[U-Boot] [PATCH 0/3] Add Atheros phy delay support and CPSW RGMII id support
This patch series adds support for RGMII phy internal delay support for Atheros 8031 phy driver and also add support for the phy mode configuration in control module in cpsw driver.
Tested the series on the following EVMs with a zImage download from server, logs [1] and pushed a branch for testing [2].
* DRA 72 Rev B EVM * DRA 72 Rev C EVM * DRA 74 EVM * AM437x GP EVM * AM335x BBB * AM335x GP EVM
[1] - http://pastebin.ubuntu.com/23302895/ [2] - git://git.ti.com/~mugunthanvnm/ti-u-boot/mugunth-ti-u-boot.git cpsw-rgmii
Mugunthan V N (3): drivers: net: phy: atheros: add separate config for AR8031 include: configs: am335x: add Atheros phy support driver: net: cpsw: add support for RGMII id mode support and RMII clock source selection
drivers/net/cpsw.c | 153 +++++++++++++++++++++++++++++++++++++++---- drivers/net/phy/atheros.c | 37 ++++++++++- include/configs/am335x_evm.h | 2 + include/cpsw.h | 1 + 4 files changed, 178 insertions(+), 15 deletions(-)
In the current driver implementation, config() callback is common for AR8035 and AR8031 phy. In config() callback, driver tries to configure MMD Access Control Register and MMD Access Address Data Register unconditionally for both phy versions which leads to auto negotiation failure in AM335x EVMsk second port which uses AR8031 Giga bit RGMII phy. Fixing this by adding separate config for AR8031 phy.
Reviewed-by: Sekhar Nori nsekhar@ti.com Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- drivers/net/phy/atheros.c | 37 ++++++++++++++++++++++++++++++++++++- 1 file changed, 36 insertions(+), 1 deletion(-)
diff --git a/drivers/net/phy/atheros.c b/drivers/net/phy/atheros.c index e57c412..faf5175 100644 --- a/drivers/net/phy/atheros.c +++ b/drivers/net/phy/atheros.c @@ -8,6 +8,15 @@ */ #include <phy.h>
+#define AR803x_PHY_DEBUG_ADDR_REG 0x1d +#define AR803x_PHY_DEBUG_DATA_REG 0x1e + +#define AR803x_DEBUG_REG_5 0x5 +#define AR803x_RGMII_TX_CLK_DLY 0x100 + +#define AR803x_DEBUG_REG_0 0x0 +#define AR803x_RGMII_RX_CLK_DLY 0x8000 + static int ar8021_config(struct phy_device *phydev) { phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x05); @@ -17,6 +26,32 @@ static int ar8021_config(struct phy_device *phydev) return 0; }
+static int ar8031_config(struct phy_device *phydev) +{ + if (phydev->interface == PHY_INTERFACE_MODE_RGMII_TXID || + phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) { + phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_ADDR_REG, + AR803x_DEBUG_REG_5); + phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_DATA_REG, + AR803x_RGMII_TX_CLK_DLY); + } + + if (phydev->interface == PHY_INTERFACE_MODE_RGMII_RXID || + phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) { + phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_ADDR_REG, + AR803x_DEBUG_REG_0); + phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_DATA_REG, + AR803x_RGMII_RX_CLK_DLY); + } + + phydev->supported = phydev->drv->features; + + genphy_config_aneg(phydev); + genphy_restart_aneg(phydev); + + return 0; +} + static int ar8035_config(struct phy_device *phydev) { int regval; @@ -54,7 +89,7 @@ static struct phy_driver AR8031_driver = { .uid = 0x4dd074, .mask = 0xffffffef, .features = PHY_GBIT_FEATURES, - .config = ar8035_config, + .config = ar8031_config, .startup = genphy_startup, .shutdown = genphy_shutdown, };
In AM335x GP EVM, Atheros 8031 phy is used, enable the driver as AM335x SoC RGMII delay mode has to be enabled in phy as mentioned in the silicon errata Advisory 1.0.10
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- include/configs/am335x_evm.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 272c71b..daa7dd8 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -432,6 +432,8 @@ #define CONFIG_PHY_GIGE #define CONFIG_PHYLIB #define CONFIG_PHY_SMSC +/* Enable Atheros phy driver */ +#define CONFIG_PHY_ATHEROS
/* * NOR Size = 16 MiB
cpsw driver supports only selection of phy mode in control module but control module has more setting like RGMII ID mode selection, RMII clock source selection. So ported to cpsw-phy-sel driver from kernel to u-boot.
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- drivers/net/cpsw.c | 153 ++++++++++++++++++++++++++++++++++++++++++++++++----- include/cpsw.h | 1 + 2 files changed, 140 insertions(+), 14 deletions(-)
diff --git a/drivers/net/cpsw.c b/drivers/net/cpsw.c index d17505e..1441f44 100644 --- a/drivers/net/cpsw.c +++ b/drivers/net/cpsw.c @@ -225,6 +225,18 @@ struct cpdma_chan { void *hdp, *cp, *rxfree; };
+/* AM33xx SoC specific definitions for the CONTROL port */ +#define AM33XX_GMII_SEL_MODE_MII 0 +#define AM33XX_GMII_SEL_MODE_RMII 1 +#define AM33XX_GMII_SEL_MODE_RGMII 2 + +#define AM33XX_GMII_SEL_RGMII1_IDMODE BIT(4) +#define AM33XX_GMII_SEL_RGMII2_IDMODE BIT(5) +#define AM33XX_GMII_SEL_RMII1_IO_CLK_EN BIT(6) +#define AM33XX_GMII_SEL_RMII2_IO_CLK_EN BIT(7) + +#define GMII_SEL_MODE_MASK 0x3 + #define desc_write(desc, fld, val) __raw_writel((u32)(val), &(desc)->fld) #define desc_read(desc, fld) __raw_readl(&(desc)->fld) #define desc_read_ptr(desc, fld) ((void *)__raw_readl(&(desc)->fld)) @@ -1150,12 +1162,129 @@ static inline fdt_addr_t cpsw_get_addr_by_node(const void *fdt, int node) false); }
+static void cpsw_gmii_sel_am3352(struct cpsw_priv *priv, + phy_interface_t phy_mode) +{ + u32 reg; + u32 mask; + u32 mode = 0; + bool rgmii_id = false; + int slave = priv->data.active_slave; + + reg = readl(priv->data.gmii_sel); + + switch (phy_mode) { + case PHY_INTERFACE_MODE_RMII: + mode = AM33XX_GMII_SEL_MODE_RMII; + break; + + case PHY_INTERFACE_MODE_RGMII: + mode = AM33XX_GMII_SEL_MODE_RGMII; + break; + case PHY_INTERFACE_MODE_RGMII_ID: + case PHY_INTERFACE_MODE_RGMII_RXID: + case PHY_INTERFACE_MODE_RGMII_TXID: + mode = AM33XX_GMII_SEL_MODE_RGMII; + rgmii_id = true; + break; + + case PHY_INTERFACE_MODE_MII: + default: + mode = AM33XX_GMII_SEL_MODE_MII; + break; + }; + + mask = GMII_SEL_MODE_MASK << (slave * 2) | BIT(slave + 6); + mode <<= slave * 2; + + if (priv->data.rmii_clock_external) { + if (slave == 0) + mode |= AM33XX_GMII_SEL_RMII1_IO_CLK_EN; + else + mode |= AM33XX_GMII_SEL_RMII2_IO_CLK_EN; + } + + if (rgmii_id) { + if (slave == 0) + mode |= AM33XX_GMII_SEL_RGMII1_IDMODE; + else + mode |= AM33XX_GMII_SEL_RGMII2_IDMODE; + } + + reg &= ~mask; + reg |= mode; + + writel(reg, priv->data.gmii_sel); +} + +static void cpsw_gmii_sel_dra7xx(struct cpsw_priv *priv, + phy_interface_t phy_mode) +{ + u32 reg; + u32 mask; + u32 mode = 0; + int slave = priv->data.active_slave; + + reg = readl(priv->data.gmii_sel); + + switch (phy_mode) { + case PHY_INTERFACE_MODE_RMII: + mode = AM33XX_GMII_SEL_MODE_RMII; + break; + + case PHY_INTERFACE_MODE_RGMII: + case PHY_INTERFACE_MODE_RGMII_ID: + case PHY_INTERFACE_MODE_RGMII_RXID: + case PHY_INTERFACE_MODE_RGMII_TXID: + mode = AM33XX_GMII_SEL_MODE_RGMII; + break; + + case PHY_INTERFACE_MODE_MII: + default: + mode = AM33XX_GMII_SEL_MODE_MII; + break; + }; + + switch (slave) { + case 0: + mask = GMII_SEL_MODE_MASK; + break; + case 1: + mask = GMII_SEL_MODE_MASK << 4; + mode <<= 4; + break; + default: + dev_err(priv->dev, "invalid slave number...\n"); + return; + } + + if (priv->data.rmii_clock_external) + dev_err(priv->dev, "RMII External clock is not supported\n"); + + reg &= ~mask; + reg |= mode; + + writel(reg, priv->data.gmii_sel); +} + +static void cpsw_phy_sel(struct cpsw_priv *priv, const char *compat, + phy_interface_t phy_mode) +{ + if (!strcmp(compat, "ti,am3352-cpsw-phy-sel")) + cpsw_gmii_sel_am3352(priv, phy_mode); + if (!strcmp(compat, "ti,am43xx-cpsw-phy-sel")) + cpsw_gmii_sel_am3352(priv, phy_mode); + else if (!strcmp(compat, "ti,dra7xx-cpsw-phy-sel")) + cpsw_gmii_sel_dra7xx(priv, phy_mode); +} + static int cpsw_eth_ofdata_to_platdata(struct udevice *dev) { struct eth_pdata *pdata = dev_get_platdata(dev); struct cpsw_priv *priv = dev_get_priv(dev); struct gpio_desc *mode_gpios; const char *phy_mode; + const char *phy_sel_compat = NULL; const void *fdt = gd->fdt_blob; int node = dev->of_offset; int subnode; @@ -1271,6 +1400,13 @@ static int cpsw_eth_ofdata_to_platdata(struct udevice *dev) error("Not able to get gmii_sel reg address\n"); return -ENOENT; } + + phy_sel_compat = fdt_getprop(fdt, subnode, "compatible", + NULL); + if (!phy_sel_compat) { + error("Not able to get gmii_sel compatible\n"); + return -ENOENT; + } } }
@@ -1293,20 +1429,9 @@ static int cpsw_eth_ofdata_to_platdata(struct udevice *dev) debug("%s: Invalid PHY interface '%s'\n", __func__, phy_mode); return -EINVAL; } - switch (pdata->phy_interface) { - case PHY_INTERFACE_MODE_MII: - writel(MII_MODE_ENABLE, priv->data.gmii_sel); - break; - case PHY_INTERFACE_MODE_RMII: - writel(RMII_MODE_ENABLE, priv->data.gmii_sel); - break; - case PHY_INTERFACE_MODE_RGMII: - case PHY_INTERFACE_MODE_RGMII_ID: - case PHY_INTERFACE_MODE_RGMII_RXID: - case PHY_INTERFACE_MODE_RGMII_TXID: - writel(RGMII_MODE_ENABLE, priv->data.gmii_sel); - break; - } + + /* Select phy interface in control module */ + cpsw_phy_sel(priv, phy_sel_compat, pdata->phy_interface);
return 0; } diff --git a/include/cpsw.h b/include/cpsw.h index 257d12a..f135e7b 100644 --- a/include/cpsw.h +++ b/include/cpsw.h @@ -48,6 +48,7 @@ struct cpsw_platform_data { void (*control)(int enabled); u32 host_port_num; u32 active_slave; + bool rmii_clock_external; u8 version; };
- u32 reg;
- u32 mask;
- u32 mode = 0;
- bool rgmii_id = false;
- int slave = priv->data.active_slave;
- reg = readl(priv->data.gmii_sel);
- switch (phy_mode) {
break;
break;
rgmii_id = true;
break;
- default:
break;
- mask = GMII_SEL_MODE_MASK << (slave * 2) | BIT(slave + 6);
- mode <<= slave * 2;
- if (priv->data.rmii_clock_external) {
I do not see any one updating value for priv->data.rmii_clock_external. I guess cpsw_eth_ofdata_to_platdata() should be populating this value based on DT.
Thanks and regards, Lokesh
- u32 reg;
- u32 mask;
- u32 mode = 0;
break;
break;
rgmii_id = true;
break;
- default:
break;
Oops, missed squashing fixup patches from TI repo. Will be careful next time. Thanks for pointing out early.
Regards Mugunthan V N
Joe Hershberger
Lokesh Vutla
Mugunthan V N
