[U-Boot] [PATCH 1/3] pci: Option rom class is a 24-bit number
We should pass a u32 class number to pci_rom_probe() instead of a u16.
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
drivers/pci/pci_rom.c | 20 +++++++++++--------- 1 file changed, 11 insertions(+), 9 deletions(-)
diff --git a/drivers/pci/pci_rom.c b/drivers/pci/pci_rom.c index 48c0a77..49c118d 100644 --- a/drivers/pci/pci_rom.c +++ b/drivers/pci/pci_rom.c @@ -67,6 +67,7 @@ static int pci_rom_probe(pci_dev_t dev, uint class, struct pci_rom_data *rom_data; u16 vendor, device; u16 rom_vendor, rom_device; + u32 rom_class; u32 vendev; u32 mapped_vendev; u32 rom_address; @@ -125,13 +126,13 @@ static int pci_rom_probe(pci_dev_t dev, uint class, /* Continue anyway */ }
- debug("PCI ROM image, Class Code %04x%02x, Code Type %02x\n", - rom_data->class_hi, rom_data->class_lo, rom_data->type); + rom_class = (le16_to_cpu(rom_data->class_hi) << 8) | rom_data->class_lo; + debug("PCI ROM image, Class Code %06x, Code Type %02x\n", + rom_class, rom_data->type);
- if (class != ((rom_data->class_hi << 8) | rom_data->class_lo)) { - debug("Class Code mismatch ROM %08x, dev %08x\n", - (rom_data->class_hi << 8) | rom_data->class_lo, - class); + if (class != rom_class) { + debug("Class Code mismatch ROM %06x, dev %06x\n", + rom_class, class); } *hdrp = rom_header;
@@ -232,17 +233,18 @@ int pci_run_vga_bios(pci_dev_t dev, int (*int15_handler)(void), int exec_method) { struct pci_rom_header *rom, *ram; int vesa_mode = -1; - uint16_t class; + uint class; bool emulate; int ret;
/* Only execute VGA ROMs */ - pci_read_config_word(dev, PCI_CLASS_DEVICE, &class); - if ((class ^ PCI_CLASS_DISPLAY_VGA) & 0xff00) { + pci_read_config_dword(dev, PCI_REVISION_ID, &class); + if (((class >> 16) ^ PCI_CLASS_DISPLAY_VGA) & 0xff00) { debug("%s: Class %#x, should be %#x\n", __func__, class, PCI_CLASS_DISPLAY_VGA); return -ENODEV; } + class >>= 8;
if (!should_load_oprom(dev)) return -ENXIO;
Applied to u-boot-x86, thanks!
Bin Meng
