[U-Boot] [PATCH 2/3 v2] drivers/serial/serial.c: code maintainability improvments.
Signed-off-by: Michael Zaidman michael.zaidman@gmail.com --- drivers/serial/serial.c | 27 +++++++++++++++++---------- 1 files changed, 17 insertions(+), 10 deletions(-)
diff --git a/drivers/serial/serial.c b/drivers/serial/serial.c index dd5f332..ba88cb0 100644 --- a/drivers/serial/serial.c +++ b/drivers/serial/serial.c @@ -45,24 +45,27 @@ DECLARE_GLOBAL_DATA_PTR; #else #error "No console index specified." #endif /* CONFIG_SERIAL_MULTI */ -#elif (CONFIG_CONS_INDEX < 1) || (CONFIG_CONS_INDEX > 4) +#elif CONFIG_CONS_INDEX < 1 #error "Invalid console index value." #endif
-#if CONFIG_CONS_INDEX == 1 && !defined(CONFIG_SYS_NS16550_COM1) -#error "Console port 1 defined but not configured." -#elif CONFIG_CONS_INDEX == 2 && !defined(CONFIG_SYS_NS16550_COM2) -#error "Console port 2 defined but not configured." -#elif CONFIG_CONS_INDEX == 3 && !defined(CONFIG_SYS_NS16550_COM3) -#error "Console port 3 defined but not configured." -#elif CONFIG_CONS_INDEX == 4 && !defined(CONFIG_SYS_NS16550_COM4) -#error "Console port 4 defined but not configured." +#define CONSOLE_PORT_SANITY_CHECK(port) \ + CONFIG_CONS_INDEX == port && !defined(CONFIG_SYS_NS16550_COM##port) + +#if CONSOLE_PORT_SANITY_CHECK(1) +#error Console port 1 defined but not configured. +#elif CONSOLE_PORT_SANITY_CHECK(2) +#error Console port 2 defined but not configured. +#elif CONSOLE_PORT_SANITY_CHECK(3) +#error Console port 3 defined but not configured. +#elif CONSOLE_PORT_SANITY_CHECK(4) +#error Console port 4 defined but not configured. #endif
/* Note: The port number specified in the functions is 1 based. * the array is 0 based. */ -static NS16550_t serial_ports[4] = { +static NS16550_t serial_ports[] = { #ifdef CONFIG_SYS_NS16550_COM1 (NS16550_t)CONFIG_SYS_NS16550_COM1, #else @@ -85,6 +88,8 @@ static NS16550_t serial_ports[4] = { #endif };
+#define MAX_SER_PORTS (sizeof(serial_ports) / sizeof(NS16550_t)) + #define PORT serial_ports[port-1] #if defined(CONFIG_CONS_INDEX) #define CONSOLE (serial_ports[CONFIG_CONS_INDEX-1]) @@ -160,6 +165,8 @@ int serial_init (void) { int clock_divisor;
+ BUILD_BUG_ON(CONFIG_CONS_INDEX > MAX_SER_PORTS); + #ifdef CONFIG_NS87308 initialise_ns87308(); #endif
On Fri, 2 Apr 2010 12:10:42 +0300 Michael Zaidman michael.zaidman@gmail.com wrote:
Acked-by: Kim Phillips kim.phillips@freescale.com
Kim
Dear Michael Zaidman,
In message 1270199442-5980-1-git-send-email-michael.zaidman@gmail.com you wrote:
Applied, thanks.
Applied, thanks.
Forget it, undone.
This patch cannot be applied alone (it's causing lots of "undefined reference to `BUILD_BUG_ON'" errors), and the preceding patch was still under discussion / waiting for a repost.
Hi Wolfgang,
Since no feedback was received for the http://lists.denx.de/pipermail/u-boot/2010-May/071443.html proposal it looks like no one is willing to discuss this subject anymore.
Are there still any known obstructions do not accept the http://lists.denx.de/pipermail/u-boot/2010-April/069391.html as is? This will solve all undefined references to `BUILD_BUG_ON' problem.
Thanks, Michael
In message AANLkTikG9PZl9Zw0A542OAmFrSlZLRIMNe68jpo-aLGc@mail.gmail.com you wrote:
Probably not in this verbal form. You will often notice that verbal descriptions of what could be done receive little or no echo, while a patch will.
I suggest you roll your proposal into code and submit patches - then we have a much better base to discuss.
Kim Phillips
Michael Zaidman
