[U-Boot-Users] FYI, updated CustodianGitTrees page
http://www.denx.de/wiki/rdiff/UBoot/CustodianGitTrees?rev2=1.29&rev1=1.30
The major change was adding a "maintenance" bullet to the list and add a tip on how to remove unnecessary branch labels from the remote repository. We (custodians) inherited some branches from a while ago and I wanted to clean up the unused branches, had to figure out how.
Hint of you want to do the same cleanup on your repositories:
# show all branches: git branch -a
# kill off the obsolete ones: git push ssh://gu-fdt@git.denx.de/u-boot-fdt.git :heads/dzu@denx.de git push ssh://gu-fdt@git.denx.de/u-boot-fdt.git :heads/wd@denx.de git push ssh://gu-fdt@git.denx.de/u-boot-fdt.git :heads/testing-4xx_enet git push ssh://gu-fdt@git.denx.de/u-boot-fdt.git :heads/testing-NAND git push ssh://gu-fdt@git.denx.de/u-boot-fdt.git :heads/testing-USB
While I was in the page, I also changed all the "git+ssh" to "ssh" - unless I'm grossly confused, newer git versions no longer need to use the "git+" hack. I also changed the "gu-fdt" ssh user names to the generic form "git-<subrepo>" so people cutting and pasting get a better hint if they forget to fix the login name.
Best regards, gvb
Hi Jerry,
I found NIOS2-5_0_0 branch. I think we can kill off this too.
Michal Simek
Best regards, gvb
Jerry Van Baren
Michal Simek
