[U-Boot] [PATCH 0/2] arm/km: configuration of the mv88e6352 switch on kmnusa
This series adds supoort for the configuration of the mv88e6352 external switch on kmnusa. It has a clear dependancy to the minimal mv88e6352 net/phy driver: http://patchwork.ozlabs.org/patch/177953/
Valentin Longchamp (2): arm/km: add mv88e6352 configuration for kmnusa km_kirkwood: enable MV88E6352_SWITCH support for kmnusa
board/keymile/km_arm/km_arm.c | 63 +++++++++++++++++++++++++++++++++++++++++ include/configs/km_kirkwood.h | 2 + 2 files changed, 65 insertions(+), 0 deletions(-)
The kmnusa board uses a mv88e6352 switch that is connected to the main eth interface of the kirkwood. Therefore the switch must be configured so that the kirkwood's egiga eth inferface can be used.
Signed-off-by: Valentin Longchamp valentin.longchamp@keymile.com Cc: Holger Brunck holger.brunck@keymile.com Cc: Prafulla Wadaskar prafulla@marvell.com --- board/keymile/km_arm/km_arm.c | 63 +++++++++++++++++++++++++++++++++++++++++ 1 files changed, 63 insertions(+), 0 deletions(-)
diff --git a/board/keymile/km_arm/km_arm.c b/board/keymile/km_arm/km_arm.c index 2b2ca39..c0069c1 100644 --- a/board/keymile/km_arm/km_arm.c +++ b/board/keymile/km_arm/km_arm.c @@ -385,6 +385,69 @@ void reset_phy(void) /* reset the phy */ miiphy_reset(name, CONFIG_PHY_BASE_ADR); } +#elif defined(CONFIG_KM_PIGGY4_88E6352) + +#include <mv88e6352.h> + +#if defined(CONFIG_KM_NUSA) +struct mv88e_sw_reg extsw_conf[] = { + /* port 0, PIGY4, autoneg */ + /* first the fix for the 1000Mbits Autoneg, this is from + * a Marvell errata, the regs are undocumented */ + { PHY(0), PHY_PAGE, AN1000FIX_PAGE }, + { PHY(0), PHY_STATUS, AN1000FIX }, + { PHY(0), PHY_PAGE, 0 }, + /* now the real port and phy configuration */ + { PORT(0), PORT_PHY, NO_SPEED_FOR }, + { PORT(0), PORT_CTRL, FORWARDING | EGRS_FLD_ALL }, + { PHY(0), PHY_1000_CTRL, NO_ADV }, + { PHY(0), PHY_SPEC_CTRL, AUTO_MDIX_EN }, + { PHY(0), PHY_CTRL, PHY_100_MBPS | AUTONEG_EN | AUTONEG_RST | + FULL_DUPLEX }, + /* port 1, unused */ + { PORT(1), PORT_CTRL, PORT_DIS }, + { PHY(1), PHY_CTRL, PHY_PWR_DOWN }, + { PHY(1), PHY_SPEC_CTRL, SPEC_PWR_DOWN }, + /* port 2, unused */ + { PORT(2), PORT_CTRL, PORT_DIS }, + { PHY(2), PHY_CTRL, PHY_PWR_DOWN }, + { PHY(2), PHY_SPEC_CTRL, SPEC_PWR_DOWN }, + /* port 3, unused */ + { PORT(3), PORT_CTRL, PORT_DIS }, + { PHY(3), PHY_CTRL, PHY_PWR_DOWN }, + { PHY(3), PHY_SPEC_CTRL, SPEC_PWR_DOWN }, + /* port 4, ICNEV, SerDes, SGMII */ + { PORT(4), PORT_STATUS, NO_PHY_DETECT }, + { PORT(4), PORT_PHY, SPEED_1000_FOR }, + { PORT(4), PORT_CTRL, FORWARDING | EGRS_FLD_ALL }, + { PHY(4), PHY_CTRL, PHY_PWR_DOWN }, + { PHY(4), PHY_SPEC_CTRL, SPEC_PWR_DOWN }, + /* port 5, CPU_RGMII */ + { PORT(5), PORT_PHY, RX_RGMII_TIM | TX_RGMII_TIM | FLOW_CTRL_EN | + FLOW_CTRL_FOR | LINK_VAL | LINK_FOR | FULL_DPX | + FULL_DPX_FOR | SPEED_1000_FOR }, + { PORT(5), PORT_CTRL, FORWARDING | EGRS_FLD_ALL }, + /* port 6, unused, this port has no phy */ + { PORT(6), PORT_CTRL, PORT_DIS }, +}; +#else +struct mv88e_sw_reg extsw_conf[] = {}; +#endif + +void reset_phy(void) +{ +#if defined(CONFIG_KM_MVEXTSW_ADDR) + char *name = "egiga0"; + + if (miiphy_set_current_dev(name)) + return; + + mv88e_sw_program(name, CONFIG_KM_MVEXTSW_ADDR, extsw_conf, + ARRAY_SIZE(extsw_conf)); + mv88e_sw_reset(name, CONFIG_KM_MVEXTSW_ADDR); +#endif +} + #else /* Configure and enable MV88E1118 PHY on the piggy*/ void reset_phy(void)
-----Original Message----- From: Valentin Longchamp [mailto:valentin.longchamp@keymile.com] Sent: 16 August 2012 16:55 To: u-boot@lists.denx.de Cc: holger.brunck@keymile.com; Prafulla Wadaskar; valentin.longchamp@keymile.com Subject: [PATCH 1/2] arm/km: add mv88e6352 configuration for kmnusa
- /* port 0, PIGY4, autoneg */
- /* first the fix for the 1000Mbits Autoneg, this is from
May you please follow standard c-style commenting?
Otherwise ack for this patch
Regards.. Prafulla . .
OK, I will change this comment. Is it OK if I just repost this updated patch as a reply to this message since it's a very minor change or do you need the whole series ?
Thanks
Valentin
-----Original Message----- From: Valentin Longchamp [mailto:valentin.longchamp@keymile.com] Sent: 17 August 2012 14:13 To: Prafulla Wadaskar Cc: u-boot@lists.denx.de; holger.brunck@keymile.com Subject: Re: [PATCH 1/2] arm/km: add mv88e6352 configuration for kmnusa
main
configured
I think v2 for this patch only should work.
Regards... Prafulla . . .
Signed-off-by: Valentin Longchamp valentin.longchamp@keymile.com Cc: Holger Brunck holger.brunck@keymile.com Cc: Prafulla Wadaskar prafulla@marvell.com --- changes for v2: - update comment to follow c-style commenting
board/keymile/km_arm/km_arm.c | 65 +++++++++++++++++++++++++++++++++++++++++ 1 files changed, 65 insertions(+), 0 deletions(-)
diff --git a/board/keymile/km_arm/km_arm.c b/board/keymile/km_arm/km_arm.c index 2b2ca39..604085d 100644 --- a/board/keymile/km_arm/km_arm.c +++ b/board/keymile/km_arm/km_arm.c @@ -385,6 +385,71 @@ void reset_phy(void) /* reset the phy */ miiphy_reset(name, CONFIG_PHY_BASE_ADR); } +#elif defined(CONFIG_KM_PIGGY4_88E6352) + +#include <mv88e6352.h> + +#if defined(CONFIG_KM_NUSA) +struct mv88e_sw_reg extsw_conf[] = { + /* + * port 0, PIGGY4, autoneg + * first the fix for the 1000Mbits Autoneg, this is from + * a Marvell errata, the regs are undocumented + */ + { PHY(0), PHY_PAGE, AN1000FIX_PAGE }, + { PHY(0), PHY_STATUS, AN1000FIX }, + { PHY(0), PHY_PAGE, 0 }, + /* now the real port and phy configuration */ + { PORT(0), PORT_PHY, NO_SPEED_FOR }, + { PORT(0), PORT_CTRL, FORWARDING | EGRS_FLD_ALL }, + { PHY(0), PHY_1000_CTRL, NO_ADV }, + { PHY(0), PHY_SPEC_CTRL, AUTO_MDIX_EN }, + { PHY(0), PHY_CTRL, PHY_100_MBPS | AUTONEG_EN | AUTONEG_RST | + FULL_DUPLEX }, + /* port 1, unused */ + { PORT(1), PORT_CTRL, PORT_DIS }, + { PHY(1), PHY_CTRL, PHY_PWR_DOWN }, + { PHY(1), PHY_SPEC_CTRL, SPEC_PWR_DOWN }, + /* port 2, unused */ + { PORT(2), PORT_CTRL, PORT_DIS }, + { PHY(2), PHY_CTRL, PHY_PWR_DOWN }, + { PHY(2), PHY_SPEC_CTRL, SPEC_PWR_DOWN }, + /* port 3, unused */ + { PORT(3), PORT_CTRL, PORT_DIS }, + { PHY(3), PHY_CTRL, PHY_PWR_DOWN }, + { PHY(3), PHY_SPEC_CTRL, SPEC_PWR_DOWN }, + /* port 4, ICNEV, SerDes, SGMII */ + { PORT(4), PORT_STATUS, NO_PHY_DETECT }, + { PORT(4), PORT_PHY, SPEED_1000_FOR }, + { PORT(4), PORT_CTRL, FORWARDING | EGRS_FLD_ALL }, + { PHY(4), PHY_CTRL, PHY_PWR_DOWN }, + { PHY(4), PHY_SPEC_CTRL, SPEC_PWR_DOWN }, + /* port 5, CPU_RGMII */ + { PORT(5), PORT_PHY, RX_RGMII_TIM | TX_RGMII_TIM | FLOW_CTRL_EN | + FLOW_CTRL_FOR | LINK_VAL | LINK_FOR | FULL_DPX | + FULL_DPX_FOR | SPEED_1000_FOR }, + { PORT(5), PORT_CTRL, FORWARDING | EGRS_FLD_ALL }, + /* port 6, unused, this port has no phy */ + { PORT(6), PORT_CTRL, PORT_DIS }, +}; +#else +struct mv88e_sw_reg extsw_conf[] = {}; +#endif + +void reset_phy(void) +{ +#if defined(CONFIG_KM_MVEXTSW_ADDR) + char *name = "egiga0"; + + if (miiphy_set_current_dev(name)) + return; + + mv88e_sw_program(name, CONFIG_KM_MVEXTSW_ADDR, extsw_conf, + ARRAY_SIZE(extsw_conf)); + mv88e_sw_reset(name, CONFIG_KM_MVEXTSW_ADDR); +#endif +} + #else /* Configure and enable MV88E1118 PHY on the piggy*/ void reset_phy(void)
-----Original Message----- From: Valentin Longchamp [mailto:valentin.longchamp@keymile.com] Sent: 17 August 2012 15:05 To: u-boot@lists.denx.de Cc: Valentin Longchamp; Holger Brunck; Prafulla Wadaskar Subject: [PATCH v2 1/2] arm/km: add mv88e6352 configuration for kmnusa
changes for v2:
- { PHY(0), PHY_PAGE, AN1000FIX_PAGE },
- { PHY(0), PHY_STATUS, AN1000FIX },
- { PHY(0), PHY_PAGE, 0 },
- /* now the real port and phy configuration */
- { PORT(0), PORT_PHY, NO_SPEED_FOR },
- { PORT(0), PORT_CTRL, FORWARDING | EGRS_FLD_ALL },
- { PHY(0), PHY_1000_CTRL, NO_ADV },
- { PHY(0), PHY_SPEC_CTRL, AUTO_MDIX_EN },
- { PHY(0), PHY_CTRL, PHY_100_MBPS | AUTONEG_EN | AUTONEG_RST |
FULL_DUPLEX },
- /* port 1, unused */
- { PORT(1), PORT_CTRL, PORT_DIS },
- { PHY(1), PHY_CTRL, PHY_PWR_DOWN },
- { PHY(1), PHY_SPEC_CTRL, SPEC_PWR_DOWN },
- /* port 2, unused */
- { PORT(2), PORT_CTRL, PORT_DIS },
- { PHY(2), PHY_CTRL, PHY_PWR_DOWN },
- { PHY(2), PHY_SPEC_CTRL, SPEC_PWR_DOWN },
- /* port 3, unused */
- { PORT(3), PORT_CTRL, PORT_DIS },
- { PHY(3), PHY_CTRL, PHY_PWR_DOWN },
- { PHY(3), PHY_SPEC_CTRL, SPEC_PWR_DOWN },
- /* port 4, ICNEV, SerDes, SGMII */
- { PORT(4), PORT_STATUS, NO_PHY_DETECT },
- { PORT(4), PORT_PHY, SPEED_1000_FOR },
- { PORT(4), PORT_CTRL, FORWARDING | EGRS_FLD_ALL },
- { PHY(4), PHY_CTRL, PHY_PWR_DOWN },
- { PHY(4), PHY_SPEC_CTRL, SPEC_PWR_DOWN },
- /* port 5, CPU_RGMII */
- { PORT(5), PORT_PHY, RX_RGMII_TIM | TX_RGMII_TIM | FLOW_CTRL_EN |
- { PORT(5), PORT_CTRL, FORWARDING | EGRS_FLD_ALL },
- /* port 6, unused, this port has no phy */
- { PORT(6), PORT_CTRL, PORT_DIS },
- char *name = "egiga0";
- if (miiphy_set_current_dev(name))
return;
- mv88e_sw_program(name, CONFIG_KM_MVEXTSW_ADDR, extsw_conf,
- mv88e_sw_reset(name, CONFIG_KM_MVEXTSW_ADDR);
+#endif +}
#else /* Configure and enable MV88E1118 PHY on the piggy*/ void reset_phy(void) --
Acked-By: Prafulla Wadaskar prafulla@marvell.com
-----Original Message----- From: Prafulla Wadaskar Sent: 21 August 2012 12:01 To: 'Valentin Longchamp'; u-boot@lists.denx.de Cc: Holger Brunck Subject: RE: [PATCH v2 1/2] arm/km: add mv88e6352 configuration for kmnusa
kmnusa
main
configured
changes for v2:
FULL_DUPLEX },
return;
+#endif +}
Applied to u-boot-marvell.git master branch
This is required to configure the external 88e6352 switch on nusa.
Signed-off-by: Valentin Longchamp valentin.longchamp@keymile.com cc: Holger Brunck holger.brunck@keymile.com cc: Prafulla Wadaskar prafulla@marvell.com --- include/configs/km_kirkwood.h | 2 ++ 1 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/include/configs/km_kirkwood.h b/include/configs/km_kirkwood.h index fba181f..762cc10 100644 --- a/include/configs/km_kirkwood.h +++ b/include/configs/km_kirkwood.h @@ -62,6 +62,8 @@ #define CONFIG_KM_ENV_IS_IN_SPI_NOR #define CONFIG_KM_FPGA_CONFIG #define CONFIG_KM_PIGGY4_88E6352 +#define CONFIG_MV88E6352_SWITCH +#define CONFIG_KM_MVEXTSW_ADDR 0x10
/* KM_MGCOGE3UN */ #elif defined(CONFIG_KM_MGCOGE3UN)
-----Original Message----- From: Valentin Longchamp [mailto:valentin.longchamp@keymile.com] Sent: 16 August 2012 16:55 To: u-boot@lists.denx.de Cc: holger.brunck@keymile.com; Prafulla Wadaskar; valentin.longchamp@keymile.com Subject: [PATCH 2/2] km_kirkwood: enable MV88E6352_SWITCH support for kmnusa
Acked-by: Prafulla Wadaskar Prafulla@marvell.com
-----Original Message----- From: Valentin Longchamp [mailto:valentin.longchamp@keymile.com] Sent: 16 August 2012 16:55 To: u-boot@lists.denx.de Cc: holger.brunck@keymile.com; Prafulla Wadaskar; valentin.longchamp@keymile.com Subject: [PATCH 0/2] arm/km: configuration of the mv88e6352 switch on kmnusa
Hi Joe Unless above patch is in, I cannot pull this patch series, May you please check and pull it? Or let me know your ack on this if I need to pull it.
on
kmnusa
net/phy
Hi Joe
I do not find this patch pulled in. May you pls kindly ack and pull it, or I should pull it as dependency for this patch series
Prafulla Wadaskar
Valentin Longchamp
