[U-Boot] [PATCH v3] powerpc/85xx: Introduce CONFIG_SYS_EXTRA_ENV_RELOC
Some systems need to relocate the env_addr pointer early because the location it points to will get invalidated before env_relocate is called. One example is on systems that might use a L2 or L3 cache in SRAM mode and initialize that cache from SRAM mode back to being a cache in cpu_init_r.
We set this on the 85xx boards that have support for NAND, SPI, or SDHC/MMC boot support as they use a secondary cache in SRAM mode and need the env_addr pointer relocated since we change from SRAM to normal cache mode in cpu_init_r.
Also removed CONFIG_SYS_SPL as its not used anywhere.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- * Removed CONFIG_SYS_SPL as its not used anywhere
arch/powerpc/lib/board.c | 11 +++++++++++ include/configs/MPC8536DS.h | 5 +++-- include/configs/MPC8569MDS.h | 3 ++- include/configs/P1_P2_RDB.h | 5 +++-- 4 files changed, 19 insertions(+), 5 deletions(-)
diff --git a/arch/powerpc/lib/board.c b/arch/powerpc/lib/board.c index b21c1d6..9759e23 100644 --- a/arch/powerpc/lib/board.c +++ b/arch/powerpc/lib/board.c @@ -645,6 +645,17 @@ void board_init_r (gd_t *id, ulong dest_addr) gd->cpu += dest_addr - CONFIG_SYS_MONITOR_BASE; #endif
+#ifdef CONFIG_SYS_EXTRA_ENV_RELOC + /* + * Some systems need to relocate the env_addr pointer early because the + * location it points to will get invalidated before env_relocate is + * called. One example is on systems that might use a L2 or L3 cache + * in SRAM mode and initialize that cache from SRAM mode back to being + * a cache in cpu_init_r. + */ + gd->env_addr += dest_addr - CONFIG_SYS_MONITOR_BASE; +#endif + #ifdef CONFIG_SERIAL_MULTI serial_initialize(); #endif diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index 850665a..5c5be0c 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -242,9 +242,10 @@ #define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ #define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */
-#if defined(CONFIG_SYS_SPL) || defined(CONFIG_RAMBOOT_NAND) \ - || defined(CONFIG_RAMBOOT_SDCARD) || defined(CONFIG_RAMBOOT_SPIFLASH) +#if defined(CONFIG_RAMBOOT_NAND) || defined(CONFIG_RAMBOOT_SDCARD) || \ + defined(CONFIG_RAMBOOT_SPIFLASH) #define CONFIG_SYS_RAMBOOT +#define CONFIG_SYS_EXTRA_ENV_RELOC #else #undef CONFIG_SYS_RAMBOOT #endif diff --git a/include/configs/MPC8569MDS.h b/include/configs/MPC8569MDS.h index c7973b4..9620fd0 100644 --- a/include/configs/MPC8569MDS.h +++ b/include/configs/MPC8569MDS.h @@ -203,8 +203,9 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ #define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */
-#if defined(CONFIG_SYS_SPL) || defined(CONFIG_RAMBOOT_NAND) +#if defined(CONFIG_RAMBOOT_NAND) #define CONFIG_SYS_RAMBOOT +#define CONFIG_SYS_EXTRA_ENV_RELOC #else #undef CONFIG_SYS_RAMBOOT #endif diff --git a/include/configs/P1_P2_RDB.h b/include/configs/P1_P2_RDB.h index 610f3ed..a21afb7 100644 --- a/include/configs/P1_P2_RDB.h +++ b/include/configs/P1_P2_RDB.h @@ -201,9 +201,10 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ #define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */
Dear Kumar Gala,
In message 1291062731-11647-1-git-send-email-galak@kernel.crashing.org you wrote:
- Removed CONFIG_SYS_SPL as its not used anywhere
Applied, thanks.
Kumar Gala
