[U-Boot] [PATCH 0/7] TF-A Boot support for NXP Chassis 3 platforms
Includes changes in u-boot framework to support TF-A for NXP Chassis 3 platforms. A new defconfig is added namely ls*_tfa_defconfig which will be used for all boot sources when TF-A is used.
Also, provide fixes for TF-A Boot NXP Chassis 2 platforms.
Pankit Garg (3): ls1043a: add support for nand-boot cmd for TFA armv8: ls1088ardb: Add TFABOOT support armv8: ls1088aqds: Add TFABOOT support
Rajesh Bhagat (4): armv8: fsl-layerscape: fixes for TFABOOT framework drivers: ifc: restore the legacy flow for IFC config armv8: ls2088ardb: Add TFABOOT support armv8: ls2088aqds: Add TFABOOT support
arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 26 +-- arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 2 +- arch/arm/cpu/armv8/fsl-layerscape/soc.c | 13 +- arch/arm/dts/fsl-ls2088a-rdb-qspi.dts | 4 + board/freescale/ls1088a/MAINTAINERS | 4 + board/freescale/ls1088a/ddr.c | 11 ++ board/freescale/ls1088a/ls1088a.c | 193 +++++++++++++++++++ board/freescale/ls2080a/ls2080a.c | 7 + board/freescale/ls2080aqds/MAINTAINERS | 2 + board/freescale/ls2080aqds/ddr.c | 12 ++ board/freescale/ls2080ardb/MAINTAINERS | 2 + board/freescale/ls2080ardb/ddr.c | 12 ++ board/freescale/ls2080ardb/ls2080ardb.c | 37 ++++ configs/ls1088aqds_tfa_defconfig | 69 +++++++ configs/ls1088ardb_tfa_SECURE_BOOT_defconfig | 64 ++++++ configs/ls1088ardb_tfa_defconfig | 61 ++++++ configs/ls2088aqds_tfa_defconfig | 63 ++++++ configs/ls2088ardb_tfa_SECURE_BOOT_defconfig | 74 +++++++ configs/ls2088ardb_tfa_defconfig | 72 +++++++ drivers/misc/fsl_ifc.c | 173 +++++++++++++++++ include/configs/ls1043a_common.h | 2 + include/configs/ls1088a_common.h | 11 +- include/configs/ls1088aqds.h | 99 +++++++++- include/configs/ls1088ardb.h | 137 ++++++++++++- include/configs/ls2080a_common.h | 8 + include/configs/ls2080aqds.h | 40 +++- include/configs/ls2080ardb.h | 137 ++++++++++++- 27 files changed, 1310 insertions(+), 25 deletions(-) create mode 100644 configs/ls1088aqds_tfa_defconfig create mode 100644 configs/ls1088ardb_tfa_SECURE_BOOT_defconfig create mode 100644 configs/ls1088ardb_tfa_defconfig create mode 100644 configs/ls2088aqds_tfa_defconfig create mode 100644 configs/ls2088ardb_tfa_SECURE_BOOT_defconfig create mode 100644 configs/ls2088ardb_tfa_defconfig
Fixes for TFABOOT framework - update eMMC bootsrc to SD_MMC - Increase buffer size for mcinitcmd from 256 to 512 - Fix mcinitcmd and bootcmd for Secure Boot
Signed-off-by: Pankit Garg pankit.garg@nxp.com Signed-off-by: Rajesh Bhagat rajesh.bhagat@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 2 +- arch/arm/cpu/armv8/fsl-layerscape/soc.c | 13 ++++++++++++- 2 files changed, 13 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index 1fc025b581..81babd1fb4 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -675,7 +675,7 @@ enum boot_src __get_boot_src(u32 porsr1) break; case RCW_SRC_EMMC_VAL: /* RCW SRC EMMC */ - src = BOOT_SOURCE_SD_MMC2; + src = BOOT_SOURCE_SD_MMC; break; case RCW_SRC_I2C1_VAL: /* RCW SRC I2C1 Extended */ diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index 0092a22394..06f3edb302 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -684,7 +684,7 @@ int qspi_ahb_init(void) #endif
#ifdef CONFIG_TFABOOT -#define MAX_BOOTCMD_SIZE 256 +#define MAX_BOOTCMD_SIZE 512
int fsl_setenv_bootcmd(void) { @@ -812,6 +812,17 @@ int board_late_init(void) fsl_setenv_bootcmd(); fsl_setenv_mcinitcmd(); } + + /* + * If the boot mode is secure, default environment is not present then + * setenv command needs to be run by default + */ +#ifdef CONFIG_CHAIN_OF_TRUST + if ((fsl_check_boot_mode_secure() == 1)) { + fsl_setenv_bootcmd(); + fsl_setenv_mcinitcmd(); + } +#endif #endif #ifdef CONFIG_QSPI_AHB_INIT qspi_ahb_init();
This set has been applied to fsl-qoriq master, awaiting upstream. Thanks.
York
Restore the legacy flow along with TFABOOT flow for IFC configuration.
Signed-off-by: Pankit Garg pankit.garg@nxp.com Signed-off-by: Rajesh Bhagat rajesh.bhagat@nxp.com --- drivers/misc/fsl_ifc.c | 173 +++++++++++++++++++++++++++++++++++++++++ 1 file changed, 173 insertions(+)
diff --git a/drivers/misc/fsl_ifc.c b/drivers/misc/fsl_ifc.c index 0c3394f2a8..0dbf304487 100644 --- a/drivers/misc/fsl_ifc.c +++ b/drivers/misc/fsl_ifc.c @@ -7,6 +7,7 @@ #include <common.h> #include <fsl_ifc.h>
+#ifdef CONFIG_TFABOOT struct ifc_regs ifc_cfg_default_boot[CONFIG_SYS_FSL_IFC_BANK_COUNT] = { { "cs0", @@ -340,6 +341,7 @@ __weak void ifc_cfg_boot_info(struct ifc_regs_info *regs_info) regs_info->regs = ifc_cfg_default_boot; regs_info->cs_size = CONFIG_SYS_FSL_IFC_BANK_COUNT; } +#endif
void print_ifc_regs(void) { @@ -355,6 +357,7 @@ void print_ifc_regs(void) } }
+#ifdef CONFIG_TFABOOT void init_early_memctl_regs(void) { int i, j; @@ -405,3 +408,173 @@ void init_final_memctl_regs(void) regs[i].amask); } } +#else +void init_early_memctl_regs(void) +{ +#if defined(CONFIG_SYS_CSPR0) && defined(CONFIG_SYS_CSOR0) + set_ifc_ftim(IFC_CS0, IFC_FTIM0, CONFIG_SYS_CS0_FTIM0); + set_ifc_ftim(IFC_CS0, IFC_FTIM1, CONFIG_SYS_CS0_FTIM1); + set_ifc_ftim(IFC_CS0, IFC_FTIM2, CONFIG_SYS_CS0_FTIM2); + set_ifc_ftim(IFC_CS0, IFC_FTIM3, CONFIG_SYS_CS0_FTIM3); + +#ifndef CONFIG_A003399_NOR_WORKAROUND +#ifdef CONFIG_SYS_CSPR0_EXT + set_ifc_cspr_ext(IFC_CS0, CONFIG_SYS_CSPR0_EXT); +#endif +#ifdef CONFIG_SYS_CSOR0_EXT + set_ifc_csor_ext(IFC_CS0, CONFIG_SYS_CSOR0_EXT); +#endif + set_ifc_cspr(IFC_CS0, CONFIG_SYS_CSPR0); + set_ifc_amask(IFC_CS0, CONFIG_SYS_AMASK0); + set_ifc_csor(IFC_CS0, CONFIG_SYS_CSOR0); +#endif +#endif + +#ifdef CONFIG_SYS_CSPR1_EXT + set_ifc_cspr_ext(IFC_CS1, CONFIG_SYS_CSPR1_EXT); +#endif +#ifdef CONFIG_SYS_CSOR1_EXT + set_ifc_csor_ext(IFC_CS1, CONFIG_SYS_CSOR1_EXT); +#endif +#if defined(CONFIG_SYS_CSPR1) && defined(CONFIG_SYS_CSOR1) + set_ifc_ftim(IFC_CS1, IFC_FTIM0, CONFIG_SYS_CS1_FTIM0); + set_ifc_ftim(IFC_CS1, IFC_FTIM1, CONFIG_SYS_CS1_FTIM1); + set_ifc_ftim(IFC_CS1, IFC_FTIM2, CONFIG_SYS_CS1_FTIM2); + set_ifc_ftim(IFC_CS1, IFC_FTIM3, CONFIG_SYS_CS1_FTIM3); + + set_ifc_csor(IFC_CS1, CONFIG_SYS_CSOR1); + set_ifc_amask(IFC_CS1, CONFIG_SYS_AMASK1); + set_ifc_cspr(IFC_CS1, CONFIG_SYS_CSPR1); +#endif + +#ifdef CONFIG_SYS_CSPR2_EXT + set_ifc_cspr_ext(IFC_CS2, CONFIG_SYS_CSPR2_EXT); +#endif +#ifdef CONFIG_SYS_CSOR2_EXT + set_ifc_csor_ext(IFC_CS2, CONFIG_SYS_CSOR2_EXT); +#endif +#if defined(CONFIG_SYS_CSPR2) && defined(CONFIG_SYS_CSOR2) + set_ifc_ftim(IFC_CS2, IFC_FTIM0, CONFIG_SYS_CS2_FTIM0); + set_ifc_ftim(IFC_CS2, IFC_FTIM1, CONFIG_SYS_CS2_FTIM1); + set_ifc_ftim(IFC_CS2, IFC_FTIM2, CONFIG_SYS_CS2_FTIM2); + set_ifc_ftim(IFC_CS2, IFC_FTIM3, CONFIG_SYS_CS2_FTIM3); + + set_ifc_csor(IFC_CS2, CONFIG_SYS_CSOR2); + set_ifc_amask(IFC_CS2, CONFIG_SYS_AMASK2); + set_ifc_cspr(IFC_CS2, CONFIG_SYS_CSPR2); +#endif + +#ifdef CONFIG_SYS_CSPR3_EXT + set_ifc_cspr_ext(IFC_CS3, CONFIG_SYS_CSPR3_EXT); +#endif +#ifdef CONFIG_SYS_CSOR3_EXT + set_ifc_csor_ext(IFC_CS3, CONFIG_SYS_CSOR3_EXT); +#endif +#if defined(CONFIG_SYS_CSPR3) && defined(CONFIG_SYS_CSOR3) + set_ifc_ftim(IFC_CS3, IFC_FTIM0, CONFIG_SYS_CS3_FTIM0); + set_ifc_ftim(IFC_CS3, IFC_FTIM1, CONFIG_SYS_CS3_FTIM1); + set_ifc_ftim(IFC_CS3, IFC_FTIM2, CONFIG_SYS_CS3_FTIM2); + set_ifc_ftim(IFC_CS3, IFC_FTIM3, CONFIG_SYS_CS3_FTIM3); + + set_ifc_cspr(IFC_CS3, CONFIG_SYS_CSPR3); + set_ifc_amask(IFC_CS3, CONFIG_SYS_AMASK3); + set_ifc_csor(IFC_CS3, CONFIG_SYS_CSOR3); +#endif + +#ifdef CONFIG_SYS_CSPR4_EXT + set_ifc_cspr_ext(IFC_CS4, CONFIG_SYS_CSPR4_EXT); +#endif +#ifdef CONFIG_SYS_CSOR4_EXT + set_ifc_csor_ext(IFC_CS4, CONFIG_SYS_CSOR4_EXT); +#endif +#if defined(CONFIG_SYS_CSPR4) && defined(CONFIG_SYS_CSOR4) + set_ifc_ftim(IFC_CS4, IFC_FTIM0, CONFIG_SYS_CS4_FTIM0); + set_ifc_ftim(IFC_CS4, IFC_FTIM1, CONFIG_SYS_CS4_FTIM1); + set_ifc_ftim(IFC_CS4, IFC_FTIM2, CONFIG_SYS_CS4_FTIM2); + set_ifc_ftim(IFC_CS4, IFC_FTIM3, CONFIG_SYS_CS4_FTIM3); + + set_ifc_cspr(IFC_CS4, CONFIG_SYS_CSPR4); + set_ifc_amask(IFC_CS4, CONFIG_SYS_AMASK4); + set_ifc_csor(IFC_CS4, CONFIG_SYS_CSOR4); +#endif + +#ifdef CONFIG_SYS_CSPR5_EXT + set_ifc_cspr_ext(IFC_CS5, CONFIG_SYS_CSPR5_EXT); +#endif +#ifdef CONFIG_SYS_CSOR5_EXT + set_ifc_csor_ext(IFC_CS5, CONFIG_SYS_CSOR5_EXT); +#endif +#if defined(CONFIG_SYS_CSPR5) && defined(CONFIG_SYS_CSOR5) + set_ifc_ftim(IFC_CS5, IFC_FTIM0, CONFIG_SYS_CS5_FTIM0); + set_ifc_ftim(IFC_CS5, IFC_FTIM1, CONFIG_SYS_CS5_FTIM1); + set_ifc_ftim(IFC_CS5, IFC_FTIM2, CONFIG_SYS_CS5_FTIM2); + set_ifc_ftim(IFC_CS5, IFC_FTIM3, CONFIG_SYS_CS5_FTIM3); + + set_ifc_cspr(IFC_CS5, CONFIG_SYS_CSPR5); + set_ifc_amask(IFC_CS5, CONFIG_SYS_AMASK5); + set_ifc_csor(IFC_CS5, CONFIG_SYS_CSOR5); +#endif + +#ifdef CONFIG_SYS_CSPR6_EXT + set_ifc_cspr_ext(IFC_CS6, CONFIG_SYS_CSPR6_EXT); +#endif +#ifdef CONFIG_SYS_CSOR6_EXT + set_ifc_csor_ext(IFC_CS6, CONFIG_SYS_CSOR6_EXT); +#endif +#if defined(CONFIG_SYS_CSPR6) && defined(CONFIG_SYS_CSOR6) + set_ifc_ftim(IFC_CS6, IFC_FTIM0, CONFIG_SYS_CS6_FTIM0); + set_ifc_ftim(IFC_CS6, IFC_FTIM1, CONFIG_SYS_CS6_FTIM1); + set_ifc_ftim(IFC_CS6, IFC_FTIM2, CONFIG_SYS_CS6_FTIM2); + set_ifc_ftim(IFC_CS6, IFC_FTIM3, CONFIG_SYS_CS6_FTIM3); + + set_ifc_cspr(IFC_CS6, CONFIG_SYS_CSPR6); + set_ifc_amask(IFC_CS6, CONFIG_SYS_AMASK6); + set_ifc_csor(IFC_CS6, CONFIG_SYS_CSOR6); +#endif + +#ifdef CONFIG_SYS_CSPR7_EXT + set_ifc_cspr_ext(IFC_CS7, CONFIG_SYS_CSPR7_EXT); +#endif +#ifdef CONFIG_SYS_CSOR7_EXT + set_ifc_csor_ext(IFC_CS7, CONFIG_SYS_CSOR7_EXT); +#endif +#if defined(CONFIG_SYS_CSPR7) && defined(CONFIG_SYS_CSOR7) + set_ifc_ftim(IFC_CS7, IFC_FTIM0, CONFIG_SYS_CS7_FTIM0); + set_ifc_ftim(IFC_CS7, IFC_FTIM1, CONFIG_SYS_CS7_FTIM1); + set_ifc_ftim(IFC_CS7, IFC_FTIM2, CONFIG_SYS_CS7_FTIM2); + set_ifc_ftim(IFC_CS7, IFC_FTIM3, CONFIG_SYS_CS7_FTIM3); + + set_ifc_cspr(IFC_CS7, CONFIG_SYS_CSPR7); + set_ifc_amask(IFC_CS7, CONFIG_SYS_AMASK7); + set_ifc_csor(IFC_CS7, CONFIG_SYS_CSOR7); +#endif +} + +void init_final_memctl_regs(void) +{ +#ifdef CONFIG_SYS_CSPR0_FINAL + set_ifc_cspr(IFC_CS0, CONFIG_SYS_CSPR0_FINAL); +#endif +#ifdef CONFIG_SYS_AMASK0_FINAL + set_ifc_amask(IFC_CS0, CONFIG_SYS_AMASK0); +#endif +#ifdef CONFIG_SYS_CSPR1_FINAL + set_ifc_cspr(IFC_CS1, CONFIG_SYS_CSPR1_FINAL); +#endif +#ifdef CONFIG_SYS_AMASK1_FINAL + set_ifc_amask(IFC_CS1, CONFIG_SYS_AMASK1_FINAL); +#endif +#ifdef CONFIG_SYS_CSPR2_FINAL + set_ifc_cspr(IFC_CS2, CONFIG_SYS_CSPR2_FINAL); +#endif +#ifdef CONFIG_SYS_AMASK2_FINAL + set_ifc_amask(IFC_CS2, CONFIG_SYS_AMASK2); +#endif +#ifdef CONFIG_SYS_CSPR3_FINAL + set_ifc_cspr(IFC_CS3, CONFIG_SYS_CSPR3_FINAL); +#endif +#ifdef CONFIG_SYS_AMASK3_FINAL + set_ifc_amask(IFC_CS3, CONFIG_SYS_AMASK3); +#endif +} +#endif
-----Original Message----- From: York Sun Sent: Friday, January 18, 2019 2:43 AM To: Rajesh Bhagat rajesh.bhagat@nxp.com; u-boot@lists.denx.de Cc: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Pankit Garg pankit.garg@nxp.com Subject: Re: [PATCH 2/7] drivers: ifc: restore the legacy flow for IFC config
What's the reason to go back to old flow?
Hi York,
IFC configuration was made dynamic instead of static in previous patch in TF-A and non TF-A mode. Though dynamic configuration works fine for all the platforms in TF-A mode, it is broken for non TF-A mode on some of the platforms like ls1021atwr, ls1021aqds, ls1043ardb and ls1046aqds.
This patch adds the static configuration back for non TF-A mode to support above platforms.
Regards, Rajesh Bhagat
York
Signed-off-by: Pankit Garg pankit.garg@nxp.com --- include/configs/ls1043a_common.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index 27350dfa00..49b014181e 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -323,6 +323,8 @@ "env exists secureboot && esbc_halt;" #define IFC_NOR_BOOTCOMMAND "run distro_bootcmd; run nor_bootcmd; " \ "env exists secureboot && esbc_halt;" +#define IFC_NAND_BOOTCOMMAND "run distro_bootcmd; run nand_bootcmd; " \ + "env exists secureboot && esbc_halt;" #else #if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) #define CONFIG_BOOTCOMMAND "run distro_bootcmd; run qspi_bootcmd; " \
TFABOOT support includes: - ls1088ardb_tfa_defconfig to be loaded by trusted firmware - environment address and size changes for TFABOOT - MC address changes for TFABOOT - define BOOTCOMMAND for TFABOOT - ifc chip select changes for TFABOOT
Signed-off-by: Rajesh Bhagat rajesh.bhagat@nxp.com Signed-off-by: Pankit Garg pankit.garg@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 12 +- board/freescale/ls1088a/MAINTAINERS | 4 + board/freescale/ls1088a/ddr.c | 11 ++ board/freescale/ls1088a/ls1088a.c | 78 +++++++++++ configs/ls1088ardb_tfa_SECURE_BOOT_defconfig | 64 +++++++++ configs/ls1088ardb_tfa_defconfig | 61 +++++++++ include/configs/ls1088a_common.h | 11 +- include/configs/ls1088ardb.h | 137 ++++++++++++++++++- 8 files changed, 367 insertions(+), 11 deletions(-) create mode 100644 configs/ls1088ardb_tfa_SECURE_BOOT_defconfig create mode 100644 configs/ls1088ardb_tfa_defconfig
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index 2b086da79b..4e6a3cb223 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -89,7 +89,7 @@ config ARCH_LS1046A config ARCH_LS1088A bool select ARMV8_SET_SMPEN - select ARM_ERRATA_855873 + select ARM_ERRATA_855873 if !TFABOOT select FSL_LSCH3 select SYS_FSL_SRDS_1 select SYS_HAS_SERDES @@ -98,11 +98,11 @@ config ARCH_LS1088A select SYS_FSL_DDR_VER_50 select SYS_FSL_EC1 select SYS_FSL_EC2 - select SYS_FSL_ERRATUM_A009803 - select SYS_FSL_ERRATUM_A009942 - select SYS_FSL_ERRATUM_A010165 - select SYS_FSL_ERRATUM_A008511 - select SYS_FSL_ERRATUM_A008850 + select SYS_FSL_ERRATUM_A009803 if !TFABOOT + select SYS_FSL_ERRATUM_A009942 if !TFABOOT + select SYS_FSL_ERRATUM_A010165 if !TFABOOT + select SYS_FSL_ERRATUM_A008511 if !TFABOOT + select SYS_FSL_ERRATUM_A008850 if !TFABOOT select SYS_FSL_ERRATUM_A009007 select SYS_FSL_HAS_CCI400 select SYS_FSL_HAS_DDR4 diff --git a/board/freescale/ls1088a/MAINTAINERS b/board/freescale/ls1088a/MAINTAINERS index 4d804d9447..bca9969637 100644 --- a/board/freescale/ls1088a/MAINTAINERS +++ b/board/freescale/ls1088a/MAINTAINERS @@ -1,15 +1,18 @@ LS1088ARDB BOARD M: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com M: Ashish Kumar Ashish.Kumar@nxp.com +M: Rajesh Bhagat rajesh.bhagat@nxp.com S: Maintained F: board/freescale/ls1088a/ F: include/configs/ls1088ardb.h F: configs/ls1088ardb_qspi_defconfig F: configs/ls1088ardb_sdcard_qspi_defconfig +F: configs/ls1088ardb_tfa_defconfig
LS1088AQDS BOARD M: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com M: Ashish Kumar Ashish.Kumar@nxp.com +M: Rajesh Bhagat rajesh.bhagat@nxp.com S: Maintained F: board/freescale/ls1088a/ F: include/configs/ls1088aqds.h @@ -17,6 +20,7 @@ F: configs/ls1088aqds_qspi_defconfig F: configs/ls1088aqds_sdcard_qspi_defconfig F: configs/ls1088aqds_defconfig F: configs/ls1088aqds_sdcard_ifc_defconfig +F: configs/ls1088aqds_tfa_defconfig
LS1088AQDS_QSPI_SECURE_BOOT BOARD M: Udit Agarwal udit.agarwal@nxp.com diff --git a/board/freescale/ls1088a/ddr.c b/board/freescale/ls1088a/ddr.c index 78d573a845..c21a2ce059 100644 --- a/board/freescale/ls1088a/ddr.c +++ b/board/freescale/ls1088a/ddr.c @@ -111,7 +111,17 @@ found: DDR_CDR2_VREF_TRAIN_EN | DDR_CDR2_VREF_RANGE_2; }
+#ifdef CONFIG_TFABOOT +int fsl_initdram(void) +{ + gd->ram_size = tfa_get_dram_size(); + + if (!gd->ram_size) + gd->ram_size = fsl_ddr_sdram_size();
+ return 0; +} +#else int fsl_initdram(void) { puts("Initializing DDR....using SPD\n"); @@ -123,3 +133,4 @@ int fsl_initdram(void) #endif return 0; } +#endif /* CONFIG_TFABOOT */ diff --git a/board/freescale/ls1088a/ls1088a.c b/board/freescale/ls1088a/ls1088a.c index 1e2ad98c6e..f3018aa5da 100644 --- a/board/freescale/ls1088a/ls1088a.c +++ b/board/freescale/ls1088a/ls1088a.c @@ -88,6 +88,9 @@ int fixup_ls1088ardb_pb_banner(void *fdt) #if !defined(CONFIG_SPL_BUILD) int checkboard(void) { +#ifdef CONFIG_TFABOOT + enum boot_src src = get_boot_src(); +#endif char buf[64]; u8 sw; static const char *const freq[] = {"100", "125", "156.25", @@ -117,9 +120,14 @@ int checkboard(void) sw = QIXIS_READ(brdcfg[0]); sw = (sw & QIXIS_LBMAP_MASK) >> QIXIS_LBMAP_SHIFT;
+#ifdef CONFIG_TFABOOT + if (src == BOOT_SOURCE_SD_MMC) + puts("SD card\n"); +#else #ifdef CONFIG_SD_BOOT puts("SD card\n"); #endif +#endif /* CONFIG_TFABOOT */ switch (sw) { #ifdef CONFIG_TARGET_LS1088AQDS case 0: @@ -546,6 +554,10 @@ void fdt_fixup_board_enet(void *fdt) void fsl_fdt_fixup_flash(void *fdt) { int offset; +#ifdef CONFIG_TFABOOT + u32 __iomem *dcfg_ccsr = (u32 __iomem *)DCFG_BASE; + u32 val; +#endif
/* * IFC-NOR and QSPI are muxed on SoC. @@ -553,6 +565,37 @@ void fsl_fdt_fixup_flash(void *fdt) * disable QSPI node in dts in case QSPI is not enabled. */
+#ifdef CONFIG_TFABOOT + enum boot_src src = get_boot_src(); + bool disable_ifc = false; + + switch (src) { + case BOOT_SOURCE_IFC_NOR: + disable_ifc = false; + break; + case BOOT_SOURCE_QSPI_NOR: + disable_ifc = true; + break; + default: + val = in_le32(dcfg_ccsr + DCFG_RCWSR15 / 4); + if (DCFG_RCWSR15_IFCGRPABASE_QSPI == (val & (u32)0x3)) + disable_ifc = true; + break; + } + + if (disable_ifc) { + offset = fdt_path_offset(fdt, "/soc/ifc/nor"); + + if (offset < 0) + offset = fdt_path_offset(fdt, "/ifc/nor"); + } else { + offset = fdt_path_offset(fdt, "/soc/quadspi"); + + if (offset < 0) + offset = fdt_path_offset(fdt, "/quadspi"); + } + +#else #ifdef CONFIG_FSL_QSPI offset = fdt_path_offset(fdt, "/soc/ifc/nor");
@@ -563,6 +606,7 @@ void fsl_fdt_fixup_flash(void *fdt)
if (offset < 0) offset = fdt_path_offset(fdt, "/quadspi"); +#endif #endif if (offset < 0) return; @@ -613,3 +657,37 @@ int ft_board_setup(void *blob, bd_t *bd) } #endif #endif /* defined(CONFIG_SPL_BUILD) */ + +#ifdef CONFIG_TFABOOT +#ifdef CONFIG_MTD_NOR_FLASH +int is_flash_available(void) +{ + char *env_hwconfig = env_get("hwconfig"); + enum boot_src src = get_boot_src(); + int is_nor_flash_available = 1; + + switch (src) { + case BOOT_SOURCE_IFC_NOR: + is_nor_flash_available = 1; + break; + case BOOT_SOURCE_QSPI_NOR: + is_nor_flash_available = 0; + break; + /* + * In Case of SD boot,if qspi is defined in env_hwconfig + * disable nor flash probe. + */ + default: + if (hwconfig_f("qspi", env_hwconfig)) + is_nor_flash_available = 0; + break; + } + return is_nor_flash_available; +} +#endif + +void *env_sf_get_env_addr(void) +{ + return (void *)(CONFIG_SYS_FSL_QSPI_BASE + CONFIG_ENV_OFFSET); +} +#endif diff --git a/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig new file mode 100644 index 0000000000..ae177d3838 --- /dev/null +++ b/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig @@ -0,0 +1,64 @@ +CONFIG_ARM=y +CONFIG_TARGET_LS1088ARDB=y +CONFIG_SYS_TEXT_BASE=0x82000000 +CONFIG_TFABOOT=y +CONFIG_SECURE_BOOT=y +CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y +CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_QSPI_AHB_INIT=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_NR_DRAM_BANKS=2 +# CONFIG_SYS_MALLOC_F is not set +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4" +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 ramdisk_size=0x3000000 default_hugepagesz=2m hugepagesz=2m hugepages=256" +# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_MISC_INIT_R=y +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_MP=y +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1088a-rdb" +CONFIG_ENV_IS_NOWHERE=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +CONFIG_SCSI_AHCI=y +CONFIG_FSL_ESDHC=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_SPANSION=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_E1000=y +CONFIG_MII=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y +CONFIG_SYS_NS16550=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_FSL_DSPI=y +CONFIG_FSL_QSPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_DWC3=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_BLK=y +CONFIG_DM_MMC=y +CONFIG_RSA=y +CONFIG_SPL_RSA=y +CONFIG_RSA_SOFTWARE_EXP=y diff --git a/configs/ls1088ardb_tfa_defconfig b/configs/ls1088ardb_tfa_defconfig new file mode 100644 index 0000000000..3328af430d --- /dev/null +++ b/configs/ls1088ardb_tfa_defconfig @@ -0,0 +1,61 @@ +CONFIG_ARM=y +CONFIG_TARGET_LS1088ARDB=y +CONFIG_SYS_TEXT_BASE=0x82000000 +CONFIG_TFABOOT=y +CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y +CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_QSPI_AHB_INIT=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_NR_DRAM_BANKS=2 +# CONFIG_SYS_MALLOC_F is not set +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4" +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 ramdisk_size=0x3000000 default_hugepagesz=2m hugepagesz=2m hugepages=256" +# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_MISC_INIT_R=y +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_MP=y +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1088a-rdb" +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +CONFIG_SCSI_AHCI=y +CONFIG_FSL_ESDHC=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_FSL_SPI_ALIGNED_TXFIFO=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_E1000=y +CONFIG_MII=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y +CONFIG_SYS_NS16550=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_FSL_DSPI=y +CONFIG_FSL_QSPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_DWC3=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/include/configs/ls1088a_common.h b/include/configs/ls1088a_common.h index 743d0cf30f..95e6786e6c 100644 --- a/include/configs/ls1088a_common.h +++ b/include/configs/ls1088a_common.h @@ -29,16 +29,23 @@
#define LS1088ARDB_PB_BOARD 0x4A /* Link Definitions */ +#ifdef CONFIG_TFABOOT +#define CONFIG_SYS_INIT_SP_ADDR CONFIG_SYS_TEXT_BASE +#else #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_FSL_OCRAM_BASE + 0xfff0) +#endif
/* Link Definitions */ - +#ifdef CONFIG_TFABOOT +#define CONFIG_SYS_FSL_QSPI_BASE 0x20000000 +#else #ifdef CONFIG_QSPI_BOOT #define CONFIG_SYS_FSL_QSPI_BASE 0x20000000 #define CONFIG_ENV_OFFSET 0x300000 /* 3MB */ #define CONFIG_ENV_ADDR (CONFIG_SYS_FSL_QSPI_BASE + \ CONFIG_ENV_OFFSET) #endif +#endif
#define CONFIG_SKIP_LOWLEVEL_INIT
@@ -192,6 +199,7 @@ unsigned long long get_qixis_addr(void); "mcinitcmd=fsl_mc start mc 0x580a00000" \ " 0x580e00000 \0"
+#ifndef CONFIG_TFABOOT #if defined(CONFIG_QSPI_BOOT) #define CONFIG_BOOTCOMMAND "sf probe 0:0;" \ "sf read 0x80001000 0xd00000 0x100000;"\ @@ -208,6 +216,7 @@ unsigned long long get_qixis_addr(void); " cp.b $kernel_start $kernel_load" \ " $kernel_size && bootm $kernel_load" #endif +#endif /* CONFIG_TFABOOT */ #endif
/* Monitor Command Prompt */ diff --git a/include/configs/ls1088ardb.h b/include/configs/ls1088ardb.h index 5269bcd243..f52ea4d746 100644 --- a/include/configs/ls1088ardb.h +++ b/include/configs/ls1088ardb.h @@ -8,6 +8,15 @@
#include "ls1088a_common.h"
+#ifdef CONFIG_TFABOOT +#define CONFIG_SYS_MMC_ENV_DEV 0 + +#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ +#define CONFIG_ENV_OFFSET 0x500000 +#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + \ + CONFIG_ENV_OFFSET) +#define CONFIG_ENV_SECT_SIZE 0x40000 +#else #if defined(CONFIG_QSPI_BOOT) #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ #define CONFIG_ENV_SECT_SIZE 0x40000 @@ -21,8 +30,10 @@ #define CONFIG_ENV_SECT_SIZE 0x20000 #define CONFIG_ENV_SIZE 0x20000 #endif +#endif /* CONFIG_TFABOOT */
-#if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) +#if defined(CONFIG_TFABOOT) || \ + defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) #ifndef CONFIG_SPL_BUILD #define CONFIG_QIXIS_I2C_ACCESS #endif @@ -185,7 +196,8 @@ FTIM2_GPCM_TWP(0x3E)) #define SYS_FPGA_CS_FTIM3 0x0
-#if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) +#if defined(CONFIG_TFABOOT) || \ + defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) #define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT #define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR #define CONFIG_SYS_AMASK0 CONFIG_SYS_NAND_AMASK @@ -215,7 +227,6 @@ #define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NOR_FTIM3 #endif
- #define CONFIG_SYS_LS_MC_BOOT_TIMEOUT_MS 5000
#define I2C_MUX_CH_VOL_MONITOR 0xA @@ -274,7 +285,8 @@
#ifndef SPL_NO_QSPI /* QSPI device */ -#if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) +#if defined(CONFIG_TFABOOT) || \ + defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) #define FSL_QSPI_FLASH_SIZE (1 << 26) #define FSL_QSPI_FLASH_NUM 2 #endif @@ -294,6 +306,26 @@
#ifndef SPL_NO_ENV /* Initial environment variables */ +#ifdef CONFIG_TFABOOT +#define QSPI_MC_INIT_CMD \ + "sf probe 0:0;sf read 0x80000000 0xA00000 0x100000;" \ + "sf read 0x80100000 0xE00000 0x100000;" \ + "env exists secureboot && " \ + "sf read 0x80700000 0x700000 0x40000 && " \ + "sf read 0x80740000 0x740000 0x40000 && " \ + "esbc_validate 0x80700000 && " \ + "esbc_validate 0x80740000 ;" \ + "fsl_mc start mc 0x80000000 0x80100000\0" +#define SD_MC_INIT_CMD \ + "mmcinfo;mmc read 0x80000000 0x5000 0x800;" \ + "mmc read 0x80100000 0x7000 0x800;" \ + "env exists secureboot && " \ + "mmc read 0x80700000 0x3800 0x10 && " \ + "mmc read 0x80740000 0x3A00 0x10 && " \ + "esbc_validate 0x80700000 && " \ + "esbc_validate 0x80740000 ;" \ + "fsl_mc start mc 0x80000000 0x80100000\0" +#else #if defined(CONFIG_QSPI_BOOT) #define MC_INIT_CMD \ "mcinitcmd=sf probe 0:0;sf read 0x80000000 0xA00000 0x100000;" \ @@ -317,8 +349,84 @@ "fsl_mc start mc 0x80000000 0x80100000\0" \ "mcmemsize=0x70000000\0" #endif +#endif /* CONFIG_TFABOOT */
#undef CONFIG_EXTRA_ENV_SETTINGS +#ifdef CONFIG_TFABOOT +#define CONFIG_EXTRA_ENV_SETTINGS \ + "BOARD=ls1088ardb\0" \ + "hwconfig=fsl_ddr:bank_intlv=auto\0" \ + "ramdisk_addr=0x800000\0" \ + "ramdisk_size=0x2000000\0" \ + "fdt_high=0xa0000000\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "fdt_addr=0x64f00000\0" \ + "kernel_addr=0x1000000\0" \ + "kernel_addr_sd=0x8000\0" \ + "kernelhdr_addr_sd=0x4000\0" \ + "kernel_start=0x580100000\0" \ + "kernelheader_start=0x580800000\0" \ + "scriptaddr=0x80000000\0" \ + "scripthdraddr=0x80080000\0" \ + "fdtheader_addr_r=0x80100000\0" \ + "kernelheader_addr=0x800000\0" \ + "kernelheader_addr_r=0x80200000\0" \ + "kernel_addr_r=0x81000000\0" \ + "kernelheader_size=0x40000\0" \ + "fdt_addr_r=0x90000000\0" \ + "load_addr=0xa0000000\0" \ + "kernel_size=0x2800000\0" \ + "kernel_size_sd=0x14000\0" \ + "kernelhdr_size_sd=0x10\0" \ + QSPI_MC_INIT_CMD \ + "mcmemsize=0x70000000\0" \ + BOOTENV \ + "boot_scripts=ls1088ardb_boot.scr\0" \ + "boot_script_hdr=hdr_ls1088ardb_bs.out\0" \ + "scan_dev_for_boot_part=" \ + "part list ${devtype} ${devnum} devplist; " \ + "env exists devplist || setenv devplist 1; " \ + "for distro_bootpart in ${devplist}; do " \ + "if fstype ${devtype} " \ + "${devnum}:${distro_bootpart} " \ + "bootfstype; then " \ + "run scan_dev_for_boot; " \ + "fi; " \ + "done\0" \ + "scan_dev_for_boot=" \ + "echo Scanning ${devtype} " \ + "${devnum}:${distro_bootpart}...; " \ + "for prefix in ${boot_prefixes}; do " \ + "run scan_dev_for_scripts; " \ + "done;\0" \ + "boot_a_script=" \ + "load ${devtype} ${devnum}:${distro_bootpart} " \ + "${scriptaddr} ${prefix}${script}; " \ + "env exists secureboot && load ${devtype} " \ + "${devnum}:${distro_bootpart} " \ + "${scripthdraddr} ${prefix}${boot_script_hdr} " \ + "&& esbc_validate ${scripthdraddr};" \ + "source ${scriptaddr}\0" \ + "installer=load mmc 0:2 $load_addr " \ + "/flex_installer_arm64.itb; " \ + "env exists mcinitcmd && run mcinitcmd && " \ + "mmc read 0x80001000 0x6800 0x800;" \ + "fsl_mc lazyapply dpl 0x80001000;" \ + "bootm $load_addr#ls1088ardb\0" \ + "qspi_bootcmd=echo Trying load from qspi..;" \ + "sf probe && sf read $load_addr " \ + "$kernel_addr $kernel_size ; env exists secureboot " \ + "&& sf read $kernelheader_addr_r $kernelheader_addr " \ + "$kernelheader_size && esbc_validate ${kernelheader_addr_r}; "\ + "bootm $load_addr#$BOARD\0" \ + "sd_bootcmd=echo Trying load from sd card..;" \ + "mmcinfo; mmc read $load_addr " \ + "$kernel_addr_sd $kernel_size_sd ;" \ + "env exists secureboot && mmc read $kernelheader_addr_r "\ + "$kernelhdr_addr_sd $kernelhdr_size_sd " \ + " && esbc_validate ${kernelheader_addr_r};" \ + "bootm $load_addr#$BOARD\0" +#else #define CONFIG_EXTRA_ENV_SETTINGS \ "BOARD=ls1088ardb\0" \ "hwconfig=fsl_ddr:bank_intlv=auto\0" \ @@ -391,8 +499,28 @@ "$kernelhdr_addr_sd $kernelhdr_size_sd " \ " && esbc_validate ${kernelheader_addr_r};" \ "bootm $load_addr#$BOARD\0" +#endif /* CONFIG_TFABOOT */
#undef CONFIG_BOOTCOMMAND +#ifdef CONFIG_TFABOOT +#define QSPI_NOR_BOOTCOMMAND \ + "sf read 0x80001000 0xd00000 0x100000;" \ + "env exists mcinitcmd && env exists secureboot " \ + " && sf read 0x80780000 0x780000 0x100000 " \ + "&& esbc_validate 0x80780000;env exists mcinitcmd " \ + "&& fsl_mc lazyapply dpl 0x80001000;" \ + "run distro_bootcmd;run qspi_bootcmd;" \ + "env exists secureboot && esbc_halt;" +#define SD_BOOTCOMMAND \ + "env exists mcinitcmd && mmcinfo; " \ + "mmc read 0x80001000 0x6800 0x800; " \ + "env exists mcinitcmd && env exists secureboot " \ + " && mmc read 0x80780000 0x3C00 0x10 " \ + "&& esbc_validate 0x80780000;env exists mcinitcmd " \ + "&& fsl_mc lazyapply dpl 0x80001000;" \ + "run distro_bootcmd;run sd_bootcmd;" \ + "env exists secureboot && esbc_halt;" +#else #if defined(CONFIG_QSPI_BOOT) /* Try to boot an on-QSPI kernel first, then do normal distro boot */ #define CONFIG_BOOTCOMMAND \ @@ -416,6 +544,7 @@ "run distro_bootcmd;run sd_bootcmd;" \ "env exists secureboot && esbc_halt;" #endif +#endif /* CONFIG_TFABOOT */
/* MAC/PHY configuration */ #ifdef CONFIG_FSL_MC_ENET
TFABOOT support includes: - ls1088aqds_tfa_defconfig to be loaded by trusted firmware - environment address and size changes for TFABOOT - MC address changes for TFABOOT - define BOOTCOMMAND for TFABOOT - ifc chip select changes for TFABOOT
Signed-off-by: Rajesh Bhagat rajesh.bhagat@nxp.com Signed-off-by: Pankit Garg pankit.garg@nxp.com --- board/freescale/ls1088a/ls1088a.c | 115 ++++++++++++++++++++++++++++++ configs/ls1088aqds_tfa_defconfig | 69 ++++++++++++++++++ include/configs/ls1088aqds.h | 99 ++++++++++++++++++++++++- 3 files changed, 281 insertions(+), 2 deletions(-) create mode 100644 configs/ls1088aqds_tfa_defconfig
diff --git a/board/freescale/ls1088a/ls1088a.c b/board/freescale/ls1088a/ls1088a.c index f3018aa5da..35a7c34c60 100644 --- a/board/freescale/ls1088a/ls1088a.c +++ b/board/freescale/ls1088a/ls1088a.c @@ -28,6 +28,121 @@
DECLARE_GLOBAL_DATA_PTR;
+#ifdef CONFIG_TARGET_LS1088AQDS +#ifdef CONFIG_TFABOOT +struct ifc_regs ifc_cfg_ifc_nor_boot[CONFIG_SYS_FSL_IFC_BANK_COUNT] = { + { + "nor0", + CONFIG_SYS_NOR0_CSPR_EARLY, + CONFIG_SYS_NOR0_CSPR_EXT, + CONFIG_SYS_NOR_AMASK, + CONFIG_SYS_NOR_CSOR, + { + CONFIG_SYS_NOR_FTIM0, + CONFIG_SYS_NOR_FTIM1, + CONFIG_SYS_NOR_FTIM2, + CONFIG_SYS_NOR_FTIM3 + }, + 0, + CONFIG_SYS_NOR0_CSPR, + 0, + }, + { + "nor1", + CONFIG_SYS_NOR1_CSPR_EARLY, + CONFIG_SYS_NOR0_CSPR_EXT, + CONFIG_SYS_NOR_AMASK_EARLY, + CONFIG_SYS_NOR_CSOR, + { + CONFIG_SYS_NOR_FTIM0, + CONFIG_SYS_NOR_FTIM1, + CONFIG_SYS_NOR_FTIM2, + CONFIG_SYS_NOR_FTIM3 + }, + 0, + CONFIG_SYS_NOR1_CSPR, + CONFIG_SYS_NOR_AMASK, + }, + { + "nand", + CONFIG_SYS_NAND_CSPR, + CONFIG_SYS_NAND_CSPR_EXT, + CONFIG_SYS_NAND_AMASK, + CONFIG_SYS_NAND_CSOR, + { + CONFIG_SYS_NAND_FTIM0, + CONFIG_SYS_NAND_FTIM1, + CONFIG_SYS_NAND_FTIM2, + CONFIG_SYS_NAND_FTIM3 + }, + }, + { + "fpga", + CONFIG_SYS_FPGA_CSPR, + CONFIG_SYS_FPGA_CSPR_EXT, + SYS_FPGA_AMASK, + CONFIG_SYS_FPGA_CSOR, + { + SYS_FPGA_CS_FTIM0, + SYS_FPGA_CS_FTIM1, + SYS_FPGA_CS_FTIM2, + SYS_FPGA_CS_FTIM3 + }, + 0, + SYS_FPGA_CSPR_FINAL, + 0, + } +}; + +struct ifc_regs ifc_cfg_qspi_nor_boot[CONFIG_SYS_FSL_IFC_BANK_COUNT] = { + { + "nand", + CONFIG_SYS_NAND_CSPR, + CONFIG_SYS_NAND_CSPR_EXT, + CONFIG_SYS_NAND_AMASK, + CONFIG_SYS_NAND_CSOR, + { + CONFIG_SYS_NAND_FTIM0, + CONFIG_SYS_NAND_FTIM1, + CONFIG_SYS_NAND_FTIM2, + CONFIG_SYS_NAND_FTIM3 + }, + }, + { + "reserved", + }, + { + "fpga", + CONFIG_SYS_FPGA_CSPR, + CONFIG_SYS_FPGA_CSPR_EXT, + SYS_FPGA_AMASK, + CONFIG_SYS_FPGA_CSOR, + { + SYS_FPGA_CS_FTIM0, + SYS_FPGA_CS_FTIM1, + SYS_FPGA_CS_FTIM2, + SYS_FPGA_CS_FTIM3 + }, + 0, + SYS_FPGA_CSPR_FINAL, + 0, + } +}; + +void ifc_cfg_boot_info(struct ifc_regs_info *regs_info) +{ + enum boot_src src = get_boot_src(); + + if (src == BOOT_SOURCE_QSPI_NOR) + regs_info->regs = ifc_cfg_qspi_nor_boot; + else + regs_info->regs = ifc_cfg_ifc_nor_boot; + + regs_info->cs_size = CONFIG_SYS_FSL_IFC_BANK_COUNT; +} +#endif /* CONFIG_TFABOOT */ +#endif /* CONFIG_TARGET_LS1088AQDS */ + int board_early_init_f(void) { #if defined(CONFIG_SYS_I2C_EARLY_INIT) && defined(CONFIG_TARGET_LS1088AQDS) diff --git a/configs/ls1088aqds_tfa_defconfig b/configs/ls1088aqds_tfa_defconfig new file mode 100644 index 0000000000..08744dda2d --- /dev/null +++ b/configs/ls1088aqds_tfa_defconfig @@ -0,0 +1,69 @@ +CONFIG_ARM=y +CONFIG_TARGET_LS1088AQDS=y +CONFIG_SYS_TEXT_BASE=0x82000000 +CONFIG_TFABOOT=y +CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y +CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_QSPI_AHB_INIT=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_NR_DRAM_BANKS=2 +# CONFIG_SYS_MALLOC_F is not set +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4" +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 ramdisk_size=0x3000000 default_hugepagesz=2m hugepagesz=2m hugepages=256" +# CONFIG_USE_BOOTCOMMAND is not set +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_MP=y +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1088a-qds" +CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_IS_IN_NAND=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +CONFIG_SCSI_AHCI=y +CONFIG_FSL_ESDHC=y +CONFIG_MTD_NOR_FLASH=y +CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_CFI=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_FSL_SPI_ALIGNED_TXFIFO=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_E1000=y +CONFIG_MII=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y +CONFIG_SYS_NS16550=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_FSL_DSPI=y +CONFIG_FSL_QSPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_DWC3=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/include/configs/ls1088aqds.h b/include/configs/ls1088aqds.h index 829c5390cf..17d543d960 100644 --- a/include/configs/ls1088aqds.h +++ b/include/configs/ls1088aqds.h @@ -14,7 +14,15 @@ unsigned long get_board_sys_clk(void); unsigned long get_board_ddr_clk(void); #endif
+#define CONFIG_ENV_SIZE 0x20000 +#define CONFIG_ENV_OFFSET 0x500000 +#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + \ + CONFIG_ENV_OFFSET) +#define CONFIG_ENV_SECT_SIZE 0x40000 +#else #if defined(CONFIG_QSPI_BOOT) #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ #define CONFIG_ENV_SECT_SIZE 0x40000 @@ -27,6 +35,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_ENV_SECT_SIZE 0x20000 #define CONFIG_ENV_SIZE 0x20000 #endif +#endif
#if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) #define CONFIG_QIXIS_I2C_ACCESS @@ -209,6 +218,44 @@ unsigned long get_board_ddr_clk(void); FTIM2_GPCM_TWP(0x3E)) #define SYS_FPGA_CS_FTIM3 0x0
+#ifdef CONFIG_TFABOOT +#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NOR0_CSPR_EXT +#define CONFIG_SYS_CSPR0 CONFIG_SYS_NOR0_CSPR_EARLY +#define CONFIG_SYS_CSPR0_FINAL CONFIG_SYS_NOR0_CSPR +#define CONFIG_SYS_AMASK0 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR0 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NOR_FTIM3 +#define CONFIG_SYS_CSPR1_EXT CONFIG_SYS_NOR0_CSPR_EXT +#define CONFIG_SYS_CSPR1 CONFIG_SYS_NOR1_CSPR_EARLY +#define CONFIG_SYS_CSPR1_FINAL CONFIG_SYS_NOR1_CSPR +#define CONFIG_SYS_AMASK1 CONFIG_SYS_NOR_AMASK_EARLY +#define CONFIG_SYS_AMASK1_FINAL CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR1 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS1_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS1_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS1_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS1_FTIM3 CONFIG_SYS_NOR_FTIM3 +#define CONFIG_SYS_CSPR2_EXT CONFIG_SYS_NAND_CSPR_EXT +#define CONFIG_SYS_CSPR2 CONFIG_SYS_NAND_CSPR +#define CONFIG_SYS_AMASK2 CONFIG_SYS_NAND_AMASK +#define CONFIG_SYS_CSOR2 CONFIG_SYS_NAND_CSOR +#define CONFIG_SYS_CS2_FTIM0 CONFIG_SYS_NAND_FTIM0 +#define CONFIG_SYS_CS2_FTIM1 CONFIG_SYS_NAND_FTIM1 +#define CONFIG_SYS_CS2_FTIM2 CONFIG_SYS_NAND_FTIM2 +#define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_NAND_FTIM3 +#define CONFIG_SYS_CSPR3_EXT CONFIG_SYS_FPGA_CSPR_EXT +#define CONFIG_SYS_CSPR3 CONFIG_SYS_FPGA_CSPR +#define CONFIG_SYS_CSPR3_FINAL SYS_FPGA_CSPR_FINAL +#define CONFIG_SYS_AMASK3 SYS_FPGA_AMASK +#define CONFIG_SYS_CSOR3 CONFIG_SYS_FPGA_CSOR +#define CONFIG_SYS_CS3_FTIM0 SYS_FPGA_CS_FTIM0 +#define CONFIG_SYS_CS3_FTIM1 SYS_FPGA_CS_FTIM1 +#define CONFIG_SYS_CS3_FTIM2 SYS_FPGA_CS_FTIM2 +#define CONFIG_SYS_CS3_FTIM3 SYS_FPGA_CS_FTIM3 +#else #if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) #define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT #define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR @@ -265,6 +312,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_CS3_FTIM2 SYS_FPGA_CS_FTIM2 #define CONFIG_SYS_CS3_FTIM3 SYS_FPGA_CS_FTIM3 #endif +#endif
@@ -323,7 +371,8 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5
@@ -333,7 +382,8 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SPI_FLASH_STMICRO #define CONFIG_SPI_FLASH_SST #define CONFIG_SPI_FLASH_EON -#if !defined(CONFIG_QSPI_BOOT) && !defined(CONFIG_SD_BOOT_QSPI) +#if !defined(CONFIG_TFABOOT) && \ + !defined(CONFIG_QSPI_BOOT) && !defined(CONFIG_SD_BOOT_QSPI) #define CONFIG_SF_DEFAULT_BUS 1 #define CONFIG_SF_DEFAULT_CS 0 #endif @@ -377,6 +427,50 @@ unsigned long get_board_ddr_clk(void); "fsl_mc start mc 0xa0a00000 0xa0e00000\0" \ "mcmemsize=0x70000000 \0" #else /* if !(CONFIG_SECURE_BOOT) */ +#ifdef CONFIG_TFABOOT +#define QSPI_MC_INIT_CMD \ + "sf probe 0:0;sf read 0x80000000 0xA00000 0x100000;" \ + "sf read 0x80100000 0xE00000 0x100000;" \ + "fsl_mc start mc 0x80000000 0x80100000\0" +#define SD_MC_INIT_CMD \ + "mmcinfo;mmc read 0x80000000 0x5000 0x800;" \ + "mmc read 0x80100000 0x7000 0x800;" \ + "fsl_mc start mc 0x80000000 0x80100000\0" +#define IFC_MC_INIT_CMD \ + "fsl_mc start mc 0x580A00000 0x580E00000\0" + +#undef CONFIG_EXTRA_ENV_SETTINGS +#define CONFIG_EXTRA_ENV_SETTINGS \ + "hwconfig=fsl_ddr:bank_intlv=auto\0" \ + "loadaddr=0x90100000\0" \ + "kernel_addr=0x100000\0" \ + "kernel_addr_sd=0x800\0" \ + "ramdisk_addr=0x800000\0" \ + "ramdisk_size=0x2000000\0" \ + "fdt_high=0xa0000000\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "kernel_start=0x1000000\0" \ + "kernel_start_sd=0x8000\0" \ + "kernel_load=0xa0000000\0" \ + "kernel_size=0x2800000\0" \ + "kernel_size_sd=0x14000\0" \ + "mcinitcmd=sf probe 0:0;sf read 0x80000000 0xA00000 0x100000;" \ + "sf read 0x80100000 0xE00000 0x100000;" \ + "fsl_mc start mc 0x80000000 0x80100000\0" \ + "mcmemsize=0x70000000 \0" +#define QSPI_NOR_BOOTCOMMAND "sf probe 0:0;" \ + "sf read 0x80001000 0xd00000 0x100000;"\ + " fsl_mc lazyapply dpl 0x80001000 &&" \ + " sf read $kernel_load $kernel_start" \ + " $kernel_size && bootm $kernel_load" +#define SD_BOOTCOMMAND "mmcinfo;mmc read 0x80001000 0x6800 0x800;"\ + " fsl_mc lazyapply dpl 0x80001000 &&" \ + " mmc read $kernel_load $kernel_start_sd" \ + " $kernel_size_sd && bootm $kernel_load" +#define IFC_NOR_BOOTCOMMAND "fsl_mc lazyapply dpl 0x580d00000 &&" \ + " cp.b $kernel_start $kernel_load" \ + " $kernel_size && bootm $kernel_load" +#else #if defined(CONFIG_QSPI_BOOT) #undef CONFIG_EXTRA_ENV_SETTINGS #define CONFIG_EXTRA_ENV_SETTINGS \ @@ -427,6 +521,7 @@ unsigned long get_board_ddr_clk(void); "mcinitcmd=fsl_mc start mc 0x580A00000 0x580E00000\0" \ "mcmemsize=0x70000000 \0" #endif +#endif /* CONFIG_TFABOOT */ #endif /* CONFIG_SECURE_BOOT */
TFABOOT support includes: - ls2088ardb_tfa_defconfig to be loaded by trusted firmware - environment address and size changes for TFABOOT - define BOOTCOMMAND for TFABOOT - remove EL3 specific erratas for TFABOOT
Signed-off-by: Pankit Garg pankit.garg@nxp.com Signed-off-by: Ruchika Gupta ruchika.gupta@nxp.com Signed-off-by: Rajesh Bhagat rajesh.bhagat@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 14 +- arch/arm/dts/fsl-ls2088a-rdb-qspi.dts | 4 + board/freescale/ls2080a/ls2080a.c | 7 + board/freescale/ls2080ardb/MAINTAINERS | 2 + board/freescale/ls2080ardb/ddr.c | 12 ++ board/freescale/ls2080ardb/ls2080ardb.c | 37 +++++ configs/ls2088ardb_tfa_SECURE_BOOT_defconfig | 74 ++++++++++ configs/ls2088ardb_tfa_defconfig | 72 ++++++++++ include/configs/ls2080a_common.h | 8 ++ include/configs/ls2080ardb.h | 137 ++++++++++++++++++- 10 files changed, 359 insertions(+), 8 deletions(-) create mode 100644 configs/ls2088ardb_tfa_SECURE_BOOT_defconfig create mode 100644 configs/ls2088ardb_tfa_defconfig
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index 4e6a3cb223..01c5068ab6 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -145,20 +145,20 @@ config ARCH_LS2080A select SYS_FSL_SRDS_2 select FSL_TZASC_1 select FSL_TZASC_2 - select SYS_FSL_ERRATUM_A008336 - select SYS_FSL_ERRATUM_A008511 - select SYS_FSL_ERRATUM_A008514 + select SYS_FSL_ERRATUM_A008336 if !TFABOOT + select SYS_FSL_ERRATUM_A008511 if !TFABOOT + select SYS_FSL_ERRATUM_A008514 if !TFABOOT select SYS_FSL_ERRATUM_A008585 select SYS_FSL_ERRATUM_A008997 select SYS_FSL_ERRATUM_A009007 select SYS_FSL_ERRATUM_A009008 select SYS_FSL_ERRATUM_A009635 - select SYS_FSL_ERRATUM_A009663 + select SYS_FSL_ERRATUM_A009663 if !TFABOOT select SYS_FSL_ERRATUM_A009798 select SYS_FSL_ERRATUM_A009801 - select SYS_FSL_ERRATUM_A009803 - select SYS_FSL_ERRATUM_A009942 - select SYS_FSL_ERRATUM_A010165 + select SYS_FSL_ERRATUM_A009803 if !TFABOOT + select SYS_FSL_ERRATUM_A009942 if !TFABOOT + select SYS_FSL_ERRATUM_A010165 if !TFABOOT select SYS_FSL_ERRATUM_A009203 select ARCH_EARLY_INIT_R select BOARD_EARLY_INIT_F diff --git a/arch/arm/dts/fsl-ls2088a-rdb-qspi.dts b/arch/arm/dts/fsl-ls2088a-rdb-qspi.dts index c8bf9a01fe..b6d4f0f6af 100644 --- a/arch/arm/dts/fsl-ls2088a-rdb-qspi.dts +++ b/arch/arm/dts/fsl-ls2088a-rdb-qspi.dts @@ -56,3 +56,7 @@ reg = <1>; }; }; + +&sata { + status = "okay"; +}; diff --git a/board/freescale/ls2080a/ls2080a.c b/board/freescale/ls2080a/ls2080a.c index 698ae1f9a6..ad3596a8a1 100644 --- a/board/freescale/ls2080a/ls2080a.c +++ b/board/freescale/ls2080a/ls2080a.c @@ -142,3 +142,10 @@ void reset_phy(void) { } #endif + +#ifdef CONFIG_TFABOOT +void *env_sf_get_env_addr(void) +{ + return (void *)(CONFIG_SYS_FSL_QSPI_BASE1 + CONFIG_ENV_OFFSET); +} +#endif diff --git a/board/freescale/ls2080ardb/MAINTAINERS b/board/freescale/ls2080ardb/MAINTAINERS index bbe56e2052..1f6014deed 100644 --- a/board/freescale/ls2080ardb/MAINTAINERS +++ b/board/freescale/ls2080ardb/MAINTAINERS @@ -9,8 +9,10 @@ F: configs/ls2080ardb_nand_defconfig
LS2088A_QSPI-boot BOARD M: Priyanka Jain priyanka.jain@nxp.com +M: Rajesh Bhagat rajesh.bhagat@nxp.com S: Maintained F: configs/ls2088ardb_qspi_defconfig +F: configs/ls2088ardb_tfa_defconfig
LS2081ARDB BOARD M: Priyanka Jain priyanka.jain@nxp.com diff --git a/board/freescale/ls2080ardb/ddr.c b/board/freescale/ls2080ardb/ddr.c index 26eb14b812..72ce872c75 100644 --- a/board/freescale/ls2080ardb/ddr.c +++ b/board/freescale/ls2080ardb/ddr.c @@ -160,6 +160,17 @@ found: } }
+#ifdef CONFIG_TFABOOT +int fsl_initdram(void) +{ + gd->ram_size = tfa_get_dram_size(); + + if (!gd->ram_size) + gd->ram_size = fsl_ddr_sdram_size(); + + return 0; +} +#else int fsl_initdram(void) { #if defined(CONFIG_SPL) && !defined(CONFIG_SPL_BUILD) @@ -172,3 +183,4 @@ int fsl_initdram(void)
return 0; } +#endif /* CONFIG_TFABOOT */ diff --git a/board/freescale/ls2080ardb/ls2080ardb.c b/board/freescale/ls2080ardb/ls2080ardb.c index cf91bc30fb..20e1fce0fc 100644 --- a/board/freescale/ls2080ardb/ls2080ardb.c +++ b/board/freescale/ls2080ardb/ls2080ardb.c @@ -346,12 +346,47 @@ void board_quiesce_devices(void) void fsl_fdt_fixup_flash(void *fdt) { int offset; +#ifdef CONFIG_TFABOOT + u32 __iomem *dcfg_ccsr = (u32 __iomem *)DCFG_BASE; + u32 val; +#endif
/* * IFC and QSPI are muxed on board. * So disable IFC node in dts if QSPI is enabled or * disable QSPI node in dts in case QSPI is not enabled. */ +#ifdef CONFIG_TFABOOT + enum boot_src src = get_boot_src(); + bool disable_ifc = false; + + switch (src) { + case BOOT_SOURCE_IFC_NOR: + disable_ifc = false; + break; + case BOOT_SOURCE_QSPI_NOR: + disable_ifc = true; + break; + default: + val = in_le32(dcfg_ccsr + DCFG_RCWSR15 / 4); + if (DCFG_RCWSR15_IFCGRPABASE_QSPI == (val & (u32)0x3)) + disable_ifc = true; + break; + } + + if (disable_ifc) { + offset = fdt_path_offset(fdt, "/soc/ifc"); + + if (offset < 0) + offset = fdt_path_offset(fdt, "/ifc"); + } else { + offset = fdt_path_offset(fdt, "/soc/quadspi"); + + if (offset < 0) + offset = fdt_path_offset(fdt, "/quadspi"); + } + +#else #ifdef CONFIG_FSL_QSPI offset = fdt_path_offset(fdt, "/soc/ifc");
@@ -363,6 +398,8 @@ void fsl_fdt_fixup_flash(void *fdt) if (offset < 0) offset = fdt_path_offset(fdt, "/quadspi"); #endif +#endif + if (offset < 0) return;
diff --git a/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig b/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig new file mode 100644 index 0000000000..cb9490a867 --- /dev/null +++ b/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig @@ -0,0 +1,74 @@ +CONFIG_ARM=y +CONFIG_TARGET_LS2080ARDB=y +CONFIG_SYS_TEXT_BASE=0x82000000 +CONFIG_TFABOOT=y +CONFIG_SECURE_BOOT=y +CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y +CONFIG_QSPI_AHB_INIT=y +CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_NR_DRAM_BANKS=3 +# CONFIG_SYS_MALLOC_F is not set +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_BOOTDELAY=10 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS1,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0600 ramdisk_size=0x2000000 default_hugepagesz=2m hugepagesz=2m hugepages=256" +# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_MISC_INIT_R=y +CONFIG_CMD_IMLS=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_EEPROM=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_NAND=y +CONFIG_CMD_PCI=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_CACHE=y +CONFIG_CMD_DATE=y +CONFIG_MP=y +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-rdb" +CONFIG_ENV_IS_NOWHERE=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +CONFIG_FSL_CAAM=y +CONFIG_FSL_ESDHC=y +CONFIG_MTD_NOR_FLASH=y +CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_CFI=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_SPANSION=y + +CONFIG_PHYLIB=y +CONFIG_PHY_AQUANTIA=y +CONFIG_E1000=y +CONFIG_MII=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y +CONFIG_CONS_INDEX=2 +CONFIG_SYS_NS16550=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_FSL_DSPI=y +CONFIG_FSL_QSPI=y +CONFIG_FSL_SPI_ALIGNED_TXFIFO=y + +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_STORAGE=y +CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_BLK=y +CONFIG_DM_MMC=y +CONFIG_RSA=y +CONFIG_SPL_RSA=y +CONFIG_RSA_SOFTWARE_EXP=y diff --git a/configs/ls2088ardb_tfa_defconfig b/configs/ls2088ardb_tfa_defconfig new file mode 100644 index 0000000000..bb5e4f8bb5 --- /dev/null +++ b/configs/ls2088ardb_tfa_defconfig @@ -0,0 +1,72 @@ +CONFIG_ARM=y +CONFIG_TARGET_LS2080ARDB=y +CONFIG_SYS_TEXT_BASE=0x82000000 +CONFIG_TFABOOT=y +CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y +CONFIG_QSPI_AHB_INIT=y +CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_NR_DRAM_BANKS=3 +# CONFIG_SYS_MALLOC_F is not set +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_BOOTDELAY=10 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS1,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0600 ramdisk_size=0x2000000 default_hugepagesz=2m hugepagesz=2m hugepages=256" +# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_MISC_INIT_R=y +CONFIG_CMD_IMLS=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_EEPROM=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_NAND=y +CONFIG_CMD_PCI=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_CACHE=y +CONFIG_CMD_DATE=y +CONFIG_MP=y +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2088a-rdb-qspi" +CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +CONFIG_FSL_CAAM=y +CONFIG_FSL_ESDHC=y +CONFIG_MTD_NOR_FLASH=y +CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_CFI=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_SPANSION=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set + +CONFIG_PHYLIB=y +CONFIG_PHY_AQUANTIA=y +CONFIG_E1000=y +CONFIG_MII=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y +CONFIG_CONS_INDEX=2 +CONFIG_SYS_NS16550=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_FSL_DSPI=y +CONFIG_FSL_QSPI=y +CONFIG_FSL_SPI_ALIGNED_TXFIFO=y + +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_STORAGE=y +CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index 713e1d1d09..235a757f75 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -16,17 +16,23 @@ #include <asm/arch/config.h>
/* We need architecture specific misc initializations */
/* Link Definitions */ +#ifndef CONFIG_TFABOOT #ifndef CONFIG_QSPI_BOOT #else #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ #define CONFIG_ENV_OFFSET 0x300000 /* 3MB */ #define CONFIG_ENV_SECT_SIZE 0x40000 #endif +#endif
@@ -185,6 +191,7 @@ unsigned long long get_qixis_addr(void); "mcinitcmd=fsl_mc start mc 0x580a00000" \ " 0x580e00000 \0"
+#ifndef CONFIG_TFABOOT #ifdef CONFIG_SD_BOOT #define CONFIG_BOOTCOMMAND "mmc read 0x80200000 0x6800 0x800;"\ " fsl_mc apply dpl 0x80200000 &&" \ @@ -195,6 +202,7 @@ unsigned long long get_qixis_addr(void); " cp.b $kernel_start $kernel_load" \ " $kernel_size && bootm $kernel_load" #endif +#endif
/* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index 295b824aa0..ef0f4ff48e 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -69,8 +69,17 @@ unsigned long get_board_sys_clk(void); #define CONFIG_SYS_SCSI_MAX_LUN 1 #define CONFIG_SYS_SCSI_MAX_DEVICE (CONFIG_SYS_SCSI_MAX_SCSI_ID * \ CONFIG_SYS_SCSI_MAX_LUN) +#ifdef CONFIG_TFABOOT +#define CONFIG_SYS_MMC_ENV_DEV 0
-#ifndef CONFIG_FSL_QSPI +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_OFFSET 0x500000 /* 5MB */ +#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + \ + CONFIG_ENV_OFFSET) +#define CONFIG_ENV_SECT_SIZE 0x40000 +#endif + +#if !defined(CONFIG_FSL_QSPI) || defined(CONFIG_TFABOOT) /* undefined CONFIG_FSL_DDR_SYNC_REFRESH for simulator */
#define CONFIG_SYS_NOR0_CSPR_EXT (0x0) @@ -212,9 +221,11 @@ unsigned long get_board_sys_clk(void); #define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NAND_FTIM2 #define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NAND_FTIM3
+#ifndef CONFIG_TFABOOT #define CONFIG_ENV_OFFSET (2048 * 1024) #define CONFIG_ENV_SECT_SIZE 0x20000 #define CONFIG_ENV_SIZE 0x2000 +#endif #define CONFIG_SPL_PAD_TO 0x80000 #define CONFIG_SYS_NAND_U_BOOT_OFFS (1024 * 1024) #define CONFIG_SYS_NAND_U_BOOT_SIZE (512 * 1024) @@ -237,10 +248,12 @@ unsigned long get_board_sys_clk(void); #define CONFIG_SYS_CS2_FTIM2 CONFIG_SYS_NAND_FTIM2 #define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_NAND_FTIM3
+#ifndef CONFIG_TFABOOT #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x300000) #define CONFIG_ENV_SECT_SIZE 0x20000 #define CONFIG_ENV_SIZE 0x2000 #endif +#endif
/* Debug Server firmware */ #define CONFIG_SYS_DEBUG_SERVER_FW_IN_NOR @@ -323,6 +336,27 @@ unsigned long get_board_sys_clk(void); func(SCSI, scsi, 0) #include <config_distro_bootcmd.h>
+#ifdef CONFIG_TFABOOT +#define QSPI_MC_INIT_CMD \ + "env exists secureboot && " \ + "esbc_validate 0x20700000 && " \ + "esbc_validate 0x20740000;" \ + "fsl_mc start mc 0x20a00000 0x20e00000 \0" +#define SD_MC_INIT_CMD \ + "mmcinfo;mmc read 0x80000000 0x5000 0x800;" \ + "mmc read 0x80100000 0x7000 0x800;" \ + "env exists secureboot && " \ + "mmc read 0x80700000 0x3800 0x10 && " \ + "mmc read 0x80740000 0x3A00 0x10 && " \ + "esbc_validate 0x80700000 && " \ + "esbc_validate 0x80740000 ;" \ + "fsl_mc start mc 0x80000000 0x80100000\0" +#define IFC_MC_INIT_CMD \ + "env exists secureboot && " \ + "esbc_validate 0x580700000 && " \ + "esbc_validate 0x580740000; " \ + "fsl_mc start mc 0x580a00000 0x580e00000 \0" +#else #ifdef CONFIG_QSPI_BOOT #define MC_INIT_CMD \ "mcinitcmd=env exists secureboot && " \ @@ -347,9 +381,80 @@ unsigned long get_board_sys_clk(void); "esbc_validate 0x580740000; " \ "fsl_mc start mc 0x580a00000 0x580e00000 \0" #endif +#endif
/* Initial environment variables */ #undef CONFIG_EXTRA_ENV_SETTINGS +#ifdef CONFIG_TFABOOT +#define CONFIG_EXTRA_ENV_SETTINGS \ + "hwconfig=fsl_ddr:bank_intlv=auto\0" \ + "ramdisk_addr=0x800000\0" \ + "ramdisk_size=0x2000000\0" \ + "fdt_high=0xa0000000\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "fdt_addr=0x64f00000\0" \ + "kernel_addr=0x581000000\0" \ + "kernel_start=0x1000000\0" \ + "kernelheader_start=0x800000\0" \ + "scriptaddr=0x80000000\0" \ + "scripthdraddr=0x80080000\0" \ + "fdtheader_addr_r=0x80100000\0" \ + "kernelheader_addr_r=0x80200000\0" \ + "kernelheader_addr=0x580800000\0" \ + "kernel_addr_r=0x81000000\0" \ + "kernelheader_size=0x40000\0" \ + "fdt_addr_r=0x90000000\0" \ + "load_addr=0xa0000000\0" \ + "kernel_size=0x2800000\0" \ + "kernel_addr_sd=0x8000\0" \ + "kernel_size_sd=0x14000\0" \ + "console=ttyAMA0,38400n8\0" \ + "mcmemsize=0x70000000\0" \ + "sd_bootcmd=echo Trying load from SD ..;" \ + "mmcinfo; mmc read $load_addr " \ + "$kernel_addr_sd $kernel_size_sd && " \ + "bootm $load_addr#$board\0" \ + QSPI_MC_INIT_CMD \ + BOOTENV \ + "boot_scripts=ls2088ardb_boot.scr\0" \ + "boot_script_hdr=hdr_ls2088ardb_bs.out\0" \ + "scan_dev_for_boot_part=" \ + "part list ${devtype} ${devnum} devplist; " \ + "env exists devplist || setenv devplist 1; " \ + "for distro_bootpart in ${devplist}; do " \ + "if fstype ${devtype} " \ + "${devnum}:${distro_bootpart} " \ + "bootfstype; then " \ + "run scan_dev_for_boot; " \ + "fi; " \ + "done\0" \ + "scan_dev_for_boot=" \ + "echo Scanning ${devtype} " \ + "${devnum}:${distro_bootpart}...; " \ + "for prefix in ${boot_prefixes}; do " \ + "run scan_dev_for_scripts; " \ + "done;\0" \ + "boot_a_script=" \ + "load ${devtype} ${devnum}:${distro_bootpart} " \ + "${scriptaddr} ${prefix}${script}; " \ + "env exists secureboot && load ${devtype} " \ + "${devnum}:${distro_bootpart} " \ + "${scripthdraddr} ${prefix}${boot_script_hdr} " \ + "&& esbc_validate ${scripthdraddr};" \ + "source ${scriptaddr}\0" \ + "qspi_bootcmd=echo Trying load from qspi..;" \ + "sf probe && sf read $load_addr " \ + "$kernel_start $kernel_size ; env exists secureboot &&" \ + "sf read $kernelheader_addr_r $kernelheader_start " \ + "$kernelheader_size && esbc_validate ${kernelheader_addr_r}; "\ + " bootm $load_addr#$board\0" \ + "nor_bootcmd=echo Trying load from nor..;" \ + "cp.b $kernel_addr $load_addr " \ + "$kernel_size ; env exists secureboot && " \ + "cp.b $kernelheader_addr $kernelheader_addr_r " \ + "$kernelheader_size && esbc_validate ${kernelheader_addr_r}; "\ + "bootm $load_addr#$board\0" +#else #define CONFIG_EXTRA_ENV_SETTINGS \ "hwconfig=fsl_ddr:bank_intlv=auto\0" \ "ramdisk_addr=0x800000\0" \ @@ -418,7 +523,36 @@ unsigned long get_board_sys_clk(void); "cp.b $kernelheader_addr $kernelheader_addr_r " \ "$kernelheader_size && esbc_validate ${kernelheader_addr_r}; "\ "bootm $load_addr#$board\0" +#endif + +#ifdef CONFIG_TFABOOT +#define QSPI_NOR_BOOTCOMMAND \ + "env exists mcinitcmd && env exists secureboot "\ + "&& esbc_validate 0x20780000; " \ + "env exists mcinitcmd && " \ + "fsl_mc lazyapply dpl 0x20d00000; " \ + "run distro_bootcmd;run qspi_bootcmd; " \ + "env exists secureboot && esbc_halt;" + +/* Try to boot an on-SD kernel first, then do normal distro boot */ +#define SD_BOOTCOMMAND \ + "env exists mcinitcmd && env exists secureboot "\ + "&& mmcinfo && mmc read $load_addr 0x3c00 0x800 " \ + "&& esbc_validate $load_addr; " \ + "env exists mcinitcmd && run mcinitcmd " \ + "&& mmc read 0x88000000 0x6800 0x800 " \ + "&& fsl_mc lazyapply dpl 0x88000000; " \ + "run distro_bootcmd;run sd_bootcmd; " \ + "env exists secureboot && esbc_halt;"
+/* Try to boot an on-NOR kernel first, then do normal distro boot */ +#define IFC_NOR_BOOTCOMMAND \ + "env exists mcinitcmd && env exists secureboot "\ + "&& esbc_validate 0x580780000; env exists mcinitcmd "\ + "&& fsl_mc lazyapply dpl 0x580d00000;" \ + "run distro_bootcmd;run nor_bootcmd; " \ + "env exists secureboot && esbc_halt;" +#else #undef CONFIG_BOOTCOMMAND #ifdef CONFIG_QSPI_BOOT /* Try to boot an on-QSPI kernel first, then do normal distro boot */ @@ -449,6 +583,7 @@ unsigned long get_board_sys_clk(void); "run distro_bootcmd;run nor_bootcmd; " \ "env exists secureboot && esbc_halt;" #endif +#endif
TFABOOT support includes: - ls2088aqds_tfa_defconfig to be loaded by trusted firmware - environment address and size changes for TFABOOT
Signed-off-by: Pankit Garg pankit.garg@nxp.com Signed-off-by: Ruchika Gupta ruchika.gupta@nxp.com Signed-off-by: Rajesh Bhagat rajesh.bhagat@nxp.com --- board/freescale/ls2080aqds/MAINTAINERS | 2 + board/freescale/ls2080aqds/ddr.c | 12 +++++ configs/ls2088aqds_tfa_defconfig | 63 ++++++++++++++++++++++++++ include/configs/ls2080aqds.h | 40 +++++++++++++++- 4 files changed, 115 insertions(+), 2 deletions(-) create mode 100644 configs/ls2088aqds_tfa_defconfig
diff --git a/board/freescale/ls2080aqds/MAINTAINERS b/board/freescale/ls2080aqds/MAINTAINERS index f7f1f09513..e3d7635476 100644 --- a/board/freescale/ls2080aqds/MAINTAINERS +++ b/board/freescale/ls2080aqds/MAINTAINERS @@ -1,5 +1,6 @@ LS2080A BOARD M: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com, Priyanka Jain priyanka.jain@nxp.com +M: Rajesh Bhagat rajesh.bhagat@nxp.com S: Maintained F: board/freescale/ls2080aqds/ F: board/freescale/ls2080a/ls2080aqds.c @@ -8,6 +9,7 @@ F: configs/ls2080aqds_defconfig F: configs/ls2080aqds_nand_defconfig F: configs/ls2080aqds_qspi_defconfig F: configs/ls2080aqds_sdcard_defconfig +F: configs/ls2088aqds_tfa_defconfig
LS2080A_SECURE_BOOT BOARD #M: Saksham Jain saksham.jain@nxp.freescale.com diff --git a/board/freescale/ls2080aqds/ddr.c b/board/freescale/ls2080aqds/ddr.c index e9e7333c0a..fffe78c301 100644 --- a/board/freescale/ls2080aqds/ddr.c +++ b/board/freescale/ls2080aqds/ddr.c @@ -155,6 +155,17 @@ found: } }
+#ifdef CONFIG_TFABOOT +int fsl_initdram(void) +{ + gd->ram_size = tfa_get_dram_size(); + + if (!gd->ram_size) + gd->ram_size = fsl_ddr_sdram_size(); + + return 0; +} +#else int fsl_initdram(void) { #if defined(CONFIG_SPL) && !defined(CONFIG_SPL_BUILD) @@ -167,3 +178,4 @@ int fsl_initdram(void)
return 0; } +#endif /* CONFIG_TFABOOT */ diff --git a/configs/ls2088aqds_tfa_defconfig b/configs/ls2088aqds_tfa_defconfig new file mode 100644 index 0000000000..3a523f74be --- /dev/null +++ b/configs/ls2088aqds_tfa_defconfig @@ -0,0 +1,63 @@ +CONFIG_ARM=y +CONFIG_TARGET_LS2080AQDS=y +CONFIG_SYS_TEXT_BASE=0x82000000 +CONFIG_TFABOOT=y +CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y +CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_NR_DRAM_BANKS=3 +# CONFIG_SYS_MALLOC_F is not set +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_BOOTDELAY=10 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 ramdisk_size=0x2000000 default_hugepagesz=2m hugepagesz=2m hugepages=256" +# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_CMD_IMLS=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_EEPROM=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_NAND=y +CONFIG_CMD_PCI=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_CACHE=y +CONFIG_CMD_DATE=y +CONFIG_MP=y +# CONFIG_ISO_PARTITION is not set +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-qds" +CONFIG_ENV_IS_IN_FLASH=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +CONFIG_FSL_CAAM=y +CONFIG_FSL_ESDHC=y +CONFIG_MTD_NOR_FLASH=y +CONFIG_FLASH_CFI_DRIVER=y +CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_SYS_FLASH_CFI=y +CONFIG_DM_SPI_FLASH=y +CONFIG_PHYLIB=y +CONFIG_PHY_GIGE=y +CONFIG_E1000=y +CONFIG_MII=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y +CONFIG_SYS_NS16550=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_FSL_DSPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_STORAGE=y +CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index f192839fa9..2822811da5 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -55,6 +55,15 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_SCSI_MAX_DEVICE (CONFIG_SYS_SCSI_MAX_SCSI_ID * \ CONFIG_SYS_SCSI_MAX_LUN)
+#ifdef CONFIG_TFABOOT +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_ENV_SIZE 0x20000 +#define CONFIG_ENV_OFFSET 0x500000 +#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + \ + CONFIG_ENV_OFFSET) +#define CONFIG_ENV_SECT_SIZE 0x20000 +#endif + /* undefined CONFIG_FSL_DDR_SYNC_REFRESH for simulator */
#define CONFIG_SYS_NOR0_CSPR_EXT (0x0) @@ -261,7 +270,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_CS2_FTIM2 CONFIG_SYS_NAND_FTIM2 #define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_NAND_FTIM3
-#ifndef CONFIG_QSPI_BOOT +#if !defined(CONFIG_QSPI_BOOT) && !defined(CONFIG_TFABOOT) #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x300000) #define CONFIG_ENV_SECT_SIZE 0x20000 #define CONFIG_ENV_SIZE 0x2000 @@ -361,6 +370,33 @@ unsigned long get_board_ddr_clk(void); "esbc_validate 0x580740000;" \ "fsl_mc start mc 0x580a00000" \ " 0x580e00000 \0" +#else +#ifdef CONFIG_TFABOOT +#define SD_MC_INIT_CMD \ + "mmcinfo;mmc read 0x80000000 0x5000 0x800;" \ + "mmc read 0x80100000 0x7000 0x800;" \ + "fsl_mc start mc 0x80000000 0x80100000\0" +#define IFC_MC_INIT_CMD \ + "fsl_mc start mc 0x580a00000" \ + " 0x580e00000 \0" +#define CONFIG_EXTRA_ENV_SETTINGS \ + "hwconfig=fsl_ddr:bank_intlv=auto\0" \ + "loadaddr=0x80100000\0" \ + "loadaddr_sd=0x90100000\0" \ + "kernel_addr=0x100000\0" \ + "kernel_addr_sd=0x800\0" \ + "ramdisk_addr=0x800000\0" \ + "ramdisk_size=0x2000000\0" \ + "fdt_high=0xa0000000\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "kernel_start=0x581000000\0" \ + "kernel_start_sd=0x8000\0" \ + "kernel_load=0xa0000000\0" \ + "kernel_size=0x2800000\0" \ + "kernel_size_sd=0x14000\0" \ + "mcinitcmd=fsl_mc start mc 0x580a00000" \ + " 0x580e00000 \0" \ + "mcmemsize=0x70000000 \0" #elif defined(CONFIG_SD_BOOT) #define CONFIG_EXTRA_ENV_SETTINGS \ "hwconfig=fsl_ddr:bank_intlv=auto\0" \ @@ -392,9 +428,9 @@ unsigned long get_board_ddr_clk(void); "mcmemsize=0x40000000\0" \ "mcinitcmd=fsl_mc start mc 0x580a00000" \ " 0x580e00000 \0" +#endif /* CONFIG_TFABOOT */ #endif /* CONFIG_SECURE_BOOT */
- #if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) #define CONFIG_FSL_MEMAC #define CONFIG_PHYLIB_10G
Rajesh Bhagat
York Sun
