[U-Boot] [PATCH v3 6/7] arm: add a common .lds link script
Most ARM CPUs use a very similar link script. This adds a basic script that can be used by most CPUs.
Two new symbols are introduced which are intended to eventually be defined on all architectures to make things easier for generic relocation and reduce special-case code for each architecture:
__text_start is the start of the text area (equivalent to the existing _start on ARM). It marks the start of the region which must be copied to a new location during relocation.
__image_copy_end is the end of the region which must be copied to a new location during relocation. It is normally equal to the start of the BSS region, but this can vary in some cases (SPL?). Making this an explicit symbol on its own removes any ambiguity and permits common code to always do the right thing.
This new script makes use of CPUDIR, now defined by both Makefile and spl/Makefile, to find the directory containing the start.o object file, which is always placed first in the image.
To permit MMU setup prior to relocation (as used by pxa) we add an area to the link script which contains space for this. This is taken from commit 7f4cfcf. CPUs can put the contents in there using their start.S file. BTW, shouldn't that area be 16KB-aligned?
Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v3: - Add more comments in the commit message - Add section for MMU area, as required by pxa
arch/arm/cpu/u-boot.lds | 91 +++++++++++++++++++++++++++++++++++++++++++++++ 1 files changed, 91 insertions(+), 0 deletions(-) create mode 100644 arch/arm/cpu/u-boot.lds
diff --git a/arch/arm/cpu/u-boot.lds b/arch/arm/cpu/u-boot.lds new file mode 100644 index 0000000..7a859fc --- /dev/null +++ b/arch/arm/cpu/u-boot.lds @@ -0,0 +1,91 @@ +/* + * Copyright (c) 2004-2008 Texas Instruments + * + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, garyj@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + __text_start = .; + CPUDIR/start.o (.text) + *(.text) + } + + . = ALIGN(4); + .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } + + . = ALIGN(4); + .data : { + *(.data) + } + + . = ALIGN(4); + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + + __image_copy_end = .; + + .rel.dyn : { + __rel_dyn_start = .; + *(.rel*) + __rel_dyn_end = .; + } + + .dynsym : { + __dynsym_start = .; + *(.dynsym) + } + + _end = .; + + . = ALIGN(4096); + + .mmutable : { + *(.mmutable) + } + + .bss __rel_dyn_start (OVERLAY) : { + __bss_start = .; + *(.bss) + . = ALIGN(4); + __bss_end__ = .; + } + + /DISCARD/ : { *(.dynstr*) } + /DISCARD/ : { *(.dynamic*) } + /DISCARD/ : { *(.plt*) } + /DISCARD/ : { *(.interp*) } + /DISCARD/ : { *(.gnu*) } +}
Each cpu directory currently has its own .lds file. This is only needed in most cases because the start.o file is in a different subdir.
Now that we can factor out this difference, we can move most cpus over to the common .lds file.
Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v3: - Rebase to master
arch/arm/cpu/arm1136/u-boot.lds | 89 ------------------------------------- arch/arm/cpu/arm1176/u-boot.lds | 78 -------------------------------- arch/arm/cpu/arm720t/u-boot.lds | 79 -------------------------------- arch/arm/cpu/arm920t/u-boot.lds | 88 ------------------------------------ arch/arm/cpu/arm925t/u-boot.lds | 83 ---------------------------------- arch/arm/cpu/arm926ejs/u-boot.lds | 80 --------------------------------- arch/arm/cpu/arm946es/u-boot.lds | 80 --------------------------------- arch/arm/cpu/arm_intcm/u-boot.lds | 80 --------------------------------- arch/arm/cpu/armv7/u-boot.lds | 85 ----------------------------------- arch/arm/cpu/lh7a40x/u-boot.lds | 80 --------------------------------- arch/arm/cpu/pxa/u-boot.lds | 86 ----------------------------------- arch/arm/cpu/s3c44b0/u-boot.lds | 80 --------------------------------- arch/arm/cpu/sa1100/u-boot.lds | 83 ---------------------------------- 13 files changed, 0 insertions(+), 1071 deletions(-) delete mode 100644 arch/arm/cpu/arm1136/u-boot.lds delete mode 100644 arch/arm/cpu/arm1176/u-boot.lds delete mode 100644 arch/arm/cpu/arm720t/u-boot.lds delete mode 100644 arch/arm/cpu/arm920t/u-boot.lds delete mode 100644 arch/arm/cpu/arm925t/u-boot.lds delete mode 100644 arch/arm/cpu/arm926ejs/u-boot.lds delete mode 100644 arch/arm/cpu/arm946es/u-boot.lds delete mode 100644 arch/arm/cpu/arm_intcm/u-boot.lds delete mode 100644 arch/arm/cpu/armv7/u-boot.lds delete mode 100644 arch/arm/cpu/lh7a40x/u-boot.lds delete mode 100644 arch/arm/cpu/pxa/u-boot.lds delete mode 100644 arch/arm/cpu/s3c44b0/u-boot.lds delete mode 100644 arch/arm/cpu/sa1100/u-boot.lds
diff --git a/arch/arm/cpu/arm1136/u-boot.lds b/arch/arm/cpu/arm1136/u-boot.lds deleted file mode 100644 index d1e2851..0000000 --- a/arch/arm/cpu/arm1136/u-boot.lds +++ /dev/null @@ -1,89 +0,0 @@ -/* - * (C) Copyright 2009 - * Ilya Yanok, Emcraft Systems Ltd, yanok@emcraft.com - * - * Copyright (C) 2005-2007 Samsung Electronics - * Kyungin Park kyugnmin.park@samsung.com - * - * Copyright (c) 2004 Texas Instruments - * - * (C) Copyright 2002 - * Gary Jennejohn, DENX Software Engineering, garyj@denx.de - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") -OUTPUT_ARCH(arm) -ENTRY(_start) -SECTIONS -{ - . = 0x00000000; - - . = ALIGN(4); - .text : - { - arch/arm/cpu/arm1136/start.o (.text) - *(.text) - } - - . = ALIGN(4); - .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } - - . = ALIGN(4); - .data : { - *(.data) - } - - . = ALIGN(4); - - . = .; - __u_boot_cmd_start = .; - .u_boot_cmd : { *(.u_boot_cmd) } - __u_boot_cmd_end = .; - - . = ALIGN(4); - - .rel.dyn : { - __rel_dyn_start = .; - *(.rel*) - __rel_dyn_end = .; - } - - .dynsym : { - __dynsym_start = .; - *(.dynsym) - } - - _end = .; - - .bss __rel_dyn_start (OVERLAY) : { - __bss_start = .; - *(.bss) - . = ALIGN(4); - __bss_end__ = .; - } - - /DISCARD/ : { *(.dynstr*) } - /DISCARD/ : { *(.dynamic*) } - /DISCARD/ : { *(.plt*) } - /DISCARD/ : { *(.interp*) } - /DISCARD/ : { *(.gnu*) } -} diff --git a/arch/arm/cpu/arm1176/u-boot.lds b/arch/arm/cpu/arm1176/u-boot.lds deleted file mode 100644 index 27d6638..0000000 --- a/arch/arm/cpu/arm1176/u-boot.lds +++ /dev/null @@ -1,78 +0,0 @@ -/* - * (C) Copyright 2002-2004 - * Gary Jennejohn, DENX Software Engineering, garyj@denx.de - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") -OUTPUT_ARCH(arm) -ENTRY(_start) -SECTIONS -{ - . = 0x00000000; - - . = ALIGN(4); - .text : - { - arch/arm/cpu/arm1176/start.o (.text) - *(.text) - } - - . = ALIGN(4); - .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } - - . = ALIGN(4); - .data : { - *(.data) - } - - . = .; - __u_boot_cmd_start = .; - .u_boot_cmd : { *(.u_boot_cmd) } - __u_boot_cmd_end = .; - - . = ALIGN(4); - - .rel.dyn : { - __rel_dyn_start = .; - *(.rel*) - __rel_dyn_end = .; - } - - .dynsym : { - __dynsym_start = .; - *(.dynsym) - } - - _end = .; - - .bss __rel_dyn_start (OVERLAY) : { - __bss_start = .; - *(.bss) - . = ALIGN(4); - __bss_end__ = .; - } - - /DISCARD/ : { *(.dynstr*) } - /DISCARD/ : { *(.dynamic*) } - /DISCARD/ : { *(.plt*) } - /DISCARD/ : { *(.interp*) } - /DISCARD/ : { *(.gnu*) } -} diff --git a/arch/arm/cpu/arm720t/u-boot.lds b/arch/arm/cpu/arm720t/u-boot.lds deleted file mode 100644 index 9370fad..0000000 --- a/arch/arm/cpu/arm720t/u-boot.lds +++ /dev/null @@ -1,79 +0,0 @@ -/* - * (C) Copyright 2000-2004 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") -OUTPUT_ARCH(arm) -ENTRY(_start) -SECTIONS -{ - . = 0x00000000; - - . = ALIGN(4); - .text : - { - arch/arm/cpu/arm720t/start.o (.text) - *(.text) - } - - . = ALIGN(4); - .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } - - . = ALIGN(4); - .data : { - } - - . = ALIGN(4); - - . = .; - __u_boot_cmd_start = .; - .u_boot_cmd : { *(.u_boot_cmd) } - __u_boot_cmd_end = .; - - . = ALIGN(4); - - .rel.dyn : { - __rel_dyn_start = .; - *(.rel*) - __rel_dyn_end = .; - } - - .dynsym : { - __dynsym_start = .; - *(.dynsym) - } - - _end = .; - - .bss __rel_dyn_start (OVERLAY) : { - __bss_start = .; - *(.bss) - . = ALIGN(4); - __bss_end__ = .; - } - - /DISCARD/ : { *(.dynstr*) } - /DISCARD/ : { *(.dynamic*) } - /DISCARD/ : { *(.plt*) } - /DISCARD/ : { *(.interp*) } - /DISCARD/ : { *(.gnu*) } -} diff --git a/arch/arm/cpu/arm920t/u-boot.lds b/arch/arm/cpu/arm920t/u-boot.lds deleted file mode 100644 index 17ba604..0000000 --- a/arch/arm/cpu/arm920t/u-boot.lds +++ /dev/null @@ -1,88 +0,0 @@ -/* - * (c) Copyright 2004 - * Techware Information Technology, Inc. - * Ming-Len Wu minglen_wu@techware.com.tw - * - * (C) Copyright 2000-2004 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * (C) Copyright 2002 - * Gary Jennejohn, DENX Software Engineering, gj@denx.de - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - * - */ - -OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") -OUTPUT_ARCH(arm) -ENTRY(_start) -SECTIONS -{ - . = 0x00000000; - - . = ALIGN(4); - .text : - { - arch/arm/cpu/arm920t/start.o (.text) - *(.text) - } - - . = ALIGN(4); - .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } - - . = ALIGN(4); - .data : { - *(.data) - } - - . = ALIGN(4); - - . = .; - __u_boot_cmd_start = .; - .u_boot_cmd : { *(.u_boot_cmd) } - __u_boot_cmd_end = .; - - . = ALIGN(4); - - .rel.dyn : { - __rel_dyn_start = .; - *(.rel*) - __rel_dyn_end = .; - } - - .dynsym : { - __dynsym_start = .; - *(.dynsym) - } - - _end = .; - - .bss __rel_dyn_start (OVERLAY) : { - __bss_start = .; - *(.bss) - . = ALIGN(4); - __bss_end__ = .; - } - - /DISCARD/ : { *(.dynstr*) } - /DISCARD/ : { *(.dynamic*) } - /DISCARD/ : { *(.plt*) } - /DISCARD/ : { *(.interp*) } - /DISCARD/ : { *(.gnu*) } -} diff --git a/arch/arm/cpu/arm925t/u-boot.lds b/arch/arm/cpu/arm925t/u-boot.lds deleted file mode 100644 index 64e76f5..0000000 --- a/arch/arm/cpu/arm925t/u-boot.lds +++ /dev/null @@ -1,83 +0,0 @@ -/* - * (C) Copyright 2004 - * Wolfgang Denk, DENX Software Engineering, wg@denx.de - * - * (C) Copyright 2002 - * Gary Jennejohn, DENX Software Engineering, garyj@denx.de - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") -OUTPUT_ARCH(arm) -ENTRY(_start) -SECTIONS -{ - . = 0x00000000; - - . = ALIGN(4); - .text : - { - arch/arm/cpu/arm925t/start.o (.text) - *(.text) - } - - . = ALIGN(4); - .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } - - . = ALIGN(4); - .data : { - *(.data) - } - - . = ALIGN(4); - - . = .; - __u_boot_cmd_start = .; - .u_boot_cmd : { *(.u_boot_cmd) } - __u_boot_cmd_end = .; - - . = ALIGN(4); - - .rel.dyn : { - __rel_dyn_start = .; - *(.rel*) - __rel_dyn_end = .; - } - - .dynsym : { - __dynsym_start = .; - *(.dynsym) - } - - _end = .; - - .bss __rel_dyn_start (OVERLAY) : { - __bss_start = .; - *(.bss) - . = ALIGN(4); - __bss_end__ = .; - } - - /DISCARD/ : { *(.dynstr*) } - /DISCARD/ : { *(.dynamic*) } - /DISCARD/ : { *(.plt*) } - /DISCARD/ : { *(.interp*) } - /DISCARD/ : { *(.gnu*) } -} diff --git a/arch/arm/cpu/arm926ejs/u-boot.lds b/arch/arm/cpu/arm926ejs/u-boot.lds deleted file mode 100644 index 1480e0c..0000000 --- a/arch/arm/cpu/arm926ejs/u-boot.lds +++ /dev/null @@ -1,80 +0,0 @@ -/* - * (C) Copyright 2002-2004 - * Gary Jennejohn, DENX Software Engineering, gj@denx.de - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") -OUTPUT_ARCH(arm) -ENTRY(_start) -SECTIONS -{ - . = 0x00000000; - - . = ALIGN(4); - .text : - { - arch/arm/cpu/arm926ejs/start.o (.text) - *(.text) - } - - . = ALIGN(4); - .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } - - . = ALIGN(4); - .data : { - *(.data) - } - - . = ALIGN(4); - - . = .; - __u_boot_cmd_start = .; - .u_boot_cmd : { *(.u_boot_cmd) } - __u_boot_cmd_end = .; - - . = ALIGN(4); - - .rel.dyn : { - __rel_dyn_start = .; - *(.rel*) - __rel_dyn_end = .; - } - - .dynsym : { - __dynsym_start = .; - *(.dynsym) - } - - _end = .; - - .bss __rel_dyn_start (OVERLAY) : { - __bss_start = .; - *(.bss) - . = ALIGN(4); - __bss_end__ = .; - } - - /DISCARD/ : { *(.dynstr*) } - /DISCARD/ : { *(.dynamic*) } - /DISCARD/ : { *(.plt*) } - /DISCARD/ : { *(.interp*) } - /DISCARD/ : { *(.gnu*) } -} diff --git a/arch/arm/cpu/arm946es/u-boot.lds b/arch/arm/cpu/arm946es/u-boot.lds deleted file mode 100644 index ff938e4..0000000 --- a/arch/arm/cpu/arm946es/u-boot.lds +++ /dev/null @@ -1,80 +0,0 @@ -/* - * (C) Copyright 2002 - * Gary Jennejohn, DENX Software Engineering, garyj@denx.de - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") -OUTPUT_ARCH(arm) -ENTRY(_start) -SECTIONS -{ - . = 0x00000000; - - . = ALIGN(4); - .text : - { - arch/arm/cpu/arm946es/start.o (.text) - *(.text) - } - - . = ALIGN(4); - .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } - - . = ALIGN(4); - .data : { - *(.data) - } - - . = ALIGN(4); - - . = .; - __u_boot_cmd_start = .; - .u_boot_cmd : { *(.u_boot_cmd) } - __u_boot_cmd_end = .; - - . = ALIGN(4); - - .rel.dyn : { - __rel_dyn_start = .; - *(.rel*) - __rel_dyn_end = .; - } - - .dynsym : { - __dynsym_start = .; - *(.dynsym) - } - - _end = .; - - .bss __rel_dyn_start (OVERLAY) : { - __bss_start = .; - *(.bss) - . = ALIGN(4); - __bss_end__ = .; - } - - /DISCARD/ : { *(.dynstr*) } - /DISCARD/ : { *(.dynamic*) } - /DISCARD/ : { *(.plt*) } - /DISCARD/ : { *(.interp*) } - /DISCARD/ : { *(.gnu*) } -} diff --git a/arch/arm/cpu/arm_intcm/u-boot.lds b/arch/arm/cpu/arm_intcm/u-boot.lds deleted file mode 100644 index f4a146c..0000000 --- a/arch/arm/cpu/arm_intcm/u-boot.lds +++ /dev/null @@ -1,80 +0,0 @@ -/* - * (C) Copyright 2002 - * Gary Jennejohn, DENX Software Engineering, garyj@denx.de - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") -OUTPUT_ARCH(arm) -ENTRY(_start) -SECTIONS -{ - . = 0x00000000; - - . = ALIGN(4); - .text : - { - arch/arm/cpu/arm_intcm/start.o (.text) - *(.text) - } - - . = ALIGN(4); - .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } - - . = ALIGN(4); - .data : { - *(.data) - } - - . = ALIGN(4); - - . = .; - __u_boot_cmd_start = .; - .u_boot_cmd : { *(.u_boot_cmd) } - __u_boot_cmd_end = .; - - . = ALIGN(4); - - .rel.dyn : { - __rel_dyn_start = .; - *(.rel*) - __rel_dyn_end = .; - } - - .dynsym : { - __dynsym_start = .; - *(.dynsym) - } - - _end = .; - - .bss __rel_dyn_start (OVERLAY) : { - __bss_start = .; - *(.bss) - . = ALIGN(4); - __bss_end__ = .; - } - - /DISCARD/ : { *(.dynstr*) } - /DISCARD/ : { *(.dynamic*) } - /DISCARD/ : { *(.plt*) } - /DISCARD/ : { *(.interp*) } - /DISCARD/ : { *(.gnu*) } -} diff --git a/arch/arm/cpu/armv7/u-boot.lds b/arch/arm/cpu/armv7/u-boot.lds deleted file mode 100644 index 40ecf78..0000000 --- a/arch/arm/cpu/armv7/u-boot.lds +++ /dev/null @@ -1,85 +0,0 @@ -/* - * January 2004 - Changed to support H4 device - * Copyright (c) 2004-2008 Texas Instruments - * - * (C) Copyright 2002 - * Gary Jennejohn, DENX Software Engineering, garyj@denx.de - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") -OUTPUT_ARCH(arm) -ENTRY(_start) -SECTIONS -{ - . = 0x00000000; - - . = ALIGN(4); - .text : - { - arch/arm/cpu/armv7/start.o (.text) - *(.text) - } - - . = ALIGN(4); - .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } - - . = ALIGN(4); - .data : { - *(.data) - } - - . = ALIGN(4); - - . = .; - __u_boot_cmd_start = .; - .u_boot_cmd : { *(.u_boot_cmd) } - __u_boot_cmd_end = .; - - . = ALIGN(4); - - __image_copy_end = .; - - .rel.dyn : { - __rel_dyn_start = .; - *(.rel*) - __rel_dyn_end = .; - } - - .dynsym : { - __dynsym_start = .; - *(.dynsym) - } - - _end = .; - - .bss __rel_dyn_start (OVERLAY) : { - __bss_start = .; - *(.bss) - . = ALIGN(4); - __bss_end__ = .; - } - - /DISCARD/ : { *(.dynstr*) } - /DISCARD/ : { *(.dynamic*) } - /DISCARD/ : { *(.plt*) } - /DISCARD/ : { *(.interp*) } - /DISCARD/ : { *(.gnu*) } -} diff --git a/arch/arm/cpu/lh7a40x/u-boot.lds b/arch/arm/cpu/lh7a40x/u-boot.lds deleted file mode 100644 index 30934ff..0000000 --- a/arch/arm/cpu/lh7a40x/u-boot.lds +++ /dev/null @@ -1,80 +0,0 @@ -/* - * (C) Copyright 2002 - * Gary Jennejohn, DENX Software Engineering, garyj@denx.de - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") -OUTPUT_ARCH(arm) -ENTRY(_start) -SECTIONS -{ - . = 0x00000000; - - . = ALIGN(4); - .text : - { - arch/arm/cpu/lh7a40x/start.o (.text) - *(.text) - } - - . = ALIGN(4); - .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } - - . = ALIGN(4); - .data : { - *(.data) - } - - . = ALIGN(4); - - . = .; - __u_boot_cmd_start = .; - .u_boot_cmd : { *(.u_boot_cmd) } - __u_boot_cmd_end = .; - - . = ALIGN(4); - - .rel.dyn : { - __rel_dyn_start = .; - *(.rel*) - __rel_dyn_end = .; - } - - .dynsym : { - __dynsym_start = .; - *(.dynsym) - } - - _end = .; - - .bss __rel_dyn_start (OVERLAY) : { - __bss_start = .; - *(.bss) - . = ALIGN(4); - __bss_end__ = .; - } - - /DISCARD/ : { *(.dynstr*) } - /DISCARD/ : { *(.dynamic*) } - /DISCARD/ : { *(.plt*) } - /DISCARD/ : { *(.interp*) } - /DISCARD/ : { *(.gnu*) } -} diff --git a/arch/arm/cpu/pxa/u-boot.lds b/arch/arm/cpu/pxa/u-boot.lds deleted file mode 100644 index e86e781..0000000 --- a/arch/arm/cpu/pxa/u-boot.lds +++ /dev/null @@ -1,86 +0,0 @@ -/* - * (C) Copyright 2000-2005 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") -OUTPUT_ARCH(arm) -ENTRY(_start) -SECTIONS -{ - . = 0x00000000; - - . = ALIGN(4); - .text : - { - arch/arm/cpu/pxa/start.o (.text) - *(.text) - } - - . = ALIGN(4); - .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } - - . = ALIGN(4); - .data : { - *(.data) - } - - . = ALIGN(4); - - . = .; - __u_boot_cmd_start = .; - .u_boot_cmd : { *(.u_boot_cmd) } - __u_boot_cmd_end = .; - - . = ALIGN(4); - - .rel.dyn : { - __rel_dyn_start = .; - *(.rel*) - __rel_dyn_end = .; - } - - .dynsym : { - __dynsym_start = .; - *(.dynsym) - } - - . = ALIGN(4096); - - .mmutable : { - *(.mmutable) - } - - _end = .; - - .bss __rel_dyn_start (OVERLAY) : { - __bss_start = .; - *(.bss) - . = ALIGN(4); - __bss_end__ = .; - } - - /DISCARD/ : { *(.dynstr*) } - /DISCARD/ : { *(.dynamic*) } - /DISCARD/ : { *(.plt*) } - /DISCARD/ : { *(.interp*) } - /DISCARD/ : { *(.gnu*) } -} diff --git a/arch/arm/cpu/s3c44b0/u-boot.lds b/arch/arm/cpu/s3c44b0/u-boot.lds deleted file mode 100644 index 74a259c..0000000 --- a/arch/arm/cpu/s3c44b0/u-boot.lds +++ /dev/null @@ -1,80 +0,0 @@ -/* - * (C) Copyright 2000-2004 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") -OUTPUT_ARCH(arm) -ENTRY(_start) -SECTIONS -{ - . = 0x00000000; - - . = ALIGN(4); - .text : - { - arch/arm/cpu/s3c44b0/start.o (.text) - *(.text) - } - - . = ALIGN(4); - .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } - - . = ALIGN(4); - .data : { - *(.data) - } - - . = ALIGN(4); - - . = .; - __u_boot_cmd_start = .; - .u_boot_cmd : { *(.u_boot_cmd) } - __u_boot_cmd_end = .; - - . = ALIGN(4); - - .rel.dyn : { - __rel_dyn_start = .; - *(.rel*) - __rel_dyn_end = .; - } - - .dynsym : { - __dynsym_start = .; - *(.dynsym) - } - - _end = .; - - .bss __rel_dyn_start (OVERLAY) : { - __bss_start = .; - *(.bss) - . = ALIGN(4); - __bss_end__ = .; - } - - /DISCARD/ : { *(.dynstr*) } - /DISCARD/ : { *(.dynamic*) } - /DISCARD/ : { *(.plt*) } - /DISCARD/ : { *(.interp*) } - /DISCARD/ : { *(.gnu*) } -} diff --git a/arch/arm/cpu/sa1100/u-boot.lds b/arch/arm/cpu/sa1100/u-boot.lds deleted file mode 100644 index e6381da..0000000 --- a/arch/arm/cpu/sa1100/u-boot.lds +++ /dev/null @@ -1,83 +0,0 @@ -/* - * (C) Copyright 2003-2004 - * MontaVista Software, Inc. - * - * (C) Copyright 2000-2004 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") -OUTPUT_ARCH(arm) -ENTRY(_start) -SECTIONS -{ - . = 0x00000000; - - . = ALIGN(4); - .text : - { - arch/arm/cpu/sa1100/start.o (.text) - *(.text) - } - - . = ALIGN(4); - .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } - - . = ALIGN(4); - .data : { - *(.data) - } - - . = ALIGN(4); - - . = .; - __u_boot_cmd_start = .; - .u_boot_cmd : { *(.u_boot_cmd) } - __u_boot_cmd_end = .; - - . = ALIGN(4); - - .rel.dyn : { - __rel_dyn_start = .; - *(.rel*) - __rel_dyn_end = .; - } - - .dynsym : { - __dynsym_start = .; - *(.dynsym) - } - - _end = .; - - .bss __rel_dyn_start (OVERLAY) : { - __bss_start = .; - *(.bss) - . = ALIGN(4); - __bss_end__ = .; - } - - /DISCARD/ : { *(.dynstr*) } - /DISCARD/ : { *(.dynamic*) } - /DISCARD/ : { *(.plt*) } - /DISCARD/ : { *(.interp*) } - /DISCARD/ : { *(.gnu*) } -}
Hi Simon,
Please name it _image_copy_start, not __text_start
Signed-off-by: Simon Glasssjg@chromium.org
Changes in v3:
- Copyright (c) 2004-2008 Texas Instruments
- (C) Copyright 2002
- Gary Jennejohn, DENX Software Engineering,garyj@denx.de
- project.
- MA 02111-1307 USA
- . = 0x00000000;
- . = ALIGN(4);
- .text :
__text_start = .;
*(.text)
- . = ALIGN(4);
- . = ALIGN(4);
- .data : {
*(.data)
- . = ALIGN(4);
- . = ALIGN(4);
This "ALIGN(4)" is what upsets my edminiv2 build and makes it not binary-identical. It is not in the current arm926ejs liner script. I will check if adding it to the current arm926ejs script produces a working and binary-identical u-boot.
- .rel.dyn : {
*(.rel*)
__rel_dyn_end = .;
- .dynsym : {
__dynsym_start = .;
*(.dynsym)
- _end = .;
Below is what I assume to be the reservation for MMU.
- . = ALIGN(4096);
- .mmutable : {
*(.mmutable)
... and I don't like it at all, more so if it is going to be actually 16 KB, because it seems to me we're wasting memory and creating a hole in the middle of our in-RAM binary, and I'm not sure we need to do it here in the first place. Do we need to have that MMU region mapped over DDR? And if so, do we need to have it mapped in the middle of u-boot? Plus you're placing it after .dynsym and .rel.dyn, but possibly overlaid with .bss. Normally this area should have gone by the time we get to use BSS, but assumption is the mother of all screw-ups.
__bss_start = .;
*(.bss)
. = ALIGN(4);
__bss_end__ = .;
Amicalement,
Hi again Simon,
Also, I realize this introduces two symbols which are not used within the same patch set.
Amicalement,
Hi Albert,
On Tue, Feb 21, 2012 at 5:11 AM, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Hi Simon,
OK will do
Changes in v3:
- project.
- MA 02111-1307 USA
- . = 0x00000000;
- . = ALIGN(4);
- .text :
- __text_start = .;
- CPUDIR/start.o (.text)
- *(.text)
- . = ALIGN(4);
- . = ALIGN(4);
- .data : {
- *(.data)
- . = ALIGN(4);
- . = ALIGN(4);
OK, but realistically we copy a word at a time (at least) and the .rel.dyn region is going to be word-aligned I think. All we are doing here is making sure that the image ends on a word boundary, which seems reasonable to me.
In other words, I would like the __image_copy_start and __image_copy_end symbols to be word-aligned.
- .rel.dyn : {
- *(.rel*)
- .dynsym : {
- *(.dynsym)
- _end = .;
- . = ALIGN(4096);
- .mmutable : {
- *(.mmutable)
Yes it will be 16KB, although of course only if it exists. At present it is only used for pxa so including it here allows pxa boards to build.
The hole is not in the middle of the binary, but at the end. The BSS may overlay it if large enough, but that doesn't take affect until after relocation.
I'm not thrilled with it either, but it does allow us to have an option to set up the MMU table at compile time for those that need it. Having thought about it a bit more I feel that we should be able to set this up at run-time instead, but still, it is needed at present for pxa, so...
I have question also, for Marek. Should this be 16KB aligned, since ARM needs this I think. The alignment is currently provided by pxa's start.S but we might as well be explicit here I think.
- __bss_start = .;
- *(.bss)
- . = ALIGN(4);
- __bss_end__ = .;
Amicalement,
Albert.
Hi Simon,
Le 21/02/2012 18:02, Simon Glass a écrit :
. = ALIGN(4);
I understand the requirement and agree to it -- only, it seems to me it is already fulfilled in the current lds files, so I still fail to see what breaks 'near binary identity'.
Amicalement,
Hi Albert,
On Tue, Feb 21, 2012 at 11:52 AM, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Hi Simon,
- . = ALIGN(4);
If we add any symbols or change the value of any of them, then the binary file may change. You can see the differences by doing something like:
armv7a-cros-linux-gnueabi-objdump -b binary -m arm -D u-boot.bin
on each file (but I guess you know that).
Amicalement,
Albert.
Hi Albert,
Hi Simon,
OK will do
Changes in v3:
- project.
- MA 02111-1307 USA
. = 0x00000000;
. = ALIGN(4);
.text :
__text_start = .;
*(.text)
. = ALIGN(4);
. = ALIGN(4);
.data : {
*(.data)
. = ALIGN(4);
. = ALIGN(4);
.rel.dyn : {
*(.rel*)
__rel_dyn_end = .;
.dynsym : {
__dynsym_start = .;
*(.dynsym)
_end = .;
. = ALIGN(4096);
.mmutable : {
*(.mmutable)
Yes, but I believe it should be only 4k aligned. This part is special in more ways actually.
This is only used on PXA250, since that has no SRAM and therefore no place for stack at boottime. But to allow locking cachelines (to create space for stack) we need the MMU table ready. Therefore I created the MMU table with 1:1 mapping in the ROM at compile time and in the init code I point the MMU to this table.
That's about it
M
__bss_start = .;
*(.bss)
. = ALIGN(4);
__bss_end__ = .;
Amicalement,
Albert.
Hi Marek,
On Tue, Feb 21, 2012 at 12:24 PM, Marek Vasut marek.vasut@gmail.com wrote:
Hi Albert,
Hi Simon,
OK will do
Changes in v3:
- project.
- MA 02111-1307 USA
- . = 0x00000000;
- . = ALIGN(4);
- .text :
- __text_start = .;
- *(.text)
- . = ALIGN(4);
- . = ALIGN(4);
- .data : {
- *(.data)
- . = ALIGN(4);
- . = ALIGN(4);
- .rel.dyn : {
- *(.rel*)
- .dynsym : {
- *(.dynsym)
- _end = .;
- . = ALIGN(4096);
- .mmutable : {
- *(.mmutable)
That's about it
OK thank you. Since this isn't needed for other CPUs and given Albert's concerns I will mark this section as deprecated in my v4 patch, just to make sure others don't start using it.
M
- __bss_start = .;
- *(.bss)
- . = ALIGN(4);
- __bss_end__ = .;
Amicalement,
Albert.
Albert ARIBAUD
