[U-Boot] [PATCH] powerpc/t1024rdb: Add support for T1024RDB-PB
T1024RDB-PB board adds 2.5G SGMII support with AQR105 PHY. rcw_0x095 is used for 10G XFI + 3x PCIex1 rcw_0x135 is used for 2.5G SGMII + 2x PCIex1
Signed-off-by: Shengzhou Liu Shengzhou.Liu@freescale.com --- based on u-boot-fsl-qoriq.git, master branch
board/freescale/t102xrdb/cpld.h | 4 ++++ board/freescale/t102xrdb/eth_t102xrdb.c | 30 +++++++++++++++++++++++++++--- board/freescale/t102xrdb/t102xrdb.c | 31 ++++++++++++++++++++++++++++++- include/configs/T102xRDB.h | 2 ++ 4 files changed, 63 insertions(+), 4 deletions(-)
diff --git a/board/freescale/t102xrdb/cpld.h b/board/freescale/t102xrdb/cpld.h index 5a3100f..db50f81 100644 --- a/board/freescale/t102xrdb/cpld.h +++ b/board/freescale/t102xrdb/cpld.h @@ -43,3 +43,7 @@ void cpld_write(unsigned int reg, u8 value); #define CPLD_LBMAP_RESET 0xFF #define CPLD_LBMAP_SHIFT 0x03 #define CPLD_BOOT_SEL 0x80 + +#define CPLD_PCIE_SGMII_MUX 0x80 +#define CPLD_OVERRIDE_BOOT_EN 0x01 +#define CPLD_OVERRIDE_MUX_EN 0x02 /* PCIE/2.5G-SGMII mux override enable */ diff --git a/board/freescale/t102xrdb/eth_t102xrdb.c b/board/freescale/t102xrdb/eth_t102xrdb.c index 2e400c4..f611ff0 100644 --- a/board/freescale/t102xrdb/eth_t102xrdb.c +++ b/board/freescale/t102xrdb/eth_t102xrdb.c @@ -21,6 +21,7 @@ #include <phy.h> #include <asm/fsl_dtsec.h> #include <asm/fsl_serdes.h> +#include "../common/fman.h"
int board_eth_init(bd_t *bis) { @@ -51,15 +52,22 @@ int board_eth_init(bd_t *bis) /* Register the 10G MDIO bus */ fm_memac_mdio_init(bis, &tgec_mdio_info);
- /* Set the two on-board RGMII PHY address */ - fm_info_set_phy_address(FM1_DTSEC3, RGMII_PHY2_ADDR); + /* Set the on-board RGMII PHY address */ fm_info_set_phy_address(FM1_DTSEC4, RGMII_PHY1_ADDR);
switch (srds_s1) { case 0x95: - /* 10G XFI with Aquantia PHY */ + /* set the on-board RGMII2 PHY */ + fm_info_set_phy_address(FM1_DTSEC3, RGMII_PHY2_ADDR); + + /* set 10G XFI with Aquantia AQR105 PHY */ fm_info_set_phy_address(FM1_10GEC1, FM1_10GEC1_PHY_ADDR); break; + case 0x77: + case 0x135: + /* set the on-board 2.5G SGMII AQR105 PHY */ + fm_info_set_phy_address(FM1_DTSEC3, SGMII_PHY1_ADDR); + break; default: printf("SerDes protocol 0x%x is not supported on T102xRDB\n", srds_s1); @@ -73,6 +81,10 @@ int board_eth_init(bd_t *bis) dev = miiphy_get_dev_by_name(DEFAULT_FM_MDIO_NAME); fm_info_set_mdio(i, dev); break; + case PHY_INTERFACE_MODE_SGMII_2500: + dev = miiphy_get_dev_by_name(DEFAULT_FM_TGEC_MDIO_NAME); + fm_info_set_mdio(i, dev); + break; default: break; } @@ -95,6 +107,18 @@ int board_eth_init(bd_t *bis) return pci_eth_init(bis); }
+void board_ft_fman_fixup_port(void *fdt, char *compat, phys_addr_t addr, + enum fm_port port, int offset) +{ + if ((fm_info_get_enet_if(port) == PHY_INTERFACE_MODE_SGMII_2500) && + (port == FM1_DTSEC3)) { + fdt_set_phy_handle(fdt, compat, addr, "sg_2500_aqr105_phy4"); + fdt_setprop(fdt, offset, "phy-connection-type", + "sgmii-2500", 10); + fdt_status_disabled_by_alias(fdt, "xg_aqr105_phy3"); + } +} + void fdt_fixup_board_enet(void *fdt) { } diff --git a/board/freescale/t102xrdb/t102xrdb.c b/board/freescale/t102xrdb/t102xrdb.c index f5c438d..9676577 100644 --- a/board/freescale/t102xrdb/t102xrdb.c +++ b/board/freescale/t102xrdb/t102xrdb.c @@ -27,6 +27,11 @@ int checkboard(void) { struct cpu_type *cpu = gd->arch.cpu; static const char *freq[3] = {"100.00MHZ", "125.00MHz", "156.25MHZ"}; + ccsr_gur_t __iomem *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + u32 srds_s1; + + srds_s1 = in_be32(&gur->rcwsr[4]) & FSL_CORENET2_RCWSR4_SRDS1_PRTCL; + srds_s1 >>= FSL_CORENET2_RCWSR4_SRDS1_PRTCL_SHIFT;
printf("Board: %sRDB, ", cpu->name); printf("Board rev: 0x%02x CPLD ver: 0x%02x, boot from ", @@ -50,11 +55,34 @@ int checkboard(void) #endif
puts("SERDES Reference Clocks:\n"); - printf("SD1_CLK1=%s, SD1_CLK2=%s\n", freq[2], freq[0]); + if (srds_s1 == 0x95) + printf("SD1_CLK1=%s, SD1_CLK2=%s\n", freq[2], freq[0]); + else + printf("SD1_CLK1=%s, SD1_CLK2=%s\n", freq[0], freq[0]);
return 0; }
+static void board_mux_lane(void) +{ + ccsr_gur_t __iomem *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + u32 srds_prtcl_s1; + u8 reg = CPLD_READ(misc_ctl_status); + + srds_prtcl_s1 = in_be32(&gur->rcwsr[4]) & + FSL_CORENET2_RCWSR4_SRDS1_PRTCL; + srds_prtcl_s1 >>= FSL_CORENET2_RCWSR4_SRDS1_PRTCL_SHIFT; + + if (srds_prtcl_s1 == 0x95) { + /* Route Lane B to PCIE */ + CPLD_WRITE(misc_ctl_status, reg & ~CPLD_PCIE_SGMII_MUX); + } else { + /* Route Lane B to SGMII */ + CPLD_WRITE(misc_ctl_status, reg | CPLD_PCIE_SGMII_MUX); + } + CPLD_WRITE(boot_override, CPLD_OVERRIDE_MUX_EN); +} + int board_early_init_r(void) { #ifdef CONFIG_SYS_FLASH_BASE @@ -86,6 +114,7 @@ int board_early_init_r(void) #ifdef CONFIG_SYS_DPAA_QBMAN setup_portals(); #endif + board_mux_lane();
return 0; } diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index 6f1fcd6..9e71836 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -743,8 +743,10 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_FMAN_ENET #define CONFIG_PHYLIB_10G #define CONFIG_PHY_REALTEK +#define CONFIG_PHY_AQUANTIA #define RGMII_PHY1_ADDR 0x2 #define RGMII_PHY2_ADDR 0x6 +#define SGMII_PHY1_ADDR 0x2 #define FM1_10GEC1_PHY_ADDR 0x1 #endif
Applied to u-boot-mpc85xx master branch, awaiting upstream.
York
Shengzhou Liu
York Sun
