[U-Boot] [PATCH v4] Correct corrupted NAND Flash access on KARO TX25 modules
Hi Scott and Stefano,
You will find below the newest patch for the NAND flash access problem on the TX25 module. I hope this version is fulfilling all your expectations.
Cordially,
Daniel
diff --git a/drivers/mtd/nand/mxc_nand.c b/drivers/mtd/nand/mxc_nand.c index 936186f..08fbb12 100644 --- a/drivers/mtd/nand/mxc_nand.c +++ b/drivers/mtd/nand/mxc_nand.c @@ -48,6 +48,17 @@ * Reading or writing a 2K or 4K page requires only 1 FDI/FDO cycle. * Also some of registers are moved and/or changed meaning as seen below. */ +/* + * NAND Flash access mode on MX25 + * + * The MX25 NAND Flash Controller supports two modes to access the Flash: + * a) symmetric mode (one Flash clock cycle per access) or + * b) asymmetric mode (two Flash clock cycles per access) + * + * By default the NAND Flash Controller is configured in the symmetric mode. + * To select the asymmetric mode, the configuration option + * CONFIG_SYS_NAND_MXC_NFC_TWO_CYCLES has to be selected. + */ #if defined(CONFIG_MX31) || defined(CONFIG_MX27) #define MXC_NFC_V1 #elif defined(CONFIG_MX25) || defined(CONFIG_MX35) @@ -1290,7 +1301,9 @@ static void mxc_setup_config1(void) uint16_t tmp;
tmp = readw(&host->regs->nfc_config1); +#ifndef CONFIG_SYS_NAND_MXC_NFC_TWO_CYCLES tmp |= NFC_ONE_CYCLE; +#endif tmp |= NFC_4_8N_ECC; writew(tmp, &host->regs->nfc_config1); if (host->pagesize_2k) diff --git a/include/configs/tx25.h b/include/configs/tx25.h index 6821528..8fa51cb 100644 --- a/include/configs/tx25.h +++ b/include/configs/tx25.h @@ -109,6 +109,7 @@ /* NAND */ #define CONFIG_NAND_MXC #define CONFIG_NAND_MXC_V1_1 +#define CONFIG_SYS_NAND_MXC_NFC_TWO_CYCLES /* 2 cycles to access NAND Flash */ #define CONFIG_MXC_NAND_REGS_BASE (0xBB000000) #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_BASE (0xBB000000)
Gachet Daniel
