[PATCH 1/2 v2] mmc: t210: Add autocal and tap/trim updates for SDMMC1/3
As per the T210 TRM, when running at 3.3v, the SDMMC1 tap/trim and autocal values need to be set to condition the signals correctly before talking to the SD-card. This is the same as what's being done in CBoot, but it gets reset when the SDMMC1 HW is soft-reset during SD driver init, so needs to be repeated here. Also set autocal and tap/trim for SDMMC3, although no T210 boards use it for SD-card at this time.
Signed-off-by: Tom Warren twarren@nvidia.com --- Changes for v2: - Added clocks.h include for TEGRA30 to fix T30 32-bit builds
arch/arm/include/asm/arch-tegra/tegra_mmc.h | 20 +++++-- drivers/mmc/tegra_mmc.c | 84 ++++++++++++++++++++++++++--- 2 files changed, 92 insertions(+), 12 deletions(-)
diff --git a/arch/arm/include/asm/arch-tegra/tegra_mmc.h b/arch/arm/include/asm/arch-tegra/tegra_mmc.h index a2b6f63..a8bfa46 100644 --- a/arch/arm/include/asm/arch-tegra/tegra_mmc.h +++ b/arch/arm/include/asm/arch-tegra/tegra_mmc.h @@ -2,7 +2,7 @@ /* * (C) Copyright 2009 SAMSUNG Electronics * Minkyu Kang mk7.kang@samsung.com - * Portions Copyright (C) 2011-2012 NVIDIA Corporation + * Portions Copyright (C) 2011-2012,2019 NVIDIA Corporation */
#ifndef __TEGRA_MMC_H_ @@ -52,7 +52,7 @@ struct tegra_mmc { unsigned char admaerr; /* offset 54h */ unsigned char res4[3]; /* RESERVED, offset 55h-57h */ unsigned long admaaddr; /* offset 58h-5Fh */ - unsigned char res5[0xa0]; /* RESERVED, offset 60h-FBh */ + unsigned char res5[0x9c]; /* RESERVED, offset 60h-FBh */ unsigned short slotintstatus; /* offset FCh */ unsigned short hcver; /* HOST Version */ unsigned int venclkctl; /* _VENDOR_CLOCK_CNTRL_0, 100h */ @@ -127,11 +127,23 @@ struct tegra_mmc {
#define TEGRA_MMC_NORINTSIGEN_XFER_COMPLETE (1 << 1)
-/* SDMMC1/3 settings from section 24.6 of T30 TRM */ +/* SDMMC1/3 settings from SDMMCx Initialization Sequence of TRM */ #define MEMCOMP_PADCTRL_VREF 7 -#define AUTO_CAL_ENABLED (1 << 29) +#define AUTO_CAL_ENABLE (1 << 29) +#if defined(CONFIG_TEGRA210) +#define AUTO_CAL_ACTIVE (1 << 31) +#define AUTO_CAL_START (1 << 31) +#define AUTO_CAL_PD_OFFSET (0x7D << 8) +#define AUTO_CAL_PU_OFFSET (0 << 0) +#define IO_TRIM_BYPASS_MASK (1 << 2) +#define TRIM_VAL_SHIFT 24 +#define TRIM_VAL_MASK (0x1F << TRIM_VAL_SHIFT) +#define TAP_VAL_SHIFT 16 +#define TAP_VAL_MASK (0xFF << TAP_VAL_SHIFT) +#else #define AUTO_CAL_PD_OFFSET (0x70 << 8) #define AUTO_CAL_PU_OFFSET (0x62 << 0) +#endif
#endif /* __ASSEMBLY__ */ #endif /* __TEGRA_MMC_H_ */ diff --git a/drivers/mmc/tegra_mmc.c b/drivers/mmc/tegra_mmc.c index f022e93..73ac58c 100644 --- a/drivers/mmc/tegra_mmc.c +++ b/drivers/mmc/tegra_mmc.c @@ -3,7 +3,7 @@ * (C) Copyright 2009 SAMSUNG Electronics * Minkyu Kang mk7.kang@samsung.com * Jaehoon Chung jh80.chung@samsung.com - * Portions Copyright 2011-2016 NVIDIA Corporation + * Portions Copyright 2011-2019 NVIDIA Corporation */
#include <bouncebuf.h> @@ -15,6 +15,9 @@ #include <asm/io.h> #include <asm/arch-tegra/tegra_mmc.h> #include <linux/err.h> +#if defined(CONFIG_TEGRA30) || defined(CONFIG_TEGRA210) +#include <asm/arch/clock.h> +#endif
struct tegra_mmc_plat { struct mmc_config cfg; @@ -30,6 +33,7 @@ struct tegra_mmc_priv { struct gpio_desc wp_gpio; /* Write Protect GPIO */ unsigned int version; /* SDHCI spec. version */ unsigned int clock; /* Current clock (MHz) */ + int mmc_id; /* peripheral id */ };
static void tegra_mmc_set_power(struct tegra_mmc_priv *priv, @@ -446,16 +450,19 @@ static int tegra_mmc_set_ios(struct udevice *dev)
static void tegra_mmc_pad_init(struct tegra_mmc_priv *priv) { -#if defined(CONFIG_TEGRA30) +#if defined(CONFIG_TEGRA30) || defined(CONFIG_TEGRA210) u32 val; + u16 clk_con; + int timeout; + int id = priv->mmc_id;
- debug("%s: sdmmc address = %08x\n", __func__, (unsigned int)priv->reg); + debug("%s: sdmmc address = %p, id = %d\n", __func__, + priv->reg, id);
/* Set the pad drive strength for SDMMC1 or 3 only */ - if (priv->reg != (void *)0x78000000 && - priv->reg != (void *)0x78000400) { + if (id != PERIPH_ID_SDMMC1 && id != PERIPH_ID_SDMMC3) { debug("%s: settings are only valid for SDMMC1/SDMMC3!\n", - __func__); + __func__); return; }
@@ -464,11 +471,65 @@ static void tegra_mmc_pad_init(struct tegra_mmc_priv *priv) val |= MEMCOMP_PADCTRL_VREF; writel(val, &priv->reg->sdmemcmppadctl);
+ /* Disable SD Clock Enable before running auto-cal as per TRM */ + clk_con = readw(&priv->reg->clkcon); + debug("%s: CLOCK_CONTROL = 0x%04X\n", __func__, clk_con); + clk_con &= ~TEGRA_MMC_CLKCON_SD_CLOCK_ENABLE; + writew(clk_con, &priv->reg->clkcon); + val = readl(&priv->reg->autocalcfg); val &= 0xFFFF0000; - val |= AUTO_CAL_PU_OFFSET | AUTO_CAL_PD_OFFSET | AUTO_CAL_ENABLED; + val |= AUTO_CAL_PU_OFFSET | AUTO_CAL_PD_OFFSET; writel(val, &priv->reg->autocalcfg); -#endif + val |= AUTO_CAL_START | AUTO_CAL_ENABLE; + writel(val, &priv->reg->autocalcfg); + debug("%s: AUTO_CAL_CFG = 0x%08X\n", __func__, val); + udelay(1); + timeout = 100; /* 10 mSec max (100*100uS) */ + do { + val = readl(&priv->reg->autocalsts); + udelay(100); + } while ((val & AUTO_CAL_ACTIVE) && --timeout); + val = readl(&priv->reg->autocalsts); + debug("%s: Final AUTO_CAL_STATUS = 0x%08X, timeout = %d\n", + __func__, val, timeout); + + /* Re-enable SD Clock Enable when auto-cal is done */ + clk_con |= TEGRA_MMC_CLKCON_SD_CLOCK_ENABLE; + writew(clk_con, &priv->reg->clkcon); + clk_con = readw(&priv->reg->clkcon); + debug("%s: final CLOCK_CONTROL = 0x%04X\n", __func__, clk_con); + + if (timeout == 0) { + printf("%s: Warning: Autocal timed out!\n", __func__); + /* TBD: Set CFG2TMC_SDMMC1_PAD_CAL_DRV* regs here */ + } + +#if defined(CONFIG_TEGRA210) + u32 tap_value, trim_value; + + /* Set tap/trim values for SDMMC1/3 @ <48MHz here */ + val = readl(&priv->reg->venspictl); /* aka VENDOR_SYS_SW_CNTL */ + val &= IO_TRIM_BYPASS_MASK; + if (id == PERIPH_ID_SDMMC1) { + tap_value = 4; /* default */ + if (val) + tap_value = 3; + trim_value = 2; + } else { /* SDMMC3 */ + tap_value = 3; + trim_value = 3; + } + + val = readl(&priv->reg->venclkctl); + val &= ~TRIM_VAL_MASK; + val |= (trim_value << TRIM_VAL_SHIFT); + val &= ~TAP_VAL_MASK; + val |= (tap_value << TAP_VAL_SHIFT); + writel(val, &priv->reg->venclkctl); + debug("%s: VENDOR_CLOCK_CNTRL = 0x%08X\n", __func__, val); +#endif /* T210 */ +#endif /* T30/T210 */ }
static void tegra_mmc_reset(struct tegra_mmc_priv *priv, struct mmc *mmc) @@ -514,6 +575,13 @@ static int tegra_mmc_init(struct udevice *dev) unsigned int mask; debug(" tegra_mmc_init called\n");
+#if defined(CONFIG_TEGRA210) + priv->mmc_id = clock_decode_periph_id(dev); + if (priv->mmc_id == PERIPH_ID_NONE) { + printf("%s: Missing/invalid peripheral ID\n", __func__); + return -EINVAL; + } +#endif tegra_mmc_reset(priv, mmc);
#if defined(CONFIG_TEGRA124_MMC_DISABLE_EXT_LOOPBACK)
twarren@nvidia.com
