[PATCH v5 0/4] VIM3: add support for checking 'Function' button state
Hi All,
This patchset adds all building blocks needed for checking the 'Function' button state in the boot script on Amlogic A311D based VIM3 board. This button is connected to the ADC lines of the SoC, so it required to enable meson SARADC, the clocks needed for it and a simple button-adc drivers.
Once applied, one can use following commands in the boot scripts: -->8--- echo Checking Func button state: \c if button Function then echo Selected alternative boot ... fi --->8---
Best regards Marek Szyprowski Samsung R&D Institute Poland
Changelog: v5: - rebased onto latest uboot-amlogic/u-boot-amlogic-next branch - synchronized adc-keys binding with the recent version from the Linux kernel - updated adc-keys driver to match behavior from dt-bindings - added a patch for meson-saradc driver to register vdd reference supply to the ADC framework
v4: https://lists.denx.de/pipermail/u-boot/2020-December/435641.html - rebased onto uboot-amlogic/u-boot-amlogic-next and dropped merged patches - added adc-keys bindings docs (copied from Linux kernel) - minor code adjustments pointed by Simon - enabled driver also in khadas-vim3l_defconfig
v3: https://lists.denx.de/pipermail/u-boot/2020-December/435072.html - removed 'button' env variable - extended kconfig and patch descriptions
v2: https://lists.denx.de/pipermail/u-boot/2020-December/434991.html - removed Change-Id tags - split defconfig changes into ADC and button related
v1: https://lists.denx.de/pipermail/u-boot/2020-December/434875.html - initial submission
Patch summary:
Marek Szyprowski (4): dt-bindings: input: adc-keys bindings documentation button: add a simple Analog to Digital Converter device based button driver adc: meson-saradc: add support for getting reference voltage value configs: khadas-vim3(l): enable Function button support
configs/khadas-vim3_defconfig | 2 + configs/khadas-vim3l_defconfig | 2 + doc/device-tree-bindings/input/adc-keys.txt | 67 +++++++++ drivers/adc/meson-saradc.c | 21 +++ drivers/button/Kconfig | 8 + drivers/button/Makefile | 1 + drivers/button/button-adc.c | 156 ++++++++++++++++++++ 7 files changed, 257 insertions(+) create mode 100644 doc/device-tree-bindings/input/adc-keys.txt create mode 100644 drivers/button/button-adc.c
Dump adc-keys bindings documentation from Linux kernel source tree from commit 698dc0cf9447 ("dt-bindings: input: adc-keys: clarify description").
Signed-off-by: Marek Szyprowski m.szyprowski@samsung.com --- doc/device-tree-bindings/input/adc-keys.txt | 67 +++++++++++++++++++++ 1 file changed, 67 insertions(+) create mode 100644 doc/device-tree-bindings/input/adc-keys.txt
diff --git a/doc/device-tree-bindings/input/adc-keys.txt b/doc/device-tree-bindings/input/adc-keys.txt new file mode 100644 index 0000000000..6c8be6a9ac --- /dev/null +++ b/doc/device-tree-bindings/input/adc-keys.txt @@ -0,0 +1,67 @@ +ADC attached resistor ladder buttons +------------------------------------ + +Required properties: + - compatible: "adc-keys" + - io-channels: Phandle to an ADC channel + - io-channel-names = "buttons"; + - keyup-threshold-microvolt: Voltage above or equal to which all the keys are + considered up. + +Optional properties: + - poll-interval: Poll interval time in milliseconds + - autorepeat: Boolean, Enable auto repeat feature of Linux input + subsystem. + +Each button (key) is represented as a sub-node of "adc-keys": + +Required subnode-properties: + - label: Descriptive name of the key. + - linux,code: Keycode to emit. + - press-threshold-microvolt: voltage above or equal to which this key is + considered pressed. + +No two values of press-threshold-microvolt may be the same. +All values of press-threshold-microvolt must be less than +keyup-threshold-microvolt. + +Example: + +#include <dt-bindings/input/input.h> + + adc-keys { + compatible = "adc-keys"; + io-channels = <&lradc 0>; + io-channel-names = "buttons"; + keyup-threshold-microvolt = <2000000>; + + button-up { + label = "Volume Up"; + linux,code = <KEY_VOLUMEUP>; + press-threshold-microvolt = <1500000>; + }; + + button-down { + label = "Volume Down"; + linux,code = <KEY_VOLUMEDOWN>; + press-threshold-microvolt = <1000000>; + }; + + button-enter { + label = "Enter"; + linux,code = <KEY_ENTER>; + press-threshold-microvolt = <500000>; + }; + }; + ++--------------------------------+------------------------+ +| 2.000.000 <= value | no key pressed | ++--------------------------------+------------------------+ +| 1.500.000 <= value < 2.000.000 | KEY_VOLUMEUP pressed | ++--------------------------------+------------------------+ +| 1.000.000 <= value < 1.500.000 | KEY_VOLUMEDOWN pressed | ++--------------------------------+------------------------+ +| 500.000 <= value < 1.000.000 | KEY_ENTER pressed | ++--------------------------------+------------------------+ +| value < 500.000 | no key pressed | ++--------------------------------+------------------------+
On Tue, 26 Jan 2021 at 02:51, Marek Szyprowski m.szyprowski@samsung.com wrote:
Add a simple Analog to Digital Converter device based button driver. This driver binds to the 'adc-keys' device tree node.
Signed-off-by: Marek Szyprowski m.szyprowski@samsung.com --- drivers/button/Kconfig | 8 ++ drivers/button/Makefile | 1 + drivers/button/button-adc.c | 156 ++++++++++++++++++++++++++++++++++++ 3 files changed, 165 insertions(+) create mode 100644 drivers/button/button-adc.c
diff --git a/drivers/button/Kconfig b/drivers/button/Kconfig index 6b3ec7e55d..6db3c5e93a 100644 --- a/drivers/button/Kconfig +++ b/drivers/button/Kconfig @@ -9,6 +9,14 @@ config BUTTON can provide access to board-specific buttons. Use of the device tree for configuration is encouraged.
+config BUTTON_ADC + bool "Button adc" + depends on BUTTON + help + Enable support for buttons which are connected to Analog to Digital + Converter device. The ADC driver must use driver model. Buttons are + configured using the device tree. + config BUTTON_GPIO bool "Button gpio" depends on BUTTON diff --git a/drivers/button/Makefile b/drivers/button/Makefile index fcc10ebe8d..bbd18af149 100644 --- a/drivers/button/Makefile +++ b/drivers/button/Makefile @@ -3,4 +3,5 @@ # Copyright (C) 2020 Philippe Reynes philippe.reynes@softathome.com
obj-$(CONFIG_BUTTON) += button-uclass.o +obj-$(CONFIG_BUTTON_ADC) += button-adc.o obj-$(CONFIG_BUTTON_GPIO) += button-gpio.o diff --git a/drivers/button/button-adc.c b/drivers/button/button-adc.c new file mode 100644 index 0000000000..1901d59a0e --- /dev/null +++ b/drivers/button/button-adc.c @@ -0,0 +1,156 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2021 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * Author: Marek Szyprowski m.szyprowski@samsung.com + */ + +#include <common.h> +#include <adc.h> +#include <button.h> +#include <log.h> +#include <dm.h> +#include <dm/lists.h> +#include <dm/of_access.h> +#include <dm/uclass-internal.h> + +/** + * struct button_adc_priv - private data for button-adc driver. + * + * @adc: Analog to Digital Converter device to which button is connected. + * @channel: channel of the ADC device to probe the button state. + * @min: minimal raw ADC sample value to consider button as pressed. + * @max: maximal raw ADC sample value to consider button as pressed. + */ +struct button_adc_priv { + struct udevice *adc; + int channel; + int min; + int max; +}; + +static enum button_state_t button_adc_get_state(struct udevice *dev) +{ + struct button_adc_priv *priv = dev_get_priv(dev); + unsigned int val; + int ret; + + ret = adc_start_channel(priv->adc, priv->channel); + if (ret) + return ret; + + ret = adc_channel_data(priv->adc, priv->channel, &val); + if (ret) + return ret; + + if (ret == 0) + return (val >= priv->min && val < priv->max) ? + BUTTON_ON : BUTTON_OFF; + + return ret; +} + +static int button_adc_probe(struct udevice *dev) +{ + struct button_uc_plat *uc_plat = dev_get_uclass_plat(dev); + struct button_adc_priv *priv = dev_get_priv(dev); + struct ofnode_phandle_args args; + u32 treshold, up_treshold, t; + unsigned int mask; + ofnode node; + int ret, vdd; + + /* Ignore the top-level button node */ + if (!uc_plat->label) + return 0; + + ret = dev_read_phandle_with_args(dev->parent, "io-channels", + "#io-channel-cells", 0, 0, &args); + if (ret) + return ret; + + ret = uclass_get_device_by_ofnode(UCLASS_ADC, args.node, &priv->adc); + if (ret) + return ret; + + ret = ofnode_read_u32(dev_ofnode(dev->parent), + "keyup-threshold-microvolt", &up_treshold); + if (ret) + return ret; + + ret = ofnode_read_u32(dev_ofnode(dev), "press-threshold-microvolt", + &treshold); + if (ret) + return ret; + + dev_for_each_subnode(node, dev->parent) { + ret = ofnode_read_u32(dev_ofnode(dev), + "press-threshold-microvolt", &t); + if (ret) + return ret; + + if (t > treshold) + up_treshold = t; + } + + ret = adc_vdd_value(priv->adc, &vdd); + if (ret) + return ret; + + ret = adc_data_mask(priv->adc, &mask); + if (ret) + return ret; + + priv->channel = args.args[0]; + priv->min = mask * (treshold / 1000) / (vdd / 1000); + priv->max = mask * (up_treshold / 1000) / (vdd / 1000); + + return ret; +} + +static int button_adc_bind(struct udevice *parent) +{ + struct udevice *dev; + ofnode node; + int ret; + + dev_for_each_subnode(node, parent) { + struct button_uc_plat *uc_plat; + const char *label; + + label = ofnode_read_string(node, "label"); + if (!label) { + debug("%s: node %s has no label\n", __func__, + ofnode_get_name(node)); + return -EINVAL; + } + ret = device_bind_driver_to_node(parent, "button_adc", + ofnode_get_name(node), + node, &dev); + if (ret) + return ret; + uc_plat = dev_get_uclass_plat(dev); + uc_plat->label = label; + } + + return 0; +} + +static const struct button_ops button_adc_ops = { + .get_state = button_adc_get_state, +}; + +static const struct udevice_id button_adc_ids[] = { + { .compatible = "adc-keys" }, + { } +}; + +U_BOOT_DRIVER(button_adc) = { + .name = "button_adc", + .id = UCLASS_BUTTON, + .of_match = button_adc_ids, + .ops = &button_adc_ops, + .priv_auto = sizeof(struct button_adc_priv), + .bind = button_adc_bind, + .probe = button_adc_probe, +};
+config BUTTON_ADC
- bool "Button adc"
- depends on BUTTON
- help
- config BUTTON_GPIO bool "Button gpio" depends on BUTTON
- Copyright (C) 2021 Samsung Electronics Co., Ltd.
- Author: Marek Szyprowski m.szyprowski@samsung.com
- struct button_adc_priv - private data for button-adc driver.
- @adc: Analog to Digital Converter device to which button is connected.
- @channel: channel of the ADC device to probe the button state.
- @min: minimal raw ADC sample value to consider button as pressed.
- @max: maximal raw ADC sample value to consider button as pressed.
- struct udevice *adc;
- int channel;
- int min;
- int max;
- struct button_adc_priv *priv = dev_get_priv(dev);
- unsigned int val;
- int ret;
- ret = adc_start_channel(priv->adc, priv->channel);
- if (ret)
return ret;
- ret = adc_channel_data(priv->adc, priv->channel, &val);
- if (ret)
return ret;
- if (ret == 0)
- return ret;
- struct button_uc_plat *uc_plat = dev_get_uclass_plat(dev);
- struct ofnode_phandle_args args;
- u32 treshold, up_treshold, t;
- unsigned int mask;
- ofnode node;
- int ret, vdd;
- /* Ignore the top-level button node */
- if (!uc_plat->label)
- ret = dev_read_phandle_with_args(dev->parent, "io-channels",
- if (ret)
return ret;
- ret = uclass_get_device_by_ofnode(UCLASS_ADC, args.node, &priv->adc);
- if (ret)
return ret;
- ret = ofnode_read_u32(dev_ofnode(dev->parent),
- if (ret)
return ret;
- ret = ofnode_read_u32(dev_ofnode(dev), "press-threshold-microvolt",
&treshold);
- if (ret)
return ret;
- dev_for_each_subnode(node, dev->parent) {
if (ret)
return ret;
if (t > treshold)
up_treshold = t;
Linux' Documentation/devicetree/bindings/input/adc-keys.txt describes that one virtual key is created per sub-node.
If I read your code correctly, this is not what you are implementing. Instead you only define a single key per adc-keys node.
Why are your deviating from the bindings document?
Best regards
Heinrich
- ret = adc_vdd_value(priv->adc, &vdd);
- if (ret)
return ret;
- ret = adc_data_mask(priv->adc, &mask);
- if (ret)
return ret;
- priv->channel = args.args[0];
- priv->min = mask * (treshold / 1000) / (vdd / 1000);
- priv->max = mask * (up_treshold / 1000) / (vdd / 1000);
- return ret;
- struct udevice *dev;
- ofnode node;
- int ret;
- dev_for_each_subnode(node, parent) {
const char *label;
if (!label) {
return -EINVAL;
node, &dev);
if (ret)
return ret;
- .get_state = button_adc_get_state,
- { .compatible = "adc-keys" },
- .name = "button_adc",
- .id = UCLASS_BUTTON,
- .of_match = button_adc_ids,
- .ops = &button_adc_ops,
- .priv_auto = sizeof(struct button_adc_priv),
- .bind = button_adc_bind,
- .probe = button_adc_probe,
Hi Heinrich,
- * http://www.samsung.com
connected.
+ return ret; +}
No I don't. button_adc_bind() binds to the root node with 'adc-keys' compatible, while the dev_for_each_subnode() loop instantiates driver for each subnode, so the button_adc_probe() is called for each defined key. I've copied this pattern from gpio-keys driver.
Here is the related code:
+ return 0; +}
Best regards
On 26.01.21 12:25, Marek Szyprowski wrote:
Hi Heinrich,
connected.
+ return ret; +}
Thanks for pointing this out.
To really test the driver we would need an emulated device on the sandbox where we can set the voltage and see which button is activated.
I assume this can be added to test/dm/adc.c.
Best regards
Heinrich
+ return 0; +}
Best regards
Hi Heinrich,
+config BUTTON_ADC
- bool "Button adc"
- depends on BUTTON
- help
Digital
Buttons are
connected.
- int channel;
- int min;
- int max;
- unsigned int val;
- int ret;
- if (ret)
return ret;
- if (ret)
return ret;
- if (ret == 0)
- return ret;
- ofnode node;
- int ret, vdd;
- if (ret)
return ret;
&priv->adc);
- if (ret)
return ret;
- if (ret)
return ret;
&treshold);
- if (ret)
return ret;
if (ret)
return ret;
if (t > treshold)
up_treshold = t;
Yes please!
Hi Simon,
+config BUTTON_ADC
- bool "Button adc"
- depends on BUTTON
- help
Digital
Buttons are
connected.
- int channel;
- int min;
- int max;
- unsigned int val;
- int ret;
- if (ret)
return ret;
- if (ret)
return ret;
- if (ret == 0)
- return ret;
- ofnode node;
- int ret, vdd;
- if (ret)
return ret;
&priv->adc);
- if (ret)
return ret;
- if (ret)
return ret;
&treshold);
- if (ret)
return ret;
if (ret)
return ret;
if (t > treshold)
up_treshold = t;
Yes please!
Could you give me a bit more hints or point where to start? I've tried to build sandbox, but it fails for v2021.01 release (I've did make sandbox_defconfig && make all). I assume I would need to add adc and adc-keys devices to some sandbox dts and some code triggering and checking the key values, but that's all I know now.
Best regards
Hi Marek,
On Thu, 4 Feb 2021 at 03:36, Marek Szyprowski m.szyprowski@samsung.com wrote:
Hi Simon,
+config BUTTON_ADC
- bool "Button adc"
- depends on BUTTON
- help
Digital
Buttons are
connected.
- int channel;
- int min;
- int max;
- unsigned int val;
- int ret;
- if (ret)
return ret;
- if (ret)
return ret;
- if (ret == 0)
- return ret;
- ofnode node;
- int ret, vdd;
- if (ret)
return ret;
&priv->adc);
- if (ret)
return ret;
- if (ret)
return ret;
&treshold);
- if (ret)
return ret;
if (ret)
return ret;
if (t > treshold)
up_treshold = t;
Yes please!
Well you do need to be able to build sandbox or you will get nowhere...what error did you get? Once we understand what went wrong we can update the docs. Maybe it is missing a dependency.
BTW for testing there is a series with more docs at u-boot-dm/test-working that might be useful.
You can add your node to sandbox.dtsi and then run U-Boot with -T to get the test devicetree. Something like:
$ ./u-boot -T (U-Boot starts)
ut dm adc_multi_channel_shot
(test runs)
You just need to probe your device and then button_get_state() on it.
BTW I think all of the code in your probe() method should move to of_to_plat(). It has nothing to do with probing the device and is all about reading from the devicetree.
Hi Simon,
... Could you give me a bit more hints or point where to start? I've tried to build sandbox, but it fails for v2021.01 release (I've did make sandbox_defconfig && make all). I assume I would need to add adc and adc-keys devices to some sandbox dts and some code triggering and checking the key values, but that's all I know now.
$ gcc --version gcc (Ubuntu 7.5.0-3ubuntu1~18.04) 7.5.0 Copyright (C) 2017 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
$ git checkout v2021.01
$ make sandbox_defconfig # # configuration written to .config #
$ make scripts/kconfig/conf --syncconfig Kconfig CFG u-boot.cfg GEN include/autoconf.mk GEN include/autoconf.mk.dep CFGCHK u-boot.cfg UPD include/generated/timestamp_autogenerated.h HOSTCC tools/mkenvimage.o HOSTLD tools/mkenvimage HOSTCC tools/fit_image.o HOSTCC tools/image-host.o HOSTCC tools/dumpimage.o HOSTLD tools/dumpimage HOSTCC tools/mkimage.o HOSTLD tools/mkimage HOSTLD tools/fit_info HOSTLD tools/fit_check_sign
CC arch/sandbox/cpu/cpu.o In file included from include/common.h:26:0, from arch/sandbox/cpu/cpu.c:6: include/asm/global_data.h:112:58: warning: call-clobbered register used for global register variable #define DECLARE_GLOBAL_DATA_PTR register volatile gd_t *gd asm ("r9") ^ include/dm/of.h:86:1: note: in expansion of macro ‘DECLARE_GLOBAL_DATA_PTR’ DECLARE_GLOBAL_DATA_PTR; ^~~~~~~~~~~~~~~~~~~~~~~ In file included from arch/sandbox/cpu/cpu.c:18:0: ./arch/sandbox/include/asm/state.h:98:30: error: ‘CONFIG_SANDBOX_SPI_MAX_BUS’ undeclared here (not in a function); did you mean ‘CONFIG_SANDBOX_SPI’? struct sandbox_spi_info spi[CONFIG_SANDBOX_SPI_MAX_BUS] ^~~~~~~~~~~~~~~~~~~~~~~~~~ CONFIG_SANDBOX_SPI ./arch/sandbox/include/asm/state.h:99:7: error: ‘CONFIG_SANDBOX_SPI_MAX_CS’ undeclared here (not in a function); did you mean ‘CONFIG_SANDBOX_SPI_MAX_BUS’? [CONFIG_SANDBOX_SPI_MAX_CS]; ^~~~~~~~~~~~~~~~~~~~~~~~~ CONFIG_SANDBOX_SPI_MAX_BUS arch/sandbox/cpu/cpu.c: In function ‘is_in_sandbox_mem’: arch/sandbox/cpu/cpu.c:83:41: error: ‘volatile struct arch_global_data’ has no member named ‘ram_buf’ return (const uint8_t *)ptr >= gd->arch.ram_buf && ^ arch/sandbox/cpu/cpu.c:84:34: error: ‘volatile struct arch_global_data’ has no member named ‘ram_buf’ (const uint8_t *)ptr < gd->arch.ram_buf + gd->ram_size; ^ arch/sandbox/cpu/cpu.c: At top level: arch/sandbox/cpu/cpu.c:97:7: error: redefinition of ‘phys_to_virt’ void *phys_to_virt(phys_addr_t paddr) ^~~~~~~~~~~~ In file included from include/asm/io.h:495:0, from arch/sandbox/cpu/cpu.c:15: include/asm-generic/io.h:30:21: note: previous definition of ‘phys_to_virt’ was here static inline void *phys_to_virt(phys_addr_t paddr) ^~~~~~~~~~~~ arch/sandbox/cpu/cpu.c: In function ‘phys_to_virt’: arch/sandbox/cpu/cpu.c:104:27: error: ‘volatile struct arch_global_data’ has no member named ‘ram_buf’ return (void *)(gd->arch.ram_buf + paddr); ^ In file included from include/linux/posix_types.h:4:0, from include/linux/types.h:4, from include/time.h:7, from include/common.h:18, from arch/sandbox/cpu/cpu.c:6: include/linux/stddef.h:17:33: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast] #define offsetof(TYPE, MEMBER) ((size_t) &((TYPE *)0)->MEMBER) ^ include/linux/kernel.h:274:29: note: in expansion of macro ‘offsetof’ (type *)( (char *)__mptr - offsetof(type,member) );}) ^~~~~~~~ include/linux/list.h:327:2: note: in expansion of macro ‘container_of’ container_of(ptr, type, member) ^~~~~~~~~~~~ include/linux/list.h:424:13: note: in expansion of macro ‘list_entry’ for (pos = list_entry((head)->next, typeof(*pos), member); \ ^~~~~~~~~~ arch/sandbox/cpu/cpu.c:111:2: note: in expansion of macro ‘list_for_each_entry’ list_for_each_entry(mentry, &state->mapmem_head, sibling_node) { ^~~~~~~~~~~~~~~~~~~ include/linux/stddef.h:17:33: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast] #define offsetof(TYPE, MEMBER) ((size_t) &((TYPE *)0)->MEMBER) ^ include/linux/kernel.h:274:29: note: in expansion of macro ‘offsetof’ (type *)( (char *)__mptr - offsetof(type,member) );}) ^~~~~~~~ include/linux/list.h:327:2: note: in expansion of macro ‘container_of’ container_of(ptr, type, member) ^~~~~~~~~~~~ include/linux/list.h:426:13: note: in expansion of macro ‘list_entry’ pos = list_entry(pos->member.next, typeof(*pos), member)) ^~~~~~~~~~ arch/sandbox/cpu/cpu.c:111:2: note: in expansion of macro ‘list_for_each_entry’ list_for_each_entry(mentry, &state->mapmem_head, sibling_node) { ^~~~~~~~~~~~~~~~~~~ arch/sandbox/cpu/cpu.c: In function ‘find_tag’: include/linux/stddef.h:17:33: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast] #define offsetof(TYPE, MEMBER) ((size_t) &((TYPE *)0)->MEMBER) ^ include/linux/kernel.h:274:29: note: in expansion of macro ‘offsetof’ (type *)( (char *)__mptr - offsetof(type,member) );}) ^~~~~~~~ include/linux/list.h:327:2: note: in expansion of macro ‘container_of’ container_of(ptr, type, member) ^~~~~~~~~~~~ include/linux/list.h:424:13: note: in expansion of macro ‘list_entry’ for (pos = list_entry((head)->next, typeof(*pos), member); \ ^~~~~~~~~~ arch/sandbox/cpu/cpu.c:132:2: note: in expansion of macro ‘list_for_each_entry’ list_for_each_entry(mentry, &state->mapmem_head, sibling_node) { ^~~~~~~~~~~~~~~~~~~ include/linux/stddef.h:17:33: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast] #define offsetof(TYPE, MEMBER) ((size_t) &((TYPE *)0)->MEMBER) ^ include/linux/kernel.h:274:29: note: in expansion of macro ‘offsetof’ (type *)( (char *)__mptr - offsetof(type,member) );}) ^~~~~~~~ include/linux/list.h:327:2: note: in expansion of macro ‘container_of’ container_of(ptr, type, member) ^~~~~~~~~~~~ include/linux/list.h:426:13: note: in expansion of macro ‘list_entry’ pos = list_entry(pos->member.next, typeof(*pos), member)) ^~~~~~~~~~ arch/sandbox/cpu/cpu.c:132:2: note: in expansion of macro ‘list_for_each_entry’ list_for_each_entry(mentry, &state->mapmem_head, sibling_node) { ^~~~~~~~~~~~~~~~~~~ arch/sandbox/cpu/cpu.c: At top level: arch/sandbox/cpu/cpu.c:142:13: error: redefinition of ‘virt_to_phys’ phys_addr_t virt_to_phys(void *ptr) ^~~~~~~~~~~~ In file included from include/asm/io.h:495:0, from arch/sandbox/cpu/cpu.c:15: include/asm-generic/io.h:46:27: note: previous definition of ‘virt_to_phys’ was here static inline phys_addr_t virt_to_phys(void *vaddr) ^~~~~~~~~~~~ arch/sandbox/cpu/cpu.c: In function ‘virt_to_phys’: arch/sandbox/cpu/cpu.c:151:49: error: ‘volatile struct arch_global_data’ has no member named ‘ram_buf’ return (phys_addr_t)((uint8_t *)ptr - gd->arch.ram_buf); ^ arch/sandbox/cpu/cpu.c: At top level: arch/sandbox/cpu/cpu.c:165:7: error: redefinition of ‘map_physmem’ void *map_physmem(phys_addr_t paddr, unsigned long len, unsigned long flags) ^~~~~~~~~~~ In file included from include/asm/io.h:495:0, from arch/sandbox/cpu/cpu.c:15: include/asm-generic/io.h:86:21: note: previous definition of ‘map_physmem’ was here static inline void *map_physmem(phys_addr_t paddr, unsigned long len, ^~~~~~~~~~~ arch/sandbox/cpu/cpu.c: In function ‘map_physmem’: arch/sandbox/cpu/cpu.c:172:25: warning: implicit declaration of function ‘pci_map_physmem’; did you mean ‘map_physmem’? [-Wimplicit-function-declaration] if (enable_pci_map && !pci_map_physmem(paddr, &len, &map_dev, &ptr)) { ^~~~~~~~~~~~~~~ map_physmem arch/sandbox/cpu/cpu.c: At top level: arch/sandbox/cpu/cpu.c:185:6: error: conflicting types for ‘unmap_physmem’ void unmap_physmem(const void *ptr, unsigned long flags) ^~~~~~~~~~~~~ In file included from include/asm/io.h:495:0, from arch/sandbox/cpu/cpu.c:15: include/asm-generic/io.h:103:20: note: previous definition of ‘unmap_physmem’ was here static inline void unmap_physmem(void *vaddr, unsigned long flags) ^~~~~~~~~~~~~ arch/sandbox/cpu/cpu.c: In function ‘unmap_physmem’: arch/sandbox/cpu/cpu.c:189:3: warning: implicit declaration of function ‘pci_unmap_physmem’; did you mean ‘unmap_physmem’? [-Wimplicit-function-declaration] pci_unmap_physmem(ptr, map_len, map_dev); ^~~~~~~~~~~~~~~~~ unmap_physmem arch/sandbox/cpu/cpu.c: In function ‘map_to_sysmem’: arch/sandbox/cpu/cpu.c:204:30: error: ‘volatile struct arch_global_data’ has no member named ‘ram_buf’ return (u8 *)ptr - gd->arch.ram_buf; ^ arch/sandbox/cpu/cpu.c: At top level: arch/sandbox/cpu/cpu.c:233:50: warning: ‘enum sandboxio_size_t’ declared inside parameter list will not be visible outside of this definition or declaration unsigned int sandbox_read(const void *addr, enum sandboxio_size_t size) ^~~~~~~~~~~~~~~~ arch/sandbox/cpu/cpu.c:233:67: error: parameter 2 (‘size’) has incomplete type unsigned int sandbox_read(const void *addr, enum sandboxio_size_t size) ^~~~ arch/sandbox/cpu/cpu.c:233:14: warning: function declaration isn’t a prototype [-Wstrict-prototypes] unsigned int sandbox_read(const void *addr, enum sandboxio_size_t size) ^~~~~~~~~~~~ arch/sandbox/cpu/cpu.c: In function ‘sandbox_read’: arch/sandbox/cpu/cpu.c:241:7: error: ‘SB_SIZE_8’ undeclared (first use in this function); did you mean ‘PCI_SIZE_8’? case SB_SIZE_8: ^~~~~~~~~ PCI_SIZE_8 arch/sandbox/cpu/cpu.c:241:7: note: each undeclared identifier is reported only once for each function it appears in arch/sandbox/cpu/cpu.c:243:7: error: ‘SB_SIZE_16’ undeclared (first use in this function); did you mean ‘SB_SIZE_8’? case SB_SIZE_16: ^~~~~~~~~~ SB_SIZE_8 arch/sandbox/cpu/cpu.c:245:7: error: ‘SB_SIZE_32’ undeclared (first use in this function); did you mean ‘SB_SIZE_16’? case SB_SIZE_32: ^~~~~~~~~~ SB_SIZE_16 arch/sandbox/cpu/cpu.c:247:7: error: ‘SB_SIZE_64’ undeclared (first use in this function); did you mean ‘SB_SIZE_32’? case SB_SIZE_64: ^~~~~~~~~~ SB_SIZE_32 arch/sandbox/cpu/cpu.c: At top level: arch/sandbox/cpu/cpu.c:254:55: warning: ‘enum sandboxio_size_t’ declared inside parameter list will not be visible outside of this definition or declaration void sandbox_write(void *addr, unsigned int val, enum sandboxio_size_t size) ^~~~~~~~~~~~~~~~ arch/sandbox/cpu/cpu.c:254:72: error: parameter 3 (‘size’) has incomplete type void sandbox_write(void *addr, unsigned int val, enum sandboxio_size_t size) ^~~~ arch/sandbox/cpu/cpu.c:254:6: warning: function declaration isn’t a prototype [-Wstrict-prototypes] void sandbox_write(void *addr, unsigned int val, enum sandboxio_size_t size) ^~~~~~~~~~~~~ arch/sandbox/cpu/cpu.c: In function ‘sandbox_write’: arch/sandbox/cpu/cpu.c:262:7: error: ‘SB_SIZE_8’ undeclared (first use in this function); did you mean ‘PCI_SIZE_8’? case SB_SIZE_8: ^~~~~~~~~ PCI_SIZE_8 arch/sandbox/cpu/cpu.c:265:7: error: ‘SB_SIZE_16’ undeclared (first use in this function); did you mean ‘SB_SIZE_8’? case SB_SIZE_16: ^~~~~~~~~~ SB_SIZE_8 arch/sandbox/cpu/cpu.c:268:7: error: ‘SB_SIZE_32’ undeclared (first use in this function); did you mean ‘SB_SIZE_16’? case SB_SIZE_32: ^~~~~~~~~~ SB_SIZE_16 arch/sandbox/cpu/cpu.c:271:7: error: ‘SB_SIZE_64’ undeclared (first use in this function); did you mean ‘SB_SIZE_32’? case SB_SIZE_64: ^~~~~~~~~~ SB_SIZE_32 arch/sandbox/cpu/cpu.c: In function ‘sandbox_read_fdt_from_file’: arch/sandbox/cpu/cpu.c:306:9: warning: implicit declaration of function ‘map_sysmem’; did you mean ‘map_physmem’? [-Wimplicit-function-declaration] blob = map_sysmem(CONFIG_SYS_FDT_LOAD_ADDR, 0); ^~~~~~~~~~ map_physmem arch/sandbox/cpu/cpu.c:306:7: warning: assignment makes pointer from integer without a cast [-Wint-conversion] blob = map_sysmem(CONFIG_SYS_FDT_LOAD_ADDR, 0); ^ arch/sandbox/cpu/cpu.c: In function ‘is_in_sandbox_mem’: arch/sandbox/cpu/cpu.c:85:1: warning: control reaches end of non-void function [-Wreturn-type] } ^ scripts/Makefile.build:265: recipe for target 'arch/sandbox/cpu/cpu.o' failed make[1]: *** [arch/sandbox/cpu/cpu.o] Error 1 Makefile:1784: recipe for target 'arch/sandbox/cpu' failed make: *** [arch/sandbox/cpu] Error 2
Best regards
HI Marek,
On Mon, 8 Feb 2021 at 09:10, Marek Szyprowski m.szyprowski@samsung.com wrote:
Hi Simon,
This is pretty mysterious. Are you sure you are using an x86_64 machine?
On 2/8/21 6:08 PM, Simon Glass wrote:
HI Marek,
Hi Simon,
r9 relates to ARMv7.
You have to unset CROSS_COMPILE when you build the sandbox.
The sandbox runs fine on aarch64.
There are a bunch of errors currently when building on 32bit architectures. Simon has a lot of patches pending.
Best regards
Heinrich
HI Marek,
Hi Simon,
Hello Simon,
it was your patch
091401131085 ("command: Remove the cmd_tbl_t typedef") 2020-05-10
that broke building the sandbox on ARMv7.
Once your 32bit corrections are merged we should try to add cross-compiling the sandbox for aarch64 and armv7 to Gitlab CI.
Best regards
Heinrich
Hi Heinrich,
HI Marek,
Hi Simon,
Hello Simon,
it was your patch
Oh dear.
Yes, what we don't test doesn't work :-)
Hi Simon,
I've finally found what caused the issue on my build system. It is x86_64 machine, but after some old cross-builds I had an 'asm' symlink in u-boot/include directory pointing to arch/arm directory. I'm quite surprised that it has not been removed by make clean/distclean/mrproper combo.
Best regards
Hi Marek,
On Tue, 9 Feb 2021 at 01:43, Marek Szyprowski m.szyprowski@samsung.com wrote:
Hi Simon,
OK. I wonder if this is after building a U-Boot from 2013? I will send a patch.
Add support for getting the 'vref-supply' regulator and register it as ADC's reference voltage regulator, so clients can translate sampled ADC values to the voltage.
Signed-off-by: Marek Szyprowski m.szyprowski@samsung.com --- drivers/adc/meson-saradc.c | 21 +++++++++++++++++++++ 1 file changed, 21 insertions(+)
diff --git a/drivers/adc/meson-saradc.c b/drivers/adc/meson-saradc.c index 21db55831d..1a45a3a265 100644 --- a/drivers/adc/meson-saradc.c +++ b/drivers/adc/meson-saradc.c @@ -18,6 +18,7 @@ #include <linux/delay.h> #include <linux/math64.h> #include <linux/bitfield.h> +#include <power/regulator.h>
#define MESON_SAR_ADC_REG0 0x00 #define MESON_SAR_ADC_REG0_PANEL_DETECT BIT(31) @@ -656,7 +657,10 @@ static int meson_saradc_stop(struct udevice *dev)
static int meson_saradc_probe(struct udevice *dev) { + struct adc_uclass_plat *uc_pdata = dev_get_uclass_plat(dev); struct meson_saradc_priv *priv = dev_get_priv(dev); + struct udevice *vref; + int vref_uv; int ret;
ret = regmap_init_mem(dev_ofnode(dev), &priv->regmap); @@ -675,6 +679,23 @@ static int meson_saradc_probe(struct udevice *dev)
priv->active_channel = -1;
+ ret = device_get_supply_regulator(dev, "vref-supply", &vref); + if (ret) { + printf("can't get vref-supply: %d\n", ret); + return ret; + } + + vref_uv = regulator_get_value(vref); + if (vref_uv < 0) { + printf("can't get vref-supply value: %d\n", vref_uv); + return vref_uv; + } + + /* VDD supplied by common vref pin */ + uc_pdata->vdd_supply = vref; + uc_pdata->vdd_microvolts = vref_uv; + uc_pdata->vss_microvolts = 0; + return 0; }
Add options required to check the 'Function' button state.
Signed-off-by: Marek Szyprowski m.szyprowski@samsung.com --- configs/khadas-vim3_defconfig | 2 ++ configs/khadas-vim3l_defconfig | 2 ++ 2 files changed, 4 insertions(+)
diff --git a/configs/khadas-vim3_defconfig b/configs/khadas-vim3_defconfig index 5d16652fd6..bc17430569 100644 --- a/configs/khadas-vim3_defconfig +++ b/configs/khadas-vim3_defconfig @@ -31,6 +31,8 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_ADC=y CONFIG_SARADC_MESON=y +CONFIG_BUTTON=y +CONFIG_BUTTON_ADC=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MESON=y CONFIG_DM_MMC=y diff --git a/configs/khadas-vim3l_defconfig b/configs/khadas-vim3l_defconfig index 6b13ce045c..c1877922c7 100644 --- a/configs/khadas-vim3l_defconfig +++ b/configs/khadas-vim3l_defconfig @@ -31,6 +31,8 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_ADC=y CONFIG_SARADC_MESON=y +CONFIG_BUTTON=y +CONFIG_BUTTON_ADC=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MESON=y CONFIG_DM_MMC=y
Marek Szyprowski
