[U-Boot] [PATCH] QE/DeepSleep: add QE deepsleep support for mpc85xx
Muram will power off during deepsleep, and the microcode of qe in muram will be lost, it should be reload when resume.
Signed-off-by: Zhao Qiang B45475@freescale.com --- arch/arm/include/asm/arch-ls102xa/config.h | 4 -- board/freescale/common/mpc85xx_sleep.c | 8 +++ drivers/qe/qe.c | 82 ++++++++++++++++++++++++++++++ drivers/qe/qe.h | 6 +++ include/linux/immap_qe.h | 12 +++++ 5 files changed, 108 insertions(+), 4 deletions(-)
diff --git a/arch/arm/include/asm/arch-ls102xa/config.h b/arch/arm/include/asm/arch-ls102xa/config.h index 25cc862..4f686e3 100644 --- a/arch/arm/include/asm/arch-ls102xa/config.h +++ b/arch/arm/include/asm/arch-ls102xa/config.h @@ -105,10 +105,6 @@
#define DCU_LAYER_MAX_NUM 16
-#define QE_MURAM_SIZE 0x6000UL -#define MAX_QE_RISC 1 -#define QE_NUM_OF_SNUM 28 - #define CONFIG_SYS_FSL_SRDS_1
#ifdef CONFIG_LS102XA diff --git a/board/freescale/common/mpc85xx_sleep.c b/board/freescale/common/mpc85xx_sleep.c index f924e7f..9e4132c 100644 --- a/board/freescale/common/mpc85xx_sleep.c +++ b/board/freescale/common/mpc85xx_sleep.c @@ -7,6 +7,9 @@ #include <common.h> #include <asm/immap_85xx.h> #include "sleep.h" +#ifdef CONFIG_U_QE +#include "../../../drivers/qe/qe.h" +#endif
DECLARE_GLOBAL_DATA_PTR;
@@ -65,6 +68,11 @@ static void dp_resume_prepare(void) disable_cpc_sram(); #endif enable_cpc(); + +#ifdef CONFIG_U_QE + u_qe_resume(); +#endif + }
int fsl_dp_resume(void) diff --git a/drivers/qe/qe.c b/drivers/qe/qe.c index d24651b..84e1433 100644 --- a/drivers/qe/qe.c +++ b/drivers/qe/qe.c @@ -196,6 +196,18 @@ void u_qe_init(void) } #endif
+#ifdef CONFIG_U_QE +void u_qe_resume(void) +{ + qe_map_t *qe_immrr; + uint qe_base = CONFIG_SYS_IMMR + QE_IMMR_OFFSET; /* QE immr base */ + qe_immrr = (qe_map_t *)qe_base; + + u_qe_firmware_resume((const void *)CONFIG_SYS_QE_FW_ADDR, qe_immrr); + out_be32(&qe_immrr->iram.iready, QE_IRAM_READY); +} +#endif + void qe_reset(void) { qe_issue_cmd(QE_RESET, QE_CR_SUBBLOCK_INVALID, @@ -580,6 +592,76 @@ int u_qe_upload_firmware(const struct qe_firmware *firmware) } #endif
+#ifdef CONFIG_U_QE +int u_qe_firmware_resume(const struct qe_firmware *firmware, qe_map_t *qe_immrr) +{ + unsigned int i; + unsigned int j; + const struct qe_header *hdr; + const u32 *code; +#ifdef CONFIG_DEEP_SLEEP +#ifdef CONFIG_PPC + ccsr_gur_t __iomem *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); +#else + struct ccsr_gur __iomem *gur = (void *)CONFIG_SYS_FSL_GUTS_ADDR; +#endif +#endif + + if (!firmware) + return -EINVAL; + + hdr = &firmware->header; + + /* Check the magic */ + if ((hdr->magic[0] != 'Q') || (hdr->magic[1] != 'E') || + (hdr->magic[2] != 'F')) { +#ifdef CONFIG_DEEP_SLEEP + setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_QE_DISABLE); +#endif + return -EPERM; + } + + /* + * If the microcode calls for it, split the I-RAM. + */ + if (!firmware->split) { + out_be16(&qe_immrr->cp.cercr, + in_be16(&qe_immrr->cp.cercr) | QE_CP_CERCR_CIR); + } + + /* Loop through each microcode. */ + for (i = 0; i < firmware->count; i++) { + const struct qe_microcode *ucode = &firmware->microcode[i]; + + /* Upload a microcode if it's present */ + if (!ucode->code_offset) + return 0; + + code = (const void *)firmware + be32_to_cpu(ucode->code_offset); + + /* Use auto-increment */ + out_be32(&qe_immrr->iram.iadd, be32_to_cpu(ucode->iram_offset) | + QE_IRAM_IADD_AIE | QE_IRAM_IADD_BADDR); + + for (i = 0; i < be32_to_cpu(ucode->count); i++) + out_be32(&qe_immrr->iram.idata, be32_to_cpu(code[i])); + + /* Program the traps for this processor */ + for (j = 0; j < 16; j++) { + u32 trap = be32_to_cpu(ucode->traps[j]); + + if (trap) + out_be32(&qe_immrr->rsp[i].tibcr[j], trap); + } + + /* Enable traps */ + out_be32(&qe_immrr->rsp[i].eccr, be32_to_cpu(ucode->eccr)); + } + + return 0; +} +#endif + struct qe_firmware_info *qe_get_firmware_info(void) { return qe_firmware_uploaded ? &qe_firmware_info : NULL; diff --git a/drivers/qe/qe.h b/drivers/qe/qe.h index 33878f8..77b18e9 100644 --- a/drivers/qe/qe.h +++ b/drivers/qe/qe.h @@ -11,6 +11,9 @@ #define __QE_H__
#include "common.h" +#ifdef CONFIG_U_QE +#include <linux/immap_qe.h> +#endif
#define QE_NUM_OF_BRGS 16 #define UCC_MAX_NUM 8 @@ -288,6 +291,9 @@ void qe_reset(void); #ifdef CONFIG_U_QE void u_qe_init(void); int u_qe_upload_firmware(const struct qe_firmware *firmware); +void u_qe_resume(void); +int u_qe_firmware_resume(const struct qe_firmware *firmware, + qe_map_t *qe_immrr); #endif
#endif /* __QE_H__ */ diff --git a/include/linux/immap_qe.h b/include/linux/immap_qe.h index b317dcb..6d1f88e 100644 --- a/include/linux/immap_qe.h +++ b/include/linux/immap_qe.h @@ -24,6 +24,18 @@ #endif #endif
+#ifdef CONFIG_LS102XA +#define QE_MURAM_SIZE 0x6000UL +#define MAX_QE_RISC 1 +#define QE_NUM_OF_SNUM 28 +#endif + +#ifdef CONFIG_PPC +#define QE_IMMR_OFFSET 0x00140000 +#else +#define QE_IMMR_OFFSET 0x01400000 +#endif + /* QE I-RAM */ typedef struct qe_iram { u32 iadd; /* I-RAM Address Register */
Applied to fsl-qoriq master, awaiting upstream.
York
York Sun
Zhao Qiang
