[PATCH] usb: host: dwc3-sti-glue: Fix ofnode_valid() parameter
node varaible is used as iterator into ofnode_for_each_subnode() loop, when exiting of it, node is no more a valid ofnode. Use dwc3_node instead as parameter of ofnode_valid()
Fixes: ac28e59a574d ("usb: Migrate to support live DT for some driver") Signed-off-by: Patrice Chotard patrice.chotard@st.com ---
drivers/usb/host/dwc3-sti-glue.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/usb/host/dwc3-sti-glue.c b/drivers/usb/host/dwc3-sti-glue.c index a72ab20168..3e6c1429d6 100644 --- a/drivers/usb/host/dwc3-sti-glue.c +++ b/drivers/usb/host/dwc3-sti-glue.c @@ -159,7 +159,7 @@ static int sti_dwc3_glue_bind(struct udevice *dev) dwc3_node = node; }
- if (!ofnode_valid(node)) { + if (!ofnode_valid(dwc3_node)) { pr_err("Can't find dwc3 subnode for %s\n", dev->name); return -ENODEV; }
Hi
Just a gentle reminder as this patch is present on mailing list since 2 months.
Regards
Patrice
- if (!ofnode_valid(dwc3_node)) { pr_err("Can't find dwc3 subnode for %s\n", dev->name); return -ENODEV; }
Patrice CHOTARD
Patrice Chotard
