $(MAKE) xilinx_ppc440 + +xilinx_ppc440: unconfig + @mkdir -p $(obj)include $(BOARD_DIR) + @cp $(LINK_SCRIPT) $(BOARD_DIR)/u-boot.lds + @echo "TEXT_BASE = $(TEXT_BASE)" > $(BOARD_DIR)/config.mk + @$(MKCONFIG) $(CONFIG_SCRIPT) + + XPEDITE1K_config: unconfig @$(MKCONFIG) $(@:_config=) ppc ppc4xx xpedite1k
diff --git a/board/avnet/v5fx30teval/.gitignore b/board/avnet/v5fx30teval/.gitignore new file mode 100644 index 0000000..06ac9c1 --- /dev/null +++ b/board/avnet/v5fx30teval/.gitignore @@ -0,0 +1,3 @@ +/u-boot.lds +/config.tmp +/config.mk diff --git a/board/avnet/v5fx30teval/Makefile b/board/avnet/v5fx30teval/Makefile new file mode 100644 index 0000000..de23f29 --- /dev/null +++ b/board/avnet/v5fx30teval/Makefile @@ -0,0 +1,27 @@ +# +# (C) Copyright 2008 +# Ricardo Ribalda,Universidad Autonoma de Madrid, ricardo.ribalda@uam.es +# This work has been supported by: Qtechnology http://qtec.com/ +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +COBJS += $(BOARD).o + +include $(SRCTREE)/board/xilinx/ppc440-generic/Makefile diff --git a/board/avnet/v5fx30teval/v5fx30teval.c b/board/avnet/v5fx30teval/v5fx30teval.c new file mode 100644 index 0000000..14a1d5d --- /dev/null +++ b/board/avnet/v5fx30teval/v5fx30teval.c @@ -0,0 +1,28 @@ +/* + * (C) Copyright 2008 + * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@uam.es + * This work has been supported by: QTechnology http://qtec.com/ + * This program is free software: you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation, either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. +*/ + +#include <config.h> +#include <common.h> +#include <asm/processor.h> + + +int checkboard(void) +{ + puts("Avnet Virtex 5 FX30 Evaluation Board\n"); + return 0; +} diff --git a/board/avnet/v5fx30teval/xparameters.h b/board/avnet/v5fx30teval/xparameters.h new file mode 100644 index 0000000..bb657fc --- /dev/null +++ b/board/avnet/v5fx30teval/xparameters.h @@ -0,0 +1,33 @@ +/* + * (C) Copyright 2008 + * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@uam.es + * This work has been supported by: QTechnology http://qtec.com/ + * based on xparameters.h by Xilinx + * + * This program is free software: you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation, either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. +*/ + +#ifndef XPARAMETER_H +#define XPARAMETER_H + +#define XPAR_DDR2_SDRAM_MEM_BASEADDR 0x00000000 +#define XPAR_INTC_0_BASEADDR 0x81800000 +#define XPAR_UARTLITE_0_BASEADDR 0x84000000 +#define XPAR_FLASH_MEM0_BASEADDR 0xFF000000 +#define XPAR_PLB_CLOCK_FREQ_HZ 100000000 +#define XPAR_CORE_CLOCK_FREQ_HZ 400000000 +#define XPAR_INTC_MAX_NUM_INTR_INPUTS 13 +#define XPAR_UARTLITE_0_BAUDRATE 9600 + +#endif diff --git a/board/xilinx/ml507/.gitignore b/board/xilinx/ml507/.gitignore new file mode 100644 index 0000000..06ac9c1 --- /dev/null +++ b/board/xilinx/ml507/.gitignore @@ -0,0 +1,3 @@ +/u-boot.lds +/config.tmp +/config.mk diff --git a/board/xilinx/ml507/Makefile b/board/xilinx/ml507/Makefile index 7283704..de23f29 100644 --- a/board/xilinx/ml507/Makefile +++ b/board/xilinx/ml507/Makefile @@ -1,6 +1,7 @@ # -# (C) Copyright 2000-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# (C) Copyright 2008 +# Ricardo Ribalda,Universidad Autonoma de Madrid, ricardo.ribalda@uam.es +# This work has been supported by: Qtechnology http://qtec.com/ # # See file CREDITS for list of people who contributed to this # project. @@ -21,38 +22,6 @@ # MA 02111-1307 USA #
-include $(TOPDIR)/config.mk -ifneq ($(OBJTREE),$(SRCTREE)) -endif +COBJS += $(BOARD).o
-INCS := -CFLAGS += $(INCS) -HOST_CFLAGS += $(INCS) - -LIB = $(obj)lib$(BOARD).a - -COBJS = $(BOARD).o - -SOBJS = init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(AR) $(ARFLAGS) $@ $^ - -clean: - rm -f $(SOBJS) $(OBJS) - -distclean: clean - rm -f $(LIB) core *.bak .depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +include $(SRCTREE)/board/xilinx/ppc440-generic/Makefile diff --git a/board/xilinx/ml507/config.mk b/board/xilinx/ml507/config.mk deleted file mode 100644 index e827e8a..0000000 --- a/board/xilinx/ml507/config.mk +++ /dev/null @@ -1,27 +0,0 @@ -# -# (C) Copyright 2000 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# See file CREDITS for list of people who contributed to this -# project. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# -sinclude $(OBJTREE)/board/$(BOARDDIR)/config.tmp - -ifndef TEXT_BASE -TEXT_BASE = 0x04000000 -endif diff --git a/board/xilinx/ml507/init.S b/board/xilinx/ml507/init.S deleted file mode 100644 index 3228a65..0000000 --- a/board/xilinx/ml507/init.S +++ /dev/null @@ -1,53 +0,0 @@ -/* - * (C) Copyright 2008 - * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@uam.es - * This work has been supported by: QTechnology http://qtec.com/ - * - * This program is free software: you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation, either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program. If not, see http://www.gnu.org/licenses/. -*/ - -#include <ppc_asm.tmpl> -#include <config.h> -#include <asm-ppc/mmu.h> - -.section .bootpg,"ax" -.globl tlbtab - -tlbtab: -tlbtab_start - /* SDRAM */ -tlbentry(XPAR_DDR2_SDRAM_MEM_BASEADDR, SZ_256M, CFG_SDRAM_BASE, 0, - AC_R | AC_W | AC_X | SA_G | SA_I) - /* UART */ -tlbentry(XPAR_UARTLITE_0_BASEADDR, SZ_64K, XPAR_UARTLITE_0_BASEADDR, 0, - AC_R | AC_W | SA_G | SA_I) - /* PIC */ -tlbentry(XPAR_INTC_0_BASEADDR, SZ_64K, XPAR_INTC_0_BASEADDR, 0, - AC_R | AC_W | SA_G | SA_I) -#ifdef XPAR_IIC_EEPROM_BASEADDR - /* I2C */ -tlbentry(XPAR_IIC_EEPROM_BASEADDR, SZ_64K, XPAR_IIC_EEPROM_BASEADDR, 0, - AC_R | AC_W | SA_G | SA_I) -#endif -#ifdef XPAR_LLTEMAC_0_BASEADDR - /* Net */ -tlbentry(XPAR_LLTEMAC_0_BASEADDR, SZ_64K, XPAR_LLTEMAC_0_BASEADDR, 0, - AC_R | AC_W | SA_G | SA_I) -#endif -#ifdef XPAR_FLASH_MEM0_BASEADDR - /*Flash*/ -tlbentry(XPAR_FLASH_MEM0_BASEADDR, SZ_256M, XPAR_FLASH_MEM0_BASEADDR, 0, - AC_R | AC_W | AC_X | SA_G | SA_I) -#endif -tlbtab_end diff --git a/board/xilinx/ml507/ml507.c b/board/xilinx/ml507/ml507.c index d499303..f9789cf 100644 --- a/board/xilinx/ml507/ml507.c +++ b/board/xilinx/ml507/ml507.c @@ -20,28 +20,9 @@ #include <common.h> #include <asm/processor.h>
-int board_pre_init(void) -{ - return 0; -}
int checkboard(void) { - puts("ML507 Board\n"); + puts("Xilinx ML507 Board\n"); return 0; } - -phys_size_t initdram(int board_type) -{ - return get_ram_size(XPAR_DDR2_SDRAM_MEM_BASEADDR, - CFG_SDRAM_SIZE_MB * 1024 * 1024); -} - -void get_sys_info(sys_info_t * sysInfo) -{ - sysInfo->freqProcessor = XPAR_CORE_CLOCK_FREQ_HZ; - sysInfo->freqPLB = XPAR_PLB_CLOCK_FREQ_HZ; - sysInfo->freqPCI = 0; - - return; -} diff --git a/board/xilinx/ml507/u-boot-ram.lds b/board/xilinx/ml507/u-boot-ram.lds deleted file mode 100644 index 2c98d27..0000000 --- a/board/xilinx/ml507/u-boot-ram.lds +++ /dev/null @@ -1,134 +0,0 @@ -/* - * (C) Copyright 2000-2004 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_ARCH(powerpc) -ENTRY(_start_440) - -SECTIONS -{ - /* Read-only sections, merged into text segment: */ - . = + SIZEOF_HEADERS; - .interp : { *(.interp) } - .hash : { *(.hash) } - .dynsym : { *(.dynsym) } - .dynstr : { *(.dynstr) } - .rel.text : { *(.rel.text) } - .rela.text : { *(.rela.text) } - .rel.data : { *(.rel.data) } - .rela.data : { *(.rela.data) } - .rel.rodata : { *(.rel.rodata) } - .rela.rodata : { *(.rela.rodata) } - .rel.got : { *(.rel.got) } - .rela.got : { *(.rela.got) } - .rel.ctors : { *(.rel.ctors) } - .rela.ctors : { *(.rela.ctors) } - .rel.dtors : { *(.rel.dtors) } - .rela.dtors : { *(.rela.dtors) } - .rel.bss : { *(.rel.bss) } - .rela.bss : { *(.rela.bss) } - .rel.plt : { *(.rel.plt) } - .rela.plt : { *(.rela.plt) } - .init : { *(.init) } - .plt : { *(.plt) } - .text : - { - /* WARNING - the following is hand-optimized to fit within */ - /* the sector layout of our flash chips! XXX FIXME XXX */ - - - *(.text) - *(.fixup) - *(.got1) - } - _etext = .; - PROVIDE (etext = .); - .rodata : - { - *(.rodata) - *(.rodata1) - *(.rodata.str1.4) - *(.eh_frame) - } - .fini : { *(.fini) } =0 - .ctors : { *(.ctors) } - .dtors : { *(.dtors) } - - /* Read-write section, merged into data segment: */ - . = (. + 0x00FF) & 0xFFFFFF00; - _erotext = .; - PROVIDE (erotext = .); - .reloc : - { - *(.got) - _GOT2_TABLE_ = .; - *(.got2) - _FIXUP_TABLE_ = .; - *(.fixup) - } - __got2_entries = (_FIXUP_TABLE_ - _GOT2_TABLE_) >>2; - __fixup_entries = (. - _FIXUP_TABLE_)>>2; - - .data : - { - *(.data) - *(.data1) - *(.sdata) - *(.sdata2) - *(.dynamic) - CONSTRUCTORS - } - _edata = .; - PROVIDE (edata = .); - - . = .; - __u_boot_cmd_start = .; - .u_boot_cmd : { *(.u_boot_cmd) } - __u_boot_cmd_end = .; - - - . = .; - __start___ex_table = .; - __ex_table : { *(__ex_table) } - __stop___ex_table = .; - - . = ALIGN(256); - __init_begin = .; - .text.init : { *(.text.init) } - .data.init : { *(.data.init) } - . = ALIGN(256); - __init_end = .; - - __bss_start = .; - .bss (NOLOAD) : - { - *(.sbss) *(.scommon) - *(.dynbss) - *(.bss) - *(COMMON) - } - - ppcenv_assert = ASSERT(. < 0xFFFFB000, ".bss section too big, overlaps .ppcenv section. Please update your confguration: CFG_MONITOR_BASE, CFG_MONITOR_LEN and TEXT_BASE may need to be modified."); - - _end = . ; - PROVIDE (end = .); -} diff --git a/board/xilinx/ml507/u-boot-rom.lds b/board/xilinx/ml507/u-boot-rom.lds deleted file mode 100644 index d5da018..0000000 --- a/board/xilinx/ml507/u-boot-rom.lds +++ /dev/null @@ -1,144 +0,0 @@ -/* - * (C) Copyright 2000-2004 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_ARCH(powerpc) -ENTRY(_start_440) - -SECTIONS -{ - .resetvec 0xFFFFFFFC : - { - *(.resetvec) - } = 0xffff - - .bootpg 0xFFFFF000 : - { - cpu/ppc4xx/start.o (.bootpg) - } = 0xffff - - /* Read-only sections, merged into text segment: */ - . = + SIZEOF_HEADERS; - .interp : { *(.interp) } - .hash : { *(.hash) } - .dynsym : { *(.dynsym) } - .dynstr : { *(.dynstr) } - .rel.text : { *(.rel.text) } - .rela.text : { *(.rela.text) } - .rel.data : { *(.rel.data) } - .rela.data : { *(.rela.data) } - .rel.rodata : { *(.rel.rodata) } - .rela.rodata : { *(.rela.rodata) } - .rel.got : { *(.rel.got) } - .rela.got : { *(.rela.got) } - .rel.ctors : { *(.rel.ctors) } - .rela.ctors : { *(.rela.ctors) } - .rel.dtors : { *(.rel.dtors) } - .rela.dtors : { *(.rela.dtors) } - .rel.bss : { *(.rel.bss) } - .rela.bss : { *(.rela.bss) } - .rel.plt : { *(.rel.plt) } - .rela.plt : { *(.rela.plt) } - .init : { *(.init) } - .plt : { *(.plt) } - .text : - { - /* WARNING - the following is hand-optimized to fit within */ - /* the sector layout of our flash chips! XXX FIXME XXX */ - - - *(.text) - *(.fixup) - *(.got1) - } - _etext = .; - PROVIDE (etext = .); - .rodata : - { - *(.rodata) - *(.rodata1) - *(.rodata.str1.4) - *(.eh_frame) - } - .fini : { *(.fini) } =0 - .ctors : { *(.ctors) } - .dtors : { *(.dtors) } - - /* Read-write section, merged into data segment: */ - . = (. + 0x00FF) & 0xFFFFFF00; - _erotext = .; - PROVIDE (erotext = .); - .reloc : - { - *(.got) - _GOT2_TABLE_ = .; - *(.got2) - _FIXUP_TABLE_ = .; - *(.fixup) - } - __got2_entries = (_FIXUP_TABLE_ - _GOT2_TABLE_) >>2; - __fixup_entries = (. - _FIXUP_TABLE_)>>2; - - .data : - { - *(.data) - *(.data1) - *(.sdata) - *(.sdata2) - *(.dynamic) - CONSTRUCTORS - } - _edata = .; - PROVIDE (edata = .); - - . = .; - __u_boot_cmd_start = .; - .u_boot_cmd : { *(.u_boot_cmd) } - __u_boot_cmd_end = .; - - - . = .; - __start___ex_table = .; - __ex_table : { *(__ex_table) } - __stop___ex_table = .; - - . = ALIGN(256); - __init_begin = .; - .text.init : { *(.text.init) } - .data.init : { *(.data.init) } - . = ALIGN(256); - __init_end = .; - - __bss_start = .; - .bss (NOLOAD) : - { - *(.sbss) *(.scommon) - *(.dynbss) - *(.bss) - *(COMMON) - } - - ppcenv_assert = ASSERT(. < 0xFFFFB000, ".bss section too big, overlaps .ppcenv section. Please update your confguration: CFG_MONITOR_BASE, CFG_MONITOR_LEN and TEXT_BASE may need to be modified."); - - _end = . ; - PROVIDE (end = .); -} diff --git a/board/xilinx/ml507/xparameters.h b/board/xilinx/ml507/xparameters.h index 77d2ddf..1992fff 100644 --- a/board/xilinx/ml507/xparameters.h +++ b/board/xilinx/ml507/xparameters.h @@ -21,15 +21,14 @@ #ifndef XPARAMETER_H #define XPARAMETER_H
-#define XPAR_DDR2_SDRAM_MEM_BASEADDR 0x00000000 -#define XPAR_IIC_EEPROM_BASEADDR 0x81600000 -#define XPAR_INTC_0_BASEADDR 0x81800000 -#define XPAR_LLTEMAC_0_BASEADDR 0x81C00000 -#define XPAR_UARTLITE_0_BASEADDR 0x84000000 -#define XPAR_FLASH_MEM0_BASEADDR 0xFE000000 -#define XPAR_PLB_CLOCK_FREQ_HZ 100000000 -#define XPAR_CORE_CLOCK_FREQ_HZ 400000000 -#define XPAR_INTC_MAX_NUM_INTR_INPUTS 13 +#define XPAR_DDR2_SDRAM_MEM_BASEADDR 0x00000000 +#define XPAR_IIC_EEPROM_BASEADDR 0x81600000 +#define XPAR_INTC_0_BASEADDR 0x81800000 +#define XPAR_UARTLITE_0_BASEADDR 0x84000000 +#define XPAR_FLASH_MEM0_BASEADDR 0xFE000000 +#define XPAR_PLB_CLOCK_FREQ_HZ 100000000 +#define XPAR_CORE_CLOCK_FREQ_HZ 400000000 +#define XPAR_INTC_MAX_NUM_INTR_INPUTS 13 #define XPAR_UARTLITE_0_BAUDRATE 9600
#endif diff --git a/board/xilinx/ppc440-generic/.gitignore b/board/xilinx/ppc440-generic/.gitignore new file mode 100644 index 0000000..06ac9c1 --- /dev/null +++ b/board/xilinx/ppc440-generic/.gitignore @@ -0,0 +1,3 @@ +/u-boot.lds +/config.tmp +/config.mk diff --git a/board/xilinx/ppc440-generic/Makefile b/board/xilinx/ppc440-generic/Makefile new file mode 100644 index 0000000..f7405a8 --- /dev/null +++ b/board/xilinx/ppc440-generic/Makefile @@ -0,0 +1,62 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2008 +# Ricardo Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@uam.es +# Work supported by Qtechnology http://www.qtec.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk +ifneq ($(OBJTREE),$(SRCTREE)) +endif + +INCS := +CFLAGS += $(INCS) +HOST_CFLAGS += $(INCS) + +LIB = $(obj)lib$(BOARD).a + +COBJS += $(SRCTREE)/board/xilinx/ppc440-generic/xilinx_ppc440_generic.o + +SOBJS += $(SRCTREE)/board/xilinx/ppc440-generic/init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $^ + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/xilinx/ppc440-generic/init.S b/board/xilinx/ppc440-generic/init.S new file mode 100644 index 0000000..1409467 --- /dev/null +++ b/board/xilinx/ppc440-generic/init.S @@ -0,0 +1,45 @@ +/* + * (C) Copyright 2008 + * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@uam.es + * This work has been supported by: QTechnology http://qtec.com/ + * + * This program is free software: you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation, either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. +*/ + +#include <ppc_asm.tmpl> +#include <config.h> +#include <asm-ppc/mmu.h> + +.section .bootpg,"ax" +.globl tlbtab + +tlbtab: +tlbtab_start +tlbentry(0x00000000, SZ_256M, 0x00000000, 0, AC_R | AC_W | AC_X | SA_G | SA_I) +tlbentry(0x10000000, SZ_256M, 0x10000000, 0, AC_R | AC_W | AC_X | SA_G | SA_I) +tlbentry(0x20000000, SZ_256M, 0x20000000, 0, AC_R | AC_W | AC_X | SA_G | SA_I) +tlbentry(0x30000000, SZ_256M, 0x30000000, 0, AC_R | AC_W | AC_X | SA_G | SA_I) +tlbentry(0x40000000, SZ_256M, 0x40000000, 0, AC_R | AC_W | AC_X | SA_G | SA_I) +tlbentry(0x50000000, SZ_256M, 0x50000000, 0, AC_R | AC_W | AC_X | SA_G | SA_I) +tlbentry(0x60000000, SZ_256M, 0x60000000, 0, AC_R | AC_W | AC_X | SA_G | SA_I) +tlbentry(0x70000000, SZ_256M, 0x70000000, 0, AC_R | AC_W | AC_X | SA_G | SA_I) +tlbentry(0x80000000, SZ_256M, 0x80000000, 0, AC_R | AC_W | AC_X | SA_G | SA_I) +tlbentry(0x90000000, SZ_256M, 0x90000000, 0, AC_R | AC_W | AC_X | SA_G | SA_I) +tlbentry(0xa0000000, SZ_256M, 0xa0000000, 0, AC_R | AC_W | AC_X | SA_G | SA_I) +tlbentry(0xb0000000, SZ_256M, 0xb0000000, 0, AC_R | AC_W | AC_X | SA_G | SA_I) +tlbentry(0xc0000000, SZ_256M, 0xc0000000, 0, AC_R | AC_W | AC_X | SA_G | SA_I) +tlbentry(0xd0000000, SZ_256M, 0xd0000000, 0, AC_R | AC_W | AC_X | SA_G | SA_I) +tlbentry(0xe0000000, SZ_256M, 0xe0000000, 0, AC_R | AC_W | AC_X | SA_G | SA_I) +tlbentry(0xf0000000, SZ_256M, 0xf0000000, 0, AC_R | AC_W | AC_X | SA_G | SA_I) +tlbtab_end diff --git a/board/xilinx/ppc440-generic/u-boot-ram.lds b/board/xilinx/ppc440-generic/u-boot-ram.lds new file mode 100644 index 0000000..2c98d27 --- /dev/null +++ b/board/xilinx/ppc440-generic/u-boot-ram.lds @@ -0,0 +1,134 @@ +/* + * (C) Copyright 2000-2004 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_ARCH(powerpc) +ENTRY(_start_440) + +SECTIONS +{ + /* Read-only sections, merged into text segment: */ + . = + SIZEOF_HEADERS; + .interp : { *(.interp) } + .hash : { *(.hash) } + .dynsym : { *(.dynsym) } + .dynstr : { *(.dynstr) } + .rel.text : { *(.rel.text) } + .rela.text : { *(.rela.text) } + .rel.data : { *(.rel.data) } + .rela.data : { *(.rela.data) } + .rel.rodata : { *(.rel.rodata) } + .rela.rodata : { *(.rela.rodata) } + .rel.got : { *(.rel.got) } + .rela.got : { *(.rela.got) } + .rel.ctors : { *(.rel.ctors) } + .rela.ctors : { *(.rela.ctors) } + .rel.dtors : { *(.rel.dtors) } + .rela.dtors : { *(.rela.dtors) } + .rel.bss : { *(.rel.bss) } + .rela.bss : { *(.rela.bss) } + .rel.plt : { *(.rel.plt) } + .rela.plt : { *(.rela.plt) } + .init : { *(.init) } + .plt : { *(.plt) } + .text : + { + /* WARNING - the following is hand-optimized to fit within */ + /* the sector layout of our flash chips! XXX FIXME XXX */ + + + *(.text) + *(.fixup) + *(.got1) + } + _etext = .; + PROVIDE (etext = .); + .rodata : + { + *(.rodata) + *(.rodata1) + *(.rodata.str1.4) + *(.eh_frame) + } + .fini : { *(.fini) } =0 + .ctors : { *(.ctors) } + .dtors : { *(.dtors) } + + /* Read-write section, merged into data segment: */ + . = (. + 0x00FF) & 0xFFFFFF00; + _erotext = .; + PROVIDE (erotext = .); + .reloc : + { + *(.got) + _GOT2_TABLE_ = .; + *(.got2) + _FIXUP_TABLE_ = .; + *(.fixup) + } + __got2_entries = (_FIXUP_TABLE_ - _GOT2_TABLE_) >>2; + __fixup_entries = (. - _FIXUP_TABLE_)>>2; + + .data : + { + *(.data) + *(.data1) + *(.sdata) + *(.sdata2) + *(.dynamic) + CONSTRUCTORS + } + _edata = .; + PROVIDE (edata = .); + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + + . = .; + __start___ex_table = .; + __ex_table : { *(__ex_table) } + __stop___ex_table = .; + + . = ALIGN(256); + __init_begin = .; + .text.init : { *(.text.init) } + .data.init : { *(.data.init) } + . = ALIGN(256); + __init_end = .; + + __bss_start = .; + .bss (NOLOAD) : + { + *(.sbss) *(.scommon) + *(.dynbss) + *(.bss) + *(COMMON) + } + + ppcenv_assert = ASSERT(. < 0xFFFFB000, ".bss section too big, overlaps .ppcenv section. Please update your confguration: CFG_MONITOR_BASE, CFG_MONITOR_LEN and TEXT_BASE may need to be modified."); + + _end = . ; + PROVIDE (end = .); +} diff --git a/board/xilinx/ppc440-generic/u-boot-rom.lds b/board/xilinx/ppc440-generic/u-boot-rom.lds new file mode 100644 index 0000000..d5da018 --- /dev/null +++ b/board/xilinx/ppc440-generic/u-boot-rom.lds @@ -0,0 +1,144 @@ +/* + * (C) Copyright 2000-2004 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_ARCH(powerpc) +ENTRY(_start_440) + +SECTIONS +{ + .resetvec 0xFFFFFFFC : + { + *(.resetvec) + } = 0xffff + + .bootpg 0xFFFFF000 : + { + cpu/ppc4xx/start.o (.bootpg) + } = 0xffff + + /* Read-only sections, merged into text segment: */ + . = + SIZEOF_HEADERS; + .interp : { *(.interp) } + .hash : { *(.hash) } + .dynsym : { *(.dynsym) } + .dynstr : { *(.dynstr) } + .rel.text : { *(.rel.text) } + .rela.text : { *(.rela.text) } + .rel.data : { *(.rel.data) } + .rela.data : { *(.rela.data) } + .rel.rodata : { *(.rel.rodata) } + .rela.rodata : { *(.rela.rodata) } + .rel.got : { *(.rel.got) } + .rela.got : { *(.rela.got) } + .rel.ctors : { *(.rel.ctors) } + .rela.ctors : { *(.rela.ctors) } + .rel.dtors : { *(.rel.dtors) } + .rela.dtors : { *(.rela.dtors) } + .rel.bss : { *(.rel.bss) } + .rela.bss : { *(.rela.bss) } + .rel.plt : { *(.rel.plt) } + .rela.plt : { *(.rela.plt) } + .init : { *(.init) } + .plt : { *(.plt) } + .text : + { + /* WARNING - the following is hand-optimized to fit within */ + /* the sector layout of our flash chips! XXX FIXME XXX */ + + + *(.text) + *(.fixup) + *(.got1) + } + _etext = .; + PROVIDE (etext = .); + .rodata : + { + *(.rodata) + *(.rodata1) + *(.rodata.str1.4) + *(.eh_frame) + } + .fini : { *(.fini) } =0 + .ctors : { *(.ctors) } + .dtors : { *(.dtors) } + + /* Read-write section, merged into data segment: */ + . = (. + 0x00FF) & 0xFFFFFF00; + _erotext = .; + PROVIDE (erotext = .); + .reloc : + { + *(.got) + _GOT2_TABLE_ = .; + *(.got2) + _FIXUP_TABLE_ = .; + *(.fixup) + } + __got2_entries = (_FIXUP_TABLE_ - _GOT2_TABLE_) >>2; + __fixup_entries = (. - _FIXUP_TABLE_)>>2; + + .data : + { + *(.data) + *(.data1) + *(.sdata) + *(.sdata2) + *(.dynamic) + CONSTRUCTORS + } + _edata = .; + PROVIDE (edata = .); + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + + . = .; + __start___ex_table = .; + __ex_table : { *(__ex_table) } + __stop___ex_table = .; + + . = ALIGN(256); + __init_begin = .; + .text.init : { *(.text.init) } + .data.init : { *(.data.init) } + . = ALIGN(256); + __init_end = .; + + __bss_start = .; + .bss (NOLOAD) : + { + *(.sbss) *(.scommon) + *(.dynbss) + *(.bss) + *(COMMON) + } + + ppcenv_assert = ASSERT(. < 0xFFFFB000, ".bss section too big, overlaps .ppcenv section. Please update your confguration: CFG_MONITOR_BASE, CFG_MONITOR_LEN and TEXT_BASE may need to be modified."); + + _end = . ; + PROVIDE (end = .); +} diff --git a/board/xilinx/ppc440-generic/xilinx_ppc440_generic.c b/board/xilinx/ppc440-generic/xilinx_ppc440_generic.c new file mode 100644 index 0000000..0867226 --- /dev/null +++ b/board/xilinx/ppc440-generic/xilinx_ppc440_generic.c @@ -0,0 +1,52 @@ +/* + * (C) Copyright 2008 + * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@uam.es + * This work has been supported by: QTechnology http://qtec.com/ + * + * This program is free software: you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation, either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. +*/ + +#include <config.h> +#include <common.h> +#include <asm/processor.h> + +int __board_pre_init(void) +{ + return 0; +} +int board_pre_init(void) __attribute__((weak, alias("__board_pre_init"))); + +int __checkboard(void) +{ + puts("Xilinx PPC440 Generic Board\n"); + return 0; +} +int checkboard(void) __attribute__((weak, alias("__checkboard"))); + +phys_size_t __initdram(int board_type) +{ + return get_ram_size(XPAR_DDR2_SDRAM_MEM_BASEADDR, + CFG_SDRAM_SIZE_MB * 1024 * 1024); +} +phys_size_t initdram(int) __attribute__((weak, alias("__initdram"))); + +void __get_sys_info(sys_info_t *sysInfo) +{ + sysInfo->freqProcessor = XPAR_CORE_CLOCK_FREQ_HZ; + sysInfo->freqPLB = XPAR_PLB_CLOCK_FREQ_HZ; + sysInfo->freqPCI = 0; + + return; +} +void get_sys_info(sys_info_t *) __attribute__((weak, alias("__get_sys_info"))); diff --git a/board/xilinx/ppc440-generic/xparameters.h b/board/xilinx/ppc440-generic/xparameters.h new file mode 100644 index 0000000..1992fff --- /dev/null +++ b/board/xilinx/ppc440-generic/xparameters.h @@ -0,0 +1,34 @@ +/* + * (C) Copyright 2008 + * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@uam.es + * This work has been supported by: QTechnology http://qtec.com/ + * based on xparameters-ml507.h by Xilinx + * + * This program is free software: you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation, either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. +*/ + +#ifndef XPARAMETER_H +#define XPARAMETER_H + +#define XPAR_DDR2_SDRAM_MEM_BASEADDR 0x00000000 +#define XPAR_IIC_EEPROM_BASEADDR 0x81600000 +#define XPAR_INTC_0_BASEADDR 0x81800000 +#define XPAR_UARTLITE_0_BASEADDR 0x84000000 +#define XPAR_FLASH_MEM0_BASEADDR 0xFE000000 +#define XPAR_PLB_CLOCK_FREQ_HZ 100000000 +#define XPAR_CORE_CLOCK_FREQ_HZ 400000000 +#define XPAR_INTC_MAX_NUM_INTR_INPUTS 13 +#define XPAR_UARTLITE_0_BAUDRATE 9600 + +#endif diff --git a/include/configs/ml507.h b/include/configs/ml507.h index f8cd499..37d93bb 100644 --- a/include/configs/ml507.h +++ b/include/configs/ml507.h @@ -17,106 +17,33 @@
#ifndef __CONFIG_H #define __CONFIG_H -/* -#define DEBUG -#define ET_DEBUG -*/ - /*CPU*/ -#define CONFIG_XILINX_ML507 1 -#define CONFIG_XILINX_440 1 + +/*CPU*/ #define CONFIG_440 1 -#define CONFIG_4xx 1 +#define CONFIG_XILINX_ML507 1 #include "../board/xilinx/ml507/xparameters.h"
/*Mem Map*/ -#define CFG_SDRAM_BASE 0x0 #define CFG_SDRAM_SIZE_MB 256 -#define CFG_MONITOR_BASE TEXT_BASE -#define CFG_MONITOR_LEN ( 192 * 1024 ) -#define CFG_MALLOC_LEN ( CFG_ENV_SIZE + 128 * 1024 ) - -/*Uart*/ -#define CONFIG_XILINX_UARTLITE -#define CONFIG_BAUDRATE XPAR_UARTLITE_0_BAUDRATE -#define CFG_BAUDRATE_TABLE { XPAR_UARTLITE_0_BAUDRATE } -#define CONFIG_SERIAL_BASE XPAR_UARTLITE_0_BASEADDR - -/*Cmd*/ -#include <config_cmd_default.h> -#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_DIAG -#define CONFIG_CMD_ELF -#define CONFIG_CMD_IRQ -#define CONFIG_CMD_REGINFO -#define CONFIG_CMD_JFFS2 -#define CONFIG_JFFS2_CMDLINE -#undef CONFIG_CMD_I2C -#undef CONFIG_CMD_DTT -#undef CONFIG_CMD_NET -#undef CONFIG_CMD_PING -#undef CONFIG_CMD_DHCP -#undef CONFIG_CMD_EEPROM -#undef CONFIG_CMD_IMLS
/*Env*/ -#define CFG_ENV_IS_IN_FLASH +#define CFG_ENV_IS_IN_FLASH 1 #define CFG_ENV_SIZE 0x20000 #define CFG_ENV_SECT_SIZE 0x20000 -#define CFG_ENV_OFFSET 0x340000 -#define CFG_ENV_ADDR (XPAR_FLASH_MEM0_BASEADDR+CFG_ENV_OFFSET) +#define CFG_ENV_OFFSET 0x340000 +#define CFG_ENV_ADDR (XPAR_FLASH_MEM0_BASEADDR+CFG_ENV_OFFSET)
/*Misc*/ -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ -#define CFG_LONGHELP /* undef to save memory */ -#define CFG_PROMPT "board:/# " /* Monitor Command Prompt */ -#if defined(CONFIG_CMD_KGDB) -#define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CFG_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CFG_PBSIZE ( CFG_CBSIZE + sizeof( CFG_PROMPT ) + 16 ) -#define CFG_MAXARGS 16 /* max number of command args */ -#define CFG_BARGSIZE CFG_CBSIZE /* Boot Argument Buffer Size */ -#define CFG_MEMTEST_START 0x00400000 /* memtest works on */ -#define CFG_MEMTEST_END 0x00C00000 /* 4 ... 12 MB in DRAM */ -#define CFG_LOAD_ADDR 0x00400000 /* default load address */ -#define CFG_EXTBDINFO 1 /* Extended board_into (bd_t) */ -#define CFG_HZ 1000 /* decrementer freq: 1 ms ticks */ -#define CONFIG_CMDLINE_EDITING /* add command line history */ -#define CONFIG_AUTO_COMPLETE /* add autocompletion support */ -#define CONFIG_LOOPW /* enable loopw command */ -#define CONFIG_MX_CYCLIC /* enable mdc/mwc commands */ -#define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ -#define CONFIG_VERSION_VARIABLE /* include version env variable */ -#define CFG_CONSOLE_INFO_QUIET /* don't print console @ startup */ -#define CFG_HUSH_PARSER /* Use the HUSH parser */ -#define CFG_PROMPT_HUSH_PS2 "> " -#define CONFIG_LOADS_ECHO /* echo on for serial download */ -#define CFG_LOADS_BAUD_CHANGE /* allow baudrate change */ -#define CFG_BOOTMAPSZ ( 8 << 20 ) /* Initial Memory map for Linux */ +#define CFG_PROMPT "ml507:/# " /* Monitor Command Prompt */ #define CONFIG_PREBOOT "echo U-Boot is up and runnining;"
-/*Stack*/ -#define CFG_INIT_RAM_ADDR 0x800000 /* Initial RAM address */ -#define CFG_INIT_RAM_END 0x2000 /* End of used area in RAM */ -#define CFG_GBL_DATA_SIZE 128 /* num bytes initial data */ -#define CFG_GBL_DATA_OFFSET ( CFG_INIT_RAM_END - CFG_GBL_DATA_SIZE ) -#define CFG_INIT_SP_OFFSET CFG_GBL_DATA_OFFSET -/*Speed*/ -#define CONFIG_SYS_CLK_FREQ XPAR_CORE_CLOCK_FREQ_HZ - /*Flash*/ -#define CFG_FLASH_BASE XPAR_FLASH_MEM0_BASEADDR #define CFG_FLASH_SIZE (32*1024*1024) -#define CFG_FLASH_CFI 1 -#define CONFIG_FLASH_CFI_DRIVER 1 -#define CFG_FLASH_EMPTY_INFO 1 -#define CFG_MAX_FLASH_BANKS 1 #define CFG_MAX_FLASH_SECT 259 -#define CFG_FLASH_PROTECTION #define MTDIDS_DEFAULT "nor0=ml507-flash" #define MTDPARTS_DEFAULT "mtdparts=ml507-flash:-(user)"
+/*Generic Configs*/ +#include <configs/xilinx-ppc440.h>
#endif /* __CONFIG_H */ diff --git a/include/configs/v5fx30teval.h b/include/configs/v5fx30teval.h new file mode 100644 index 0000000..67d8d7f --- /dev/null +++ b/include/configs/v5fx30teval.h @@ -0,0 +1,49 @@ +/* + * (C) Copyright 2008 + * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@uam.es + * This work has been supported by: QTechnology http://qtec.com/ + * This program is free software: you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation, either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. +*/ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/*CPU*/ +#define CONFIG_440 1 +#define CONFIG_XILINX_ML507 1 +#include "../board/avnet/v5fx30teval/xparameters.h" + +/*Mem Map*/ +#define CFG_SDRAM_SIZE_MB 64 + +/*Env*/ +#define CFG_ENV_IS_IN_FLASH 1 +#define CFG_ENV_SIZE 0x20000 +#define CFG_ENV_SECT_SIZE 0x20000 +#define CFG_ENV_OFFSET 0x1A0000 +#define CFG_ENV_ADDR (XPAR_FLASH_MEM0_BASEADDR+CFG_ENV_OFFSET) + +/*Misc*/ +#define CFG_PROMPT "v5fx30t:/# " /* Monitor Command Prompt */ +#define CONFIG_PREBOOT "echo U-Boot is up and runnining;" + +/*Flash*/ +#define CFG_FLASH_SIZE (16*1024*1024) +#define CFG_MAX_FLASH_SECT 131 +#define MTDIDS_DEFAULT "nor0=v5fx30t-flash" +#define MTDPARTS_DEFAULT "mtdparts=v5fx30t-flash:-(user)" + +/*Generic Configs*/ +#include <configs/xilinx-ppc440.h> + +#endif /* __CONFIG_H */ diff --git a/include/configs/xilinx-ppc440-generic.h b/include/configs/xilinx-ppc440-generic.h new file mode 100644 index 0000000..4e8080b --- /dev/null +++ b/include/configs/xilinx-ppc440-generic.h @@ -0,0 +1,49 @@ +/* + * (C) Copyright 2008 + * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@uam.es + * This work has been supported by: QTechnology http://qtec.com/ + * This program is free software: you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation, either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. +*/ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/*CPU*/ +#define CONFIG_440 1 +#define CONFIG_XILINX_PPC440_GENERIC 1 +#include "../board/xilinx/ppc440-generic/xparameters.h" + +/*Mem Map*/ +#define CFG_SDRAM_SIZE_MB 256 + +/*Env*/ +#define CFG_ENV_IS_IN_FLASH 1 +#define CFG_ENV_SIZE 0x20000 +#define CFG_ENV_SECT_SIZE 0x20000 +#define CFG_ENV_OFFSET 0x340000 +#define CFG_ENV_ADDR (XPAR_FLASH_MEM0_BASEADDR+CFG_ENV_OFFSET) + +/*Misc*/ +#define CFG_PROMPT "board:/# " /* Monitor Command Prompt */ +#define CONFIG_PREBOOT "echo U-Boot is up and runnining;" + +/*Flash*/ +#define CFG_FLASH_SIZE (32*1024*1024) +#define CFG_MAX_FLASH_SECT 259 +#define MTDIDS_DEFAULT "nor0=ml507-flash" +#define MTDPARTS_DEFAULT "mtdparts=ml507-flash:-(user)" + +/*Generic Configs*/ +#include <configs/xilinx-ppc440.h> + +#endif /* __CONFIG_H */ diff --git a/include/configs/xilinx-ppc440.h b/include/configs/xilinx-ppc440.h new file mode 100644 index 0000000..40293cd --- /dev/null +++ b/include/configs/xilinx-ppc440.h @@ -0,0 +1,106 @@ +/* + * (C) Copyright 2008 + * Ricado Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@uam.es + * This work has been supported by: QTechnology http://qtec.com/ + * This program is free software: you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation, either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. +*/ + +#ifndef __CONFIG_GEN_H +#define __CONFIG_GEN_H +/* +#define DEBUG +#define ET_DEBUG +*/ + /*CPU*/ +#define CONFIG_XILINX_440 1 +#define CONFIG_440 1 +#define CONFIG_4xx 1 + +/*Mem Map*/ +#define CFG_SDRAM_BASE 0x0 +#define CFG_MONITOR_BASE TEXT_BASE +#define CFG_MONITOR_LEN (192 * 1024) +#define CFG_MALLOC_LEN (CFG_ENV_SIZE + 128 * 1024) + +/*Uart*/ +#define CONFIG_XILINX_UARTLITE +#define CONFIG_BAUDRATE XPAR_UARTLITE_0_BAUDRATE +#define CFG_BAUDRATE_TABLE { XPAR_UARTLITE_0_BAUDRATE } +#define CONFIG_SERIAL_BASE XPAR_UARTLITE_0_BASEADDR + +/*Cmd*/ +#include <config_cmd_default.h> +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_DIAG +#define CONFIG_CMD_ELF +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_REGINFO +#define CONFIG_CMD_JFFS2 +#define CONFIG_JFFS2_CMDLINE +#undef CONFIG_CMD_SPI +#undef CONFIG_CMD_I2C +#undef CONFIG_CMD_DTT +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_PING +#undef CONFIG_CMD_DHCP +#undef CONFIG_CMD_EEPROM +#undef CONFIG_CMD_IMLS + +/*Misc*/ +#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ +#define CFG_LONGHELP /* undef to save memory */ +#if defined(CONFIG_CMD_KGDB) +#define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ +#else +#define CFG_CBSIZE 256 /* Console I/O Buffer Size */ +#endif +#define CFG_PBSIZE (CFG_CBSIZE + sizeof(CFG_PROMPT) + 16) +#define CFG_MAXARGS 16 /* max number of command args */ +#define CFG_BARGSIZE CFG_CBSIZE /* Boot Argument Buffer Size */ +#define CFG_MEMTEST_START 0x00400000 /* memtest works on */ +#define CFG_MEMTEST_END 0x00C00000 /* 4 ... 12 MB in DRAM */ +#define CFG_LOAD_ADDR 0x00400000 /* default load address */ +#define CFG_EXTBDINFO 1 /* Extended board_into (bd_t) */ +#define CFG_HZ 1000 /* decrementer freq: 1 ms ticks */ +#define CONFIG_CMDLINE_EDITING /* add command line history */ +#define CONFIG_AUTO_COMPLETE /* add autocompletion support */ +#define CONFIG_LOOPW /* enable loopw command */ +#define CONFIG_MX_CYCLIC /* enable mdc/mwc commands */ +#define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ +#define CONFIG_VERSION_VARIABLE /* include version env variable */ +#define CFG_CONSOLE_INFO_QUIET /* don't print console @ startup */ +#define CFG_HUSH_PARSER /* Use the HUSH parser */ +#define CFG_PROMPT_HUSH_PS2 "> " +#define CONFIG_LOADS_ECHO /* echo on for serial download */ +#define CFG_LOADS_BAUD_CHANGE /* allow baudrate change */ +#define CFG_BOOTMAPSZ (8 << 20)/* Initial Memory map for Linux */ + +/*Stack*/ +#define CFG_INIT_RAM_ADDR 0x800000 /* Initial RAM address */ +#define CFG_INIT_RAM_END 0x2000 /* End of used area in RAM */ +#define CFG_GBL_DATA_SIZE 128 /* num bytes initial data */ +#define CFG_GBL_DATA_OFFSET (CFG_INIT_RAM_END - CFG_GBL_DATA_SIZE) +#define CFG_INIT_SP_OFFSET CFG_GBL_DATA_OFFSET +/*Speed*/ +#define CONFIG_SYS_CLK_FREQ XPAR_CORE_CLOCK_FREQ_HZ + +/*Flash*/ +#define CFG_FLASH_BASE XPAR_FLASH_MEM0_BASEADDR +#define CFG_FLASH_CFI 1 +#define CONFIG_FLASH_CFI_DRIVER 1 +#define CFG_FLASH_EMPTY_INFO 1 +#define CFG_MAX_FLASH_BANKS 1 +#define CFG_FLASH_PROTECTION + +#endif /* __CONFIG_H */
Ricardo,
sorry that the review took so long. Here we go:
One thing I noticed after applying your patch is the output while running MAKEALL:
[stefan@kubuntu u-boot-ppc4xx (master)]$ ./MAKEALL ml507_flash BOARD_DIR=board/xilinx/ml507 \ TEXT_BASE=0xFE360000 \ LINK_SCRIPT=board/xilinx/ppc440-generic/u-boot-rom.lds \ CONFIG_SCRIPT="ml507 ppc ppc4xx ml507 xilinx" \ make xilinx_ppc440 make[1]: Entering directory `/home/stefan/git/u-boot/u-boot-ppc4xx' Configuring for ml507 board... make[1]: Leaving directory `/home/stefan/git/u-boot/u-boot-ppc4xx' text data bss dec hex filename 149144 7652 14892 171688 29ea8 ./u-boot
Could you please reduce this output to the "normal" output style:
[stefan@kubuntu u-boot-ppc4xx (master)]$ ./MAKEALL canyonlands Configuring for canyonlands board... text data bss dec hex filename 331288 19348 332032 682668 a6aac ./u-boot
And did you check if your patch also has no problems with out-of-tree builds? I didn't check, just making sure.
Other than that look good. Please fix the issue mentioned above and resubmit. Thanks.
Best regards, Stefan
Hello Stefan
I did want to reduce the code replication in the Makefile. So I created a common target called xilinx_ppc440 that uses three variables: BOARD_DIR,TEXT_BASE (u-boot location), LINK_SCRIPT and CONFIG_SCRIPT (to setup board dir and config .h), every board just setup this variables and run the make command again.
The weird output is because I do not know how to setup Makefile's variables and run another target without running make again. I can change the Makefile to the "normal" behaviour, but with a lot of code replication.
I attach you a Makefile codesnipset:
ml507_flash_config: unconfig BOARD_DIR=$(obj)board/xilinx/ml507 \ TEXT_BASE=0xFE360000 \ LINK_SCRIPT=$(obj)board/xilinx/ppc440-generic/u-boot-rom.lds \ CONFIG_SCRIPT="ml507 ppc ppc4xx ml507 xilinx" \ $(MAKE) xilinx_ppc440
xilinx_ppc440: unconfig @mkdir -p $(obj)include $(BOARD_DIR) @cp $(LINK_SCRIPT) $(BOARD_DIR)/u-boot.lds @echo "TEXT_BASE = $(TEXT_BASE)" > $(BOARD_DIR)/config.mk @$(MKCONFIG) $(CONFIG_SCRIPT)
Any suggestions to improve it is more than welcome
Best regards
On Fri, Aug 29, 2008 at 03:48, Stefan Roese sr@denx.de wrote:
Ricardo,
Dear Ricardo,
in message aa76a2be0808290416m4d030725oadef47643c90a8b2@mail.gmail.com you wrote:
The Makefile is not the right place to provide configuration information. It shouls select a target board, and build it, nothing more.
All board specific configuration information should be kept in the board specific files only (please also keep in mind the next one who has to port Linux to a new board - config information should not be scattered over too many polaces, and especially no into common , central files).
Dear Wolfgang:
I believe that it is not setting any configuration information. In many boards the TEXT_BASE address is set up in the makefile depending if the user wants to compile u-boot for ram o for flash. Like the acadia (and many others)
@echo "TEXT_BASE = 0x01000000" > $(obj)board/amcc/acadia/config.tmp
I have no problem in setting the Makefile in the classic way, I just wanted to create a new way with the less code replication possible.
Shall I continue with this idea or I move back to the old way?
Regards
On Fri, Aug 29, 2008 at 07:41, Wolfgang Denk wd@denx.de wrote:
Dear Ricardo,
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de Change is the essential process of all existence. -- Spock, "Let That Be Your Last Battlefield", stardate 5730.2
Dear "Ricardo Ribalda Delgado",
In message aa76a2be0808290451w33492233l6cb0f66ec22a1ab2@mail.gmail.com you wrote:
I'm not sure if I really understand what the "old" and the "new" way is, but we must limit the growth of the Makefile; it is not a place to configura boards. Yes, this has been done in the past (when U-Boot supported only a fraction of the boards we have today), and maybe we even clean up the old boards one day, but at least don't let us add more of this stuff.
Hello Wolfgang
Before this "unification" patch I send another path that did treat the avnet board as a new board (a lot of code replication). This is what I call the old way.
Let me be more clear. What do we want:
MODE A =========
ml507_config: unconfig BOARD_DIR=$(obj)board/xilinx/ml507 \ TEXT_BASE=0x3000000 \ LINK_SCRIPT=$(obj)board/xilinx/ppc440-generic/u-boot-ram.lds \ CONFIG_SCRIPT="ml507 ppc ppc4xx ml507 xilinx" \ $(MAKE) xilinx_ppc440
v5fx30teval: LIKE BEFORE
v5fx30teval_flash: LIKE BEFORE
MODE B ==========
ml507: unconfig @mkdir -p $(obj)include $(obj)board/xilinx/ml507 @cp $(obj)board/xilinx/ppc440-generic/u-boot-rom.lds $(obj)board/xilinx/ml507/u-boot.lds @echo "TEXT_BASE = 0x30000000" > $(obj)board/xilinx/ml507/config.mk @$(MKCONFIG) ml507 ppc ppc4xx ml507 xilinx
ml507_flash: unconfig @mkdir -p $(obj)include $(obj)board/xilinx/ml507 @cp $(obj)board/xilinx/ppc440-generic/u-boot-rom.lds $(obj)board/xilinx/ml507/u-boot.lds @echo "TEXT_BASE = 0x30000000" > $(obj)board/xilinx/ml507/config.mk @$(MKCONFIG) ml507 ppc ppc4xx ml507 xilinx
MODE C ======== Please write your suggestion here.
My opinion:
Mode A is more "magical": it calls the make program again, but it is easier to maintain and has less code duplication: There are 6 boards that have to be configured the same way. Nevertheless is your/Stefan choose.
Regards
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de "It takes all sorts of in & out-door schooling to get adapted to my kind of fooling" - R. Frost
In message aa76a2be0808291417i462624fdya22c97d12f74db68@mail.gmail.com you wrote:
MODE A
BOARD_DIR, TEXT_BASE, LINK_SCRIPT and CONFIG_SCRIPT have no place in the top level Makefile. Please move this to board specific directories.
The normal entry for a board should consist of not more than
<name>_config: unconfig @$(MKCONFIG) <name> ppc4xx xilinx <name>
or similar.
Dear "Wolfgang Denk"
OK, just two questions.
All the boards I am using use the same link script, shall I copy it to its specific directory? Do you really want this? It is not better to do it like the MODE B (cp common_script to board dir)?
I want to create two different targets: ml507 and ml507_flash. Could you write an example of how to do this without writing the TEXT_BASE in the Makefile? I did it in this way because I didn't found any other method in the main Makefile
Thank you very much for your help
Regards
MODE A
or similar.
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de "Most people would like to be delivered from temptation but would like it to keep in touch." - Robert Orben
In message aa76a2be0808291544l54b95bd1k4c3c450dcbe50510@mail.gmail.com you wrote:
If they use the same linker script you can handle this for example like it's being handled for many other systems which use a common linker script in the CPU directory:
-> find cpu -name '*.lds' cpu/arm926ejs/at91/u-boot.lds cpu/mpc5xx/u-boot.lds cpu/mpc5xxx/u-boot-customlayout.lds cpu/mpc5xxx/u-boot.lds cpu/mpc8220/u-boot.lds cpu/mpc824x/u-boot.lds cpu/mpc8260/u-boot.lds cpu/mpc83xx/u-boot.lds
What exactly is the difference between these two targets?
Hello Again
Ok, I will take a close look to it
ml507 creates an image that runs in ram. This image is downloaded via jtag cable or a first stage loader: it is used for debugging and restore the system. ml507_flash generates an image that is stored in the flash of the system: It will be used on a normal base.
Thanks and Best Regards
Stefan Roese
