[U-Boot-Users] [PATCH 04/10 v3] [ARM] TQMA31: add new board with i.MX31 processor
Signed-off-by: Jens Gehrlein sew_s@tqs.de ---
Fixed the following issues (compared to v1): a) Myself: added NFS mount option "rw" to default environment b) Magnus: added prefix $(obj) in front of .depend in Makefile. Thank you for catching that. c) Jean-Christophe: used $(BOARD) in Makefile, fixed whitespace, tabs, special character, patched mach-types.h d) Heiko: removed defines for default netmask, ipaddr, serverip
MAINTAINERS | 4 MAKEALL | 1 Makefile | 3 board/tqc/tqma31/Makefile | 48 ++++ board/tqc/tqma31/config.mk | 2 board/tqc/tqma31/lowlevel_init.S | 375 +++++++++++++++++++++++++++++++++ board/tqc/tqma31/tqma31.c | 89 ++++++++ board/tqc/tqma31/u-boot.lds | 72 ++++++ include/asm-arm/arch-mx31/mx31-regs.h | 42 ++++ include/asm-arm/mach-types.h | 13 + include/configs/TQMA31.h | 266 +++++++++++++++++++++++ 11 files changed, 915 insertions(+), 0 deletions(-) create mode 100644 board/tqc/tqma31/Makefile create mode 100644 board/tqc/tqma31/config.mk create mode 100644 board/tqc/tqma31/lowlevel_init.S create mode 100644 board/tqc/tqma31/tqma31.c create mode 100644 board/tqc/tqma31/u-boot.lds create mode 100644 include/configs/TQMA31.h
diff --git a/MAINTAINERS b/MAINTAINERS index a3d70b1..dff1757 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -591,6 +591,10 @@ Michael Schwingen michael@schwingen.org actux3 xscale actux4 xscale
+Jens Gehrlein sew_s@tqs.de + + TQMA31 i.MX31 + ######################################################################### # x86 Systems: # # # diff --git a/MAKEALL b/MAKEALL index 32caab7..4e442c5 100755 --- a/MAKEALL +++ b/MAKEALL @@ -524,6 +524,7 @@ LIST_ARM11=" \ imx31_litekit \ imx31_phycore \ mx31ads \ + TQMA31 \ "
######################################################################### diff --git a/Makefile b/Makefile index 8bfc891..e3ade25 100644 --- a/Makefile +++ b/Makefile @@ -2664,6 +2664,9 @@ imx31_phycore_config : unconfig mx31ads_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm1136 mx31ads NULL mx31
+TQMA31_config : unconfig + @$(MKCONFIG) $(@:_config=) arm arm1136 tqma31 tqc mx31 + #======================================================================== # i386 #======================================================================== diff --git a/board/tqc/tqma31/Makefile b/board/tqc/tqma31/Makefile new file mode 100644 index 0000000..a2a9eb3 --- /dev/null +++ b/board/tqc/tqma31/Makefile @@ -0,0 +1,48 @@ +# +# Copyright (C) 2008, Guennadi Liakhovetski lg@denx.de +# Copyright (C) 2008, Jens Gehrlein sew_s@tqs.de +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := $(BOARD).o +SOBJS := lowlevel_init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/tqc/tqma31/config.mk b/board/tqc/tqma31/config.mk new file mode 100644 index 0000000..19df69e --- /dev/null +++ b/board/tqc/tqma31/config.mk @@ -0,0 +1,2 @@ +TEXT_BASE = 0x8ff00000 + diff --git a/board/tqc/tqma31/lowlevel_init.S b/board/tqc/tqma31/lowlevel_init.S new file mode 100644 index 0000000..7e0a80e --- /dev/null +++ b/board/tqc/tqma31/lowlevel_init.S @@ -0,0 +1,375 @@ +/* + * Copyright (C) 2008, Guennadi Liakhovetski lg@denx.de + * Copyright (C) 2008, Jens Gehrlein sew_s@tqs.de + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <asm/arch/mx31-regs.h> +#include <config.h> + +.macro REG reg, val + ldr r2, =\reg + ldr r3, =\val + str r3, [r2] +.endm + +.macro REG8 reg, val + ldr r2, =\reg + ldr r3, =\val + strb r3, [r2] +.endm + +.macro DELAY loops + ldr r2, =\loops +1: + subs r2, r2, #1 + nop + bcs 1b +.endm + + +/* + * AIPS setup - Only setup MPROTx registers. + * The PACR default values are good. + */ +.macro init_aips + + /* Setup the Peripheral Port Remap register inside the core */ + ldr r0, =0x40000015 /* start from AIPS 2GB region */ + mcr p15, 0, r0, c15, c2, 4 + + /* + * Set all MPROTx to be non-bufferable, trusted for R/W, + * not forced to user-mode. + */ + ldr r0, =0x43F00000 + ldr r1, =0x77777777 + str r1, [r0, #0x00] + str r1, [r0, #0x04] + ldr r0, =0x53F00000 + str r1, [r0, #0x00] + str r1, [r0, #0x04] + + /* + * Clear the on and off peripheral modules Supervisor Protect bit + * for SDMA to access them. Did not change the AIPS control registers + * (offset 0x20) access type + */ + ldr r0, =0x43F00000 + ldr r1, =0x0 + str r1, [r0, #0x40] + str r1, [r0, #0x44] + str r1, [r0, #0x48] + str r1, [r0, #0x4C] + ldr r1, [r0, #0x50] + and r1, r1, #0x00FFFFFF + str r1, [r0, #0x50] + + ldr r0, =0x53F00000 + ldr r1, =0x0 + str r1, [r0, #0x40] + str r1, [r0, #0x44] + str r1, [r0, #0x48] + str r1, [r0, #0x4C] + ldr r1, [r0, #0x50] + and r1, r1, #0x00FFFFFF + str r1, [r0, #0x50] +.endm /* init_aips */ + + +/* RedBoot: MAX (Multi-Layer AHB Crossbar Switch) setup */ +.macro init_max + ldr r0, =0x43F04000 + /* MPR - priority is M4 > M2 > M3 > M5 > M0 > M1 */ + ldr r1, =0x00302154 + str r1, [r0, #0x000] /* for S0 */ + str r1, [r0, #0x100] /* for S1 */ + str r1, [r0, #0x200] /* for S2 */ + str r1, [r0, #0x300] /* for S3 */ + str r1, [r0, #0x400] /* for S4 */ + /* SGPCR - always park on last master */ + ldr r1, =0x10 + str r1, [r0, #0x010] /* for S0 */ + str r1, [r0, #0x110] /* for S1 */ + str r1, [r0, #0x210] /* for S2 */ + str r1, [r0, #0x310] /* for S3 */ + str r1, [r0, #0x410] /* for S4 */ + /* MGPCR - restore default values */ + ldr r1, =0x0 + str r1, [r0, #0x800] /* for M0 */ + str r1, [r0, #0x900] /* for M1 */ + str r1, [r0, #0xA00] /* for M2 */ + str r1, [r0, #0xB00] /* for M3 */ + str r1, [r0, #0xC00] /* for M4 */ + str r1, [r0, #0xD00] /* for M5 */ +.endm /* init_max */ + + +/* RedBoot: M3IF setup */ +.macro init_m3if + /* Configure M3IF registers */ + ldr r1, =0xB8003000 + /* + * M3IF Control Register (M3IFCTL) + * MRRP[0] = L2CC0 not on priority list (0 << 0) = 0x00000000 + * MRRP[1] = L2CC1 not on priority list (0 << 0) = 0x00000000 + * MRRP[2] = MBX not on priority list (0 << 0) = 0x00000000 + * MRRP[3] = MAX1 not on priority list (0 << 0) = 0x00000000 + * MRRP[4] = SDMA not on priority list (0 << 0) = 0x00000000 + * MRRP[5] = MPEG4 not on priority list (0 << 0) = 0x00000000 + * MRRP[6] = IPU1 on priority list (1 << 6) = 0x00000040 + * MRRP[7] = IPU2 not on priority list (0 << 0) = 0x00000000 + * ------------ + * 0x00000040 + */ + ldr r0, =0x00000040 + str r0, [r1] /* M3IF control reg */ +.endm /* init_m3if */ + + +/* RedBoot: To support 133MHz DDR */ +.macro init_drive_strength + /* + * Disable maximum drive strength SDRAM/DDR lines by clearing DSE1 bits + * in SW_PAD_CTL registers + */ + + /* SDCLK */ + ldr r1, =0x43FAC200 + ldr r0, [r1, #0x6C] + bic r0, r0, #(1 << 12) + str r0, [r1, #0x6C] + + /* CAS */ + ldr r0, [r1, #0x70] + bic r0, r0, #(1 << 22) + str r0, [r1, #0x70] + + /* RAS */ + ldr r0, [r1, #0x74] + bic r0, r0, #(1 << 2) + str r0, [r1, #0x74] + + /* CS2 (CSD0) */ + ldr r0, [r1, #0x7C] + bic r0, r0, #(1 << 22) + str r0, [r1, #0x7C] + + /* DQM3 */ + ldr r0, [r1, #0x84] + bic r0, r0, #(1 << 22) + str r0, [r1, #0x84] + + /* DQM2, DQM1, DQM0, SD31-SD0, A25-A0, MA10 (0x288..0x2DC) */ + ldr r2, =22 /* (0x2E0 - 0x288) / 4 = 22 */ +pad_loop: + ldr r0, [r1, #0x88] + bic r0, r0, #(1 << 22) + bic r0, r0, #(1 << 12) + bic r0, r0, #(1 << 2) + str r0, [r1, #0x88] + add r1, r1, #4 + subs r2, r2, #0x1 + bne pad_loop +.endm /* init_drive_strength */ + + +/* initialize PLL */ +.macro init_pll + /* + * Switch on Display Interface because of the change of the clock + * divider. According to the description of PDR0[HSP_PODF] in the + * processor reference manual the CCM waits for an ackn. of the IPU. + */ + REG IPU_CONF, IPU_CONF_DI_EN + + /* Clock Control Module: */ + REG CCM_CCMR, 0x074B0BF5 /* Use CKIH, MCU PLL off */ + DELAY 0x40000 + REG CCM_CCMR, 0x074B0BF5 | CCMR_MPE /* MCU PLL on */ + REG CCM_CCMR, (0x074B0BF5 | CCMR_MPE) & ~CCMR_MDS /* Switch to MCU PLL */ + +#if defined CONFIG_MX31_CPU_399_MHZ + /* Platform clocks */ + REG CCM_PDR0, PDR0_CSI_PODF(0x1ff) /* camera sensor interface */ \ + | PDR0_PER_PODF(6-1) /* periph. if derived from USB clock */ \ + | PDR0_HSP_PODF(3-1) /* IPU 133 MHz */ \ + | PDR0_NFC_PODF(7-1) /* NAND FC 19 MHz */ \ + | PDR0_IPG_PODF(2-1) /* peripherals 66.5 MHz */ \ + | PDR0_MAX_PODF(3-1) /* AHB 133 MHz */ \ + | PDR0_MCU_PODF(1-1) /* core 399 MHz */ + /* MCU PLL */ + REG CCM_MPCTL, PLL_PD(1-1) | PLL_MFD(52-1) | PLL_MFI(7) | PLL_MFN(35) +#elif defined CONFIG_MX31_CPU_532_MHZ + /* Platform clocks */ + REG CCM_PDR0, PDR0_CSI_PODF(0x1ff) /* camera sensor interface */ \ + | PDR0_PER_PODF(8-1) /* periph. if derived from USB clock */ \ + | PDR0_HSP_PODF(4-1) /* IPU 133 MHz */ \ + | PDR0_NFC_PODF(7-1) /* NAND FC 19 MHz */ \ + | PDR0_IPG_PODF(2-1) /* peripherals 66.5 MHz */ \ + | PDR0_MAX_PODF(4-1) /* AHB 133 MHz */ \ + | PDR0_MCU_PODF(1-1) /* core 532 MHz */ + /* MCU PLL */ + REG CCM_MPCTL, PLL_PD(1-1) | PLL_MFD(52-1) | PLL_MFI(10) | PLL_MFN(12) +#else +#error Please define CPU core frequency (CONFIG_CPU_399_MHZ or CONFIG_CPU_532_MHZ)! +#endif /* CONFIG_CPU_xxx_MHZ */ + + /* Serial PLL. Default: 1, 4, 12, 1 */ + REG CCM_SPCTL, PLL_PD(2-1) | PLL_MFD(5-1) | PLL_MFI(12) | PLL_MFN(1) +.endm /* init_pll */ + + +/* setup SDRAM on CSD0 */ +.macro init_sdram + /* + * Enhanced SDRAM Miscellaneous Register + * Latency Hiding Enable + * LPDDR delay line measure unit is enabled + * LPDDR Delay Line is not reset + * Enable Mobile DDR SDRAM operation + * Soft Reset is disabled + */ + REG ESDMISC, 0x00000004 + + /* + * Enhanced SDRAM Configuration Register 0 + * tXP 4 clock delay before new COMMAND issued to LPDDR + * tWTR tLPDDR WRITE to READ Command Delay = 2 clock + * tRP SDRAM Row Precharge Delay = 3 clock + * tMRD SDRAM Load Mode Register to ACTIVE Command = 3 clock + * tWR SDRAM WRITE to PRECHARGE Command = 3 clock + * tRAS SDRAM ACTIVE to PRECHARGE Command = 6 clock + * tRRD ACTIVE Bank A to ACTIVE Bank B Command = 2 clock + * tCAS CAS Latency = 3 clock + * tRCD SDRAM Row to Column Delay = 3 clock + * tRC SDRAM Row Cycle Delay = 13 clocks + */ + REG ESDCFG0, 0x006ac73c + + /* + * Enhanced SDRAM Control Register 0 + * Enhanced SDRAM Controller Enable = 1 + * SDRAM Controller Operating Mode = 001 Precharge Command + * Supervisor Protect = 0 User mode accesses are allowed to this + * chip select region + * ROW Row Address Width. = 011 14 Row Addresses + * COL Column Address Width = 01 9 Col Addresses + * DSIZ SDRAM Memory Data Width = 00 00 16-bit memory width + * aligned to D[31:16] + * SREFR SDRAM Refresh Rate = 000 Refresh Disabled + * (bit field reset value) + * PWDT Power Down = 00 Disabled (bit field reset value) Run Mode + * FP Full Page = 0 0 Burst Length of the external memory device + * is not set to Full Page + * BL Burst Length = 0 + * PRCT Precharge Timer 000000 Disabled (Bit field reset value) + */ + REG ESDCTL0, 0x92200000 + REG 0x80000f00, 0x12344321 + + + /* + * Enhanced SDRAM Control Register 0 + * Enhanced SDRAM Controller Enable = 1 + * SDRAM Controller Operating Mode = 010 Auto-Refresh Command + * Supervisor Protect = 0 User mode accesses are allowed to this + * chip select region + * ROW Row Address Width. = 011 14 Row Addresses + * COL Column Address Width = 01 9 Col Addresses + * DSIZ SDRAM Memory Data Width = 00 00 16-bit memory width + * aligned to D[31:16] + * SREFR SDRAM Refresh Rate = 000 Refresh Disabled + * (bit field reset value) + * PWDT Power Down = 00 Disabled (bit field reset value) Run Mode + * FP Full Page = 0 0 Burst Length of the external memory device + * is not set to Full Page + * BL Burst Length = 0 + * PRCT Precharge Timer 000000 Disabled (Bit field reset value) + */ + REG ESDCTL0, 0xa2200000 + REG 0x80000000, 0x12344321 + REG 0x80000000, 0x12344321 + + /* + * Enhanced SDRAM Control Register 0 + * Enhanced SDRAM Controller Enable = 1 + * SDRAM Controller Operating Mode = 001 Precharge Command + * Supervisor Protect = 0 User mode accesses are allowed to this + * chip select region + * ROW Row Address Width. = 011 14 Row Addresses + * COL Column Address Width = 01 9 Col Addresses + * DSIZ SDRAM Memory Data Width = 00 00 16-bit memory width + * aligned to D[31:16] + * SREFR SDRAM Refresh Rate = 000 Refresh Disabled + * (bit field reset value) + * PWDT Power Down = 00 Disabled (bit field reset value) Run Mode + * FP Full Page = 0 0 Burst Length of the external memory device + * is not set to Full Page. + * BL Burst Length = 0 + * PRCT Precharge Timer 000000 Disabled (Bit field reset value) + */ + REG ESDCTL0, 0xb2200000 + REG8 0x80000033, 0xda + REG8 0x81000000, 0xff + + /* + * Enhanced SDRAM Control Register 0 + * Enhanced SDRAM Controller Enable = 1 + * SDRAM Controller Operating Mode = 000 Normal Read/Write + * Supervisor Protect = 0 User mode accesses are allowed to this + * chip select region + * ROW Row Address Width. = 011 14 Row Addresses + * COL Column Address Width = 10 10 Col Addresses + * DSIZ SDRAM Memory Data Width = 10 32-bit memory width + * SREFR SDRAM Refresh Rate = 011 Refresh 7,81 microseconds + * PWDT Power Down = 00 Disabled (bit field reset value) Run Mode + * FP Full Page = 0 0 Burst Length of the external memory device + * is not set to Full Page + * BL Burst Length = 8 + * PRCT Precharge Timer 000000 Disabled (Bit field reset value) + */ + REG ESDCTL0, 0x83226080 + REG 0x80000000, 0xDEADBEEF + + /* + * Enhanced SDRAM Miscellaneous Register + * Latency Hiding Enable + * LPDDR delay line measure unit is enabled + * LPDDR Delay Line is reset + * Enable Mobile DDR SDRAM operation + * Soft Reset is disabled + */ + REG ESDMISC, 0x0000000c +.endm /* init_sdram */ + + +.globl lowlevel_init +lowlevel_init: + init_aips + + init_max + + init_m3if + + init_drive_strength + + init_pll + + init_sdram + + mov pc, lr diff --git a/board/tqc/tqma31/tqma31.c b/board/tqc/tqma31/tqma31.c new file mode 100644 index 0000000..e0d0975 --- /dev/null +++ b/board/tqc/tqma31/tqma31.c @@ -0,0 +1,89 @@ +/* + * Copyright (C) 2008, Jens Gehrlein sew_s@tqs.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/mx31.h> +#include <asm/arch/mx31-regs.h> + +DECLARE_GLOBAL_DATA_PTR; + +static void setup_chipselects (void) +{ + /* NOR Flash on CS0 */ + __REG (CSCR_U(0)) = CSCR_U_CNC_3 | CSCR_U_WSC_12 | CSCR_U_EDC_4; + __REG (CSCR_A(0)) = CSCR_A_RWA_2 | CSCR_A_RWN_2 | CSCR_A_LBN_2_MUM0; + __REG (CSCR_L(0)) = CSCR_L_OEA_10 | CSCR_L_EBWA_3 | CSCR_L_EBWN_3 \ + | CSCR_L_EBC_ONLY_WA | CSCR_L_DSZ_16_MUM0 | CSCR_L_CSEN; + + /* Ethernet controller on CS4 */ + __REG (CSCR_U(4)) = CSCR_U_CNC_1 | CSCR_U_WSC_22 | CSCR_U_EDC_4; + __REG (CSCR_A(4)) = CSCR_A_RWA_2 | CSCR_A_RWN_15; + __REG (CSCR_L(4)) = CSCR_L_OEA_2 | CSCR_L_OEN_15 | CSCR_L_CSN_15 \ + | CSCR_L_DSZ_16_MUM0 | CSCR_L_CSEN; +} + +static void setup_iomux (void) +{ + /* Pins for UART1 */ + mx31_gpio_mux (MUX_RXD1__UART1_RXD_MUX); + mx31_gpio_mux (MUX_TXD1__UART1_TXD_MUX); + mx31_gpio_mux (MUX_RTS1__UART1_RTS_B); + mx31_gpio_mux (MUX_CTS1__UART1_CTS_B); +} + +int dram_init (void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + + return 0; +} + +int board_init (void) +{ + /* WEIM burst clock runs all the time */ + __REG (WCR) = WCR_BCM_1; + + setup_chipselects (); + setup_iomux (); + + /* Machine type ID for ARM linux */ + gd->bd->bi_arch_number = MACH_TYPE_TQMA31; + + /* Address of boot parameters */ + gd->bd->bi_boot_params = 0x80000100; + + /* + * Tell other U-Boot entities: relocation done. For instance, needed + * to enable command line history. + */ + gd->flags |= GD_FLG_RELOC; + + return 0; +} + +int checkboard (void) +{ + printf ("Board: TQMA31\n"); + return 0; +} diff --git a/board/tqc/tqma31/u-boot.lds b/board/tqc/tqma31/u-boot.lds new file mode 100644 index 0000000..6b1c06a --- /dev/null +++ b/board/tqc/tqma31/u-boot.lds @@ -0,0 +1,72 @@ +/* + * Copyright (C) 2008, Jens Gehrlein sew_s@tqs.de + * + * January 2004 - Changed to support H4 device + * Copyright (c) 2004 Texas Instruments + * + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, gj@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + /* WARNING - the following is hand-optimized to fit within */ + /* the sector layout of our flash chips! XXX FIXME XXX */ + + cpu/arm1136/start.o (.text) + board/tqc/tqma31/libtqma31.a (.text) + lib_arm/libarm.a (.text) + net/libnet.a (.text) + drivers/mtd/libmtd.a (.text) + + . = DEFINED(env_offset) ? env_offset : .; + common/environment.o(.text) + + *(.text) + } + + . = ALIGN(4); + .rodata : { *(.rodata) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss : { *(.bss) } + _end = .; +} diff --git a/include/asm-arm/arch-mx31/mx31-regs.h b/include/asm-arm/arch-mx31/mx31-regs.h index abe61f0..ea15108 100644 --- a/include/asm-arm/arch-mx31/mx31-regs.h +++ b/include/asm-arm/arch-mx31/mx31-regs.h @@ -61,11 +61,53 @@ #define PLL_MFI(x) (((x) & 0xf) << 10) #define PLL_MFN(x) (((x) & 0x3ff) << 0)
+#define ESDCTL_BASE 0xB8001000 +#define ESDCTL0 (ESDCTL_BASE + 0x00) +#define ESDCFG0 (ESDCTL_BASE + 0x04) +#define ESDCTL1 (ESDCTL_BASE + 0x08) +#define ESDCFG1 (ESDCTL_BASE + 0x0C) +#define ESDMISC (ESDCTL_BASE + 0x10) +#define ESDCDLY1 (ESDCTL_BASE + 0x20) +#define ESDCDLY2 (ESDCTL_BASE + 0x24) +#define ESDCDLY3 (ESDCTL_BASE + 0x28) +#define ESDCDLY4 (ESDCTL_BASE + 0x2C) +#define ESDCDLY5 (ESDCTL_BASE + 0x30) +#define ESDCDLYL (ESDCTL_BASE + 0x34) + #define WEIM_BASE 0xb8002000 #define CSCR_U(x) (WEIM_BASE + (x) * 0x10) #define CSCR_L(x) (WEIM_BASE + 4 + (x) * 0x10) #define CSCR_A(x) (WEIM_BASE + 8 + (x) * 0x10)
+#define CSCR_U_CNC_1 0x00004000 +#define CSCR_U_CNC_3 0x0000C000 +#define CSCR_U_WSC_9 0x00000900 +#define CSCR_U_WSC_12 0x00000C00 +#define CSCR_U_WSC_22 0x00001600 +#define CSCR_U_EDC_4 0x00000004 +#define CSCR_U_EDC_13 0x0000000D + +#define CSCR_L_OEA_2 0x20000000 +#define CSCR_L_OEA_4 0x40000000 +#define CSCR_L_OEA_10 0xA0000000 +#define CSCR_L_OEN_15 0x0F000000 +#define CSCR_L_EBWA_3 0x00300000 +#define CSCR_L_EBWN_3 0x00030000 +#define CSCR_L_CSA_4 0x00004000 +#define CSCR_L_CSN_15 0x000000F0 +#define CSCR_L_EBC_ONLY_WA 0x00000800 +#define CSCR_L_DSZ_16_MUM0 0x00000500 +#define CSCR_L_CSEN 0x00000001 + +#define CSCR_A_RWA_2 0x00200000 +#define CSCR_A_RWN_2 0x00020000 +#define CSCR_A_RWN_15 0x000F0000 +#define CSCR_A_LBN_2_MUM0 0x00000800 + +#define WCR (WEIM_BASE + 0x60) +#define WCR_BCM_1 0x00000004 +#define WCR_BCM_0 0x00000000 + #define IOMUXC_BASE 0x43FAC000 #define IOMUXC_GPR (IOMUXC_BASE + 0x8) #define IOMUXC_SW_MUX_CTL(x) (IOMUXC_BASE + 0xc + (x) * 4) diff --git a/include/asm-arm/mach-types.h b/include/asm-arm/mach-types.h index aaf2ea2..e44027a 100644 --- a/include/asm-arm/mach-types.h +++ b/include/asm-arm/mach-types.h @@ -1595,6 +1595,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_P300 1602 #define MACH_TYPE_XDACOMET 1603 #define MACH_TYPE_DEXFLEX2 1604 +#define MACH_TYPE_TQMA31 1810
#ifdef CONFIG_ARCH_EBSA110 # ifdef machine_arch_type @@ -20592,6 +20593,18 @@ extern unsigned int __machine_arch_type; # define machine_is_dexflex2() (0) #endif
+#ifdef CONFIG_MACH_TQMA31 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_TQMA31 +# endif +# define machine_is_tqma31() (machine_arch_type == MACH_TYPE_TQMA31) +#else +# define machine_is_tqma31() (0) +#endif + /* * These have not yet been registered */ diff --git a/include/configs/TQMA31.h b/include/configs/TQMA31.h new file mode 100644 index 0000000..de2e355 --- /dev/null +++ b/include/configs/TQMA31.h @@ -0,0 +1,266 @@ +/* + * Copyright (C) 2008, Jens Gehrlein sew_s@tqs.de + * + * Configuration settings for the TQMA31 board. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/******************************************************************************* + * CPU + ******************************************************************************/ + +#include <asm/arch/mx31-regs.h> + +/* This is an ARM1136 core */ +#define CONFIG_ARM1136 1 + +/* in an i.MX31 processor */ +#define CONFIG_MX31 1 + +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +/* Enable passing of ATAGs */ +#define CONFIG_CMDLINE_TAG 1 +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 + + +/******************************************************************************* + * Clocks + ******************************************************************************/ + + /* Frequency on CKIH in Hz. This is the MCU PLL input clock on TQMA31. */ +#define CONFIG_MX31_HCLK_FREQ 26000000 + +/* Desired CPU core frequency (see PLL settings in lowlevel_init.S) */ +#define CONFIG_MX31_CPU_399_MHZ +#undef CONFIG_MX31_CPU_532_MHZ + +/* Timer tick */ +#define CFG_HZ 32768 + +/* + * Alternative clock input for MCU PLL. + * Unused on TQMA31, but must be defined to avoid compiler errors. + */ +#define CONFIG_MX31_CLK32 32000 + + +/******************************************************************************* + * RAM + ******************************************************************************/ + +#define CONFIG_NR_DRAM_BANKS 1 + +/* + * PHYS_SDRAM_1 and PHYS_SDRAM_1_SIZE are passed to the Linux kernel. + * The size can be overridden by the kernel boot parameter "mem=". + */ +#define PHYS_SDRAM_1 CSD0_BASE +#define PHYS_SDRAM_1_SIZE (256 * 1024 * 1024) + +/* Default values for command mtest */ +#define CFG_MEMTEST_START PHYS_SDRAM_1 +#define CFG_MEMTEST_END (PHYS_SDRAM_1_SIZE - 0x100000) + + +/******************************************************************************* + * NOR-Flash + ******************************************************************************/ + +#define CFG_FLASH_BASE CS0_BASE + +/* Max number of memory banks */ +#define CFG_MAX_FLASH_BANKS 4 + +/* + * Bank start addresses. + * 4 x 32 MiB is the maximum for user and U-Boot code. Please adapt the list + * as well as CFG_MAX_FLASH_BANKS to your TQM. Also consider dual die chips + * or single die chips, e.g. one dual die chip represents two banks. + */ +#define CFG_FLASH_BANKS_LIST {CFG_FLASH_BASE, \ + CFG_FLASH_BASE + 32 * 1024 * 1024, \ + CFG_FLASH_BASE + 64 * 1024 * 1024, \ + CFG_FLASH_BASE + 96 * 1024 * 1024} + +/* Max number of sectors on one chip */ +#define CFG_MAX_FLASH_SECT 259 + +/* Monitor at beginning of flash */ +#define CFG_MONITOR_BASE CFG_FLASH_BASE + +/* Reserved flash space for U-Boot image in bytes */ +#define CFG_MONITOR_LEN (128 * 1024) + +/* Flash memory is CFI compliant */ +#define CFG_FLASH_CFI 1 + +/* Use drivers/cfi_flash.c */ +#define CFG_FLASH_CFI_DRIVER 1 + +/* Use buffered writes (~10x faster) */ +#define CFG_FLASH_USE_BUFFER_WRITE 1 + +/* Use hardware sector protection */ +#define CFG_FLASH_PROTECTION 1 + + +/******************************************************************************* + * Serial + ******************************************************************************/ + +/* Configure processor internal UART */ +#define CONFIG_MX31_UART 1 + +/* Configure UART1 */ +#define CFG_MX31_UART1 1 + +/* Use UART1 for console */ +#define CONFIG_CONS_INDEX 1 + +/* Default baudrate */ +#define CONFIG_BAUDRATE 115200 + +/* Possible baudrates */ +#define CFG_BAUDRATE_TABLE {9600, 19200, 38400, 57600, 115200} + + +/******************************************************************************* + * Ethernet + ******************************************************************************/ + +#define CONFIG_DRIVER_SMC911X 1 +#define CONFIG_DRIVER_SMC911X_32_BIT 1 +#define CONFIG_DRIVER_SMC911X_BASE CS4_BASE + + +/******************************************************************************* + * Commands + ******************************************************************************/ + +#include <config_cmd_default.h> + +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP + + +/******************************************************************************* + * Environment + ******************************************************************************/ + +#define CONFIG_BOOTDELAY 4 + +/* + * Default value for env. variable "loadaddr". + * Don't use arithmetic here, because it will be converted + * into a string (see common/environment.c) + */ +#define CONFIG_LOADADDR 0x80800000 + +/* Default load address */ +#define CFG_LOAD_ADDR CONFIG_LOADADDR + +/* Allow to modify environment variables "serial#" and "ethaddr" */ +#define CONFIG_ENV_OVERWRITE + +#define CFG_ENV_IS_IN_FLASH 1 +#define CFG_ENV_OFFSET 0x20000 +#define CFG_ENV_ADDR (CFG_FLASH_BASE + CFG_ENV_OFFSET) +#define CFG_ENV_SECT_SIZE 0x20000 +#define CFG_ENV_SIZE CFG_ENV_SECT_SIZE + +/* Address and size of redundant environment sector */ +#define CFG_ENV_OFFSET_REDUND (CFG_ENV_OFFSET + CFG_ENV_SECT_SIZE) +#define CFG_ENV_SIZE_REDUND CFG_ENV_SECT_SIZE + +/* + * Kernel parameter "jtag=on" is Freescale-specific extension of the + * mx31ads BSP. Use it to enable serial console output in Linux. + */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "netdev=eth0\0" \ + "hostname=tqma31\0" \ + "uboot_addr=0xa0000000\0" \ + "uboot=tqma31/u-boot.bin\0" \ + "kernel=tqma31/uImage\0" \ + "nfsroot=/opt/eldk/arm\0" \ + "bootargs_base=setenv bootargs " \ + "jtag=on " \ + "console=ttymxc0,115200\0" \ + "bootargs_nfs=setenv bootargs ${bootargs} " \ + "root=/dev/nfs rw " \ + "ip=${ipaddr}:${serverip}:${gatewayip}:" \ + "${netmask}:${hostname}:${netdev}:off " \ + "panic=1 " \ + "nfsroot=${serverip}:${nfsroot}\0" \ + "bootcmd=run bootcmd_net\0" \ + "bootcmd_net=run bootargs_base bootargs_nfs; " \ + "tftpboot ${loadaddr} ${kernel}; bootm\0" \ + "prg_uboot=tftpboot ${loadaddr} ${uboot}; " \ + "protect off ${uboot_addr} 0xa001ffff; " \ + "erase ${uboot_addr} 0xa001ffff; " \ + "cp.b ${loadaddr} ${uboot_addr} ${filesize}; " \ + "setenv filesize; saveenv\0" + + +/******************************************************************************* + * JFFS2 partitions + ******************************************************************************/ + +#undef CONFIG_JFFS2_CMDLINE +#define CONFIG_JFFS2_DEV "nor0" + + +/******************************************************************************* + * Miscellaneous + ******************************************************************************/ + +/* Total available space for malloc in bytes */ +#define CFG_MALLOC_LEN (CFG_ENV_SIZE + 128 * 1024) + +/* Regular stack size in bytes */ +#define CONFIG_STACKSIZE (128 * 1024) + +/* Size in bytes reserved for initial global data */ +#define CFG_GBL_DATA_SIZE 128 + +/* Console I/O buffer size in bytes */ +#define CFG_CBSIZE 256 + +/* Print buffer size in bytes */ +#define CFG_PBSIZE (CFG_CBSIZE + sizeof(CFG_PROMPT) + 16) + +/* Max number of command arguments */ +#define CFG_MAXARGS 16 + +/* Boot argument buffer size in bytes */ +#define CFG_BARGSIZE CFG_CBSIZE + +#define CFG_LONGHELP +#define CFG_PROMPT "=> " + +/* Add command line history and command line edit possibility */ +#define CONFIG_CMDLINE_EDITING + +#define CONFIG_ARP_TIMEOUT 200UL + +#endif /* __CONFIG_H */
CFG_HZ shall be always 1000.
Jens Gehrlein
