[U-Boot] [PATCH 3/5] mx6sl: Select MX6SL option via Kconfig
Currently the MX6SL option is selected via CONFIG_SYS_EXTRA_OPTIONS, but it is better to select it directly via Kconfig.
Signed-off-by: Breno Lima breno.lima@nxp.com --- arch/arm/mach-imx/mx6/Kconfig | 2 ++ configs/mx6slevk_defconfig | 2 +- configs/mx6slevk_spinor_defconfig | 2 +- configs/mx6slevk_spl_defconfig | 2 +- configs/warp_defconfig | 2 +- 5 files changed, 6 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-imx/mx6/Kconfig b/arch/arm/mach-imx/mx6/Kconfig index bee7eab..4f8bb8f 100644 --- a/arch/arm/mach-imx/mx6/Kconfig +++ b/arch/arm/mach-imx/mx6/Kconfig @@ -244,6 +244,7 @@ config TARGET_MX6SABRESD
config TARGET_MX6SLEVK bool "mx6slevk" + select MX6SL select SUPPORT_SPL
config TARGET_MX6SLLEVK @@ -395,6 +396,7 @@ config TARGET_WANDBOARD
config TARGET_WARP bool "WaRP" + select MX6SL select BOARD_LATE_INIT
config TARGET_XPRESS diff --git a/configs/mx6slevk_defconfig b/configs/mx6slevk_defconfig index 7b1ddac..aafddfa 100644 --- a/configs/mx6slevk_defconfig +++ b/configs/mx6slevk_defconfig @@ -3,7 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SLEVK=y # CONFIG_CMD_BMODE is not set CONFIG_DEFAULT_DEVICE_TREE="imx6sl-evk" -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6slevk/imximage.cfg,MX6SL" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6slevk/imximage.cfg" CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y diff --git a/configs/mx6slevk_spinor_defconfig b/configs/mx6slevk_spinor_defconfig index 4b9c04e..0d3cb59 100644 --- a/configs/mx6slevk_spinor_defconfig +++ b/configs/mx6slevk_spinor_defconfig @@ -3,7 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SLEVK=y # CONFIG_CMD_BMODE is not set CONFIG_DEFAULT_DEVICE_TREE="imx6sl-evk" -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6slevk/imximage.cfg,MX6SL" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6slevk/imximage.cfg" CONFIG_SPI_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y diff --git a/configs/mx6slevk_spl_defconfig b/configs/mx6slevk_spl_defconfig index 05a5c9e..0dbd308 100644 --- a/configs/mx6slevk_spl_defconfig +++ b/configs/mx6slevk_spl_defconfig @@ -10,7 +10,7 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y # CONFIG_CMD_BMODE is not set CONFIG_DEFAULT_DEVICE_TREE="imx6sl-evk" -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg,MX6SL" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y diff --git a/configs/warp_defconfig b/configs/warp_defconfig index 5e7eef0..2ac1c6c 100644 --- a/configs/warp_defconfig +++ b/configs/warp_defconfig @@ -2,7 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_WARP=y # CONFIG_CMD_BMODE is not set -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/warp/imximage.cfg,MX6SL" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/warp/imximage.cfg" CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y
Reviewed-by: Fabio Estevam fabio.estevam@nxp.com
-----Original Message----- From: Breno Lima [mailto:brenomatheus@gmail.com] Sent: Tuesday, November 28, 2017 7:06 AM To: Fabio Estevam fabio.estevam@nxp.com; sbabic@denx.de Cc: otavio@ossystems.com.br; Peng Fan peng.fan@nxp.com; u- boot@lists.denx.de; Breno Matheus Lima breno.lima@nxp.com Subject: [PATCH 3/5] mx6sl: Select MX6SL option via Kconfig
diff --git a/arch/arm/mach-imx/mx6/Kconfig b/arch/arm/mach- imx/mx6/Kconfig index bee7eab..4f8bb8f 100644 --- a/arch/arm/mach-imx/mx6/Kconfig +++ b/arch/arm/mach-imx/mx6/Kconfig @@ -244,6 +244,7 @@ config TARGET_MX6SABRESD
- select MX6SL select SUPPORT_SPL
- select MX6SL select BOARD_LATE_INIT
CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6slevk/imx image.cfg,MX6SL" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6slevk/im ximage.cfg" CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y diff --git a/configs/mx6slevk_spinor_defconfig b/configs/mx6slevk_spinor_defconfig index 4b9c04e..0d3cb59 100644 --- a/configs/mx6slevk_spinor_defconfig +++ b/configs/mx6slevk_spinor_defconfig @@ -3,7 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SLEVK=y # CONFIG_CMD_BMODE is not set CONFIG_DEFAULT_DEVICE_TREE="imx6sl-evk"
CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6slevk/imx image.cfg,MX6SL" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6slevk/im ximage.cfg" CONFIG_SPI_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y diff --git a/configs/mx6slevk_spl_defconfig b/configs/mx6slevk_spl_defconfig index 05a5c9e..0dbd308 100644 --- a/configs/mx6slevk_spl_defconfig +++ b/configs/mx6slevk_spl_defconfig @@ -10,7 +10,7 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y # CONFIG_CMD_BMODE is not set CONFIG_DEFAULT_DEVICE_TREE="imx6sl-evk" -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach- imx/spl_sd.cfg,MX6SL" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach- imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y diff --git a/configs/warp_defconfig b/configs/warp_defconfig index 5e7eef0..2ac1c6c 100644 --- a/configs/warp_defconfig +++ b/configs/warp_defconfig @@ -2,7 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_WARP=y # CONFIG_CMD_BMODE is not set
CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/warp/imximage.cfg,MX 6SL" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/warp/imximage.cfg"
Reviewed-by: Peng Fan peng.fan@nxp.com
CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y -- 2.7.4
Best regards, Stefano Babic
Breno Lima
Fabio Estevam
Peng Fan
Stefano Babic
