[U-Boot] Riscv: CONFIG_DEFAULT_DEVICE_TREE failures
I attempted to merge in the latest master branch into https://github.com/sifive/u-boot/tree/sandbox and I got the following error, which seems somewhat broken..
Device Tree Source is not correctly specified. Please define 'CONFIG_DEFAULT_DEVICE_TREE' or build with 'DEVICE_TREE=<device_tree>' argument
dts/Makefile:28: recipe for target 'arch/riscv/dts/fu540.dtb' failed
Does anyone have any idea what would have caused that?
Also any feedback or pointers on why the serial_sifive.c driver with CONFIG_DM_SERIAL would not work, but serial_hifive.c without CONFIG_DM_SERIAL does seem to work might be appreciated.
You'll need to do something like
commit 89c2b5c02049aea746b1edee0b4e1d8519dec2f4 Author: Masahiro Yamada yamada.masahiro@socionext.com Date: Thu Mar 14 14:58:33 2019 +0900
ARM: fix arch/arm/dts/Makefile
Since commit 27cb7300ffda ("Ensure device tree DTS is compiled"), build succeeds irrespective of the correctness of Makefile.
In fact, you can compile any defconfig without adding any entry in arch/*/dts/Makefile.
As a result, a lot of wrong code have been merged unnoticed.
I am going to revert that commit, and lots of hidden issues have come to light:
[1] Typos
armada-3720-uDPU.dts, sun8i-a83t-tbs-a711.dts
use the extension ".dts" instead of ".dtb"
[2] DTB is associated to undefined CONFIG option
For example, mx6sllevk_defconfig defines CONFIG_MX6SLL, but associates its device tree to CONFIG_MX6SL, which is undefined.
[3] Lots of entries are missing
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com Reviewed-by: Chris Packham judge.packham@gmail.com [trini: add imx6ul pico dtbs] Signed-off-by: Tom Rini trini@konsulko.com
But to arch/riscv/dts/Makefile
[1] Typos
armada-3720-uDPU.dts, sun8i-a83t-tbs-a711.dts use the extension ".dts" instead of ".dtb"
-- Tom
I ended up reverting that commit, and we now have https://github.com/sifive/u-boot/tree/sandbox booting to a prompt based on upstream master.
It still needs the macb driver ported over, and probably re-worked to do what Rockchip boards do to put the Denali memory init code in the device tree.
[1] Typos
Note that you just need something like: obj-y += first.dtb \ second.dtb
[1] Typos
It should be:
dtb-y += first.dtb \ second.dtb
[1] Typos
It should be:
Ah right, thanks!
Masahiro Yamada
Troy Benjegerdes
Troy Benjegerdes
