[U-Boot] [PATCH v2 0/2] Add Arndale board support
The Arndale board is based on samsung's exynos5250 SOC. First patch moves board specific options to board specific config file and the second patch adds the initial config and dts file for the arndale board.
Changes in v2: - Added entry is MAINTAINERS - Added Chander's Acked-by
Inderpal Singh (2): smdk5250: move board specific options to board specific config file Exynos5: Arndale: Add support for exynos5250 based arndale board.
MAINTAINERS | 4 ++ board/samsung/dts/exynos5250-arndale.dts | 36 ++++++++++++++++++ boards.cfg | 1 + include/configs/arndale.h | 39 +++++++++++++++++++ include/configs/exynos5250-dt.h | 60 ------------------------------ include/configs/smdk5250.h | 35 +++++++++++++++++ 6 files changed, 115 insertions(+), 60 deletions(-) create mode 100644 board/samsung/dts/exynos5250-arndale.dts create mode 100644 include/configs/arndale.h
Signed-off-by: Inderpal Singh inderpal.singh@linaro.org Acked-by: Chander Kashyap chander.kashyap@linaro.org --- include/configs/exynos5250-dt.h | 60 --------------------------------------- include/configs/smdk5250.h | 35 +++++++++++++++++++++++ 2 files changed, 35 insertions(+), 60 deletions(-)
diff --git a/include/configs/exynos5250-dt.h b/include/configs/exynos5250-dt.h index 3fa86b2..d4a589c 100644 --- a/include/configs/exynos5250-dt.h +++ b/include/configs/exynos5250-dt.h @@ -73,7 +73,6 @@ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (4 << 20))
/* select serial console configuration */ -#define CONFIG_SERIAL3 /* use SERIAL 3 */ #define CONFIG_BAUDRATE 115200 #define EXYNOS5_DEFAULT_UART_OFFSET 0x010000
@@ -139,7 +138,6 @@ /* Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT "SMDK5250 # " #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ @@ -179,7 +177,6 @@ /* FLASH and environment organization */ #define CONFIG_SYS_NO_FLASH #undef CONFIG_CMD_IMLS -#define CONFIG_IDENT_STRING " for SMDK5250"
#define CONFIG_SYS_MMC_ENV_DEV 0
@@ -232,57 +229,10 @@ #define CONFIG_I2C_EDID
/* PMIC */ -#define CONFIG_PMIC -#define CONFIG_PMIC_I2C -#define CONFIG_PMIC_MAX77686 - -/* SPI */ -#define CONFIG_ENV_IS_IN_SPI_FLASH -#define CONFIG_SPI_FLASH - -#ifdef CONFIG_SPI_FLASH -#define CONFIG_EXYNOS_SPI -#define CONFIG_CMD_SF -#define CONFIG_CMD_SPI -#define CONFIG_SPI_FLASH_WINBOND -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 -#define CONFIG_SF_DEFAULT_SPEED 50000000 -#define EXYNOS5_SPI_NUM_CONTROLLERS 5 -#endif - -#ifdef CONFIG_ENV_IS_IN_SPI_FLASH -#define CONFIG_ENV_SPI_MODE SPI_MODE_0 -#define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE -#define CONFIG_ENV_SPI_BUS 1 -#define CONFIG_ENV_SPI_MAX_HZ 50000000 -#endif - -/* PMIC */ #define CONFIG_POWER #define CONFIG_POWER_I2C #define CONFIG_POWER_MAX77686
-/* SPI */ -#define CONFIG_ENV_IS_IN_SPI_FLASH -#define CONFIG_SPI_FLASH - -#ifdef CONFIG_SPI_FLASH -#define CONFIG_EXYNOS_SPI -#define CONFIG_CMD_SF -#define CONFIG_CMD_SPI -#define CONFIG_SPI_FLASH_WINBOND -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 -#define CONFIG_SF_DEFAULT_SPEED 50000000 -#define EXYNOS5_SPI_NUM_CONTROLLERS 5 -#endif - -#ifdef CONFIG_ENV_IS_IN_SPI_FLASH -#define CONFIG_ENV_SPI_MODE SPI_MODE_0 -#define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE -#define CONFIG_ENV_SPI_BUS 1 -#define CONFIG_ENV_SPI_MAX_HZ 50000000 -#endif - /* Ethernet Controllor Driver */ #ifdef CONFIG_CMD_NET #define CONFIG_SMC911X @@ -314,14 +264,4 @@ #define CONFIG_SHA1 #define CONFIG_SHA256
-/* Display */ -#define CONFIG_LCD -#ifdef CONFIG_LCD -#define CONFIG_EXYNOS_FB -#define CONFIG_EXYNOS_DP -#define LCD_XRES 2560 -#define LCD_YRES 1600 -#define LCD_BPP LCD_COLOR16 -#endif - #endif /* __CONFIG_H */ diff --git a/include/configs/smdk5250.h b/include/configs/smdk5250.h index 81f83a8..51c4215 100644 --- a/include/configs/smdk5250.h +++ b/include/configs/smdk5250.h @@ -30,4 +30,39 @@ #undef CONFIG_DEFAULT_DEVICE_TREE #define CONFIG_DEFAULT_DEVICE_TREE exynos5250-smdk5250
+#define CONFIG_SYS_PROMPT "SMDK5250 # " +#define CONFIG_SERIAL3 /* use SERIAL 3 */ +#define CONFIG_IDENT_STRING " for SMDK5250" + +/* SPI */ +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_SPI_FLASH + +#ifdef CONFIG_SPI_FLASH +#define CONFIG_EXYNOS_SPI +#define CONFIG_CMD_SF +#define CONFIG_CMD_SPI +#define CONFIG_SPI_FLASH_WINBOND +#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 +#define CONFIG_SF_DEFAULT_SPEED 50000000 +#define EXYNOS5_SPI_NUM_CONTROLLERS 5 +#endif + +#ifdef CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_SPI_MODE SPI_MODE_0 +#define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE +#define CONFIG_ENV_SPI_BUS 1 +#define CONFIG_ENV_SPI_MAX_HZ 50000000 +#endif + +/* Display */ +#define CONFIG_LCD +#ifdef CONFIG_LCD +#define CONFIG_EXYNOS_FB +#define CONFIG_EXYNOS_DP +#define LCD_XRES 2560 +#define LCD_YRES 1600 +#define LCD_BPP LCD_COLOR16 +#endif + #endif /* __CONFIG_SMDK_H */
On Mon, Feb 25, 2013 at 9:13 PM, Inderpal Singh inderpal.singh@linaro.org wrote:
Sorry I have only just seen this - I don't think this patch is wholly correct.
The intent with the -dt.h file is to enable things that might be used by exynos5250 boards. For example it is OK to enable multiple pmic drivers, SPI, MMC, etc. even if not all boards use them. Device tree nodes have a 'status = "disabled" feature to deal with turning individual peripherals on/ff. I agree that the smdk5250 string is wrong, but you should perhaps change this to exynos5250 instead. By all means undef and define things in your board, but we should not defeat the purpose of the -dt.h file. The device tree should be used to configure/enable drivers where possible.
Now I realise that what I am saying is not entirely possible right now (in that for example some drivers are not device tree-enabled), but we should try to avoid just treating this file as an exynos 'common' file.
1.7.9.5
The Arndale board is based on samsung's exynos5250 SOC. This patch adds a initial config and dts file.
Signed-off-by: Inderpal Singh inderpal.singh@linaro.org Acked-by: Chander Kashyap chander.kashyap@linaro.org --- This depends on the first 6 patches from Amar at [1]
[1] http://comments.gmane.org/gmane.comp.boot-loaders.u-boot/151523
MAINTAINERS | 4 +++ board/samsung/dts/exynos5250-arndale.dts | 36 +++++++++++++++++++++++++++ boards.cfg | 1 + include/configs/arndale.h | 39 ++++++++++++++++++++++++++++++ 4 files changed, 80 insertions(+) create mode 100644 board/samsung/dts/exynos5250-arndale.dts create mode 100644 include/configs/arndale.h
diff --git a/MAINTAINERS b/MAINTAINERS index 45e2dd4..da0dd38 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -736,6 +736,10 @@ Chander Kashyap k.chander@samsung.com SMDKV310 ARM ARMV7 (EXYNOS4210 SoC) SMDK5250 ARM ARMV7 (EXYNOS5250 SoC)
+Inderpal Singh inderpal.singh@linaro.org + + arndale ARM ARMV7 (EXYNOS5250 SoC) + Lukasz Majewski l.majewski@samsung.com
trats ARM ARMV7 (EXYNOS4210 SoC) diff --git a/board/samsung/dts/exynos5250-arndale.dts b/board/samsung/dts/exynos5250-arndale.dts new file mode 100644 index 0000000..9b4d6b2 --- /dev/null +++ b/board/samsung/dts/exynos5250-arndale.dts @@ -0,0 +1,36 @@ +/* + * SAMSUNG Arndale board device tree source + * + * Copyright (c) 2013 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. +*/ + +/dts-v1/; +/include/ ARCH_CPU_DTS + +/ { + model = "SAMSUNG Arndale board based on EXYNOS5250"; + compatible = "samsung,arndale", "samsung,exynos5250"; + + mmc@12200000 { + samsung,bus-width = <8>; + samsung,timing = <1 3 3>; + }; + + mmc@12210000 { + status = "disabled"; + }; + + mmc@12220000 { + samsung,bus-width = <4>; + samsung,timing = <1 2 3>; + }; + + mmc@12230000 { + status = "disabled"; + }; +}; diff --git a/boards.cfg b/boards.cfg index b1319aa..2017ce0 100644 --- a/boards.cfg +++ b/boards.cfg @@ -287,6 +287,7 @@ smdkc100 arm armv7 smdkc100 samsung origen arm armv7 origen samsung exynos s5pc210_universal arm armv7 universal_c210 samsung exynos smdk5250 arm armv7 smdk5250 samsung exynos +arndale arm armv7 smdk5250 samsung exynos smdkv310 arm armv7 smdkv310 samsung exynos trats arm armv7 trats samsung exynos harmony arm armv7:arm720t harmony nvidia tegra20 diff --git a/include/configs/arndale.h b/include/configs/arndale.h new file mode 100644 index 0000000..c71370e --- /dev/null +++ b/include/configs/arndale.h @@ -0,0 +1,39 @@ +/* + * Copyright (C) 2013 Samsung Electronics + * + * Configuration settings for the SAMSUNG Arndale board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_ARNDALE_H +#define __CONFIG_ARNDALE_H + +#include <configs/exynos5250-dt.h> + +#undef CONFIG_DEFAULT_DEVICE_TREE +#define CONFIG_DEFAULT_DEVICE_TREE exynos5250-arndale + +#define CONFIG_SERIAL2 +#define CONFIG_SYS_PROMPT "Arndale # " +#define CONFIG_IDENT_STRING " for Arndale" + +#define CONFIG_ENV_IS_IN_MMC + +#endif /* __CONFIG_ARNDALE_H */
Inderpal Singh
