[U-Boot-Users] [Patch03]AS352X:U-Boot1.1.6 patch 3 for AS352X SOC
From:thomas.luo@austriamicrosystems. U-Boot1.1.6 for AS352X Port to U-boot to New ARM base SOC AS352X, support NAND flash Boot. Part 3: Br
Signed-off-by: Thomas Luo
------------------------------------------------------------------------ ---- diff -urN u-boot-1.1.6.org/include/as352x.h u-boot-1.1.6/include/as352x.h --- u-boot-1.1.6.org/include/as352x.h 1970-01-01 08:00:00.000000000 +0800 +++ u-boot-1.1.6/include/as352x.h 2006-12-01 17:42:16.000000000 +0800 @@ -0,0 +1,352 @@ +/* +* (C) Copyright 2006 +* Copyright (C) 2006 Austriamicrosystems, by thomas.luo +* +* This program is free software; you can redistribute it and/or +* modify it under the terms of the GNU General Public License as +* published by the Free Software Foundation; either version 2 of +* the License, or (at your option) any later version. +* +* This program is distributed in the hope that it will be useful, +* but WITHOUT ANY WARRANTY; without even the implied warranty of +* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +* GNU General Public License for more details. +* +* You should have received a copy of the GNU General Public License +* along with this program; if not, write to the Free Software +* Foundation, Inc., 59 Temple Place, Suite 330, Boston, +* MA 02111-1307 USA +*/ +#ifndef __AS352X_H__ +#define __AS352X_H__ + +#define AS352X_UART_CHANNELS 1 + +/* AS352X only supports 512 Byte HW ECC */ +#define AS352X_ECCSIZE 512 +#define AS352X_ECCBYTES 3 + + +/* AS352X device base addresses */ + + +/* ------------------------------------------------------------------------ +* AS352X Registers +* ------------------------------------------------------------------------ +* +*/ + + +/* AHB */ +#define AS352X_USB_BASE 0xC6000000 +#define AS352X_VIC_BASE 0xC6010000 +#define AS352X_DMAC_BASE 0xC6020000 +#define AS352X_MPMC_BASE 0xC6030000 +#define AS352X_MEMSTICK_BASE 0xC6040000 +#define AS352X_CF_IDE_BASE 0xC6050000 + +/* APB */ +#define AS352X_NAND_FLASH_BASE 0xC8000000 +#define AS352X_BIST_MANAGER_BASE 0xC8010000 +#define AS352X_SD_MCI_BASE 0xC8020000 +#define AS352X_TIMER_BASE 0xC8040000 +#define AS352X_WDT_BASE 0xC8050000 +#define AS352X_I2C_MS_BASE 0xC8060000 +#define AS352X_I2C_AUDIO_BASE 0xC8070000 +#define AS352X_SSP_BASE 0xC8080000 +#define AS352X_I2SIN_BASE 0xC8090000 +#define AS352X_I2SOUT_BASE 0xC80A0000 +#define AS352X_GPIO1_BASE 0xC80B0000 +#define AS352X_GPIO2_BASE 0xC80C0000 +#define AS352X_GPIO3_BASE 0xC80D0000 +#define AS352X_GPIO4_BASE 0xC80E0000 +#define AS352X_CGU_BASE 0xC80F0000 +#define AS352X_CCU_BASE 0xC8100000 +#define AS352X_UART0_BASE 0xC8110000 +#define AS352X_DBOP_BASE 0xC8120000 + + + + + + + + +/* ------------------------------------------------------------------------ +* AS352X control registers +* ------------------------------------------------------------------------ +*/ + +#define CCU_SRC ( (AS352X_CCU_BASE) + 0x00) +#define CCU_SRL ( (AS352X_CCU_BASE) + 0x04) +#define CCU_MEMMAP ( (AS352X_CCU_BASE) + 0x08) +#define CCU_IO ( (AS352X_CCU_BASE) + 0x0C) +#define CCU_SCON ( (AS352X_CCU_BASE) + 0x10) +#define CCU_VERS ( (AS352X_CCU_BASE) + 0x14) + + +/** +* Reset Control Lines in CCU_SRC register +**/ +#define CCU_SRC_DBOP_EN ( 1 << 24 ) +#define CCU_SRC_SPDIF_EN ( 1 << 22 ) +#define CCU_SRC_TIMER_EN ( 1 << 21 ) +#define CCU_SRC_SSP_EN ( 1 << 20 ) +#define CCU_SRC_WDO_EN ( 1 << 19 ) +#define CCU_SRC_IDE_EN ( 1 << 18 ) +#define CCU_SRC_IDE_AHB_EN ( 1 << 17 ) +#define CCU_SRC_UART0 ( 1 << 16 ) +#define CCU_SRC_NAF_EN ( 1 << 15 ) +#define CCU_SRC_SDMCI_EN ( 1 << 14 ) +#define CCU_SRC_GPIO_EN ( 1 << 13 ) +#define CCU_SRC_I2C_AUDIO_EN ( 1 << 12 ) +#define CCU_SRC_I2C_EN ( 1 << 11 ) +#define CCU_SRC_MST_EN ( 1 << 10 ) +#define CCU_SRC_I2SIN ( 1 << 9 ) +#define CCU_SRC_I2SOUT ( 1 << 8 ) +#define CCU_SRC_USB_AHB_EN ( 1 << 7 ) +#define CCU_SRC_USB_PHY_EN ( 1 << 6 ) +#define CCU_SRC_DMAC_EN ( 1 << 5 ) +#define CCU_SRC_VIC_EN ( 1 << 4 ) + +/** +* Magic number for CCU_SRL for reset. +**/ +#define CCU_SRL_MAGIC_NUMBER 0x1A720212 + +/** +* Chip select lines for NAF. Use these constants to select/deselct the CE lines +* for NAND flashes in Register CCU_IO. +**/ +#define CCU_IO_NAF_CE_LINE_0 ( 0 << 7 ) +#define CCU_IO_NAF_CE_LINE_1 ( 1 << 7 ) +#define CCU_IO_NAF_CE_LINE_2 ( 2 << 7 ) +#define CCU_IO_NAF_CE_LINE_3 ( 3 << 7 ) + +/* CCU IO Select/Deselect IDE */ +#define CCU_IO_IDE ( 1 << 5 ) + +/* CCU IO Select/desect I2C */ +#define CCU_IO_I2C_MASTER_SLAVE ( 1 << 1 ) + +/* CCU IO Select/desect UART */ +#define CCU_IO_UART0 ( 1 << 0 ) + + +#define CCU_RESET_ALL_BUT_MEMORY \ + ( CCU_SRC_DBOP_EN \ + | CCU_SRC_SPDIF_EN \ + | CCU_SRC_TIMER_EN \ + | CCU_SRC_SSP_EN \ + | CCU_SRC_WDO_EN \ + | CCU_SRC_IDE_EN \ + | CCU_SRC_IDE_AHB_EN \ + | CCU_SRC_UART0 \ + | CCU_SRC_NAF_EN \ + | CCU_SRC_SDMCI_EN \ + | CCU_SRC_GPIO_EN \ + | CCU_SRC_I2C_AUDIO_EN \ + | CCU_SRC_I2C_EN \ + | CCU_SRC_MST_EN \ + | CCU_SRC_I2SIN \ + | CCU_SRC_I2SOUT \ + | CCU_SRC_USB_AHB_EN \ + | CCU_SRC_USB_PHY_EN \ + | CCU_SRC_DMAC_EN \ + | CCU_SRC_VIC_EN \ + ) + +/** +* Magic number for CCU_SRL for reset. +**/ +#define CCU_SRL_MAGIC_NUMBER 0x1A720212 + +/** +* Chip select lines for NAF. Use these constants to select/deselct the CE lines +* for NAND flashes in Register CCU_IO. +**/ +#define CCU_IO_NAF_CE_LINE_0 ( 0 << 7 ) +#define CCU_IO_NAF_CE_LINE_1 ( 1 << 7 ) +#define CCU_IO_NAF_CE_LINE_2 ( 2 << 7 ) +#define CCU_IO_NAF_CE_LINE_3 ( 3 << 7 ) + +/* CCU IO Select/Deselect IDE */ +#define CCU_IO_IDE ( 1 << 5 ) + +/* CCU IO Select/desect I2C */ +#define CCU_IO_I2C_MASTER_SLAVE ( 1 << 1 ) + +/* CCU IO Select/desect UART */ +#define CCU_IO_UART ( 1 << 0 ) +/* ------------------------------------------------------------------------ +* AS352X clock control registers +* ------------------------------------------------------------------------ +*/ + +#define CGU_REG_PLLA ( (AS352X_CGU_BASE) + 0x00 ) +#define CGU_REG_PLLB ( (AS352X_CGU_BASE) + 0x04 ) +#define CGU_REG_PLLASUP ( (AS352X_CGU_BASE) + 0x08 ) +#define CGU_REG_PLLBSUP ( (AS352X_CGU_BASE) + 0x0C ) +#define CGU_REG_PROC ( (AS352X_CGU_BASE) + 0x10 ) +#define CGU_REG_PERI ( (AS352X_CGU_BASE) + 0x14 ) +#define CGU_REG_AUDIO ( (AS352X_CGU_BASE) + 0x18 ) +#define CGU_REG_USB ( (AS352X_CGU_BASE) + 0x1C ) +#define CGU_REG_INTCTRL ( (AS352X_CGU_BASE) + 0x20 ) +#define CGU_REG_IRQ ( (AS352X_CGU_BASE) + 0x24 ) +#define CGU_REG_COUNTA ( (AS352X_CGU_BASE) + 0x28 ) +#define CGU_REG_COUNTB ( (AS352X_CGU_BASE) + 0x2C ) +#define CGU_REG_IDE ( (AS352X_CGU_BASE) + 0x30 ) +#define CGU_REG_MEMSTICK ( (AS352X_CGU_BASE) + 0x34 ) +#define CGU_REG_DBOP ( (AS352X_CGU_BASE) + 0x38 ) + + +/* --- are disabled after reset --- */ +#define CGU_DMA_CLOCK_ENABLE ( 1 << 22 ) /* dma */ +#define CGU_USB_CLOCK_ENABLE ( 1 << 21 ) /* usb */ +#define CGU_I2SOUT_APB_CLOCK_ENABLE ( 1 << 20 ) /* i2sout */ +#define CGU_I2SIN_APB_CLOCK_ENABLE ( 1 << 19 ) /* i2sin */ +#define CGU_I2C_MASTER_SLAVE_CLOCK_ENABLE ( 1 << 18 ) /* i2c master/slave */ +#define CGU_I2C_AUDIO_MASTER_CLOCK_ENABLE ( 1 << 17 ) /* i2c audio master */ +#define CGU_GPIO_CLOCK_ENABLE ( 1 << 16 ) /* gpio */ +#define CGU_MCI_CLOCK_ENABLE ( 1 << 15 ) /* mmc + sd */ +#define CGU_NAF_CLOCK_ENABLE ( 1 << 14 ) /* naf */ +#define CGU_UART_APB_CLOCK_ENABLE ( 1 << 13 ) /* uart */ +#define CGU_WDOCNT_CLOCK_ENABLE ( 1 << 12 ) /* watchdog counter */ +#define CGU_WDOIF_CLOCK_ENABLE ( 1 << 11 ) /* watchdog timer module */ +#define CGU_SSP_CLOCK_ENABLE ( 1 << 10 ) /* ssp */ +#define CGU_TIMER1_CLOCK_ENABLE ( 1 << 9 ) /* timer 1 */ +#define CGU_TIMER2_CLOCK_ENABLE ( 1 << 8 ) /* timer 2 */ +#define CGU_TIMERIF_CLOCK_ENABLE ( 1 << 7 ) /* timer interface */ + +/** ------------------------------------------------------------------ +* Number of cycles to wait before cgu is safely locked. +**/ +#define CGU_LOCK_CNT 0xFF + +/* FIFO depth is 16 for tx and rx fifo */ +#define UART_FIFO_DEPTH 16 + +/* ------------------- UART Line Control Register bit fields -------------------- */ + +#define UART_LNCTL_DLSEN (1 << 7) /* Device latch select bit */ + + +/* -------------- UART Interrupt Control Register bit fields --------------- */ + +#define UART_INTR_RXDRDY 0x1 /* Data ready interrupt */ +#define UART_INTR_TXEMT 0x2 /* Transmit data empty interrupt */ +#define UART_INTR_RXLINESTATUS 0x4 /* Receive line status interrupt */ + +/* ------------------- UART Line Status Register bit fields -------------------- */ + +#define UART_ERRORBITS 0x1E +#define UART_RX_DATA_READY (1 << 0) +#define UART_TX_HOLD_REG_EMPTY (1 << 5) + +/* ------------------- FIFO CNTL Register contants -------------------*/ + +#define UART_FIFO_EN (1 << 0) /* Enable the UART FIFO */ +#define UART_TX_FIFO_RST (1 << 1) /* Enable the UART FIFO */ +#define UART_RX_FIFO_RST (1 << 2) +#define UART_RXFIFO_TRIGLVL_1 (0 << 4) /* RX FIFO TRIGGER_LEVEL 1 */ +#define UART_RXFIFO_TRIGLVL_4 0x08 /* RX FIFO TRIGGER_LEVEL 4 */ +#define UART_RXFIFO_TRIGLVL_8 0x10 /* RX FIFO TRIGGER_LEVEL 8 */ +#define UART_RXFIFO_TRIGLVL_14 0x18 /* RX FIFO TRIGGER_LEVEL 14 */ + + +/* ------------------- FIFO status Register contants ------------------*/ +#define UART_TX_FIFO_FULL (1 << 0) +#define UART_RX_FIFO_FULL (1 << 1) +#define UART_TX_FIFO_EMPTY (1 << 2) +#define UART_RX_FIFO_EMPTY (1 << 3) + + +/* ----------------------- defines ---------------------------------------- */ + +#define UART_DATA_REG ( (AS352X_UART0_BASE) + 0x00 ) /* Data register */ +#define UART_DLO_REG ( (AS352X_UART0_BASE) + 0x00 ) /* Clock divider(lower byte) register */ +#define UART_DHI_REG ( (AS352X_UART0_BASE) + 0x04 ) /* Clock divider(higher byte) register */ +#define UART_INTEN_REG ( (AS352X_UART0_BASE) + 0x04 ) /* Interrupt enable register */ +#define UART_INTSTATUS_REG ( (AS352X_UART0_BASE) + 0x08 ) /* Interrupt status register */ +#define UART_FCTL_REG ( (AS352X_UART0_BASE) + 0x0C ) /* Fifo control register */ +#define UART_FSTATUS_REG ( (AS352X_UART0_BASE) + 0x0C ) /* Fifo status register */ +#define UART_LNCTL_REG ( (AS352X_UART0_BASE) + 0x10 ) /* Line control register */ +#define UART_LNSTATUS_REG ( (AS352X_UART0_BASE) + 0x14 ) /* Line status register */ + + +#define TIMER_LOAD ( (AS352X_TIMER_BASE) + 0x00 ) /* 32-bit width */ +#define TIMER_VALUE ( (AS352X_TIMER_BASE) + 0x04 ) /* 32 bit width */ +#define TIMER_CONTROL ( (AS352X_TIMER_BASE) + 0x08 ) /* 8 bit width */ +#define TIMER_INTCLR ( (AS352X_TIMER_BASE) + 0x0C ) /* clears ir by write access */ +#define TIMER_RIS ( (AS352X_TIMER_BASE) + 0x10 ) /* 1 bit width */ +#define TIMER_MIS ( (AS352X_TIMER_BASE) + 0x14 ) /* 1 bit width */ + +/** +* Counter/Timer control register bits +**/ +#define TIMER_ENABLE 0x80 +#define TIMER_PERIODIC 0x40 +#define TIMER_INT_ENABLE 0x20 +#define TIMER_32_BIT 0x02 +#define TIMER_ONE_SHOT 0x01 +#define TIMER_PRESCALE_1 0x00 +#define TIMER_PRESCALE_16 0x04 +#define TIMER_PRESCALE_256 0x08 + + + +#define NAF_CONFIG ( (AS352X_NAND_FLASH_BASE) + 0x00 ) +#define NAF_CONTROL ( (AS352X_NAND_FLASH_BASE) + 0x04 ) +#define NAF_ECC ( (AS352X_NAND_FLASH_BASE) + 0x08 ) +#define NAF_DATA ( (AS352X_NAND_FLASH_BASE) + 0x0C ) +#define NAF_MODE ( (AS352X_NAND_FLASH_BASE) + 0x10 ) +#define NAF_STATUS ( (AS352X_NAND_FLASH_BASE) + 0x14 ) +#define NAF_MASK ( (AS352X_NAND_FLASH_BASE) + 0x18 ) +#define NAF_FIFODATA ( (AS352X_NAND_FLASH_BASE) + 0x1C ) +#define NAF_WORDS ( (AS352X_NAND_FLASH_BASE) + 0x20 ) +#define NAF_CLEAR ( (AS352X_NAND_FLASH_BASE) + 0x24 ) +#define NAF_TEST ( (AS352X_NAND_FLASH_BASE) + 0x28 ) + + + +#define set_reg_bits32( registerAddress, value ) \ + ( *( (volatile u32 *)(registerAddress) ) |= ( (u32)(value) ) ) + + +#define clr_reg_bits32( registerAddress, value ) \ + ( *( (volatile u32 *)(registerAddress) ) &= ( ~( (u32)(value) ) ) ) + +#define rreg32( registerAddress ) \ + ( *( ( const volatile u32 * )( registerAddress ) ) ) + +#define wreg32( registerAddress, value ) \ + ( *( (volatile u32 *)(registerAddress) ) = ( (u32)(value) ) ) + + + +#define rreg16( registerAddress ) \ + ( *( ( const volatile u16 * )( registerAddress ) ) ) + +#define wreg16( registerAddress, value ) \ + ( *( (volatile u16 *)(registerAddress) ) = ( (u16)(value) ) ) + +#define set_reg_bits16( registerAddress, value ) \ + ( *( (volatile u16 *)(registerAddress) ) |= ( (u16)(value) ) ) + +#define clr_reg_bits16( registerAddress, value ) \ + ( *( (volatile u16 *)(registerAddress) ) &= ( ~( (u16)(value) ) ) ) + + +#define rreg8( registerAddress ) \ + ( *( ( const volatile u8 * )( registerAddress ) ) ) + +#define wreg8( registerAddress, value ) \ + ( *( (volatile u8 *)(registerAddress) ) = ( (u8)(value) ) ) + +#define set_reg_bits8( registerAddress, value ) \ + ( *( (volatile u8 *)(registerAddress) ) |= ( (u8)(value) ) ) + +#define clr_reg_bits8( registerAddress, value ) \ + ( *( (volatile u8 *)(registerAddress) ) &= ( ~( (u8)(value) ) ) ) +/* Wait until rINTPND is changed for the case that the ISR is very short. */ +#endif /*__AS352X_H__*/ diff -urN u-boot-1.1.6.org/include/asm-arm/mach-types.h u-boot-1.1.6/include/asm-arm/mach-types.h --- u-boot-1.1.6.org/include/asm-arm/mach-types.h 2006-12-01 17:49:35.000000000 +0800 +++ u-boot-1.1.6/include/asm-arm/mach-types.h 2006-12-01 18:01:45.000000000 +0800 @@ -737,6 +737,7 @@ #define MACH_TYPE_CB3RUFC 726 #define MACH_TYPE_MP2USB 727 #define MACH_TYPE_PDNB3 1002 +#define MACH_TYPE_AS352X 1166
#ifdef CONFIG_ARCH_EBSA110 # ifdef machine_arch_type @@ -6054,7 +6055,7 @@ # define machine_is_ess710() (0) #endif
-#ifdef CONFIG_MACH_MX3ADS +#ifdef CONFIG_MACH_MX31ADS # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type @@ -9401,6 +9402,18 @@ #else # define machine_is_mp2usb() (0) #endif +#ifdef CONFIG_MACH_AS352X +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_AS352X +# endif +# define machine_is_as352x() (machine_arch_type == MACH_TYPE_AS352X) +#else +# define machine_is_as352x() (0) +#endif +
/* * These have not yet been registered diff -urN u-boot-1.1.6.org/include/configs/as352xpb.h u-boot-1.1.6/include/configs/as352xpb.h --- u-boot-1.1.6.org/include/configs/as352xpb.h 1970-01-01 08:00:00.000000000 +0800 +++ u-boot-1.1.6/include/configs/as352xpb.h 2006-12-01 17:42:50.000000000 +0800 @@ -0,0 +1,218 @@ +/* +* (C) Copyright 2006 +* Copyright (C) 2006 Austriamicrosystems, by thomas.luo +* +* This program is free software; you can redistribute it and/or +* modify it under the terms of the GNU General Public License as +* published by the Free Software Foundation; either version 2 of +* the License, or (at your option) any later version. +* +* This program is distributed in the hope that it will be useful, +* but WITHOUT ANY WARRANTY; without even the implied warranty of +* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +* GNU General Public License for more details. +* +* You should have received a copy of the GNU General Public License +* along with this program; if not, write to the Free Software +* Foundation, Inc., 59 Temple Place, Suite 330, Boston, +* MA 02111-1307 USA +*/ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* +* High Level Configuration Options +* (easy to change) +*/ +#define CONFIG_ARM922T 1 /* This is an ARM922T Core */ +#define CONFIG_AS352X 1 /* in a AS352X SoC */ +#define CONFIG_AS352XPB 1 /* on a AS352XPB Board */ +#define CFG_NO_FLASH 1 + +/* input clock of PLL */ +#define CONFIG_SYS_CLK_FREQ 24000000/* the AS352XPB has 24MHz input clock */ + + +#define USE_922T_MMU 1 +#undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */ + +/* +* Size of malloc() pool +*/ +#define CFG_MALLOC_LEN (((CFG_ENV_SIZE + 128*1024 + 0x4000-1) /0x4000)*0x4000) +#define CFG_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ + +/* +* Hardware drivers +*/ + +/* +* select serial console configuration +*/ +#define CONFIG_SERIAL1 1 /* we use SERIAL 1 on AS352XPB */ + +/************************************************************ +* RTC +************************************************************/ +#define CONFIG_RTC_AS352X 0 + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE + +#define CONFIG_BAUDRATE 38400 + +/*********************************************************** +* Command definition +***********************************************************/ +#define CONFIG_COMMANDS \ + ((CONFIG_CMD_DFL | \ + /* CFG_CMD_CACHE |*/ \ + CFG_CMD_NAND | \ + /*CFG_CMD_EEPROM |*/ \ + /*CFG_CMD_I2C |*/ \ + /*CFG_CMD_USB |*/ \ + CFG_CMD_REGINFO \ + /*CFG_CMD_ELF*/ )& ~(CFG_CMD_FLASH|CFG_CMD_IMLS|CFG_CMD_NET|CFG_CMD_XIMG)) +/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ +#define CONFIG_CMDLINE_TAG 1 +#define CONFIG_INITRD_TAG 1 +#define CONFIG_BOOTDELAY 5 +#define CONFIG_BOOTARGS "root=/dev/ram0 rw init=/linuxrc console=ttyS0 mem=64M" +#define CONFIG_BOOTCOMMAND "nand read 0x30007FC0 0x80000 0x200000; nand read 0x32000000 0x280000 0x200000;bootm 0x30007FC0 0x32000000" +#define CONFIG_AUTOBOOT_KEYED 1 +#define CONFIG_AUTOBOOT_PROMPT "autoboot in %d seconds (stop with 's')...\n" +#define CONFIG_AUTOBOOT_STOP_STR "s" +/*#define CONFIG_ETHADDR 08:00:3e:26:0a:5b */ +/*#define CONFIG_NETMASK 255.255.255.0*/ +/*#define CONFIG_IPADDR 10.0.0.110*/ +/*#define CONFIG_SERVERIP 10.0.0.1*/ +/*#define CONFIG_BOOTFILE "" */ +/*#define CONFIG_BOOTCOMMAND "tftp; bootm" */ + +#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#define CONFIG_KGDB_BAUDRATE 115200 /* speed to run kgdb serial port */ +/* what's this ? it's not used anywhere */ +#define CONFIG_KGDB_SER_INDEX 1 /* which serial port to use */ +#endif + +#undef CFG_ENV_IS_IN_FLASH +/* +* Miscellaneous configurable options +*/ +#define CFG_LONGHELP 1 /* undef to save memory */ +#define CFG_PROMPT "AS352X # " /* Monitor Command Prompt */ +#define CFG_CBSIZE 256 /* Console I/O Buffer Size */ +#define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) /* Print Buffer Size */ +#define CFG_MAXARGS 8 /* max number of command args */ +#define CFG_BARGSIZE CFG_CBSIZE /* Boot Argument Buffer Size */ + +#define CFG_MEMTEST_START 0x30000000 /* memtest works on */ +#define CFG_MEMTEST_END 0x33F00000 /* 63 MB in DRAM */ + +#undef CFG_CLKS_IN_HZ /* everything, incl board info, in Hz */ + +#define CFG_LOAD_ADDR 0x30008000 /* default load address */ + +#define CFG_HZ 1500000 + +/* valid baudrates */ +#define CFG_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +#define CFG_ENV_IS_IN_NAND 1 + +#define CFG_ENV_NAND_ERASE_SIZE 0x20000 +#define CFG_ENV_SIZE 0x800 /* Total Size of Environment Sector */ +#if CFG_ENV_IS_IN_NAND +#define CFG_ENV_OFFSET 0x60000 + +#endif +/*--------------------------------------------------------------------- -- +* Stack sizes +* +* The stack sizes are set up in start.S using the settings below +*/ +#define CONFIG_STACKSIZE (128*1024) /* regular stack */ +#ifdef CONFIG_USE_IRQ +#define CONFIG_STACKSIZE_IRQ (4*1024) /* IRQ stack */ +#define CONFIG_STACKSIZE_FIQ (4*1024) /* FIQ stack */ +#endif + +/*--------------------------------------------------------------------- -- +* Physical Memory Map +*/ +#define CONFIG_NR_DRAM_BANKS 1 /* we have 1 bank of DRAM */ +#define PHYS_SDRAM_1 0x30000000 /* SDRAM Bank #1 */ +#define PHYS_SDRAM_1_SIZE 0x04000000 /* 64 MB */ + +#define PHYS_FLASH_1 0x00000000 /* Flash Bank #1 */ + +#define CFG_FLASH_BASE PHYS_FLASH_1 + +/*--------------------------------------------------------------------- -- +* FLASH and environment organization +*/ + +#define CONFIG_AMD_LV400 0 /* uncomment this if you have a LV400 flash */ +#if 0 +#define CONFIG_AMD_LV800 1 /* uncomment this if you have a LV800 flash */ +#endif + +#define CFG_MAX_FLASH_BANKS 0 /* max number of memory banks */ +#ifdef CONFIG_AMD_LV800 +#define PHYS_FLASH_SIZE 0x00100000 /* 1MB */ +#define CFG_MAX_FLASH_SECT (19) /* max number of sectors on one chip */ +#define CFG_ENV_ADDR (CFG_FLASH_BASE + 0x0F0000) /* addr of environment */ +#endif +#ifdef CONFIG_AMD_LV400 +#define PHYS_FLASH_SIZE 0x00080000 /* 512KB */ +#define CFG_MAX_FLASH_SECT (11) /* max number of sectors on one chip */ +#define CFG_ENV_ADDR (CFG_FLASH_BASE + 0x070000) /* addr of environment */ +#endif + + +#define CFG_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ +#define SECTORSIZE 512 + +#define ADDR_COLUMN 1 +#define ADDR_PAGE 2 +#define ADDR_COLUMN_PAGE 3 + +#define NAND_ChipID_UNKNOWN 0x00 +#define NAND_MAX_FLOORS 1 +#define NAND_MAX_CHIPS 1 + + +#define NAND_DISABLE_CE(nand) do { } while(0) +#define NAND_ENABLE_CE(nand) do { } while(0) + +#define NAND_WAIT_READY(nand) + +#define WRITE_NAND_COMMAND(d, adr) do{ } while(0) +#define WRITE_NAND_ADDRESS(d, adr) do{ } while(0) +#define WRITE_NAND(d, adr) do{} while(0) +#define READ_NAND(adr) () +/* the following are NOP's in our implementation */ +#define NAND_CTL_CLRALE(nandptr) +#define NAND_CTL_SETALE(nandptr) +#define NAND_CTL_CLRCLE(nandptr) +#define NAND_CTL_SETCLE(nandptr) + +/* timeout values are in ticks */ +#define CFG_FLASH_ERASE_TOUT (5*CFG_HZ) /* Timeout for Flash Erase */ +#define CFG_FLASH_WRITE_TOUT (5*CFG_HZ) /* Timeout for Flash Write */ + + + + + + +#include <as352x.h> +#define CFG_NAND_BASE NAF_DATA +#include <cmd_confdefs.h> + +#define NAND_ALLOW_ERASE_ALL + + + +#endif /* __CONFIG_H */ diff -urN u-boot-1.1.6.org/MAINTAINERS u-boot-1.1.6/MAINTAINERS --- u-boot-1.1.6.org/MAINTAINERS 2006-12-01 17:49:32.000000000 +0800 +++ u-boot-1.1.6/MAINTAINERS 2006-11-30 09:40:51.000000000 +0800 @@ -566,6 +566,17 @@ Haavard Skinnemoen hskinnemoen@atmel.com
ATSTK1000 AT32AP7000 +####################################################################### ## +# AS352X Systems: # +# # +# Maintainer Name, Email Address # +# Board CPU # +####################################################################### ## + +Thomas Luo thomas.luo@austriamicrosystems.com + + AS352XPB AS352X +
######################################################################## # # End of MAINTAINERS list # diff -urN u-boot-1.1.6.org/MAKEALL u-boot-1.1.6/MAKEALL --- u-boot-1.1.6.org/MAKEALL 2006-12-01 17:49:32.000000000 +0800 +++ u-boot-1.1.6/MAKEALL 2006-11-30 09:33:22.000000000 +0800 @@ -189,13 +189,13 @@ LIST_ARM9=" \ at91rm9200dk cmc_pu2 \ ap920t ap922_XA10 ap926ejs ap946es \ - ap966 cp920t cp922_XA10 cp926ejs \ + ap966 cp920t cp922t cp922_XA10 cp926ejs \ cp946es cp966 lpd7a400 mp2usb \ mx1ads mx1fs2 netstar omap1510inn \ omap1610h2 omap1610inn omap730p2 sbc2410x \ scb9328 smdk2400 smdk2410 trab \ VCMA9 versatile versatileab versatilepb \ - voiceblue \ + voiceblue as3525pb \ "
######################################################################## # diff -urN u-boot-1.1.6.org/Makefile u-boot-1.1.6/Makefile --- u-boot-1.1.6.org/Makefile 2006-12-01 17:49:33.000000000 +0800 +++ u-boot-1.1.6/Makefile 2006-11-30 09:38:22.000000000 +0800 @@ -2253,6 +2253,9 @@ @./mkconfig $(@:_config=) avr32 at32ap atstk1000 atmel at32ap7000
######################################################################## # +as352xpb_config : unconfig + @$(MKCONFIG) $(@:_config=) arm arm922t as352xpb NULL as352x +
Luo Thomas
