[U-Boot] [PATCH v2 1/3] ARM: cache: add an empty stub function for invalidate/flush dcache
Since some driver like ohci, lcd used dcache functions. But some ARM cpu don't implement the invalidate_dcache_range()/flush_dcache_range() functions.
To avoid compiling errors this patch adds an weak empty stub function for all ARM cpu.
And each cpu can implement its own implementation. If not implemented by default it will use an empty function.
Signed-off-by: Josh Wu josh.wu@atmel.com ---
Changes in v2: new added
arch/arm/lib/cache.c | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/arch/arm/lib/cache.c b/arch/arm/lib/cache.c index 74cfde6..bc48f53 100644 --- a/arch/arm/lib/cache.c +++ b/arch/arm/lib/cache.c @@ -53,6 +53,15 @@ __weak void enable_caches(void) puts("WARNING: Caches not enabled\n"); }
+__weak void invalidate_dcache_range(unsigned long start, unsigned long stop) +{ + /* An empty stub, real implementation should be in platform code */ +} +__weak void flush_dcache_range(unsigned long start, unsigned long stop) +{ + /* An empty stub, real implementation should be in platform code */ +} + #ifdef CONFIG_SYS_NONCACHED_MEMORY /* * Reserve one MMU section worth of address space below the malloc() area that
Since some driver like ohci, lcd used dcache functions. But m68k don't implement the invalidate_dcache_range()/flush_dcache_range() functions.
To avoid compiling errors this patch adds an weak empty stub function for all m68k cpu.
Also each cpu can implement its own implementation. If not implemented then by default is using an empty function.
Changes in v2: new added.
arch/m68k/lib/cache.c | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/arch/m68k/lib/cache.c b/arch/m68k/lib/cache.c index 21daf3d..ace791b 100644 --- a/arch/m68k/lib/cache.c +++ b/arch/m68k/lib/cache.c @@ -132,3 +132,12 @@ void dcache_invalid(void) __asm__ __volatile__("movec %0, %%cacr"::"r"(temp)); #endif } + +__weak void invalidate_dcache_range(unsigned long start, unsigned long stop) +{ + /* An empty stub, real implementation should be in platform code */ +} +__weak void flush_dcache_range(unsigned long start, unsigned long stop) +{ + /* An empty stub, real implementation should be in platform code */ +}
Acked-by: Angelo Dureghello angelo@sysam.it
Remove the CONFIG_DM_USB limitation to enable cache support functions. Tested on SAMA5D3x-EK board.
Signed-off-by: Josh Wu josh.wu@atmel.com Acked-by: Hans de Goede hdegoede@redhat.com ---
Changes in v2: - CONFIG_DM_USB in periodic_unlink() should be remove as well. This version remove it. - Add Hans de Goede's acked-by.
drivers/usb/host/ohci-hcd.c | 12 +----------- drivers/usb/host/ohci.h | 2 +- 2 files changed, 2 insertions(+), 12 deletions(-)
diff --git a/drivers/usb/host/ohci-hcd.c b/drivers/usb/host/ohci-hcd.c index 494b760..4300e09 100644 --- a/drivers/usb/host/ohci-hcd.c +++ b/drivers/usb/host/ohci-hcd.c @@ -103,21 +103,13 @@ static struct pci_device_id ehci_pci_ids[] = { # define m32_swap(x) cpu_to_le32(x) #endif /* CONFIG_SYS_OHCI_BE_CONTROLLER */
-#ifdef CONFIG_DM_USB -/* - * We really should do proper cache flushing everywhere, but for now we only - * do it for new (driver-model) usb code to avoid regressions. - */ +/* We really should do proper cache flushing everywhere */ #define flush_dcache_buffer(addr, size) \ flush_dcache_range((unsigned long)(addr), \ ALIGN((unsigned long)(addr) + size, ARCH_DMA_MINALIGN)) #define invalidate_dcache_buffer(addr, size) \ invalidate_dcache_range((unsigned long)(addr), \ ALIGN((unsigned long)(addr) + size, ARCH_DMA_MINALIGN)) -#else -#define flush_dcache_buffer(addr, size) -#define invalidate_dcache_buffer(addr, size) -#endif
/* Do not use sizeof(ed / td) as our ed / td structs contain extra members */ #define flush_dcache_ed(addr) flush_dcache_buffer(addr, 16) @@ -782,12 +774,10 @@ static void periodic_unlink(struct ohci *ohci, volatile struct ed *ed, if (((struct ed *) m32_swap((unsigned long)ed_p)) == ed) { *ed_p = ed->hwNextED; -#ifdef CONFIG_DM_USB aligned_ed_p = (unsigned long)ed_p; aligned_ed_p &= ~(ARCH_DMA_MINALIGN - 1); flush_dcache_range(aligned_ed_p, aligned_ed_p + ARCH_DMA_MINALIGN); -#endif break; } ed_p = &(((struct ed *) diff --git a/drivers/usb/host/ohci.h b/drivers/usb/host/ohci.h index f52b4c1..47bd85b 100644 --- a/drivers/usb/host/ohci.h +++ b/drivers/usb/host/ohci.h @@ -18,7 +18,7 @@ # define ohci_writel(a, b) (*((volatile u32 *)(b)) = ((volatile u32)a)) #endif /* CONFIG_SYS_OHCI_SWAP_REG_ACCESS */
-#if defined CONFIG_DM_USB && ARCH_DMA_MINALIGN > 16 +#if ARCH_DMA_MINALIGN > 16 #define ED_ALIGNMENT ARCH_DMA_MINALIGN #else #define ED_ALIGNMENT 16
So, why exactly can't this be entirely common code , but a CPU-specific code ? :)
Best regards, Marek Vasut
Hi, Marek
Do you mean to make those empty functions as common code for all arch cpu to use? It seems there is no place to put common code for all arch cpu.
Best Regards, Josh Wu
On Monday, June 08, 2015 at 04:05:04 AM, Josh Wu wrote:
Hi, Marek
Yes.
Isn't that what the common/ directory is for ? ;-)
Hi, Marek
Hi, Marek
Yes.
Oh, yes ;-)
I just think maybe it's more logical to keep those to the <arch>/lib/cache.c as cache are <arch> dependent.
Another point is if we create a new cache.c in common/, then the cache implementation code are in three files: <arch>/cpu/cache.c or cpu.c <arch>/lib/cache.c common/cache.c
It seems too fragmented. What do you think?
Hi, Marek
Yes.
No, this is making something common for the sake of making it common rather than good architecutre of the code I think. We aren't going to share real cache functions just these dummy ones. We may re-evaluate our dummy ones at some point in the future when people try and use some particular combination harder, see for example the PowerPC dummy cache functions we just recently dropped. Thanks!
Hi, Tom
Hi, Marek
Yes.
So it is the right place: arch/arm/lib/cache.c to put the dummy cache function.
If this patch set are ok for you. I will sent more patches to drop the dummy cache functions in <arch>/cpu/ folders. Also the flush_cache() in arch/arm/lib/cache.c can be dropped and just call flush_dcache_range() as the ARM1136, ARM926ejs alreay implemented their own flush_cache().
On Tue, Jun 09, 2015 at 11:54:14AM +0800, Josh Wu wrote:
Hi, Tom
Hi, Marek
Yes.
Yes.
Right, that's the best palce I think, baring an existing arch having a location for weak cache functions already (like arm does).
Nope, other things fail if you do that (vpac270_nor_256 and 24 others at least so far in my test build).
Hi, Tom
Hi, Marek
On Friday, June 05, 2015 at 09:47:30 AM, Josh Wu wrote: > Since some driver like ohci, lcd used dcache functions. But some ARM > cpu don't implement the invalidate_dcache_range()/flush_dcache_range() > functions. > > To avoid compiling errors this patch adds an weak empty stub function > for all ARM cpu. > > And each cpu can implement its own implementation. If not implemented > by default it will use an empty function. > > Signed-off-by: Josh Wu josh.wu@atmel.com > --- > > Changes in v2: new added > > arch/arm/lib/cache.c | 9 +++++++++ > 1 file changed, 9 insertions(+) So, why exactly can't this be entirely common code , but a CPU-specific code ? :)
Yes.
Yes.
Does it fail to compile or on running? As I don't have the board to test the binary, but I don't find any compile error when I apply such a patch. Maybe it is better to sent out my patch for you to check.
Hi, Tom
Hi, Marek
On 6/5/2015 9:18 PM, Marek Vasut wrote: > On Friday, June 05, 2015 at 09:47:30 AM, Josh Wu wrote: >> Since some driver like ohci, lcd used dcache functions. But some >> ARM cpu don't implement the >> invalidate_dcache_range()/flush_dcache_range() functions. >> >> To avoid compiling errors this patch adds an weak empty stub >> function for all ARM cpu. >> >> And each cpu can implement its own implementation. If not >> implemented by default it will use an empty function. >> >> Signed-off-by: Josh Wu josh.wu@atmel.com >> --- >> >> Changes in v2: new added >> >> arch/arm/lib/cache.c | 9 +++++++++ >> 1 file changed, 9 insertions(+) > > So, why exactly can't this be entirely common code , but a > CPU-specific code ? :)
Yes.
Yes.
VPAC is PXA270 and to my knowledge, PXA has no cache support in place at all.
Hi, Tom
On Monday, June 08, 2015 at 04:05:04 AM, Josh Wu wrote: > Hi, Marek > > On 6/5/2015 9:18 PM, Marek Vasut wrote: >> On Friday, June 05, 2015 at 09:47:30 AM, Josh Wu wrote: >>> Since some driver like ohci, lcd used dcache functions. But some >>> ARM cpu don't implement the >>> invalidate_dcache_range()/flush_dcache_range() functions. >>> >>> To avoid compiling errors this patch adds an weak empty stub >>> function for all ARM cpu. >>> >>> And each cpu can implement its own implementation. If not >>> implemented by default it will use an empty function. >>> >>> Signed-off-by: Josh Wu josh.wu@atmel.com >>> --- >>> >>> Changes in v2: new added >>> >>> arch/arm/lib/cache.c | 9 +++++++++ >>> 1 file changed, 9 insertions(+) >> So, why exactly can't this be entirely common code , but a >> CPU-specific code ? :) > Do you mean to make those empty functions as common code for all arch > cpu to use? Yes.
> It seems there is no place to put common code for all arch cpu. Isn't that what the common/ directory is for ? ;-)
Yes.
ok, so use a empty function is reasonable for pxa.
Marek, Tom
I just sent out another two patches: first one is drop the invalidate_dcache_range()/flush_dcache_range(). second one is drop the flush_cache() function.
Could you check those two patches? thank you.
Hi, Tom
Hi, Marek
On 6/5/2015 9:18 PM, Marek Vasut wrote: >On Friday, June 05, 2015 at 09:47:30 AM, Josh Wu wrote: >>Since some driver like ohci, lcd used dcache functions. But some ARM >>cpu don't implement the invalidate_dcache_range()/flush_dcache_range() >>functions. >> >>To avoid compiling errors this patch adds an weak empty stub function >>for all ARM cpu. >> >>And each cpu can implement its own implementation. If not implemented >>by default it will use an empty function. >> >>Signed-off-by: Josh Wu josh.wu@atmel.com >>--- >> >>Changes in v2: new added >> >> arch/arm/lib/cache.c | 9 +++++++++ >> 1 file changed, 9 insertions(+) >So, why exactly can't this be entirely common code , but a CPU-specific >code ? :) Do you mean to make those empty functions as common code for all arch cpu to use?
Yes.
Yes.
It was a link failure for me when I just dropped flush_cache() from arch/arm/lib/cache.c
This series is based on the patch I sent: http://patchwork.ozlabs.org/patch/481095/ As above introduces the default empty function for invalidate_dcache_range() & flush_dcache_range() in arch/arm/lib/cache.c. So in this series, we can drop the empty stubs in arch/arm/cpu/
Also this series introduces a default function for flush_cache().
Josh Wu (2): ARM: cache: drop the empty dcache functions as we have it in lib/cache.c ARM: cache: implement a default flush_cache() function
arch/arm/cpu/arm1136/cpu.c | 17 ----------------- arch/arm/cpu/arm926ejs/cache.c | 17 ----------------- arch/arm/cpu/armv7/cache_v7.c | 21 --------------------- arch/arm/cpu/armv8/cache_v8.c | 16 ---------------- arch/arm/lib/cache.c | 26 +++++--------------------- 5 files changed, 5 insertions(+), 92 deletions(-)
As there are empty function invalidate_dcache_range(), flush_dcache_range() in arch/arm/lib/cache.c. So we can reuse it by just drop them in arch/arm/cpu/.
arch/arm/cpu/arm1136/cpu.c | 8 -------- arch/arm/cpu/arm926ejs/cache.c | 8 -------- arch/arm/cpu/armv7/cache_v7.c | 8 -------- arch/arm/cpu/armv8/cache_v8.c | 8 -------- 4 files changed, 32 deletions(-)
diff --git a/arch/arm/cpu/arm1136/cpu.c b/arch/arm/cpu/arm1136/cpu.c index a7aed4b..b4d1d54 100644 --- a/arch/arm/cpu/arm1136/cpu.c +++ b/arch/arm/cpu/arm1136/cpu.c @@ -134,14 +134,6 @@ void flush_dcache_all(void) { }
-void invalidate_dcache_range(unsigned long start, unsigned long stop) -{ -} - -void flush_dcache_range(unsigned long start, unsigned long stop) -{ -} - void flush_cache(unsigned long start, unsigned long size) { } diff --git a/arch/arm/cpu/arm926ejs/cache.c b/arch/arm/cpu/arm926ejs/cache.c index 8d7873c..99d1a13 100644 --- a/arch/arm/cpu/arm926ejs/cache.c +++ b/arch/arm/cpu/arm926ejs/cache.c @@ -83,14 +83,6 @@ void flush_dcache_all(void) { }
-void invalidate_dcache_range(unsigned long start, unsigned long stop) -{ -} - -void flush_dcache_range(unsigned long start, unsigned long stop) -{ -} - void flush_cache(unsigned long start, unsigned long size) { } diff --git a/arch/arm/cpu/armv7/cache_v7.c b/arch/arm/cpu/armv7/cache_v7.c index e8ee875..4f0e406 100644 --- a/arch/arm/cpu/armv7/cache_v7.c +++ b/arch/arm/cpu/armv7/cache_v7.c @@ -304,14 +304,6 @@ void flush_dcache_all(void) { }
-void invalidate_dcache_range(unsigned long start, unsigned long stop) -{ -} - -void flush_dcache_range(unsigned long start, unsigned long stop) -{ -} - void arm_init_before_mmu(void) { } diff --git a/arch/arm/cpu/armv8/cache_v8.c b/arch/arm/cpu/armv8/cache_v8.c index c5ec529..f8c17cc 100644 --- a/arch/arm/cpu/armv8/cache_v8.c +++ b/arch/arm/cpu/armv8/cache_v8.c @@ -149,14 +149,6 @@ void flush_dcache_all(void) { }
-void invalidate_dcache_range(unsigned long start, unsigned long stop) -{ -} - -void flush_dcache_range(unsigned long start, unsigned long stop) -{ -} - void dcache_enable(void) { }
Hello Josh,
Sorry this series somehow dropped off my radar completely. Is it still needed now? If it does, then it would require rework as some of the functions removed are not empty anymore.
void dcache_enable(void) { } -- 1.9.1
Amicalement,
On Sat, Sep 12, 2015 at 11:14:18AM +0200, Albert ARIBAUD wrote:
Hello Josh,
An updated version of this series which handled other arches has been applied now.
It will just call flush_dcache_range().
As ARM1136 & ARM926ejs already implemented their own flush_cache(), those code in weak function in arch/arm/lib/cache.c can be dropped.
arch/arm/cpu/arm1136/cpu.c | 9 --------- arch/arm/cpu/arm926ejs/cache.c | 9 --------- arch/arm/cpu/armv7/cache_v7.c | 13 ------------- arch/arm/cpu/armv8/cache_v8.c | 8 -------- arch/arm/lib/cache.c | 26 +++++--------------------- 5 files changed, 5 insertions(+), 60 deletions(-)
diff --git a/arch/arm/cpu/arm1136/cpu.c b/arch/arm/cpu/arm1136/cpu.c index b4d1d54..f092ffc 100644 --- a/arch/arm/cpu/arm1136/cpu.c +++ b/arch/arm/cpu/arm1136/cpu.c @@ -120,11 +120,6 @@ void flush_dcache_range(unsigned long start, unsigned long stop) asm volatile("mcr p15, 0, %0, c7, c10, 4" : : "r" (0)); }
-void flush_cache(unsigned long start, unsigned long size) -{ - flush_dcache_range(start, start + size); -} - #else /* #ifndef CONFIG_SYS_DCACHE_OFF */ void invalidate_dcache_all(void) { @@ -133,10 +128,6 @@ void invalidate_dcache_all(void) void flush_dcache_all(void) { } - -void flush_cache(unsigned long start, unsigned long size) -{ -} #endif /* #ifndef CONFIG_SYS_DCACHE_OFF */
#if !defined(CONFIG_SYS_ICACHE_OFF) || !defined(CONFIG_SYS_DCACHE_OFF) diff --git a/arch/arm/cpu/arm926ejs/cache.c b/arch/arm/cpu/arm926ejs/cache.c index 99d1a13..e5c1a6a 100644 --- a/arch/arm/cpu/arm926ejs/cache.c +++ b/arch/arm/cpu/arm926ejs/cache.c @@ -69,11 +69,6 @@ void flush_dcache_range(unsigned long start, unsigned long stop)
asm volatile("mcr p15, 0, %0, c7, c10, 4\n" : : "r"(0)); } - -void flush_cache(unsigned long start, unsigned long size) -{ - flush_dcache_range(start, start + size); -} #else /* #ifndef CONFIG_SYS_DCACHE_OFF */ void invalidate_dcache_all(void) { @@ -82,10 +77,6 @@ void invalidate_dcache_all(void) void flush_dcache_all(void) { } - -void flush_cache(unsigned long start, unsigned long size) -{ -} #endif /* #ifndef CONFIG_SYS_DCACHE_OFF */
/* diff --git a/arch/arm/cpu/armv7/cache_v7.c b/arch/arm/cpu/armv7/cache_v7.c index 4f0e406..a5aa4fa 100644 --- a/arch/arm/cpu/armv7/cache_v7.c +++ b/arch/arm/cpu/armv7/cache_v7.c @@ -286,15 +286,6 @@ void mmu_page_table_flush(unsigned long start, unsigned long stop) flush_dcache_range(start, stop); v7_inval_tlb(); } - -/* - * Flush range from all levels of d-cache/unified-cache used: - * Affects the range [start, start + size - 1] - */ -void flush_cache(unsigned long start, unsigned long size) -{ - flush_dcache_range(start, start + size); -} #else /* #ifndef CONFIG_SYS_DCACHE_OFF */ void invalidate_dcache_all(void) { @@ -308,10 +299,6 @@ void arm_init_before_mmu(void) { }
-void flush_cache(unsigned long start, unsigned long size) -{ -} - void mmu_page_table_flush(unsigned long start, unsigned long stop) { } diff --git a/arch/arm/cpu/armv8/cache_v8.c b/arch/arm/cpu/armv8/cache_v8.c index f8c17cc..92b66c3 100644 --- a/arch/arm/cpu/armv8/cache_v8.c +++ b/arch/arm/cpu/armv8/cache_v8.c @@ -217,11 +217,3 @@ void __weak enable_caches(void) icache_enable(); dcache_enable(); } - -/* - * Flush range from all levels of d-cache/unified-cache - */ -void flush_cache(unsigned long start, unsigned long size) -{ - flush_dcache_range(start, start + size); -} diff --git a/arch/arm/lib/cache.c b/arch/arm/lib/cache.c index bc48f53..cd13db3 100644 --- a/arch/arm/lib/cache.c +++ b/arch/arm/lib/cache.c @@ -10,29 +10,13 @@ #include <common.h> #include <malloc.h>
+/* + * Flush range from all levels of d-cache/unified-cache. + * Affects the range [start, start + size - 1]. + */ __weak void flush_cache(unsigned long start, unsigned long size) { -#if defined(CONFIG_CPU_ARM1136) - -#if !defined(CONFIG_SYS_ICACHE_OFF) - asm("mcr p15, 0, r1, c7, c5, 0"); /* invalidate I cache */ -#endif - -#if !defined(CONFIG_SYS_DCACHE_OFF) - asm("mcr p15, 0, r1, c7, c14, 0"); /* Clean+invalidate D cache */ -#endif - -#endif /* CONFIG_CPU_ARM1136 */ - -#ifdef CONFIG_CPU_ARM926EJS -#if !(defined(CONFIG_SYS_ICACHE_OFF) && defined(CONFIG_SYS_DCACHE_OFF)) - /* test and clean, page 2-23 of arm926ejs manual */ - asm("0: mrc p15, 0, r15, c7, c10, 3\n\t" "bne 0b\n" : : : "memory"); - /* disable write buffer as well (page 2-22) */ - asm("mcr p15, 0, %0, c7, c10, 4" : : "r" (0)); -#endif -#endif /* CONFIG_CPU_ARM926EJS */ - return; + flush_dcache_range(start, start + size); }
Any feedback for this series patch?
participants (5)
Albert ARIBAUD
Angelo Dureghello
Josh Wu
