[PATCH v2] sunxi: clock: H6/H616: Fix PLL clock factor encodings
Most clock factors and dividers in the H6 PLLs use a "+1 encoding", which we were missing on two occasions.
This fixes the MMC clock setup on the H6, which could be slightly off due to the wrong parent frequency: mmc 2 set mod-clk req 52000000 parent 1176000000 n 2 m 12 rate 49000000
Also the CPU frequency was a tad too high before.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- Changelog v1 .. v2: - Also fix PLL5 factor calculation (video, currently unused) - Also fix PLL1 factor calculation (CPU clock)
arch/arm/include/asm/arch-sunxi/clock_sun50i_h6.h | 4 ++-- arch/arm/mach-sunxi/clock_sun50i_h6.c | 2 +- 2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/include/asm/arch-sunxi/clock_sun50i_h6.h b/arch/arm/include/asm/arch-sunxi/clock_sun50i_h6.h index 62abfc4ef6b..2e076cf594d 100644 --- a/arch/arm/include/asm/arch-sunxi/clock_sun50i_h6.h +++ b/arch/arm/include/asm/arch-sunxi/clock_sun50i_h6.h @@ -233,14 +233,14 @@ struct sunxi_ccm_reg { #define CCM_PLL1_OUT_EN BIT(27) #define CCM_PLL1_CLOCK_TIME_2 (2 << 24) #define CCM_PLL1_CTRL_P(p) ((p) << 16) -#define CCM_PLL1_CTRL_N(n) ((n) << 8) +#define CCM_PLL1_CTRL_N(n) (((n) - 1) << 8)
/* pll5 bit field */ #define CCM_PLL5_CTRL_EN BIT(31) #define CCM_PLL5_LOCK_EN BIT(29) #define CCM_PLL5_LOCK BIT(28) #define CCM_PLL5_OUT_EN BIT(27) -#define CCM_PLL5_CTRL_N(n) ((n) << 8) +#define CCM_PLL5_CTRL_N(n) (((n) - 1) << 8) #define CCM_PLL5_CTRL_DIV1(div1) ((div1) << 0) #define CCM_PLL5_CTRL_DIV2(div0) ((div0) << 1)
diff --git a/arch/arm/mach-sunxi/clock_sun50i_h6.c b/arch/arm/mach-sunxi/clock_sun50i_h6.c index 492fc4a3fca..a947463e0a5 100644 --- a/arch/arm/mach-sunxi/clock_sun50i_h6.c +++ b/arch/arm/mach-sunxi/clock_sun50i_h6.c @@ -94,7 +94,7 @@ unsigned int clock_get_pll6(void) int m = IS_ENABLED(CONFIG_MACH_SUN50I_H6) ? 4 : 2;
uint32_t rval = readl(&ccm->pll6_cfg); - int n = ((rval & CCM_PLL6_CTRL_N_MASK) >> CCM_PLL6_CTRL_N_SHIFT); + int n = ((rval & CCM_PLL6_CTRL_N_MASK) >> CCM_PLL6_CTRL_N_SHIFT) + 1; int div1 = ((rval & CCM_PLL6_CTRL_DIV1_MASK) >> CCM_PLL6_CTRL_DIV1_SHIFT) + 1; int div2 = ((rval & CCM_PLL6_CTRL_DIV2_MASK) >>
On Wed, 5 May 2021 13:53:05 +0100 Andre Przywara andre.przywara@arm.com wrote:
can someone please confirm that I didn't mess this up?
Cheers, Andre
Changelog v1 .. v2:
- int n = ((rval & CCM_PLL6_CTRL_N_MASK) >> CCM_PLL6_CTRL_N_SHIFT) + 1; int div1 = ((rval & CCM_PLL6_CTRL_DIV1_MASK) >> CCM_PLL6_CTRL_DIV1_SHIFT) + 1; int div2 = ((rval & CCM_PLL6_CTRL_DIV2_MASK) >>
Hi!
Dne četrtek, 27. maj 2021 ob 01:49:48 CEST je Andre Przywara napisal(a):
Cheers, Andre
Changelog v1 .. v2:
H6 and H616 DRAM drivers actually consider this "- 1" in the code. Either drop this change or fix DRAM drivers.
With that: Reviewed-by: Jernej Skrabec jernej.skrabec@gmail.com
Best regards, Jernej
1;
Andre Przywara
Jernej Škrabec
